74HCT4066D-Q100,11
74HCT4066D-Q100,11
    NEXPERIA(安世)
    SOIC14_150MIL
    四极单极单掷模拟开关
74HCT4066D-Q100,11 数据手册
74HC4066-Q100; 74HCT4066-Q100 Quad single-pole single-throw analog switch Rev. 4 — 14 April 2020 Product data sheet 1. General description The 74HC4066-Q100; 74HCT4066-Q100 is a quad single pole, single throw analog switch. Each switch features two input/output terminals (nY and nZ) and an active HIGH enable input (nE). When nE is LOW, the analog switch is turned off. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits • • • • • • • Automotive product qualification in accordance with AEC-Q100 (Grade 1) • Specified from -40 °C to +85 °C and from -40 °C to +125 °C Input levels nE inputs: • For 74HC4066-Q100: CMOS level • For 74HCT4066-Q100: TTL level Low ON resistance: • 50 Ω (typical) at VCC = 4.5 V • 45 Ω (typical) at VCC = 6.0 V • 35 Ω (typical) at VCC = 9.0 V Specified in compliance with JEDEC standard no. 7A ESD protection: • MIL-STD-883, method 3015 exceeds 2000 V • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω) Multiple package options DHVQFN package with Side-Wettable Flanks enabling Automatic Optical Inspection (AOI) of solder joints 3. Ordering information Table 1. Ordering information Type number Package 74HC4066D-Q100 Temperature range Name Description Version -40 °C to +125 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 -40 °C to +125 °C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 -40 °C to +125 °C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 × 3 × 0.85 mm 74HCT4066D-Q100 74HC4066PW-Q100 74HCT4066PW-Q100 74HC4066BQ-Q100 74HCT4066BQ-Q100 SOT762-1 Nexperia 74HC4066-Q100; 74HCT4066-Q100 Quad single-pole single-throw analog switch 4. Functional diagram 1Y 1 1Z 1 2 13 # 1E 13 2Y 4 1 2Z 4 3Y 8 3 9 8 8 9 11 4Z 10 11 10 12 # 12 # 4E 12 6# 6# 4Y 11 5# 5# 3Z 3E 6 4 13 # 3 2E 5 2 1 1 X1 1 1 3 X1 1 1 9 X1 1 1 10 X1 (a) (b) 001aad270 001aad269 Fig. 1. 2 Logic symbol Fig. 2. IEC logic symbol nY nE VCC VCC GND nZ 001aad271 Fig. 3. Schematic diagram (one switch) 5. Pinning information 1 1Y terminal 1 index area 1Y 1 14 VCC 1Z 2 13 1E 4 2E 5 3E 6 9 3Z GND 7 8 3Y 4066 Product data sheet 4 4066 11 4Y 2E 5 VCC(1) 10 4Z 3E 6 9 10 4Z 3Z 001aac116 Transparent top view Pin configuration SOT108-1 (SO14) and SOT402-1 (TSSOP14) 74HC_HCT4066_Q100 2Y 11 4Y (1) This is not a supply pin. There is no electrical or mechanical requirement to solder the pad. In case soldered, the solder land should remain floating or connected to VCC. 001aad268 Fig. 4. 13 1E 12 4E 8 2Y 3 3Y 12 4E 2 2Z 7 3 1Z GND 2Z 14 VCC 5.1. Pinning Fig. 5. Pin configuration SOT762-1 (DHVQFN14) All information provided in this document is subject to legal disclaimers. Rev. 4 — 14 April 2020 © Nexperia B.V. 2020. All rights reserved 2 / 20 Nexperia 74HC4066-Q100; 74HCT4066-Q100 Quad single-pole single-throw analog switch 5.2. Pin description Table 2. Pin description Symbol Pin Description 1Z, 2Z, 3Z, 4Z 2, 3, 9, 10 independent input or output 1Y, 2Y, 3Y, 4Y 1, 4, 8, 11 independent input or output GND 7 ground (0 V) 1E, 2E, 3E, 4E 13, 5, 6, 12 enable input (active HIGH) VCC 14 supply voltage 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level. Input nE Switch L OFF H ON 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V ISK switch clamping current VSW < -0.5 V or VSW > VCC + 0.5 V ISW switch current VSW = -0.5 V to VCC + 0.5 V ICC supply current IGND ground current Tstg storage temperature Ptot total power dissipation Tamb = -40 °C to +125 °C P power dissipation per switch [1] [2] Conditions [1] [2] Min Max Unit -0.5 +11.0 V - ±20 mA - ±20 mA - ±25 mA - 50 mA - -50 mA -65 +150 °C - 500 mW - 100 mW To avoid drawing VCC current out of terminal Z, when switch current flows in terminals Yn, the voltage drop across the bidirectional switch must not exceed 0.4 V. If the switch current flows into terminal Z, no VCC current will flow out of terminals Yn. In this case there is no limit for the voltage drop across the switch, but the voltages at Yn and Z may not exceed VCC or GND. For SOT108-1 (SO14) package: Ptot derates linearly with 10.1 mW/K above 100 °C. For SOT402-1 (TSSOP14) package: Ptot derates linearly with 7.3 mW/K above 81 °C. For SOT762-1 (DHVQFN14) package: Ptot derates linearly with 9.6 mW/K above 98 °C. 74HC_HCT4066_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 14 April 2020 © Nexperia B.V. 2020. All rights reserved 3 / 20 Nexperia 74HC4066-Q100; 74HCT4066-Q100 Quad single-pole single-throw analog switch 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions 74HC4066-Q100 74HCT4066-Q100 Unit Min Typ Max Min Typ Max 2.0 5.0 10.0 4.5 5.0 5.5 V - VCC GND - VCC V VCC supply voltage VI input voltage GND VSW switch voltage GND - VCC GND - VCC V Tamb ambient temperature -40 +25 +125 -40 +25 +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V VCC = 10.0 V - - 35 - - - ns/V 9. Static characteristics Table 6. RON resistance per switch for types 74HC4066-Q100 and 74HCT4066-Q100 VI = VIH or VIL; for test circuit see Fig. 6. Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. For 74HC4066-Q100: VCC - GND = 2.0 V, 4.5 V, 6.0 V and 9.0 V. For 74HCT4066-Q100: VCC - GND = 4.5 V. Symbol Parameter RON(peak) ON resistance (peak) Conditions -40 °C to +85 °C Min Typ[1] Max Min Max - - - - - Ω VCC = 4.5 V; ISW = 1000 μA - 54 - 118 142 Ω VCC = 6.0 V; ISW = 1000 μA - 42 - 105 126 Ω VCC = 9.0 V; ISW = 1000 μA - 32 - 88 105 Ω - 80 - - - Ω VCC = 4.5 V; ISW = 1000 μA - 35 - 95 115 Ω VCC = 6.0 V; ISW = 1000 μA - 27 - 82 100 Ω VCC = 9.0 V; ISW = 1000 μA - 20 - 70 85 Ω - 100 - - - Ω VCC = 4.5 V; ISW = 1000 μA - 42 - 106 128 Ω VCC = 6.0 V; ISW = 1000 μA - 35 - 94 113 Ω VCC = 9.0 V; ISW = 1000 μA - 20 - 78 95 Ω Vis = VCC to GND VCC = 2.0 V; ISW = 100 μA RON(rail) ON resistance (rail) -40 °C to +125 °C Unit [2] Vis = GND VCC = 2.0 V; ISW = 100 μA [2] Vis = VCC VCC = 2.0 V; ISW = 100 μA 74HC_HCT4066_Q100 Product data sheet [2] All information provided in this document is subject to legal disclaimers. Rev. 4 — 14 April 2020 © Nexperia B.V. 2020. All rights reserved 4 / 20 Nexperia 74HC4066-Q100; 74HCT4066-Q100 Quad single-pole single-throw analog switch Symbol Parameter Conditions -40 °C to +85 °C Min ΔRON [1] [2] -40 °C to +125 °C Unit Typ[1] Max Min Max Vis = VCC to GND ON resistance mismatch between channels VCC = 2.0 V - - - - - Ω VCC = 4.5 V [2] - 5 - - - Ω VCC = 6.0 V - 4 - - - Ω VCC = 9.0 V - 3 - - - Ω Typical values are measured at Tamb = 25 °C. At supply voltages (VCC - GND) approaching 2 V, the analog switch ON resistance becomes extremely non-linear. Therefore it is recommended that these devices be used to transmit digital signals only, when using these supply voltages. aaa-003459 60 RON (Ω) VCC = 4.5 V 50 VSW VCC 6V 40 9V nE VIH nY Vis 30 nZ GND ISW 20 aaa-003458 10 Vis = 0 V to VCC 0 1.8 3.6 5.4 7.2 Vis (V) 9.0 Vis = 0 V to VCC Fig. 6. Test circuit for measuring RON Fig. 7. Typical RON as a function of input voltage Vis Table 7. Static characteristics 74HC4066-Q100 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. Symbol Parameter Conditions Min Typ[1] Max Unit VCC = 2.0 V 1.5 1.2 - V VCC = 4.5 V 3.15 2.4 - V VCC = 6.0 V 4.2 3.2 - V VCC = 9.0 V 6.3 4.7 - V VCC = 2.0 V - 0.8 0.5 V VCC = 4.5 V - 2.1 1.35 V VCC = 6.0 V - 2.8 1.80 V VCC = 9.0 V - 4.3 2.70 V VCC = 6.0 V - - ±1.0 μA VCC = 10.0 V - - ±2.0 μA - - ±1.0 μA Tamb = -40 °C to +85 °C VIH VIL II IS(OFF) HIGH-level input voltage LOW-level input voltage input leakage current OFF-state leakage current VI = VCC or GND VCC = 10.0 V; VI = VIH or VIL; |VSW| = VCC - GND; see Fig. 8 per channel 74HC_HCT4066_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 14 April 2020 © Nexperia B.V. 2020. All rights reserved 5 / 20 Nexperia 74HC4066-Q100; 74HCT4066-Q100 Quad single-pole single-throw analog switch Symbol Parameter Conditions Min Typ[1] Max Unit IS(ON) ON-state leakage current VCC = 10.0 V; VI = VIH or VIL; |VSW| = VCC - GND; see Fig. 9 - - ±1.0 μA ICC supply current VI = VCC or GND; Vis = GND or VCC; Vos = VCC or GND VCC = 6.0 V - - 20.0 μA VCC = 10.0 V - - 40.0 μA CI input capacitance - 3.5 - pF Csw switch capacitance - 8 - pF VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 9.0 V 6.3 - - V VCC = 2.0 V - - 0.50 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.80 V VCC = 9.0 V - - 2.70 V VCC = 6.0 V - - ±1.0 μA VCC = 10.0 V - - ±2.0 μA - - ±1.0 μA - - ±1.0 μA VCC = 6.0 V - - 40 μA VCC = 10.0 V - - 80 μA Tamb = -40 °C to +125 °C VIH HIGH-level input voltage VIL LOW-level input voltage II input leakage current IS(OFF) OFF-state leakage current VI = VCC or GND VCC = 10.0 V; VI = VIH or VIL; |VSW| = VCC - GND; see Fig. 8 per channel IS(ON) ON-state leakage current VCC = 10.0 V; VI = VIH or VIL; |VSW| = VCC - GND; see Fig. 9 ICC supply current VI = VCC or GND; Vis = GND or VCC; Vos = VCC or GND [1] Typical values are measured at Tamb = 25 °C. 74HC_HCT4066_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 14 April 2020 © Nexperia B.V. 2020. All rights reserved 6 / 20 Nexperia 74HC4066-Q100; 74HCT4066-Q100 Quad single-pole single-throw analog switch Table 8. Static characteristics 74HCT4066-Q100 At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. Symbol Parameter Conditions Min Typ[1] Max Unit - V Tamb = -40 °C to +85 °C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - ±1.0 μA IS(OFF) OFF-state leakage current VCC = 5.5 V; VI = VIH or VIL; |VSW| = VCC - GND; see Fig. 8 - - ±1.0 μA IS(ON) ON-state leakage current VCC = 5.5 V; VI = VIH or VIL; |VSW| = VCC - GND; see Fig. 9 - - ±1.0 μA ICC supply current VI = VCC or GND; Vis = GND or VCC; Vos = VCC or GND; VCC = 4.5 V to 5.5 V - - 20.0 μA ΔICC additional supply current per input pin; VI = VCC - 2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V - 100 450 μA CI input capacitance - 3.5 - pF Csw switch capacitance - 8 - pF per channel Tamb = -40 °C to +125 °C VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 V II input leakage current VI = VCC or GND; VCC = 5.5 V - - ±1.0 μA IS(OFF) OFF-state leakage current VCC = 5.5 V; VI = VIH or VIL; |VSW| = VCC - GND; see Fig. 8 - - ±1.0 μA per channel IS(ON) ON-state leakage current VCC = 5.5 V; VI = VIH or VIL; |VSW| = VCC - GND; see Fig. 9 - - ±1.0 μA ICC supply current VI = VCC or GND; Vis = GND or VCC; Vos = VCC or GND; VCC = 4.5 V to 5.5 V - - 40 μA ΔICC additional supply current per input pin; VI = VCC - 2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V - - 490 μA [1] Typical values are measured at Tamb = 25 °C. VCC VCC E VIL ISW Vis VIH Yn Z GND ISW ISW Vos E Z Yn Vos Vis GND aaa-003456 aaa-003457 Vis = VCC and Vos = GND Vis = GND and Vos = VCC Fig. 8. Vis = VCC and Vos = open Vis = GND and Vos = open Test circuit for measuring OFF-state leakage current 74HC_HCT4066_Q100 Product data sheet Fig. 9. Test circuit for measuring ON-state leakage current All information provided in this document is subject to legal disclaimers. Rev. 4 — 14 April 2020 © Nexperia B.V. 2020. All rights reserved 7 / 20 Nexperia 74HC4066-Q100; 74HCT4066-Q100 Quad single-pole single-throw analog switch 10. Dynamic characteristics Table 9. Dynamic characteristics 74HC4066-Q100 GND = 0 V; tr = tf = 6 ns; CL = 50 pF unless specified otherwise; for test circuit see Fig. 12. Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. Symbol Parameter tpd toff ton Conditions -40 °C to +85 °C Typ[1] Max Min Max VCC = 2.0 V - 8 75 - 90 ns VCC = 4.5 V - 3 15 - 18 ns VCC = 6.0 V - 2 13 - 15 ns VCC = 9.0 V - 2 10 - 12 ns VCC = 2.0 V - 44 190 - 225 ns VCC = 4.5 V - 16 38 - 45 ns VCC = 5.0 V; CL = 15 pF - 13 - - - ns VCC = 6.0 V - 13 33 - 38 ns VCC = 9.0 V - 16 26 - 30 ns VCC = 2.0 V - 36 125 - 150 ns VCC = 4.5 V - 13 25 - 30 ns VCC = 5.0 V; CL = 15 pF - 11 - - - ns VCC = 6.0 V - 10 21 - 26 ns - 8 16 - 20 ns - 11 - - - pF propagation delay nY to nZ or nZ to nY; RL = ∞ Ω; see Fig. 10 turn-off time turn-on time nE to nY or nZ; see Fig. 11 nE to nY or nZ; see Fig. 11 [2] [3] [4] VCC = 9.0 V CPD [1] [2] [3] [4] [5] power dissipation capacitance -40 °C to +125 °C Unit Min per switch; VI = GND to VCC [5] Typical values are measured at Tamb = 25 °C. tpd is the same as tPHL and tPLH. toff is the same as tPZH and tPZL. ton is the same as tPHZ and tPLZ. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi + ∑{(CL + Csw) x VCC x fo} where: fi = input frequency in MHz; fo = output frequency in MHz; 2 ∑{(CL + Csw) x VCC x fo} = sum of outputs; CL = output load capacitance in pF; Csw = switch capacitance in pF; VCC = supply voltage in V. 74HC_HCT4066_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 14 April 2020 © Nexperia B.V. 2020. All rights reserved 8 / 20 Nexperia 74HC4066-Q100; 74HCT4066-Q100 Quad single-pole single-throw analog switch Table 10. Dynamic characteristics 74HCT4066-Q100 GND = 0 V; tr = tf = 6 ns; CL = 50 pF unless specified otherwise; for test circuit see Fig. 12. Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. Symbol Parameter tpd propagation delay Conditions -40 °C to +85 °C Min Typ[1] Max Min Max - 3 15 - 18 ns - 20 44 - 53 ns - 16 - - - ns VCC = 4.5 V - 12 30 - 36 ns VCC = 5.0 V; CL = 15 pF - 12 - - - ns - 12 - - - pF nY to nZ or nZ to nY; RL = ∞ Ω; see Fig. 10 [2] VCC = 4.5 V toff turn-off time nE to nY or nZ; see Fig. 11 [3] VCC = 4.5 V VCC = 5.0 V; CL = 15 pF ton CPD [1] [2] [3] [4] [5] turn-on time -40 °C to +125 °C Unit nE to nY or nZ; see Fig. 11 [4] power dissipation per switch; capacitance VI = GND to (VCC - 1.5 V) [5] Typical values are measured at Tamb = 25 °C. tpd is the same as tPHL and tPLH. toff is the same as tPZH and tPZL. ton is the same as tPHZ and tPLZ. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi + ∑{(CL + Csw) x VCC x fo} where: fi = input frequency in MHz; fo = output frequency in MHz; 2 ∑{(CL + Csw) x VCC x fo} = sum of outputs; CL = output load capacitance in pF; Csw = switch capacitance in pF; VCC = supply voltage in V. 10.1. Waveforms and test circuit Vis input 50 % tPLH tPHL 50 % Vos output 001aad555 Fig. 10. Input (Vis) to output (Vos) propagation delays 74HC_HCT4066_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 14 April 2020 © Nexperia B.V. 2020. All rights reserved 9 / 20 Nexperia 74HC4066-Q100; 74HCT4066-Q100 Quad single-pole single-throw analog switch VI VM E input 0V tPLZ tPZL 50 % Vos output 10 % tPHZ tPZH 90 % 50 % Vos output switch ON switch OFF switch ON aaa-003460 Measurement points are shown in Table 11. Fig. 11. Turn-on and turn-off times Table 11. Measurement points Type VI VM 74HC4066-Q100 VCC 0.5VCC 74HCT4066-Q100 3.0 V 1.3 V VI negative pulse tW 90 % VM 0V tf 0V tr tr VI positive pulse VM 10 % tf 90 % VM VM 10 % tW VCC Vis PULSE GENERATOR VI VCC Vos RL DUT RT S1 open CL GND 001aag732 Test data is given in Table 12. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig. 12. Test circuit for measuring switching times 74HC_HCT4066_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 14 April 2020 © Nexperia B.V. 2020. All rights reserved 10 / 20 Nexperia 74HC4066-Q100; 74HCT4066-Q100 Quad single-pole single-throw analog switch Table 12. Test data Test Input Output Control E Switch Yn (Z) tr, tf S1 position Switch Z (Yn) VI[1] Vis CL RL tPHL, tPLH GND GND to VCC 6 ns 50 pF - open tPHZ, tPZH GND to VCC VCC 6 ns 50 pF, 15 pF 1 kΩ GND tPLZ, tPZL GND to VCC GND 6 ns 50 pF, 15 pF 1 kΩ VCC [1] For 74HCT4066-Q100: maximum input voltage VI = 3.0 V. 11. Additional dynamic characteristics Table 13. Additional dynamic characteristics Recommended conditions and typical values; GND = 0 V; Tamb = 25 °C. Vis is the input voltage at a Yn or Z terminal, whichever is assigned as an input. Vos is the output voltage at a Yn or Z terminal, whichever is assigned as an output. Symbol Parameter THD Min Conditions Typ Max total harmonic distortion fi = 1 kHz; RL = 10 kΩ; CL = 50 pF; see Fig. 13 Unit % VCC = 4.5 V; VI = 4.0 V (p-p) - 0.04 - % VCC = 9.0 V; VI = 8.0 V (p-p) - 0.02 - % VCC = 4.5 V; VI = 4.0 V (p-p) - 0.12 - % VCC = 9.0 V; VI = 8.0 V (p-p) - 0.06 - % VCC = 4.5 V - 180 - MHz VCC = 9.0 V - 200 - MHz VCC = 4.5 V - -50 - dB VCC = 9.0 V - -50 - dB - 110 - mV - 220 - mV VCC = 4.5 V - -60 - dB VCC = 9.0 V - -60 - dB fi = 10 kHz; RL = 10 kΩ; CL = 50 pF; see Fig. 13 f(-3dB) αiso -3 dB frequency response isolation (OFF-state) Vct crosstalk voltage RL = 50 Ω; CL = 10 pF; see Fig. 14 RL = 600 Ω; CL = 50 pF; fi = 1 MHz; see Fig. 15 [1] [2] between digital input and switch (peak to peak value); RL = 600 Ω; CL = 50 pF; fi = 1 MHz; see Fig. 16 VCC = 4.5 V VCC = 9.0 V Xtalk [1] [2] crosstalk between switches; RL = 600 Ω; CL = 50 pF; fi = 1 MHz; see Fig. 17 [2] Adjust input voltage Vis to 0 dBm level at Vos for fi = 1 MHz (0 dBm = 1 mW into 50 Ω). After set-up, fi is increased to obtain a reading of -3 dB at Vos. Adjust input voltage Vis to 0 dBm level (0 dBm = 1 mW into 600 Ω). 74HC_HCT4066_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 14 April 2020 © Nexperia B.V. 2020. All rights reserved 11 / 20 Nexperia 74HC4066-Q100; 74HCT4066-Q100 Quad single-pole single-throw analog switch VCC VCC nE VIH 2RL 10 µF nY/nZ nZ/nY fi VO 2RL D CL 001aaj468 Fig. 13. Test circuit for measuring total harmonic distortion mna083 5 (dB) 0 -5 10 102 103 104 105 fi (kHz) 106 a. Typical -3 dB frequency response VCC VCC nE VIH 2RL 0.1 µF nY/nZ nZ/nY fi VO 2RL CL dB 001aaj469 b. Test circuit VCC = 4.5 V; GND = 0 V; RL = 50 Ω; Rsource = 1 kΩ. Fig. 14. -3 dB frequency response as a function of frequency 74HC_HCT4066_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 14 April 2020 © Nexperia B.V. 2020. All rights reserved 12 / 20 Nexperia 74HC4066-Q100; 74HCT4066-Q100 Quad single-pole single-throw analog switch mna082 0 (dB) - 20 - 40 - 60 - 80 - 100 10 102 103 104 105 fi (kHz) 106 a. Isolation (OFF-state) VCC VCC nE VIL 2RL 0.1 µF nY/nZ nZ/nY fi VO CL 2RL dB 001aaj470 b. Test circuit VCC = 4.5 V; GND = 0 V; RL = 600 Ω; Rsource = 1 kΩ. Fig. 15. Isolation (OFF-state) as a function of frequency VCC nE VCC GND 2RL nY/nZ VCC 2RL DUT 2RL 2RL CL nZ/nY oscilloscope GND mnb011 a. Test circuit V(p- p) mnb012 b. Crosstalk voltage Fig. 16. Test circuit for measuring crosstalk voltage (between the digital input and the switch) 74HC_HCT4066_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 14 April 2020 © Nexperia B.V. 2020. All rights reserved 13 / 20 Nexperia 74HC4066-Q100; 74HCT4066-Q100 Quad single-pole single-throw analog switch VCC 1E VIH 0.1 µF RL 2RL 1Y or 1Z 1Z or 1Y CHANNEL ON fi 2RL CL V VO1 V VO2 2E VIL VCC VCC 2RL 2RL 2Y or 2Z 2RL 2Z or 2Y CHANNEL OFF 2RL CL 001aai846 Fig. 17. Test circuit for measuring crosstalk (between the switches) 74HC_HCT4066_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 14 April 2020 © Nexperia B.V. 2020. All rights reserved 14 / 20 Nexperia 74HC4066-Q100; 74HCT4066-Q100 Quad single-pole single-throw analog switch 12. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig. 18. Package outline SOT108-1 (SO14) 74HC_HCT4066_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 14 April 2020 © Nexperia B.V. 2020. All rights reserved 15 / 20 Nexperia 74HC4066-Q100; 74HCT4066-Q100 Quad single-pole single-throw analog switch TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm D SOT402-1 E A X c y HE v M A Z 8 14 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 7 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 19. Package outline SOT402-1 (TSSOP14) 74HC_HCT4066_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 14 April 2020 © Nexperia B.V. 2020. All rights reserved 16 / 20 Nexperia 74HC4066-Q100; 74HCT4066-Q100 Quad single-pole single-throw analog switch DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 x 3 x 0.85 mm B D SOT762-1 A A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e v w b 2 6 C A B C y y1 C L 1 7 14 8 Eh e k 13 9 Dh X k 0 2 Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 1 A1 b 0.05 0.30 0.02 0.25 0.00 0.18 4 mm scale c D(1) Dh E(1) Eh e e1 0.2 3.1 3.0 2.9 1.65 1.50 1.35 2.6 2.5 2.4 1.15 1.00 0.85 0.5 2 k L v 0.2 0.5 0.4 0.3 0.1 w y 0.05 0.05 y1 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Outline version References IEC SOT762-1 JEDEC JEITA sot762-1_po European projection Issue date 15-04-10 15-05-05 MO-241 Fig. 20. Package outline SOT762-1 (DHVQFN14) 13. Abbreviations 74HC_HCT4066_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 14 April 2020 © Nexperia B.V. 2020. All rights reserved 17 / 20 Nexperia 74HC4066-Q100; 74HCT4066-Q100 Quad single-pole single-throw analog switch Table 14. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 15. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT4066_Q100 v.4 20200414 Product data sheet - 74HC_HCT4066_Q100 v.3 Modifications: • • • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Table 4: Derating values for Ptot total power dissipation have been updated. Table 9: CPD value of 74HC4066-Q100 moved to typical column. Package outline drawing of SOT762-1 (Fig. 20) updated. 74HC_HCT4066_Q100 v.3 20131216 Modifications: • 74HC_HCT4066_Q100 v.2 20130404 Modifications: • • 74HC_HCT4066_Q100 v.1 20120712 74HC_HCT4066_Q100 Product data sheet Product data sheet - 74HC_HCT4066_Q100 v.2 Features and benefits updated (errata). Product data sheet - 74HC_HCT4066_Q100 v.1 Descriptive title corrected (errata). New general description (errata). Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 4 — 14 April 2020 - © Nexperia B.V. 2020. All rights reserved 18 / 20 Nexperia 74HC4066-Q100; 74HCT4066-Q100 Quad single-pole single-throw analog switch equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 15. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or 74HC_HCT4066_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 14 April 2020 © Nexperia B.V. 2020. All rights reserved 19 / 20 Nexperia 74HC4066-Q100; 74HCT4066-Q100 Quad single-pole single-throw analog switch Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................2 5.1. Pinning.........................................................................2 5.2. Pin description............................................................. 3 6. Functional description................................................. 3 7. Limiting values............................................................. 3 8. Recommended operating conditions..........................4 9. Static characteristics....................................................4 10. Dynamic characteristics............................................ 8 10.1. Waveforms and test circuit........................................ 9 11. Additional dynamic characteristics.........................11 12. Package outline........................................................ 15 13. Abbreviations............................................................ 17 14. Revision history........................................................18 15. Legal information......................................................19 © Nexperia B.V. 2020. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 14 April 2020 74HC_HCT4066_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 14 April 2020 © Nexperia B.V. 2020. All rights reserved 20 / 20
74HCT4066D-Q100,11 价格&库存
很抱歉,暂时无法提供与“74HCT4066D-Q100,11”相匹配的价格&库存,您可以联系我们找货
74HCT4066D-Q100,11
  • 2500+1.344452500+0.16678
库存:2492
