HEF4053B-Q100
Triple single-pole double-throw analog switch
Rev. 2 — 11 September 2014
Product data sheet
1. General description
The HEF4053B-Q100 is a triple single-pole double-throw (SPDT) analog switch, suitable
for use as an analog or digital multiplexer/demultiplexer. Each switch has a digital select
input (Sn), two independent inputs/outputs (nY0 and nY1) and a common input/output
(nZ). All three switches share an enable input (E). A HIGH on E causes all switches into
the high-impedance OFF-state, independent of Sn.
VDD and VSS are the supply voltage connections for the digital control inputs (Sn and E).
The VDD to VSS range is 3 V to 15 V. The analog inputs/outputs (nY0, nY1 and nZ) can
swing between VDD as a positive limit and VEE as a negative limit. VDD VEE may not
exceed 15 V. Unused inputs must be connected to VDD, VSS, or another input. For
operation as a digital multiplexer/demultiplexer, VEE is connected to VSS (typically
ground). VEE and VSS are the supply voltage connections for the switches.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
Complies with JEDEC standard JESD 13-B
3. Applications
Analog multiplexing and demultiplexing
Digital multiplexing and demultiplexing
Signal gating
HEF4053B-Q100
Nexperia
4. Ordering information
Table 1.
All types operate from 40 C to +125 C.
Type number
Package
HEF4053BT-Q100
Name
Description
Version
SO16
plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
plastic thin shrink small outline package; 16 leads; body width 4.4 mm
SOT403-1
HEF4053BTT-Q100 TSSOP16
5. Functional diagram
E
6
VDD
16
13 1Y1
S1 11
LOGIC
LEVEL
CONVERSION
12 1Y0
DECODER
14 1Z
1 2Y1
S2 10
6
很抱歉,暂时无法提供与“HEF4053BTT-Q100J”相匹配的价格&库存,您可以联系我们找货
