HEF4052B-Q100
Dual 4-channel analog multiplexer/demultiplexer
Rev. 2 — 11 September 2014
Product data sheet
1. General description
The HEF4052B-Q100 is a dual 4-channel analog multiplexer/demultiplexer with common
channel select logic. Each multiplexer/demultiplexer has four independent inputs/outputs
(nY0 to nY3) and a common input/output (nZ). The common channel select logic includes
two select inputs (S1 and S2) and an active LOW enable input (E). Both
multiplexers/demultiplexers contain four bidirectional analog switches, each with one side
connected to an independent input/output (nY0 to nY3) and the other side connected to a
common input/output (nZ). With E LOW, one of the four switches is selected
(low-impedance ON-state) by S1 and S2. With E HIGH, all switches are in the
high-impedance OFF-state, independent of S1 and S2. If break before make is needed,
then it is necessary to use the enable input.
VDD and VSS are the supply voltage connections for the digital control inputs (S1 and S2,
and E). The VDD to VSS range is 3 V to 15 V. The analog inputs/outputs (nY0 to nY3, and
nZ) can swing between VDD as a positive limit and VEE as a negative limit. VDD VEE may
not exceed 15 V. Unused inputs must be connected to VDD, VSS, or another input. For
operation as a digital multiplexer/demultiplexer, VEE is connected to VSS (typically
ground). VEE and VSS are the supply voltage connections for the switches.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
ESD protection:
MIL-STD-833, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pf, R = 0 )
Complies with JEDEC standard JESD 13-B
3. Applications
Analog multiplexing and demultiplexing
Digital multiplexing and demultiplexing
Signal gating
HEF4052B-Q100
Nexperia
4. Ordering information
Table 1.
All types operate from 40 C to +125 C.
Type number
Package
Name
Description
Version
HEF4052BT-Q100
SO16
plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
HEF4052BTT-Q100
TSSOP16
plastic thin shrink small outline package; 16 leads; body width 4.4 mm
SOT403-1
5. Functional diagram
VDD
16
13
12
14
15
S1
10
11
S2
9
LOGIC
LEVEL
CONVERSION
1 - OF - 4
DECODER
1
5
E
1Z
1Y0
1Y1
1Y2
1Y3
2Y0
2Y1
6
2
4
3
8
7
VSS
VEE
2Y2
2Y3
2Z
mnb042
Fig 1.
Functional diagram
nYn
VDD
VDD
nZ
VEE
001aak604
Fig 2.
Schematic diagram (one switch)
HEF4052B_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 21
HEF4052B-Q100
Nexperia
10
9
13
6
4×
G4
1Z
1Y0
12
MDX
10
S1
1Y1
14
9
S2
1Y2
15
1Y3
11
2
2Y0
1
3
2Y1
5
2Y2
2
2Y3
4
6
E
3
Fig 3.
Logic symbol
HEF4052B_Q100
Product data sheet
5
1
2
4
12
14
13
15
2Z
3
1
001aak605
mnb041
Fig 4.
IEC logic symbol
3 of 21
HEF4052B-Q100
Nexperia
1Z
1Y0
S1
LEVEL
CONVERTER
1Y1
S2
LEVEL
CONVERTER
1Y2
E
LEVEL
CONVERTER
1Y3
2Y0
2Y1
2Y2
2Y3
2Z
001aak634
Fig 5.
Logic diagram
HEF4052B_Q100
Product data sheet
4 of 21
HEF4052B-Q100
Nexperia
6. Pinning information
6.1 Pinning
+()%4
很抱歉,暂时无法提供与“HEF4052BTT-Q100,11”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5.119401+0.65200
- 10+4.2565010+0.54210
- 100+3.21860100+0.40990
- 500+2.74050500+0.34900
- 1000+2.204001000+0.28070
- 2500+1.959102500+0.24950
- 5000+1.842505000+0.23470
- 10000+1.7842010000+0.22720
- 25000+1.7143025000+0.21830
