74HC4852-Q100;
74HCT4852-Q100
Dual 4-channel analog multiplexer/demultiplexer with
injection-current effect control
Rev. 2 — 28 April 2020
Product data sheet
1. General description
The 74HC4852-Q100; 74HCT4852-Q100 are dual single-pole quad-throw analog switches (SP4T)
suitable for use in analog or digital 4:1 multiplexer/demultiplexer applications. Each switch features
four independent inputs/outputs (nY0, nY1, nY2 and nY3) and a common input/output (nZ). A
digital enable input (E) and two digital select inputs (S0 & S1) are common to both switches. When
E is HIGH, the switches are turned off. The device features injection-current effect control. This
allows signals at disabled analog input channels to exceed the supply voltage without affecting
the signal of the enabled analog channel, eliminating the need for external diode/resistor networks
typically used to keep the analog channel signals within the supply-voltage range. Inputs include
clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in
excess of VCC.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
Injection-current cross coupling < 1 mV/mA
Wide supply voltage range from 2.0 V to 6.0 V for 74HC4852-Q100
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pf, R = 0 Ω)
Latch-up performance exceeds 100 mA per JESD 78 Class II level A
Low ON-state resistance:
• 400 Ω (typical) at VCC = 2.0 V
• 215 Ω (typical) at VCC = 3.0 V
• 120 Ω (typical) at VCC = 3.3 V
• 76 Ω (typical) at VCC = 4.5 V
• 59 Ω (typical) at VCC = 6.0 V
DHVQFN package with Side-Wettable Flanks enabling Automatic Optical Inspection (AOI) of
solder joints
3. Applications
Analog multiplexing and demultiplexing
Digital multiplexing and demultiplexing
Signal gating
Automotive application
Nexperia
Dual 4-channel analog multiplexer/demultiplexer with injection-current effect control
4. Ordering information
Table 1. Ordering information
Type number
Package
74HC4852D-Q100
Temperature range
Name
Description
Version
-40 °C to +125 °C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
-40 °C to +125 °C
TSSOP16
plastic thin shrink small outline package; 16 leads; SOT403-1
body width 4.4 mm
-40 °C to +125 °C
DHVQFN16 plastic dual in-line compatible thermal
enhanced very thin quad flat package; no leads;
16 terminals; body 2.5 × 3.5 × 0.85 mm
74HCT4852D-Q100
74HC4852PW-Q100
74HCT4852PW-Q100
74HC4852BQ-Q100
74HCT4852BQ-Q100
SOT763-1
5. Functional diagram
10
9
13
1Z
1Y0
12
1Y1
14
10
S0
1Y2
15
9
S1
1Y3
11
2Y0
1
6
E
2Z
3
Fig. 1.
6
Logic symbol
74HC_HCT4852_Q100
Product data sheet
2Y1
5
2Y2
2
2Y3
4
4×
G4
MUX/DMUX
1
2
3
1
2
3
001aag093
1
5
2
4
12
14
15
11
001aag094
Fig. 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2020. All rights reserved
2 / 19
Nexperia
VCC
16
S0
10
1-OF-4
DECODER
S1
E
9
6
GND
INJECTION
CURRENT
CONTROL
13
INJECTION
CURRENT
CONTROL
12
INJECTION
CURRENT
CONTROL
14
INJECTION
CURRENT
CONTROL
15
INJECTION
CURRENT
CONTROL
11
INJECTION
CURRENT
CONTROL
1
INJECTION
CURRENT
CONTROL
5
INJECTION
CURRENT
CONTROL
2
INJECTION
CURRENT
CONTROL
4
INJECTION
CURRENT
CONTROL
3
8
Fig. 3.
1Z
1Y0
1Y1
1Y2
1Y3
2Y0
2Y1
2Y2
2Y3
2Z
001aag095
Functional diagram
74HC_HCT4852_Q100
Product data sheet
3 / 19
Nexperia
6. Pinning information
6.1. Pinning
1
16 VCC
terminal 1
index area
74HC4852
74HCT4852
3
14 1Y1
2
15 1Y2
2Y3
4
13 1Z
2Y1
5
12 1Y0
E
6
n.c.
7
2Z
3
14 1Y1
2Y3
4
13 1Z
2Y1
5
12 1Y0
9
2Z
2Y2
E
6
11 1Y3
S1
15 1Y2
16 VCC
8
2
1
GND
2Y2
2Y0
n.c.
7
10 S0
GND
8
9
GND(1)
11 1Y3
10 S0
001aag097
Transparent top view
(1) This is not a ground pin. There is no electrical or
mechanical requirement to solder the pad. In case
soldered, the solder land should remain floating or
connected to GND.
S1
001aag096
Fig. 4.
2Y0
74HC4852
74HCT4852
Pin configuration SOT109-1 (SO16) and
SOT403-1 (TSSOP16)
Fig. 5.
Pin configuration SOT763-1 (DHVQFN16)
6.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
2Y0
1
independent input/output
2Y2
2
2Z
3
common input/output
2Y3
4
2Y1
5
E
6
enable input (active LOW)
n.c.
7
not connected
GND
8
ground (0 V)
S1
9
select input
S0
10
select input
1Y3
11
1Y0
12
1Z
13
common input/output
1Y1
14
1Y2
15
VCC
16
supply voltage
74HC_HCT4852_Q100
Product data sheet
4 / 19
Nexperia
7. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care.
Input
Channel ON
E
S1
S0
L
L
L
nY0 to nZ
L
L
H
nY1 to nZ
L
H
L
nY2 to nZ
L
H
H
nY3 to nZ
H
X
X
8. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VSW
switch voltage
IIK
input clamping
current
ISK
Min
Max
Unit
-0.5
+7.0
V
[1]
-0.5
VCC + 0.5
V
[2]
-0.5
VCC + 0.5
V
VI < -0.5 V or VI > VCC + 0.5 V
±20
mA
switch clamping
current
VSW < -0.5 V or VSW > VCC + 0.5 V
±20
mA
ISW
switch current
VSW > -0.5 V or VSW < VCC + 0.5 V
±25
mA
ICC
supply current
50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power
dissipation
500
mW
[1]
[2]
[3]
Conditions
Tamb = -40 °C to +125 °C
[3]
The minimum and maximum input voltage rating may be exceeded if the input clamping current rating is observed.
The minimum and maximum switch voltage rating may be exceeded if the switch clamping current rating is observed.
For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C.
For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C.
For SOT763-1 (DHVQFN16) package: Ptot derates linearly with 11.2 mW/K above 106 °C.
74HC_HCT4852_Q100
Product data sheet
5 / 19
Nexperia
9. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol
Parameter
Conditions
VCC
supply voltage
VI
input voltage
VSW
switch voltage
Tamb
ambient temperature
Δt/ΔV
input transition rise and
fall rate
74HC4852-Q100
74HCT4852-Q100
Unit
Min
Typ
Max
Min
Typ
Max
2.0
6.0
4.5
5.0
5.5
V
VCC
VCC
V
VCC
VCC
V
-40
+125
-40
+125
°C
VCC = 2.0 V
6.0
1 000
ns/V
VCC = 3.0 V
6.0
800
ns/V
VCC = 3.3 V
6.0
800
ns/V
VCC = 4.5 V
6.0
500
6.0
500
ns/V
VCC = 6.0 V
6.0
400
ns/V
10. Static characteristics
Table 6. RON resistance
At recommended operating conditions; voltages are referenced to GND (ground 0 V); For test circuit see Fig. 8.
Symbol
Parameter
Conditions
25 °C
-40 °C to +85 °C -40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
RON(peak) ON resistance VI = VCC to GND; E = VIL
(peak)
VCC = 2.0 V; ISW = 2 mA
400
650
670
700
Ω
VCC = 3.0 V; ISW ≤ 2 mA
215
330
360
380
Ω
VCC = 3.3 V; ISW ≤ 2 mA
120
270
305
345
Ω
VCC = 4.5 V; ISW ≤ 2 mA
76
210
240
270
Ω
VCC = 6.0 V; ISW ≤ 2 mA
59
195
220
250
Ω
4
10
15
Ω
2
8
12
16
Ω
2
8
12
16
Ω
2
8
12
16
Ω
3
9
13
18
Ω
(peak)
76
210
240
270
Ω
2
8
12
16
Ω
74HC4852-Q100
ΔRON
ON resistance VI = 0.5 x VCC; E = VIL
mismatch
between
channels
74HCT4852-Q100
ΔRON
mismatch
between
channels
74HC_HCT4852_Q100
Product data sheet
6 / 19
Nexperia
Table 7. Injection current coupling
At recommended operating conditions; voltages are referenced to GND (ground 0 V); For test circuit see Fig. 9.
Symbol
Parameter
Conditions
74HC4852-Q100
74HCT4852-Q100
Unit
Min
Typ[1]
Max
Min
Typ[1]
Max
VCC = 3.3 V
0.05
1
mV
VCC = 5.0 V
0.03
1
0.03
1
mV
VCC = 3.3 V
0.55
5
mV
VCC = 5.0 V
0.27
5
0.27
5
mV
VCC = 3.3 V
0.04
2
mV
VCC = 5.0 V
0.03
2
0.03
2
mV
VCC = 3.3 V
0.56
mV
VCC = 5.0 V
0.48
mV
ΔVO
output voltage
variation
|ISW| ≤ 1 mA; RS ≤ 3.9 kΩ
[2][3]
|ISW| ≤ 10 mA; RS ≤ 3.9 kΩ
|ISW| ≤ 1 mA; RS ≤ 20 kΩ
|ISW| ≤ 10 mA; RS ≤ 20 kΩ
[1]
[2]
[3]
Typical values are measured at Tamb = 25 °C.
ΔVO here is the maximum variation of output voltage of an enabled analog channel when current is injected into any disabled channel.
ISW = total current injected into all disabled channels.
Table 8. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground 0 V).
Symbol Parameter
Conditions
25 °C
Min
Typ Max
Min
Max
Min
Max
Unit
74HC4852-Q100
VIH
VIL
control inputs
HIGH-level
input voltage
VCC = 2.0 V
1.5
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 3.3 V
2.3
2.3
2.3
V
VCC = 4.5 V
3.15
3.15
3.15
V
VCC = 6.0 V
4.2
4.2
4.2
V
control inputs
LOW-level
input voltage
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 3.3 V
1.0
1.0
1.0
V
VCC = 4.5 V
1.35
1.35
1.35
V
VCC = 6.0 V
1.8
1.8
1.8
V
±0.1
±0.1
±1.0
μA
nYn; per channel
±0.1
±0.5
±1.0
μA
nZ; all channels
±0.2
±2.0
±4.0
μA
II
input leakage control inputs; VI = GND or VCC
current
VCC = 6.0 V
IS(OFF)
OFF-state
leakage
current
74HC_HCT4852_Q100
Product data sheet
E = VIH; VI = GND or VCC;
VO = VCC or GND; VCC = 6.0 V;
see Fig. 6
7 / 19
Nexperia
Symbol Parameter
Conditions
25 °C
Min
IS(ON)
ON-state
leakage
current
E = VIL; VI = GND or VCC;
see Fig. 7
ICC
supply
current
VI = GND or VCC
CI
input
capacitance
Csw
switch
capacitance
Typ Max
Min
Max
Min
Max
Unit
±0.1
±0.5
±1.0
μA
2.0
5.0
20.0
μA
S0, S1, S2 and E
2
10
10
10
pF
nZ; OFF-state
15
40
40
40
pF
nYn; OFF-state
3
15
15
15
pF
control inputs
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
2.0
2.0
V
control inputs
LOW-level
input voltage
0.8
0.8
0.8
V
II
current
VCC = 5.5 V
±0.1
±0.1
±1.0
μA
IS(OFF)
OFF-state
leakage
current
per channel
±0.1
±0.5
±1.0
μA
all channels
±0.2
±2.0
±4.0
μA
±0.1
±0.5
±1.0
μA
2.0
5.0
20.0
μA
VCC = 6.0 V
74HCT4852-Q100
VIH
VIL
VO = VCC or GND; VCC = 5.5 V;
see Fig. 6
IS(ON)
ON-state
leakage
current
see Fig. 7
ICC
supply
current
VI = GND or VCC
ΔICC
additional
supply
current
control inputs; VI = VCC - 2.1 V;
other inputs at VCC or GND;
VCC = 4.5 V to 5.5 V; IO = 0 A
300
370
370
μA
CI
input
capacitance
S0, S1, S2 and E
2
10
10
10
pF
Csw
switch
capacitance
nZ; OFF-state
9
40
40
40
pF
nYn; OFF-state
3
15
15
15
pF
74HC_HCT4852_Q100
Product data sheet
VCC = 5.5 V
8 / 19
Nexperia
VCC
IS
nYn
selected channel(1)
VI
nZ
VCC
VIH
IS
E
VIL
E
n.c.
nYn
nYn
nZ
IS
VO
GND
VI
GND
VO
001aag099
(1) Channel is selected by S0 and S1.
001aag098
Fig. 6.
Test circuit for measuring OFF-state leakage
current
Fig. 7.
Test circuit for measuring ON-state leakage
current
VCC
nYn
VI(1)
ISW
nZ
VSW
V
VCC
E
VI(2)
nYn
RS
E
VIL
nYn
VI
GND
Test circuit for measuring ON resistance
Product data sheet
GND
VO
ISW
001aag101
(1)
(1)
VI < GND or VI > VCC.
(2)
GND < VI < VCC.
RON = VSW / ISW.
74HC_HCT4852_Q100
selected channel(1)
VI
nZ
001aag100
Fig. 8.
VIL
Fig. 9.
Test circuit for injection current coupling
9 / 19
Nexperia
11. Dynamic characteristics
Table 9. Dynamic characteristics
At recommended operating conditions; voltages are referenced to GND (ground 0 V); for test circuit see Fig. 14.
Symbol Parameter
Conditions
25 °C
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
2.2
9.3
33
2.2
34
2.2
35
ns
VCC = 3.0 V
2.2
4.9
16.5
1.9
18
1.9
19.5
ns
VCC = 3.3 V
2.0
4.4
15.0
1.6
16.5
1.6
18.5
ns
VCC = 4.5 V
1.6
3.2
11.6
1.1
12.5
1.1
13.5
ns
VCC = 6.0 V
1.5
2.5
10.2
0.9
11
0.9
12
ns
VCC = 2.0 V
7.7
16.8
38
6.3
40
6.3
42
ns
VCC = 3.0 V
4.9
8.8
21.5
3.9
23
ns
VCC = 3.3 V
4.4
7.9
17.5
3.4
19
3.4
22
ns
VCC = 4.5 V
3.2
5.8
14
2.3
15
2.3
17
ns
VCC = 6.0 V
2.4
4.8
12.6
1.6
14.5
1.6
16.5
ns
VCC = 2.0 V
10.5
20.5
47.5
8.5
52.5
8.5
57.5
ns
VCC = 3.0 V
6.2
10.6
45
5.2
50
5.2
55
ns
VCC = 3.3 V
5.6
9.4
42.5
4.6
47.5
4.6
52.5
ns
VCC = 4.5 V
4.2
6.9
40
3
45
3
50
ns
VCC = 6.0 V
3.2
5.6
39
2.2
40
2.2
40
ns
VCC = 2.0 V
39.5
75.4
100
39.3
105
39
115
ns
VCC = 3.0 V
35.2
69.5
90
35.5
100
35
110
ns
VCC = 3.3 V
34.6
68.1
85
34.6
95
34.5
105
ns
VCC = 4.5 V
28.5
63
80
28.2
90
28
100
ns
VCC = 6.0 V
14.4
57.9
78
13.5
80
13.0
80
ns
VCC = 3.3 V
42
pF
VCC = 5.0 V
47
pF
74HC4852-Q100
tpd
propagation
delay
nZ, nYn to nYn, nZ;
see Fig. 10
[1]
Sn to nZ, nYn; see Fig. 11 [1]
ten
tdis
CPD
enable time
disable time
power
dissipation
capacitance
74HC_HCT4852_Q100
Product data sheet
E to nZ, nYn; see Fig. 12
per channel; see Fig. 13
[2]
[3]
[4]
10 / 19
Nexperia
Symbol Parameter
Conditions
25 °C
Min
Typ
Max
Min
Max
Min
Max
1.6
3.5
11.5
1.1
12.5
1.1
13.5
ns
3.2
7.6
13
2.3
15
1.6
17
ns
4.2
8.3
25
3.0
30
3.0
35
ns
28.5
61.8
80
28.2
90
28.0
100
ns
47
pF
74HCT4852-Q100
tpd
propagation
delay
nZ, nYn to nYn, nZ;
see Fig. 10
[1]
VCC = 4.5 V
VCC = 4.5 V
ten
enable time
[2]
VCC = 4.5 V
tdis
disable time
[3]
VCC = 4.5 V
CPD
[1]
[2]
[3]
[4]
power
dissipation
capacitance
[4]
VCC = 5.0 V
tpd is the same as tPLH and tPHL.
ten is the same as tPZH and tPZL.
tdis is the same as tPLZ and tPHZ.
CPD is used to determine the dynamic power dissipation (PD in μW):
2
2
PD = CPD x VCC x fi + ∑{(CL + Csw) x VCC x fo} where:
fi = input frequency in MHz;
fo = output frequency in MHz;
2
∑{(CL + Csw) x VCC x fo} = sum of outputs;
CL = output load capacitance in pF;
Csw = switch capacitance in pF;
VCC = supply voltage in V.
11.1. Waveforms
VCC
nZ or nYn
input
0.5VCC
GND
tPLH
tPHL
VCC
nYn or nZ
output
0.5VCC
GND
001aah578
Fig. 10. Input (nZ, nYn) to output (nYn, nZ) propagation delays
VI
VM
Sn input
GND
tPLH
VCC
nYn or nZ
output
tPHL
VM
GND
001aah579
Measurement points are given in Table 10.
Fig. 11. Input (Sn) to output (nYn, nZ) propagation delays
74HC_HCT4852_Q100
Product data sheet
11 / 19
Nexperia
VI
E input
VM
VM
0V
tPLZ
tPZL
VCC
VM
nZ or nYn output
VX
VOL
tPHZ
VOH
tPZH
VY
VM
nZ or nYn output
GND
switch ON
switch OFF
switch ON
001aah580
Measurement points are shown in Table 10.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 12. Enable and disable times
Table 10. Measurement points
Input
Type
Output
VM
VI
VM
VX
VY
74HC4852-Q100
0.5VCC
VCC
0.5VCC
VOL + 0.1(VCC - VOL) 0.9VOH
74HCT4852-Q100
1.3 V
3.0 V
0.5VCC
VCC
A
nYn
G
selected
channel
Sn
nZ
E
n.c.
nYn
disabled
channel
GND
001aah581
Fig. 13. Test circuit for measuring power dissipation capacitance
74HC_HCT4852_Q100
Product data sheet
12 / 19
Nexperia
VI
negative
pulse
tW
90 %
90 %
VM
10 %
0V
VI
positive
pulse
0V
VM
tf
tr
tr
tf
90 %
VM
VM
10 %
10 %
tW
001aac221
a. Input pulse definition
switch
VCC
G
VI
DUT
VCC
open
RL
VO
CL
RT
GND
001aaf883
Definitions for test circuit:
RL = load resistance.
CL = load capacitance including jig and probe capacitance.
RT = termination resistance should be equal to the output impedance Zo of the pulse generator.
b. Test circuit
Test data is given in Table 11.
Fig. 14. Input pulse definition and test circuit
Table 11. Test data
Test
Input
Output
Control E, Sn
Switch nYn (nZ)
VI[1]
VI
tPHL, tPLH
VCC
VCC
tPHZ, tPZH
VCC
tPLZ, tPZL
CPD
[1]
tr, tf
S1 position
Switch nZ (nYn)
CL
RL
6 ns
50 pF
open
VCC
6 ns
50 pF
10 kΩ
GND
VCC
VCC
6 ns
50 pF
10 kΩ
VCC
VCC
VCC
6 ns
0 pF
open
For 74HCT4852-Q100: input voltage VI = 3.0 V.
74HC_HCT4852_Q100
Product data sheet
13 / 19
Nexperia
12. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
w M
bp
detail X
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.16
0.15
0.05
0.039
0.016
0.028
0.020
0.01
0.01
0.004
0.028
0.012
0.244
0.041
0.228
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 15. Package outline SOT109-1 (SO16)
74HC_HCT4852_Q100
Product data sheet
14 / 19
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
D
SOT403-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
8
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 16. Package outline SOT403-1 (TSSOP16)
74HC_HCT4852_Q100
Product data sheet
15 / 19
Nexperia
DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT763-1
16 terminals; body 2.5 x 3.5 x 0.85 mm
B
D
A
A
E
A1
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
b
2
7
y
y1 C
v M C A B
w M C
L
1
8
Eh
e
16
9
15
10
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
c
D (1)
Dh
E (1)
Eh
e
e1
L
v
w
y
y1
mm
1
0.05
0.00
0.30
0.18
0.2
3.6
3.4
2.15
1.85
2.6
2.4
1.15
0.85
0.5
2.5
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT763-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig. 17. Package outline SOT763-1 (DHVQFN16)
74HC_HCT4852_Q100
Product data sheet
16 / 19
Nexperia
13. Abbreviations
Table 12. Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
14. Revision history
Table 13. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT4852_Q100 v.4
20200428
Product data sheet
74HC4852_Q100 v.1
Modifications:
74HC4852_Q100 v.1
20120712
74HC_HCT4852_Q100
Product data sheet
General description: updated.
Features updated.
Table 4: Derating values for Ptot total power dissipation have been updated.
Product data sheet
17 / 19
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
15. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74HC_HCT4852_Q100
Product data sheet
18 / 19
Nexperia
Contents
1. General description...................................................... 1
2. Features.........................................................................1
3. Applications.................................................................. 1
4. Ordering information....................................................2
5. Functional diagram.......................................................2
6. Pinning information......................................................4
6.1. Pinning.........................................................................4
6.2. Pin description............................................................. 4
7. Functional description................................................. 5
8. Limiting values............................................................. 5
9. Recommended operating conditions..........................6
10. Static characteristics..................................................6
11. Dynamic characteristics...........................................10
11.1. Waveforms............................................................... 11
12. Package outline........................................................ 14
13. Abbreviations............................................................ 17
14. Revision history........................................................17
15. Legal information......................................................18
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 28 April 2020
74HC_HCT4852_Q100
Product data sheet
19 / 19
