HEF4541BT-Q100Y
HEF4541BT-Q100Y
    NEXPERIA(安世)
    SOIC14_150MIL
    HEF4541B-Q100是一个可编程定时器。它由一个16级二进制计数器、一个集成振荡器与外部定时组件、一个自动上电复位和输出控制逻辑组成
HEF4541BT-Q100Y 数据手册
HEF4541B-Q100 Programmable timer Rev. 2 — 31 December 2013 Product data sheet 1. General description The HEF4541B-Q100 is a programmable timer. It consists of a 16-stage binary counter, an integrated oscillator to be used with external timing components, an automatic power-on reset and output control logic. The external components RTC and CTC determines the frequency of the oscillator within the frequency range 1 Hz to 100 kHz. An external clock signal at input RS can replace the oscillator. The timer advances on the positive-going transition of RS. A LOW on the auto reset input (AR) and a LOW on the master reset input (MR) enables the internal power-on reset. A HIGH level at input MR resets the counter independent on all other inputs. Resetting, disables the oscillator to provide no active power dissipation. A HIGH at input AR turns off the power-on reset to provide a low quiescent power dissipation of the timer. The 16-stage counter divides the oscillator frequency by 28, 210, 213 or 216 depending on the state of the address inputs (A0, A1). The divided oscillator frequency is available at output O. The phase input (PH) features a complementary output signal. When the mode select input (MODE) is LOW the timer is a single transition timer and when HIGH the timer is a 2n frequency divider. It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Fully static operation  5 V, 10 V, and 15 V parametric ratings  Standardized symmetrical output characteristics  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Complies with JEDEC standard JESD 13-B HEF4541B-Q100 Nexperia Programmable timer 3. Ordering information Table 1. Ordering information All types operate from 40 C to +125 C. Type number Package Name HEF4541BT-Q100 SO14 Description Version plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 4. Functional diagram RS CTC RTC 3 2 1 A0 12 A1 MODE 13 10 CONTROL INPUTS AR MR PH CP 5 6 POWER-ON RESET CD BINARY COUNTER OUTPUT STAGE 8 O 9 001aai581 Fig 1. Functional diagram HEF4541B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 31 December 2013 © Nexperia B.V. 2017. All rights reserved 2 of 17 HEF4541B-Q100 Nexperia Programmable timer CTC RTC 28 COUNTER CP RESET RS 28 28 COUNTER CP RESET 22 25 28 A0 MUX A1 AR POWER-ON RESET LATCH MR MODE PH O 001aai583 Fig 2. Logic diagram HEF4541B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 31 December 2013 © Nexperia B.V. 2017. All rights reserved 3 of 17 HEF4541B-Q100 Nexperia Programmable timer 5. Pinning information 5.1 Pinning +()%4 57&   9'' &7&   $ 56   $ QF   QF $5   02'( 05   3+ 966   2 DDD Fig 3. Pin configuration 5.2 Pin description Table 2. Pin description Symbol Pin Description RTC 1 external resistor connection CTC 2 external capacitor connection RS 3 external resistor connection (RS) or external clock input nc 4, 11 not connected AR 5 auto reset input (active low) MR 6 master reset input VSS 7 ground (0 V) O 8 timer output PH 9 phase input MODE 10 mode select input A0, A1 12, 13 address inputs VDD 14 supply voltage HEF4541B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 31 December 2013 © Nexperia B.V. 2017. All rights reserved 4 of 17 HEF4541B-Q100 Nexperia Programmable timer 6. Functional description Table 3. Function table[1] Input MODE AR MR PH MODE H L X X auto reset disabled L L X X auto reset enabled[2] X H X X master reset active X L X H normal operation selected division to output X L X L single-cycle mode[3] X L L X output initially LOW after reset X L H X output initially HIGH, after reset [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care. [2] For correct power-on reset, the supply voltage should be above 8.5 V. For VDD < 8.5 V, disable the auto reset and connect AR to VDD. [3] The timer is initialized on a reset pulse and the output changes state after 2n-1 counts and remains in that state (latched). A master reset or a LOW to HIGH transition on the MODE input, resets this latch. Table 4. Frequency selection table A0 A1 Number of counter stages n f OSC ---------- = 2 n fO L L 13 8192 L H 10 1024 H L 8 256 H H 16 65536 7. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDD supply voltage Conditions Min 0.5 VI < 0.5 V or VI > VDD + 0.5 V +18 10 Unit V IIK input clamping current VI input voltage IOK output clamping current VO < 0.5 V or VO > VDD + 0.5 V - 10 mA II/O input/output current O output - 10 mA Tstg storage temperature 65 +150 C Tamb ambient temperature 40 +125 C - 500 mW - 100 mW Ptot total power dissipation P power dissipation [1] - Max 0.5 Tamb = 40 C to +125 C [1] VDD + 0.5 mA V For SO14 package: Ptot derates linearly with 8 mW/K above 70 C. HEF4541B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 31 December 2013 © Nexperia B.V. 2017. All rights reserved 5 of 17 HEF4541B-Q100 Nexperia Programmable timer 8. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VDD VI Conditions Min Max Unit supply voltage 3 15 V input voltage 0 VDD V Tamb ambient temperature in free air 40 +125 C t/V input transition rise and fall rate VDD = 5 V - 3.75 s/V VDD = 10 V - 0.5 s/V VDD = 15 V - 0.08 s/V 9. Static characteristics Table 7. Static characteristics VSS = 0 V; VI = VSS or VDD; unless otherwise specified. Symbol Parameter VIH VIL VOH VOL IOH Conditions HIGH-level input voltage IO < 1 A LOW-level input voltage IO < 1 A HIGH-level IO < 1 A output voltage Tamb = 40 C Tamb = 25 C Tamb = 85 C Tamb = 125 C Unit Min Max Min Max Min Max Min Max 5V 3.5 - 3.5 - 3.5 - 3.5 - V 10 V 7.0 - 7.0 - 7.0 - 7.0 - V 15 V 11.0 - 11.0 - 11.0 - 11.0 - V 5V - 1.5 - 1.5 - 1.5 - 1.5 V 10 V - 3.0 - 3.0 - 3.0 - 3.0 V 15 V - 4.0 - 4.0 - 4.0 - 4.0 V 5V 4.95 - 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - 14.95 - V 5V - 0.05 - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 - 0.05 V 15 V - 0.05 - 0.05 - 0.05 - 0.05 V 5V - 1.4 - 1.2 - 0.95 - 0.95 mA VO = 4.6 V 5V - 0.5 - 0.4 - 0.3 - 0.3 VO = 9.5 V 10 V - 1.4 - 1.2 - 0.95 - 0.95 mA VO = 13.5 V 15 V - 4.8 - 4.0 - 3.2 - 3.2 mA mA LOW-level IO < 1 A output voltage HIGH-level output current VDD CTC, RTC; VO = 2.5 V mA O; HEF4541B_Q100 Product data sheet VO = 2.5 V 5V - 1.7 - 1.4 - 1.1 - 1.1 VO = 4.6 V 5V - 0.64 - 0.5 - 0.36 - 0.36 mA VO = 9.5 V 10 V - 1.6 - 1.3 - 0.9 - 0.9 mA VO = 13.5 V 15 V - 4.2 - 3.4 - 2.4 - 2.4 mA All information provided in this document is subject to legal disclaimers. Rev. 2 — 31 December 2013 © Nexperia B.V. 2017. All rights reserved 6 of 17 HEF4541B-Q100 Nexperia Programmable timer Table 7. Static characteristics …continued VSS = 0 V; VI = VSS or VDD; unless otherwise specified. Symbol Parameter IOL LOW-level output current Conditions VDD Tamb = 40 C Tamb = 25 C Tamb = 85 C Tamb = 125 C Unit Min Max Min Max Min Max Min Max CTC, RTC; VO = 0.4 V 5V 0.33 - 0.27 - 0.20 - 0.20 - mA VO = 0.5 V 10 V 1.0 - 0.85 - 0.68 - 0.68 - mA VO = 1.5 V 15 V 3.2 - 2.7 - 2.3 - 2.3 - mA VO = 0.4 V 5V 0.64 - 0.5 - 0.36 - 0.36 - mA VO = 0.5 V 10 V 1.6 - 1.3 - 0.9 - 0.9 - mA VO = 1.5 V 15 V 4.2 - 3.2 - 2.4 - 2.4 - mA 15 V - 0.1 - 0.1 - 1.0 - 1.0 A 5V - 5 - 5 - 150 - 150 A 10 V - 10 - 10 - 300 - 300 A 15 V - 20 - 20 - 600 - 600 A - - - - 7.5 - - - - pF O; II input leakage current IDD supply current IO = 0 A CI input capacitance Table 8. Reset characteristics VSS = 0 V; VI = VSS or VDD; see Table 12 for test conditions; unless otherwise specified. Symbol Parameter IDD VDD Conditions VDD supply current supply current 5V for power-on 10 V reset enable; AR = MR = 0 V; 15 V Other inputs at 0 V or VDD supply voltage supply voltage for automatic reset initialization; AR = MR = 0 V; Other inputs at 0 V or VDD HEF4541B_Q100 Product data sheet - Tamb = 40 C Tamb = +25 C Tamb = +85 C Tamb = +125 C Unit Min Max Min Typ Max Min Max Min Max - 80 - 20 80 - 230 - 230 A - 750 - 250 600 - 700 - 700 A - 1.6 - 0.5 1.3 - 1.5 - 1.5 mA - - 8.5 5 - - - - - All information provided in this document is subject to legal disclaimers. Rev. 2 — 31 December 2013 © V Nexperia B.V. 2017. All rights reserved 7 of 17 HEF4541B-Q100 Nexperia Programmable timer 10. Dynamic characteristics Table 9. Dynamic characteristics VSS = 0 V; Tamb = 25 C unless otherwise specified. For test circuit, see Figure 5. Symbol Parameter propagation delay tpd Conditions RS to O; 28 selected; see Figure 4 pulse width fclk(max) fosc Min Typ[1] 348 ns + (0.55 ns/pF)CL - 375 750 ns 10 V 139 ns + (0.23 ns/pF)CL - 150 300 ns 15 V 102 ns + (0.16 ns/pF)CL - 110 220 ns 5V 398 ns + (0.55 ns/pF)CL - 425 850 ns 10 V 154 ns + (0.23 ns/pF)CL - 165 330 ns 15 V 5V RS to O; 210 selected; see Figure 4 tW Extrapolation formula VDD [2] Max Unit 112 ns + (0.16 ns/pF)CL - 120 240 ns RS to O; 213 selected; see Figure 4 5V 483 ns + (0.55 ns/pF)CL - 510 1020 ns 10 V 179 ns + (0.23 ns/pF)CL - 190 380 ns 15 V 127 ns + (0.16 ns/pF)CL - 135 270 ns RS to O; 216 selected; see Figure 4 5V 548 ns + (0.55 ns/pF)CL - 575 1150 ns 10 V 199 ns + (0.23 ns/pF)CL - 210 420 ns 142 ns + (0.16 ns/pF)CL - 150 300 ns 15 V RS LOW; MR HIGH; see Figure 4 5V maximum clock frequency RS; see Figure 4 oscillator frequency Rt = 5 k; Ct = 1 nF; RS = 10 k; see Figure 6 Rt = 56 k; Ct = 1 nF; RS = 120 k; see Figure 6 [3] 60 30 - ns 10 V 30 15 - ns 15 V 24 12 - ns 5V 8 16 - MHz 10 V 15 30 - MHz 15 V 18 36 - MHz 5V - 90 - kHz 10 V - 90 - kHz 15 V - 90 - kHz 5V - 8 - kHz 10 V - 8 - kHz 15 V - 8 - kHz [1] The typical values of the propagation delay and transition times are calculated from the extrapolation formulas shown (CL in pF). [2] tpd is the same as tPHL and tPLH. [3] tW is the same as tWL(min) and tWH(min). HEF4541B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 31 December 2013 © Nexperia B.V. 2017. All rights reserved 8 of 17 HEF4541B-Q100 Nexperia Programmable timer Table 10. Dynamic power dissipation PD can be calculated from the formulas shown. VSS = 0 V; tr = tf  20 ns; Tamb = 25 C. Symbol Parameter VDD Typical formula PD dynamic power dissipation Per package 5V PD = 1300  fi + (fo  CL  VDD2) W 10 V PD = 5300  fi + (fo  CL  VDD2) W 15 V PD = 12000  fi + (fo  CL  VDD2) W Total, using the on-chip oscillator [1] 5V PD = 1300  fosc + foCLVDD2 + 2CTCVDD2 fosc + 10VDD W 10 V PD = 5300  fosc + foCLVDD2 + 2CTCVDD2 fosc + 100VDD W 15 V PD = 12000  fosc + foCLVDD2 + 2CTCVDD2 fosc + 400VDD W fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VDD = supply voltage in V; fosc = oscillator frequency in MHz; CTC = timing capacitance in pF. 11. Waveforms (1) 1/fclk(max) VI VM RS input VSS VOH tWH(min) tWL(min) tPLH O output tPHL VM VOL VI MR input VSS tWH(min) aaa-003391 VOL and VOH are typical output voltage levels that occur with the output load. Measurement points are given in Table 11, the test circuit in Figure 5 and the test data in Table 12 (1) 2n pulses as selected by address inputs (A0, A1). Fig 4. Propagation delay clock (RS) to output (O), clock pulse width and maximum clock frequency Table 11. Measurement points Supply voltage Input Output VDD VM VM 5 V to 15 V 0.5VDD 0.5VDD HEF4541B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 31 December 2013 © Nexperia B.V. 2017. All rights reserved 9 of 17 HEF4541B-Q100 Nexperia Programmable timer VDD VI VO G DUT CL RT 001aag182 Test data is given in Table 12. Definitions for test circuit: DUT - Device Under Test. RL = Load resistance. CL = load capacitance. RT = Termination resistance should be equal to output impedance of Zo of the pulse generator. Fig 5. Test circuit for measuring switching times Table 12. Test data Supply Input VDD VI tr, tf CL 5 V to 15 V VSS or VDD  20 ns 50 pF HEF4541B_Q100 Product data sheet Load All information provided in this document is subject to legal disclaimers. Rev. 2 — 31 December 2013 © Nexperia B.V. 2017. All rights reserved 10 of 17 HEF4541B-Q100 Nexperia Programmable timer 12. Application information RC oscillator timing component limitations RTCCTC determines the oscillator frequency, provided RTC
HEF4541BT-Q100Y 价格&库存
很抱歉,暂时无法提供与“HEF4541BT-Q100Y”相匹配的价格&库存,您可以联系我们找货
HEF4541BT-Q100Y
  • 1+9.720481+1.24685
