74HC4046AD,653
74HC4046AD,653
    NEXPERIA(安世)
    SOIC16_150MIL
    带VCO的锁相环 17MHz 3~6V
74HC4046AD,653 数据手册
INTEGRATED CIRCUITS DATA SHEET For a complete data sheet, please also download: • The IC06 74HC/HCT/HCU/HCMOS Logic Family Specifications • The IC06 74HC/HCT/HCU/HCMOS Logic Package Information • The IC06 74HC/HCT/HCU/HCMOS Logic Package Outlines 74HC/HCT4046A Phase-locked-loop with VCO Product specification Supersedes data of September 1993 File under Integrated Circuits, IC06 1997 Nov 25 Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A provided at pin 10 (DEMOUT). In contrast to conventional techniques where the DEMOUT voltage is one threshold voltage lower than the VCO input voltage, here the DEMOUT voltage equals that of the VCO input. If DEMOUT is used, a load resistor (RS) should be connected from DEMOUT to GND; if unused, DEMOUT should be left open. The VCO output (VCOOUT) can be connected directly to the comparator input (COMPIN), or connected via a frequency-divider. The VCO output signal has a duty factor of 50% (maximum expected deviation 1%), if the VCO input is held at a constant DC level. A LOW level at the inhibit input (INH) enables the VCO and demodulator, while a HIGH level turns both off to minimize standby power consumption. FEATURES • Low power consumption • Centre frequency of up to 17 MHz (typ.) at VCC = 4.5 V • Choice of three phase comparators: EXCLUSIVE-OR; edge-triggered JK flip-flop; edge-triggered RS flip-flop • Excellent VCO frequency linearity • VCO-inhibit control for ON/OFF keying and for low standby power consumption • Minimal frequency drift • Operating power supply voltage range: VCO section 3.0 to 6.0 V digital section 2.0 to 6.0 V The only difference between the HC and HCT versions is the input level specification of the INH input. This input disables the VCO section. The sections of the comparator are identical, so that there is no difference in the SIGIN (pin 14) or COMPIN (pin 3) inputs between the HC and HCT versions. • Zero voltage offset due to op-amp buffering • Output capability: standard • ICC category: MSI. GENERAL DESCRIPTION Phase comparators The 74HC/HCT4046A are high-speed Si-gate CMOS devices and are pin compatible with the “4046” of the “4000B” series. They are specified in compliance with JEDEC standard no. 7A. The signal input (SIGIN) can be directly coupled to the self-biasing amplifier at pin 14, provided that the signal swing is between the standard HC family input logic levels. Capacitive coupling is required for signals with smaller swings. The 74HC/HCT4046A are phase-locked-loop circuits that comprise a linear voltage-controlled oscillator (VCO) and three different phase comparators (PC1, PC2 and PC3) with a common signal input amplifier and a common comparator input. Phase comparator 1 (PC1) This is an EXCLUSIVE-OR network. The signal and comparator input frequencies (fi) must have a 50% duty factor to obtain the maximum locking range. The transfer characteristic of PC1, assuming ripple (fr = 2fi) is The signal input can be directly coupled to large voltage signals, or indirectly coupled (with a series capacitor) to small voltage signals. A self-bias input circuit keeps small voltage signals within the linear region of the input amplifiers. With a passive low-pass filter, the “4046A” forms a second-order loop PLL. The excellent VCO linearity is achieved by the use of linear op-amp techniques. V CC suppressed, is: V DEMOUT = ----------- ( φ SIGIN – φ COMPIN ) π where VDEMOUT is the demodulator output at pin 10; VDEMOUT = VPC1OUT (via low-pass filter). The VCO requires one external capacitor C1 (between C1A and C1B) and one external resistor R1 (between R1 and GND) or two external resistors R1 and R2 (between R1 and GND, and R2 and GND). Resistor R1 and capacitor C1 determine the frequency range of the VCO. Resistor R2 enables the VCO to have a frequency offset if required. V CC The phase comparator gain is: K p = ----------- ( V˙⁄ r ) . π The average output voltage from PC1, fed to the VCO input via the low-pass filter and seen at the demodulator output at pin 10 (VDEMOUT), is the resultant of the phase differences of signals (SIGIN) and the comparator input (COMPIN) as shown in Fig.6. The average of VDEMOUT is The high input impedance of the VCO simplifies the design of low-pass filters by giving the designer a wide choice of resistor/capacitor ranges. In order not to load the low-pass filter, a demodulator output of the VCO input voltage is equal to 1⁄2VCC when there is no signal or noise at SIGIN and with this input the VCO oscillates at the centre frequency (fo). Typical waveforms for the PC1 loop locked at fo are shown in Fig.7. 1997 Nov 25 2 Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A The frequency capture range (2fc) is defined as the frequency range of input signals on which the PLL will lock if it was initially out-of-lock. The frequency lock range (2fL) is defined as the frequency range of input signals on which the loop will stay locked if it was initially in lock. The capture range is smaller or equal to the lock range. and comparator inputs are equal in both phase and frequency. At this stable point the voltage on C2 remains constant as the PC2 output is in 3-state and the VCO input at pin 9 is a high impedance. Also in this condition, the signal at the phase comparator pulse output (PCPOUT) is a HIGH level and so can be used for indicating a locked condition. With PC1, the capture range depends on the low-pass filter characteristics and can be made as large as the lock range. This configuration retains lock even with very noisy input signals. Typical behaviour of this type of phase comparator is that it can lock to input frequencies close to the harmonics of the VCO centre frequency. Thus, for PC2, no phase difference exists between SIGIN and COMPIN over the full frequency range of the VCO. Moreover, the power dissipation due to the low-pass filter is reduced because both p and n-type drivers are “OFF” for most of the signal input cycle. It should be noted that the PLL lock range for this type of phase comparator is equal to the capture range and is independent of the low-pass filter. With no signal present at SIGIN the VCO adjusts, via PC2, to its lowest frequency. Phase comparator 2 (PC2) This is a positive edge-triggered phase and frequency detector. When the PLL is using this comparator, the loop is controlled by positive signal transitions and the duty factors of SIGIN and COMPIN are not important. PC2 comprises two D-type flip-flops, control-gating and a 3-state output stage. The circuit functions as an up-down counter (Fig.5) where SIGIN causes an up-count and COMPIN a down-count. The transfer function of PC2, assuming ripple (fr = fi) is suppressed, This is a positive edge-triggered sequential phase detector using an RS-type flip-flop. When the PLL is using this comparator, the loop is controlled by positive signal transitions and the duty factors of SIGIN and COMPIN are not important. The transfer characteristic of PC3, assuming ripple (fr = fi) is suppressed, V CC is: V DEMOUT = ----------- ( φ SIGIN – φ COMPIN ) 4π V CC is: V DEMOUT = ----------- ( φ SIGIN – φ COMPIN ) 2π where VDEMOUT is the demodulator output at pin 10; VDEMOUT = VPC2OUT (via low-pass filter). where VDEMOUT is the demodulator output at pin 10; VDEMOUT = VPC3OUT (via low-pass filter). V CC The phase comparator gain is: K p = ----------- ( V ⁄ r ) . 4π V CC The phase comparator gain is: K p = ----------- ( V ⁄ r ) . 2π VDEMOUT is the resultant of the initial phase differences of SIGIN and COMPIN as shown in Fig.8. Typical waveforms for the PC2 loop locked at fo are shown in Fig.9. The average output from PC3, fed to the VCO via the low-pass filter and seen at the demodulator output at pin 10 (VDEMOUT), is the resultant of the phase differences of SIGIN and COMPIN as shown in Fig.10. Typical waveforms for the PC3 loop locked at fo are shown in Fig.11. Phase comparator 3 (PC3) When the frequencies of SIGIN and COMPIN are equal but the phase of SIGIN leads that of COMPIN, the p-type output driver at PC2OUT is held “ON” for a time corresponding to the phase difference (φDEMOUT). When the phase of SIGIN lags that of COMPIN, the n-type driver is held “ON”. The phase-to-output response characteristic of PC3 (Fig.10) differs from that of PC2 in that the phase angle between SIGIN and COMPIN varies between 0° and 360° and is 180° at the centre frequency. Also PC3 gives a greater voltage swing than PC2 for input phase differences but as a consequence the ripple content of the VCO input signal is higher. The PLL lock range for this type of phase comparator and the capture range are dependent on the low-pass filter. With no signal present at SIGIN the VCO adjusts, via PC3, to its lowest frequency. When the frequency of SIGIN is higher than that of COMPIN, the p-type output driver is held “ON” for most of the input signal cycle time, and for the remainder of the cycle both n and p- type drivers are ”OFF” (3-state). If the SIGIN frequency is lower than the COMPIN frequency, then it is the n-type driver that is held “ON” for most of the cycle. Subsequently, the voltage at the capacitor (C2) of the low-pass filter connected to PC2OUT varies until the signal 1997 Nov 25 3 Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A QUICK REFERENCE DATA GND = 0 V; Tamb = 25 °C TYPICAL SYMBOL PARAMETER CONDITIONS UNIT HC fo VCO centre frequency CI input capacitance (pin 5) CPD power dissipation capacitance per package HCT C1 = 40 pF; R1 = 3 kΩ; VCC = 5 V 19 19 MHz 3.5 3.5 pF 24 24 pF notes 1 and 2 Notes 1. CPD is used to determine the dynamic power dissipation (PD in µW): PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where: fi = input frequency in MHz. fo = output frequency in MHz. CL = output load capacitance in pF. VCC = supply voltage in V. ∑ (CL × VCC2 × fo) = sum of outputs. 2. Applies to the phase comparator section only (VCO disabled). For power dissipation of the VCO and demodulator sections see Figs 22, 23 and 24. ORDERING INFORMATION See “74HC/HCT/HCU/HCMOS Logic Package Information”. APPLICATIONS • FM modulation and demodulation • Frequency synthesis and multiplication • Frequency discrimination • Tone decoding • Data synchronization and conditioning • Voltage-to-frequency conversion • Motor-speed control. PACKAGE OUTLINES See “74HC/HCT/HCU/HCMOS Logic Package Outlines”. 1997 Nov 25 4 Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A PIN DESCRIPTION PIN NO. SYMBOL NAME AND FUNCTION 1 PCPOUT phase comparator pulse output 2 PC1OUT phase comparator 1 output 3 COMPIN comparator input 4 VCOOUT VCO output 5 INH inhibit input 6 C1A capacitor C1 connection A 7 C1B capacitor C1 connection B 8 GND ground (0 V) 9 VCOIN VCO input 10 DEMOUT demodulator output 11 R1 resistor R1 connection 12 R2 resistor R2 connection 13 PC2OUT phase comparator 2 output 14 SIGIN signal input 15 PC3OUT phase comparator 3 output 16 VCC positive supply voltage Fig.1 Pin configuration. 1997 Nov 25 Fig.2 Logic symbol. 5 Fig.3 IEC logic symbol. Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A C1 6 C1A 7 4 3 C1B VCO OUT COMP IN 14 SIG IN 4046A identical to 4046A 12 R2 7046A PC1 OUT 2 PHASE COMPARATOR 1 R2 VCO PC2 OUT 13 11 R1 PHASE COMPARATOR PCP OUT 1 2 R1 R3 PHASE COMPARATOR 2 R4 PC3 OUT 15 PHASE COMPARATOR 3 INH 5 LOCK DETECTOR C2 LD 1 C LD DEM OUT VCO IN 10 9 15 C RS CLD (b) (a) (a) (b) Fig.4 Functional diagram. Fig.5 Logic diagram. 1997 Nov 25 PC2 OUT 13 6 MGA847 Philips Semiconductors Product specification Phase-locked-loop with VCO VDEMOUT = VPC2OUT = 74HC/HCT4046A V CC ----------- ( φ SIGIN – φ COMPIN ) π φDEMOUT = (φSIGIN − φCOMPIN). Fig.6 Phase comparator 1: average output voltage versus input phase difference. Fig.7 Typical waveforms for PLL using phase comparator 1, loop locked at fo. VDEMOUT = VPC2OUT = V CC ----------- ( φ SIGIN – φ COMPIN ) 4π φDEMOUT = (φSIGIN − φCOMPIN). Fig.8 Phase comparator 2: average output voltage versus input phase difference. 1997 Nov 25 7 Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A Fig.9 Typical waveforms for PLL using phase comparator 2, loop locked at fo. VDEMOUT = VPC3OUT = V CC ----------- ( φ SIGIN – φ COMPIN ) 2π φDEMOUT = (φSIGIN − φCOMPIN). Fig.10 Phase comparator 3: average output voltage versus input phase difference: Fig.11 Typical waveforms for PLL using phase comparator 3, loop locked at fo. 1997 Nov 25 8 Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A RECOMMENDED OPERATING CONDITIONS FOR 74HC/HCT 74HC SYMBOL 74HCT PARAMETER UNIT min. typ. max. min. typ. max. VCC DC supply voltage 3.0 5.0 6.0 4.5 5.0 5.5 V VCC DC supply voltage if VCO section is not used 2.0 5.0 6.0 4.5 5.0 5.5 V VI DC input voltage range 0 VCC 0 VCC V VO DC output voltage range 0 VCC 0 VCC V Tamb operating ambient temperature range −40 +85 −40 +85 °C Tamb operating ambient temperature range −40 +125 −40 tr, tf input rise and fall times (pin 5) CONDITIONS see DC and AC CHARACTERISTICS +125 °C 6.0 1000 6.0 500 ns VCC = 2.0 V 6.0 500 6.0 500 ns VCC = 4.5 V 6.0 400 6.0 500 ns VCC = 6.0 V RATINGS Limiting values in accordance with the Absolute Maximum System (IEC 134) Voltages are referenced to GND (ground = 0 V) SYMBOL PARAMETER MIN. MAX. UNIT VCC DC supply voltage −0.5 +7 V ±IIK DC input diode current 20 mA CONDITIONS for VI < −0.5 V or VI > VCC + 0.5 V ±IOK DC output diode current 20 mA for VO < −0.5 V or VO > VCC + 0.5 V ±IO DC output source or sink current 25 mA for −0.5 V < VO < VCC + 0.5 V ±ICC; ±IGND DC VCC or GND current 50 mA Tstg storage temperature range +150 °C Ptot power dissipation per package 1997 Nov 25 −65 plastic DIL 750 mW for temperature range: − 40 to +125 °C 74HC/HCT above + 70 °C: derate linearly with 12 mW/K plastic mini-pack (SO) 500 mW above + 70 °C: derate linearly with 8 mW/K 9 Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A DC CHARACTERISTICS FOR 74HC Quiescent supply current Voltages are referenced to GND (ground = 0 V) Tamb (°C) TEST CONDITIONS 74HC SYMBOL PARAMETER −40 to +85 +25 −40 to +125 min. typ. max. min. max. min. ICC quiescent supply current (VCO disabled) 8.0 80.0 UNIT VCC (V) OTHER µA 6.0 max. 160.0 pins 3, 5, and 14 at VCC; pin 9 at GND; II at pins 3 and 14 to be excluded Phase comparator section Voltages are referenced to GND (ground = 0 V) Tamb (°C) 74HC SYMPARAMETER BOL −40 to +85 +25 min. typ. max. min. max. VIH VIL VOH VOH VOL VOL ±II ±IOZ TEST CONDITIONS −40 to +125 min. UNIT VCC (V) max. DC coupled 1.5 HIGH level input voltage 3.15 SIGIN, COMPIN 4.2 1.2 1.5 1.5 2.4 3.15 3.15 DC coupled LOW level input voltage SIGIN, COMPIN 0.8 0.5 0.5 0.5 2.1 1.35 1.35 1.35 4.5 2.8 1.8 1.8 1.8 6.0 HIGH level output voltage 1.9 PCPOUT, PCnOUT 4.4 2.0 1.9 1.9 4.5 4.4 4.4 4.5 5.9 6.0 5.9 5.9 6.0 HIGH level output voltage 3.98 PCPOUT, PCnOUT 5.48 4.32 3.84 3.7 5.81 5.34 5.2 LOW level output voltage PCPOUT, PCnOUT 0 0.1 0.1 0.1 0 0.1 0.1 0.1 0 0.1 LOW level output voltage PCPOUT, PCnOUT input leakage current SIGIN, COMPIN 3-state OFF-state current PC2OUT 1997 Nov 25 3.2 4.2 V 2.0 4.5 4.2 6.0 V V V 2.0 2.0 4.5 6.0 V 2.0 4.5 0.1 0.1 0.15 0.26 0.33 0.4 0.16 0.26 0.33 0.4 3.0 4.0 5.0 7.0 9.0 11.0 3.0 18.0 23.0 27.0 4.5 30.0 38.0 45.0 6.0 0.5 5.0 10.0 10 OTHER VI 6.0 V 4.5 6.0 µA µA 2.0 6.0 VIH or VIL −IO = 20 µA VIH or VIL −IO = 4.0 mA VIH or VIL IO = 20 µA VIH or VIL IO = 4.0 mA −IO = 20 µA −IO = 20 µA −IO = 5.2 mA IO = 20 µA IO = 20 µA IO = 5.2 mA VCC or GND VIH or VIL VO = VCC or GND Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A Tamb (°C) TEST CONDITIONS 74HC SYMPARAMETER BOL −40 to +85 +25 min. typ. max. min. max. RI input resistance SIGIN, COMPIN −40 to +125 min. UNIT VCC (V) OTHER VI max. 800 kΩ 3.0 250 kΩ 4.5 150 kΩ 6.0 VI at self-bias operating point; ∆ VI = 0.5 V; see Figs 12, 13 and 14 VCO section Voltages are referenced to GND (ground = 0 V) Tamb (°C) SYMBOL VIH VIL VOH VOH VOL VOL VOL TEST CONDITIONS 74HC PARAMETER HIGH level input voltage INH +25 −40 to +85 −40 to +125 min. typ. max. min. max. min. 2.1 1.7 UNIT VCC (V) max. 2.1 2.1 3.15 2.4 3.15 3.15 4.5 4.2 4.2 4.2 6.0 LOW level input voltage INH 3.2 V V 3.0 1.3 0.9 0.9 0.9 2.1 1.35 1.35 1.35 4.5 2.8 1.8 1.8 1.8 6.0 V 3.0 HIGH level output voltage VCOOUT 2.9 3.0 2.9 2.9 4.4 4.5 4.4 4.4 4.5 5.9 6.0 5.9 5.9 6.0 HIGH level output voltage VCOOUT 3.98 4.32 3.84 3.7 5.48 5.81 5.34 5.2 V 0 0.1 0.1 0.1 0 0.1 0.1 0.1 0 0.1 0.1 0.1 LOW level output voltage VCOOUT 0.15 0.26 0.33 0.4 0.16 0.26 0.33 0.4 0.40 0.47 0.54 0.40 0.47 0.54 0.1 1.0 1.0 ±II input leakage current INH, VCOIN R1 resistor range 1997 Nov 25 3.0 4.5 6.0 LOW level output voltage VCOOUT LOW level output voltage C1A, C1B V 3.0 4.5 6.0 V 4.5 6.0 V 4.5 6.0 µA 6.0 kΩ 3.0 3.0 300 3.0 300 4.5 3.0 300 6.0 11 OTHER VI −IO = 20 µA VIH or VIL −IO = 20 µA VIH or VIL −IO = 5.2 mA −IO = 20 µA −IO = 4.0 mA VIH or VIL IO = 20 µA VIH or VIL IO = 4.0 mA VIH or VIL IO = 4.0 mA IO = 20 µA IO = 20 µA IO = 5.2 mA IO = 5.2 mA VCC or GND note 1 Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A Tamb (°C) SYMBOL 74HC PARAMETER min. R2 C1 TEST CONDITIONS resistor range capacitor range +25 −40 to +85 −40 to +125 typ. max. min. max. min. UNIT 3.0 300 300 kΩ 4.5 3.0 300 6.0 40 no limit pF 3.0 note 1 3.0 4.5 40 operating voltage range at VCOIN OTHER VI max. 3.0 40 VVCOIN VCC (V) 6.0 1.1 1.9 1.1 3.4 V 3.0 4.5 1.1 4.9 6.0 over the range specified for R1; for linearity see Figs 20 and 21 Note 1. The parallel value of R1 and R2 should be more than 2.7 kΩ. Optimum performance is achieved when R1 and/ or R2 are/is > 10 kΩ. Demodulator section Voltages are referenced to GND (ground = 0 V) Tamb (°C) TEST CONDITIONS 74HC SYMBOL PARAMETER −40 to+85 −40 to +125 +25 min. typ. max. min. max. RS resistor range 50 300 50 300 50 VOFF offset voltage VCOIN to VDEMOUT min. UNIT VCC OTHER V kΩ 3.0 max. 4.5 300 6.0 ±30 mV ±20 dynamic output resistance at DEMOUT 1997 Nov 25 6.0 VI = VVCOIN = 1/2 VCC; values taken over RS range; see Fig.15 3.0 VDEMOUT = 1/2 VCC 4.5 ±10 RD 3.0 Ω 25 25 4.5 25 6.0 12 at RS > 300 kΩ the leakage current can influence VDEMOUT Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A AC CHARACTERISTICS FOR 74HC Phase comparator section GND = 0 V; tr = tf = 6 ns; CL = 50 pF Tamb (°C) 74HC SYMBOL PARAMETER min. typ. max. OTHER UNIT −40 to +85 +25 tPHL/ tPLH TEST CONDITIONS VCC (V) −40 to +125 min. max. min. max. propagation delay SIGIN, COMPIN to PC1OUT 63 200 250 300 23 40 50 60 4.5 18 34 43 51 6.0 propagation delay SIGIN, COMPIN to PCPOUT 96 340 425 510 35 68 85 102 4.5 28 58 72 87 6.0 propagation delay SIGIN, COMPIN to PC3OUT 77 270 340 405 28 54 68 81 4.5 22 46 58 69 6.0 3-state output enable time SIGIN, COMPIN to PC2OUT 83 280 350 420 30 56 70 84 4.5 24 48 60 71 6.0 tPHZ/ tPLZ 3-state output disable time SIGIN, COMPIN to PC2OUT 99 325 405 490 36 65 81 98 29 55 69 83 tTHL/ tTLH output transition time 19 75 95 110 7 15 19 22 6 13 16 19 VI(p-p) AC coupled input sensitivity (peak-to-peak value) at SIGIN or COMPIN tPHL/ tPLH tPHL/ tPLH tPZH/ tPZL 1997 Nov 25 9 ns ns ns ns ns 2.0 2.0 2.0 2.0 2.0 Fig.16 Fig.16 Fig.17 Fig.17 4.5 6.0 ns 2.0 Fig.16 4.5 6.0 mV 2.0 11 3.0 15 4.5 33 6.0 13 Fig.16 fi = 1 MHz Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A VCO section GND = 0 V; tr = tf = 6 ns; CL = 50 pF Tamb (°C) TEST CONDITIONS 74HC SYMBOL PARAMETER −40 to +85 +25 min. typ. max. typ. max. ∆f/T fo ∆fVCO δVCO frequency stability with temperature change VCO centre frequency (duty factor = 50%) −40 to +125 min. UNIT V OTHER CC (V) max. 0.20 %/K 3.0 0.15 4.5 0.14 6.0 7.0 10.0 11.0 17.0 4.5 13.0 21.0 6.0 VCO frequency linearity MHz 1.0 duty factor at VCOOUT % 3.0 3.0 0.4 4.5 0.3 6.0 50 % VI = VVCOIN = 1/2 VCC; R1 = 100 kΩ; R2 = ∞; C1 = 100 pF; see Fig.18 VVCOIN = 1/2 VCC; R1 = 3 kΩ; R2 = ∞; C1 = 40 pF; see Fig.19 R1 = 100 kΩ; R2 = ∞; C1 = 100 pF; see Figs 20 and 21 3.0 50 4.5 50 6.0 DC CHARACTERISTICS FOR 74HCT Quiescent supply current Voltages are referenced to GND (ground = 0 V) Tamb (°C) TEST CONDITIONS 74HCT SYMBOL PARAMETER −40 to +85 +25 −40 to +125 min. typ. max. min. max. min. ICC quiescent supply current (VCO disabled) ∆ICC additional quiescent supply current per input pin for unit load coefficient is 1 (note 1) VI = VCC − 2.1 V 100 UNIT VCC (V) OTHER max. 8.0 80.0 160.0 µA 6.0 pins 3, 5 and 14 at VCC; pin 9 at GND; II at pins 3 and 14 to be excluded 360 450 490 µA 4.5 to 5.5 pins 3 and 14 at VCC; pin 9 at GND; II at pins 3 and 14 to be excluded Note 1. The value of additional quiescent supply current (∆ICC) for a unit load of 1 is given above. To determine ∆ICC per input, multiply this value by the unit load coefficient shown in the table below. INPUT UNIT LOAD COEFFICIENT INH 1.00 1997 Nov 25 14 Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A DC CHARACTERISTICS FOR 74HCT Phase comparator section Voltages are referenced to GND (ground = 0 V) Tamb (°C) TEST CONDITIONS 74HCT SYMBOL PARAMETER −40 to +85 −40 to +125 +25 min typ. max min max VIH DC coupled HIGH level input voltage SIGIN, COMPIN VIL DC coupled LOW level input voltage SIGIN, COMPIN VOH HIGH level output voltage PCPOUT, PCnOUT 4.4 VOH HIGH level output voltage PCPOUT, PCnOUT 3.98 4.32 VOL LOW level output voltage PCPOUT, PCnOUT 0 VOL LOW level output voltage PCPOUT, PCnOUT 0.15 0.26 ±II input leakage current SIGIN, COMPIN ±IOZ 3-state OFF-state current PC2OUT RI input resistance SIGIN, COMPin 1997 Nov 25 min. 1.35 4.5 VCC VI (V) V 4.5 V 4.5 OTHER max. 3.15 2.4 2.1 UNIT 4.4 4.4 V 4.5 VIH or VIL −IO = 20 µA 3.84 3.7 V 4.5 VIH or VIL −IO = 4.0 mA 0.1 0.1 V 4.5 VIH or VIL IO = 20 µA 0.33 0.4 V 4.5 VIH or VIL IO = 4.0 mA 30 38 45 µA 5.5 VCC or GN D 0.5 5.0 10.0 µA 5.5 VIH or VIL kΩ 4.5 VI at self-bias operating point; ∆ VI = 0.5 V; see Figs 12, 13 and 14 0.1 250 15 VO = VCC or GND Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A DC CHARACTERISTICS FOR 74HCT VCO section Voltages are referenced to GND (ground = 0 V) Tamb (°C) TEST CONDITIONS 74HCT SYMBOL PARAMETER −40 to +85 +25 min 2.0 typ. max 1.6 min VIH HIGH level input voltage INH VIL LOW level input voltage INH VOH HIGH level output voltage VCOOUT 4.4 4.5 4.4 VOH HIGH level output voltage VCOOUT 3.98 4.32 3.84 VOL LOW level output voltage VCOOUT 0 VOL LOW level output voltage VCOOUT VOL 1.2 max min. 2.0 0.8 −40 to +125 UNIT VCC VI (V) OTHER max. 2.0 V 4.5 to 5.5 V 4.5 to 5.5 4.4 V 4.5 VIH or VIL −IO = 20 µA 3.7 V 4.5 VIH or VIL −IO = 4.0 mA 0.8 0.8 0.1 0.1 V 4.5 VIH or VIL IO = 20 µA 0.15 0.26 0.33 0.4 V 4.5 VIH or VIL IO = 4.0 mA LOW level output voltage C1A, C1B (test purposes only) 0.40 0.47 0.54 V 4.5 VIH or VIL IO = 4.0 mA ±II input leakage current INH, VCOIN 0.1 1.0 1.0 µA 5.5 VCC or R1 resistor range 3.0 300 kΩ 4.5 note 1 R2 resistor range 3.0 300 kΩ 4.5 note 1 C1 capacitor range 40 no limit pF 4.5 VVCOIN operating voltage range at VCOIN 1.1 3.4 V 4.5 0.1 GND over the range specified for R1; for linearity see Figs 20 and 21 Note 1. The parallel value of R1 and R2 should be more than 2.7 kΩ. Optimum performance is achieved when R1 and/or R2 are/is > 10 kΩ. 1997 Nov 25 16 Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A DC CHARACTERISTICS FOR 74HCT Demodulator section Voltages are referenced to GND (ground = 0 V) Tamb (°C) TEST CONDITIONS 74HCT SYMBOL PARAMETER −40 to +85 +25 −40 to +125 min. typ. max. min. max. min. RS resistor range VOFF offset voltage VCOIN to VDEMOUT RD dynamic output resistance at DEMOUT UNIT VCC OTHER (V) max. kΩ 4.5 at RS > 300 kΩ the leakage current can influence VDEMOUT ±20 mV 4.5 VI = VVCOIN = 1/2 VCC; values taken over RS range; see Fig.15 25 Ω 4.5 VDEMOUT = 1/2 VCC 50 300 AC CHARACTERISTICS FOR 74HCT Phase comparator section GND = 0 V; tr = tf = 6 ns; CL = 50 pF Tamb (°C) TEST CONDITIONS 74HCT SYMBOL PARAMETER −40 to +85 +25 min. −40 to +125 typ. max. min. max. min. max. UNIT VCC (V) OTHER tPHL/ tPLH propagation delay SIGIN, COMPIN to PC1OUT 23 40 50 60 ns 4.5 Fig.16 tPHL/ tPLH propagation delay SIGIN, COMPIN to PCPOUT 35 68 85 102 ns 4.5 Fig.16 tPHL/ tPLH propagation delay SIGIN, COMPIN to PC3OUT 28 54 68 81 ns 4.5 Fig.16 tPZH/ tPZL 3-state output enable time SIGIN, COMPIN to PC2OUT 30 56 70 84 ns 4.5 Fig.17 1997 Nov 25 17 Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A Tamb (°C) TEST CONDITIONS 74HCT SYMBOL PARAMETER −40 to +85 +25 min. −40 to +125 typ. max. min. max. min. max. UNIT VCC (V) OTHER tPHZ/ tPLZ 3-state output disable time SIGIN, COMPIN to PC2OUT 36 65 81 98 ns 4.5 Fig.17 tTHL/ tTLH output transition time 7 15 19 22 ns 4.5 Fig.16 VI (p-p) AC coupled input sensitivity (peak-to-peak value) at SIGIN or COMPIN 15 mV 4.5 fi = 1 MHz VCO section GND = 0 V; tr = tf = 6 ns; CL = 50 pF Tamb (°C) TEST CONDITIONS 74HCT SYMBOL PARAMETER +25 min. ∆f/T frequency stability with temperature change fo VCO centre frequency (duty factor = 50%) ∆fVCO δVCO typ. max −40 to +85 −40 to +125 min. min. max. VCC (V) OTHER %/K 4.5 VI = VVCOIN withi n recommended range; R1 = 100 kΩ; R2 = ∞; C1 = 100 pF; see Fig.18b 17.0 MHz 4.5 VVCOIN = 1/2 VCC ; R1 = 3 kΩ; R2 = ∞; C1 = 40 pF; see Fig.19 VCO frequency linearity 0.4 % 4.5 R1 = 100 kΩ; R2 = ∞; C1 = 100 pF; see Figs 20 and 21 duty factor at VCOOUT 50 % 4.5 1997 Nov 25 0.15 max UNIT 11.0 18 Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A FIGURE REFERENCES FOR DC CHARACTERISTICS Fig.12 Typical input resistance curve at SIGIN, COMPIN. Fig.13 Input resistance at SIGIN, COMPIN with ∆VI = 0.5 V at self-bias point.  RS = 50 kΩ - - - - RS = 300 kΩ Fig.14 Input current at SIGIN, COMPIN with ∆VI = 0.5 V at self-bias point. 1997 Nov 25 Fig.15 Offset voltage at demodulator output as a function of VCOIN and RS. 19 Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A AC WAVEFORMS (1) HC : VM = 50%; VI = GND to VCC Fig.16 Waveforms showing input (SIGIN, COMPIN) to output (PCPOUT, PC1OUT, PC3OUT) propagation delays and the output transition times. (1) HC : VM = 50%; VI = GND to VCC Fig.17 Waveforms showing the 3-state enable and disable times for PC2OUT. 1997 Nov 25 20 ∆f (%) ∆f (%) 20 VCC = VCC = ∆f (%) 20 15 MSB712 25 handbook, halfpage 3V 20 5V 6V 15 6V 3V 5V 10 10 3V VCC = 3V 5V A 6V 5V 3V 5V 6V 15 10 6V 21 5 3V 5 5 0 4.5 V 5V 6V 0 0 −5 5 5 −10 10 10 −15 15 15 −20 20 20 −25 −50 0 50 25 50 0 50 (b) 100 150 Tamb ( o C) 25 50 0 50 100 150 Tamb ( o C) (c) Fig.18 Frequency stability of the VCO as a function of ambient temperature with supply voltage as a parameter.  without offset (R2 = ∞): (a) R1 = 3 kΩ; (b) R1 = 10 kΩ; (c) R1 = 300 kΩ. − − − with offset (R1 = ∞): (a) R2 = 3 kΩ; (b) R2 = 10 kΩ; (c) R2 = 300 kΩ. In (b), the frequency stability for R1 = R2 = 10 kΩ at 5 V is also given (curve A). This curve is set by the total VCO bias current, and is not simply the addition of the two 10 kΩ stability curves. C1 = 100 pF; VVCO IN = 0.5 VCC. Product specification To obtain optimum temperature stability, C1 must be as small as possible but larger than 100 pF. 74HC/HCT4046A (a) 100 150 Tamb (oC) Philips Semiconductors MSB711 25 handbook, halfpage Phase-locked-loop with VCO 1997 Nov 25 MSB710 25 book, halfpage Philips Semiconductors Product specification Phase-locked-loop with VCO (d) R2 = 3 kΩ R1 = ∞ 74HC/HCT4046A (e) R2 = 10 kΩ R1 = ∞ To obtain optimum temperature stability, C1 must be as small as possible but larger than 100 pF. Fig.18 Continued. 1997 Nov 25 22 (f) R2 = 300 kΩ R1 = ∞ Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A (b) R1 = 3 kΩ; C1 = 100 nF (a) R1 = 3 kΩ; C1 = 40 pF (d) R1 = 300 kΩ; C1 = 100 nF (c) R1 = 300 kΩ; C1 = 40 pF To obtain optimum temperature stability, C1 must be as small as possible but larger than 100 pF. Fig.19 Graphs showing VCO frequency (fVCO) as a function of the VCO input voltage (VVCOIN). 1997 Nov 25 23 Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A Fig.20 Definition of VCO frequency linearity: ∆V = 0.5 V over the VCC range: for VCO linearity f1 + f2 f‘ 0 = -------------2 f‘ 0 – f 0 linearity = ---------------- × 100% f‘ 0 Fig.21 Frequency linearity as a function of R1, C1 and VCC: R2 = ∞ and ∆V = 0.5 V.  C1 = 40 pF - - - -C1 = 1 µF  C1 = 40 pF - - - - C1 = 1 µF Fig.22 Power dissipation versus the value of R1: CL = 50 pF; R2 = ∞; VVCOIN = 1/2 VCC; Tamb = 25 °C. Fig.23 Power dissipation versus the value of R2: CL = 50 pF; R1 = ∞; VVCOIN = GND = 0 V; Tamb = 25 °C. 1997 Nov 25 24 Fig.24 Typical dc power dissipation of demodulator sections as a function of RS: R1 = R2 = ∞; Tamb = 25 °C; VVCOIN = 1/2 VCC. Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A APPLICATION INFORMATION This information is a guide for the approximation of values of external components to be used with the 74HC/HCT4046A in a phase-lock-loop system. References should be made to Figs 29, 30 and 31 as indicated in the table. Values of the selected components should be within the following ranges: R1 R2 R1 + R2 C1 between 3 kΩ and 300 kΩ; between 3 kΩ and 300 kΩ; parallel value > 2.7 kΩ; greater than 40 pF. SUBJECT PHASE COMPARATOR DESIGN CONSIDERATIONS VCO frequency characteristic VCO frequency without extra offset PC1, PC2 or PC3 With R2 = ∞ and R1 within the range 3 kΩ < R1 < 300 kΩ, the characteristics of the VCO operation will be as shown in Fig.25. (Due to R1, C1 time constant a small offset remains when R2 = ∞.). Fig.25 Frequency characteristic of VCO operating without offset: f0 = centre frequency; 2fL = frequency lock range. Selection of R1 and C1 1997 Nov 25 PC1 Given fo, determine the values of R1 and C1 using Fig.29. PC2 or PC3 Given fmax and fo, determine the values of R1 and C1 using Fig.29, use Fig.31 to obtain 2fL and then use this to calculate fmin. 25 Philips Semiconductors Product specification Phase-locked-loop with VCO SUBJECT PHASE COMPARATOR 74HC/HCT4046A DESIGN CONSIDERATIONS VCO frequency characteristic VCO frequency with extra offset PC1, PC2 or PC3 With R1 and R2 within the ranges 3 kΩ < R1 < 300 kΩ, 3 kΩ < R2 < 300 kΩ, the characteristics of the VCO operation will be as shown in Fig.26. Fig.26 Frequency characteristic of VCO operating with offset: fo = centre frequency; 2fL = frequency lock range. Selection of R1, R2 and C1 PLL conditions with no signal at the SIGIN input 1997 Nov 25 PC1, PC2 or PC3 Given fo and fL, determine the value of product R1C1 by using Fig.31. Calculate foff from the equation foff = fo  1.6fL. Obtain the values of C1 and R2 by using Fig.30. Calculate the value of R1 from the value of C1 and the product R1C1. PC1 VCO adjusts to fo with φDEMOUT = 90° and VVCOIN = 1/2 VCC (see Fig.6). PC2 VCO adjusts to fo with φDEMOUT = −360° and VVCOIN = min. (see Fig.8). PC3 VCO adjusts to fo with φDEMOUT = −360° and VVCOIN = min. (see Fig.10). 26 Philips Semiconductors Product specification Phase-locked-loop with VCO SUBJECT PLL frequency capture range 74HC/HCT4046A PHASE COMPARATOR DESIGN CONSIDERATIONS PC1, PC2 or PC3 Loop filter component selection (a) τ = R3 x C2 (b) amplitude characteristic (c) pole-zero diagram 1 A small capture range (2fc) is obtained if 2f c ≈ --- 2πf L ⁄ τ π Fig. 27 Simple loop filter for PLL without offset; R3 ≥ 500 Ω. (a) τ1 = R3 x C2; (b) amplitude characteristic (c) pole-zero diagram τ2 = R4 x C2; τ3 = (R3 + R4) x C2 Fig.28 Simple loop filter for PLL with offset; R3 + R4 ≥ 500 Ω. PLL locks on harmonics at centre frequency PC1 or PC3 yes PC2 no noise rejection at signal input PC1 high PC2 or PC3 low AC ripple content when PLL is locked PC1 fr = 2fi, large ripple content at φDEMOUT = 90° PC2 fr = fi, small ripple content at φDEMOUT = 0° PC3 fr = fi, large ripple content at φDEMOUT = 180° 1997 Nov 25 27 Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A To obtain optimum VCO performance, C1 must be as small as possible but larger than 100 pF. Interpolation for various values of R1 can be easily calculated because a constant R1C1 product will produce almost the same VCO output frequency. Fig.29 Typical value of VCO centre frequency (fo) as a function of C1: R2 = ∞; VVCOIN = 1/2 VCC; INH = GND; Tamb = 25 °C. 1997 Nov 25 28 Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A To obtain optimum VCO performance, C1 must be as small as possible but larger than 100 pF. Interpolation for various values of R2 can be easily calculated because a constant R2C1 product will produce almost the same VCO output frequency. Fig.30 Typical value of frequency offset as a function of C1: R1 = ∞; VVCOIN = 1/2 VCC; INH = GND; Tamb = 25 °C. 1997 Nov 25 29 Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A Fig.31 Typical frequency lock range (2fL) versus the product R1C1: VVCOIN range = 0.9 to (VCC − 0.9) V; R2 = ∞; VCO gain: 2f L K V = ------------------------------------- 2π ( r ⁄ s˙ ⁄ V ) . V VCOIN range 1997 Nov 25 30 Philips Semiconductors Product specification Phase-locked-loop with VCO PLL design example The frequency synthesizer, used in the design example shown in Fig.32, has the following parameters: Output frequency: 2 MHz to 3 MHz frequency steps : 100 kHz settling time : 1 ms overshoot : < 20% The open-loop gain is H (s) x G (s) = Kp × Kf × Ko × Kn. 74HC/HCT4046A The VCO gain is: 2f L ×˙2 × π K v = ----------------------------------------------- = 0.9 – ( V CC – 0.9 ) and the damping value ζ is defined as follows: 1 + Kp × Kv × Kn × τ2 1 ζ = ---------- × ----------------------------------------------------( τ1 + τ2) 2ω n 1 MHz = ----------------- × 2π ≈ 2 × 10 6 r/s/V 3.2 In Fig.33 the output frequency response to a step of input frequency is shown. The gain of the phase comparator is: V CC K p = -----------= 0.4 V/r. 4×π The overshoot and settling time percentages are now used to determine ωn. From Fig.33 it can be seen that the damping ratio ζ = 0.45 will produce an overshoot of less than 20% and settle to within 5% at ωnt = 5. The required settling time is 1 ms. This results in: 3 5 5 ω n = --- = --------------- = 5 × 10 r/s. t 0.001 Where: Kp = phase comparator gain Kf = low-pass filter transfer gain Ko = Kv/s VCO gain Kn = 1/n divider ratio The transfer gain of the filter is given by: 1 + τ2 s K f = ------------------------------------- . 1 + ( τ1 + τ2) s The programmable counter ratio Kn can be found as follows: Where: τ 1 = R3C2 and τ 2 = R4C2. f out 2 MHz N min. = ---------- = ---------------------- = 20 f step 100 kHz f out 3 MHz N max. = ---------- = ---------------------- = 30 f step 100 kHz The VCO is set by the values of R1, R2 and C1, R2 = 10 kΩ (adjustable). The values can be determined using the information in the section “DESIGN CONSIDERATIONS”. With fo = 2.5 MHz and fL = 500 kHz this gives the following values (VCC = 5.0 V): R1 = 10 kΩ R2 = 10 kΩ C1 = 500 pF 1997 Nov 25 The characteristics equation is: 1 + H (s) × G (s) = 0. This results in: 2 1 + Kp × Kv × Kn × τ2 s + ----------------------------------------------------- s+ ( τ1 + τ2) Kp × Kv × Kn -------------------------------- = 0. ( τ1 + τ2) The natural frequency ωn is defined as follows: ωn = Kp × Kv × Kn -------------------------------- . ( τ1 + τ2) 31 Rewriting the equation for natural frequency results in: Kp × Kv × Kn ( τ 1 + τ 2 ) = -------------------------------. 2 ωn The maximum overshoot occurs at Nmax.: 6 0.4 × 2 × 10 ( τ 1 + τ 2 ) = -------------------------------- = 0.0011 s. 2 5000 × 30 When C2 = 470 nF, then ( τ1 + τ2) × 2 × ωn × ζ – 1 R4 = ---------------------------------------------------------------- = 315 Ω K p × K v × K n × C2 now R3 can be calculated: τ1 R3 = ------- – R4 = 2 kΩ. C2 Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A Fig.32 Frequency synthesizer. note For an extensive description and application example please refer to application note ordering number 9398 649 90011. Also available a computer design program for PLL’s ordering number 9398 961 10061. full pagewidth ∆ωe (t) ∆ωe/ωn MSB740 1.6 0.6 ζ = 0.3 1.4 0.4 0.5 0.707 1.0 1.2 0.2 ∆Θe (t) ∆Θe/ωn ζ = 5.0 1.0 0 ζ = 2.0 0.8 0.2 0.6 0.4 0.4 0.6 0.2 0.8 0 0 1 2 3 4 5 6 7 ωnt 8 1.0 Fig.33 Type 2, second order frequency step response. Since the output frequency is proportional to the VCO control voltage, the PLL frequency response can be observed with an oscilloscope by monitoring pin 9 of the VCO. The average frequency response, as calculated by the Laplace method, is found experimentally by smoothing this voltage at pin 9 with a simple RC filter, whose time constant is long compared to the phase detector sampling rate but short compared to the PLL response time. Fig.34 Frequency compared to the time response. 1997 Nov 25 32 Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A Typical reflow temperatures range from 215 to 250 °C. Preheating is necessary to dry the paste and evaporate the binding agent. Preheating duration: 45 minutes at 45 °C. SOLDERING Introduction There is no soldering method that is ideal for all IC packages. Wave soldering is often preferred when through-hole and surface mounted components are mixed on one printed-circuit board. However, wave soldering is not always suitable for surface mounted ICs, or for printed-circuits with high population densities. In these situations reflow soldering is often used. WAVE SOLDERING Wave soldering can be used for all SO packages. Wave soldering is not recommended for SSOP and TSSOP packages, because of the likelihood of solder bridging due to closely-spaced leads and the possibility of incomplete solder penetration in multi-lead devices. This text gives a very brief insight to a complex technology. A more in-depth account of soldering ICs can be found in our “IC Package Databook” (order code 9398 652 90011). If wave soldering is used - and cannot be avoided for SSOP and TSSOP packages - the following conditions must be observed: DIP • A double-wave (a turbulent wave with high upward pressure followed by a smooth laminar wave) soldering technique should be used. SOLDERING BY DIPPING OR BY WAVE The maximum permissible temperature of the solder is 260 °C; solder at this temperature must not be in contact with the joint for more than 5 seconds. The total contact time of successive solder waves must not exceed 5 seconds. • The longitudinal axis of the package footprint must be parallel to the solder flow and must incorporate solder thieves at the downstream end. Even with these conditions: The device may be mounted up to the seating plane, but the temperature of the plastic body must not exceed the specified maximum storage temperature (Tstg max). If the printed-circuit board has been pre-heated, forced cooling may be necessary immediately after soldering to keep the temperature within the permissible limit. • Only consider wave soldering SSOP packages that have a body width of 4.4 mm, that is SSOP16 (SOT369-1) or SSOP20 (SOT266-1). REPAIRING SOLDERED JOINTS During placement and before soldering, the package must be fixed with a droplet of adhesive. The adhesive can be applied by screen printing, pin transfer or syringe dispensing. The package can be soldered after the adhesive is cured. • Do not consider wave soldering TSSOP packages with 48 leads or more, that is TSSOP48 (SOT362-1) and TSSOP56 (SOT364-1). Apply a low voltage soldering iron (less than 24 V) to the lead(s) of the package, below the seating plane or not more than 2 mm above it. If the temperature of the soldering iron bit is less than 300 °C it may remain in contact for up to 10 seconds. If the bit temperature is between 300 and 400 °C, contact may be up to 5 seconds. Maximum permissible solder temperature is 260 °C, and maximum duration of package immersion in solder is 10 seconds, if cooled to less than 150 °C within 6 seconds. Typical dwell time is 4 seconds at 250 °C. SO, SSOP and TSSOP A mildly-activated flux will eliminate the need for removal of corrosive residues in most applications. REFLOW SOLDERING Reflow soldering techniques are suitable for all SO, SSOP and TSSOP packages. REPAIRING SOLDERED JOINTS Reflow soldering requires solder paste (a suspension of fine solder particles, flux and binding agent) to be applied to the printed-circuit board by screen printing, stencilling or pressure-syringe dispensing before package placement. Fix the component by first soldering two diagonallyopposite end leads. Use only a low voltage soldering iron (less than 24 V) applied to the flat part of the lead. Contact time must be limited to 10 seconds at up to 300 °C. When using a dedicated tool, all other leads can be soldered in one operation within 2 to 5 seconds between 270 and 320 °C. Several techniques exist for reflowing; for example, thermal conduction by heated belt. Dwell times vary between 50 and 300 seconds depending on heating method. 1997 Nov 25 33 Philips Semiconductors Product specification Phase-locked-loop with VCO 74HC/HCT4046A DEFINITIONS Data sheet status Objective specification This data sheet contains target or goal specifications for product development. Preliminary specification This data sheet contains preliminary data; supplementary data may be published later. Product specification This data sheet contains final product specifications. Limiting values Limiting values given are in accordance with the Absolute Maximum Rating System (IEC 134). Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Characteristics sections of the specification is not implied. Exposure to limiting values for extended periods may affect device reliability. Application information Where application information is given, it is advisory and does not form part of the specification. LIFE SUPPORT APPLICATIONS These products are not designed for use in life support appliances, devices, or systems where malfunction of these products can reasonably be expected to result in personal injury. Philips customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Philips for any damages resulting from such improper use or sale. 1997 Nov 25 34
74HC4046AD,653 价格&库存
很抱歉,暂时无法提供与“74HC4046AD,653”相匹配的价格&库存,您可以联系我们找货
74HC4046AD,653
  • 1+5.34219
  • 10+3.95394
  • 25+3.46284
  • 50+3.15261
  • 100+2.87472
  • 250+2.57767
  • 500+2.39320
  • 1000+2.23869
  • 2500+2.22791
74HC4046AD,653
