74AUP1Z04GF,132
74AUP1Z04GF,132
    NEXPERIA(安世)
    XSON6_1X1MM
    带启用和内部电阻器的低功率X-tal驱动器
74AUP1Z04GF,132 数据手册
74AUP1Z04 Low-power X-tal driver with enable and internal resistor Rev. 5 — 9 August 2012 Product data sheet 1. General description The 74AUP1Z04 combines the functions of the 74AUP1GU04 and 74AUP1G04 with enable circuitry and an internal bias resistor to provide a device optimized for use in crystal oscillator applications. When not in use the EN input can be driven HIGH, putting the device in a low power disable mode with X1 pulled HIGH via RPU, X2 set LOW and Y set HIGH.Schmitt trigger action at the EN input makes the circuit tolerant to slower input rise and fall times across the entire VCC range from 0.8 V to 3.6 V. This device is fully specified for partial power-down applications using IOFF at output Y. The IOFF circuitry disables the output Y, preventing the damaging backflow current through the device when it is powered down. The integration of the two devices into the 74AUP1Z04 produces the benefits of a compact footprint, lower power dissipation and stable operation over a wide range of frequency and temperature. 2. Features and benefits  Wide supply voltage range from 0.8 V to 3.6 V  High noise immunity  ESD protection:  HBM JESD22-A114F Class 3A exceeds 5000 V  MM JESD22-A115-A exceeds 200 V  CDM JESD22-C101E exceeds 1000 V  Latch-up performance exceeds 100 mA per JESD78B Class II  Inputs accept voltages up to 3.6 V  Low noise overshoot and undershoot < 10 % of VCC  IOFF circuitry provides partial Power-down mode operation at output Y  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AUP1Z04GW 40 C to +125 C SC-88 plastic surface-mounted package; 6 leads SOT363 74AUP1Z04GM 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1  1.45  0.5 mm 74AUP1Z04GF 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; SOT891 6 terminals; body 1  1  0.5 mm 74AUP1Z04GN 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74AUP1Z04GS 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 4. Marking Table 2. Marking Type number Marking code[1] 74AUP1Z04GW a4 74AUP1Z04GM a4 74AUP1Z04GF a4 74AUP1Z04GN a4 74AUP1Z04GS a4 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram VCC RPU X1 3 6 Rbias EN 4 Y X2 1 001aae488 RPU = pull-up resistance. Rbias = bias resistance. Fig 1. Logic symbol 74AUP1Z04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 2 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor 6. Pinning information 6.1 Pinning 74AUP1Z04 74AUP1Z04 EN 1 6 EN 1 6 Y GND 2 5 VCC Y GND 2 5 VCC X1 3 4 X2 X1 3 4 X2 EN 1 6 Y GND 2 5 VCC X1 3 4 X2 001aad594 001aad593 Transparent top view Transparent top view 001aad592 Fig 2. 74AUP1Z04 Pin configuration SOT363 Fig 3. Pin configuration SOT886 Fig 4. Pin configuration SOT891, SOT1115 and SOT1202 6.2 Pin description Table 3. Pin description Symbol Pin Description EN 1 enable input (active LOW) GND 2 ground (0 V) X1 3 data input X2 4 data output VCC 5 supply voltage Y 6 data output 7. Functional description Table 4. Function table[1] Input Output EN X1 X2 Y L L H L L H L H H L H L H H L H [1] H = HIGH voltage level; L = LOW voltage level. 74AUP1Z04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 3 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current Conditions VI < 0 V [1] VO < 0 V [1] Min Max Unit 0.5 +4.6 V 50 - mA 0.5 +4.6 V 50 - mA 0.5 VCC + 0.5 V VO output voltage IO output current - 20 mA ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C - 250 mW total power dissipation Ptot VO = 0 V to VCC Tamb = 40 C to +125 C [2] [1] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SC-88 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. For XSON6 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC Min Max Unit supply voltage 0.8 3.6 V VI input voltage 0 3.6 V VO output voltage 0 VCC V Tamb ambient temperature 40 +125 C t/V input transition rise and fall rate - 200 ns/V 74AUP1Z04 Product data sheet Conditions VCC = 0.8 V to 3.6 V All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 4 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit 0.75  VCC - - V VCC = 0.8 V 0.70  VCC - - V VCC = 0.9 V to 1.95 V 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V - - 0.25  VCC V VCC = 0.8 V - - 0.30  VCC V VCC = 0.9 V to 1.95 V - - 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.1 - - V Tamb = 25 C VIH HIGH-level input voltage X1 input VCC = 0.8 V to 3.6 V EN input VIL LOW-level input voltage X1 input VCC = 0.8 V to 3.6 V EN input VOH HIGH-level output voltage Y output; VI at X1 input = VIH or VIL IO = 1.1 mA; VCC = 1.1 V 0.75  VCC - - V IO = 1.7 mA; VCC = 1.4 V 1.11 - - V IO = 1.9 mA; VCC = 1.65 V 1.32 - - V IO = 2.3 mA; VCC = 2.3 V 2.05 - - V IO = 3.1 mA; VCC = 2.3 V 1.9 - - V IO = 2.7 mA; VCC = 3.0 V 2.72 - - V IO = 4.0 mA; VCC = 3.0 V 2.6 - - V IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.1 - - V IO = 1.1 mA; VCC = 1.1 V 0.75  VCC - - V IO = 1.7 mA; VCC = 1.4 V 1.11 - - V IO = 1.9 mA; VCC = 1.65 V 1.32 - - V IO = 2.3 mA; VCC = 2.3 V 2.05 - - V IO = 3.1 mA; VCC = 2.3 V 1.9 - - V IO = 2.7 mA; VCC = 3.0 V 2.72 - - V IO = 4.0 mA; VCC = 3.0 V 2.6 - - V X2 output; VI = GND or VCC 74AUP1Z04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 5 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VOL Y output; VI at X1 input = VIH or VIL LOW-level output voltage Min Typ Max Unit IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3  VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.31 V IO = 1.9 mA; VCC = 1.65 V - - 0.31 V IO = 2.3 mA; VCC = 2.3 V - - 0.31 V IO = 3.1 mA; VCC = 2.3 V - - 0.44 V IO = 2.7 mA; VCC = 3.0 V - - 0.31 V IO = 4.0 mA; VCC = 3.0 V - - 0.44 V X2 output; VI = GND or VCC II input leakage current IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3  VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.31 V IO = 1.9 mA; VCC = 1.65 V - - 0.31 V IO = 2.3 mA; VCC = 2.3 V - - 0.31 V IO = 3.1 mA; VCC = 2.3 V - - 0.44 V IO = 2.7 mA; VCC = 3.0 V - - 0.31 V IO = 4.0 mA; VCC = 3.0 V - - 0.44 V - - 0.1 A - - 0.1 A X1 input VI = EN = VCC; VCC = 0 V to 3.6 V EN input VI = GND to 3.6 V; VCC = 0 V to 3.6 V Ipu pull-up current X1 input; EN = VCC - - 15 A VI or VO = 0 V to 3.6 V; VCC = 0 V [1] - - 0.2 A [1] - - 0.2 A - - 75 A - - 40 A - 1.3 - pF - 0.8 - pF VI = GND; VCC = 0.8 V to 3.6 V IOFF power-off leakage current IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V ICC supply current VI = GND or VCC; IO = 0 A; EN = GND; VCC = 0.8 V to 3.6 V ICC additional supply current EN input VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V CI input capacitance X1 input VCC = 0 V to 3.6 V; VI = GND or VCC EN input VCC = 0 V to 3.6 V; VI = GND or VCC 74AUP1Z04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 6 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions CO X2 output output capacitance Min Typ Max Unit - 1.5 - pF - 1.7 - pF VCC = 0.8 V - - - mA/V VCC = 1.1 V to 1.3 V 0.2 - 9.9 mA/V VCC = 1.4 V to 1.6 V 3.9 - 17.7 mA/V VCC = 1.65 V to 1.95 V 7.9 - 24.3 mA/V VCC = 2.3 V to 2.7 V 18 - 30.7 mA/V VO = GND; VCC = 0 V Y output VO = GND; VCC = 0 V gfs forward transconductance see Figure 10 and Figure 11 VCC = 3.0 V to 3.6 V Rbias bias resistance 20.5 - 32.4 mA/V 1.08 1.62 3.08 M 0.75  VCC - - V VCC = 0.8 V 0.70  VCC - - V VCC = 0.9 V to 1.95 V 0.65  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V - - 0.25  VCC V VCC = 0.8 V - - 0.30  VCC V VCC = 0.9 V to 1.95 V - - 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V EN = GND; fi = 0 Hz; VI = 0 V or VCC; see Figure 5; for frequency behavior see Figure 6 Tamb = 40 C to +85 C VIH HIGH-level input voltage X1 input VCC = 0.8 V to 3.6 V EN input VIL LOW-level input voltage X1 input VCC = 0.8 V to 3.6 V EN input 74AUP1Z04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 7 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VOH Y output; VI at X1 input = VIH or VIL HIGH-level output voltage Min Typ Max Unit IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.1 - - V IO = 1.1 mA; VCC = 1.1 V 0.7  VCC - - V IO = 1.7 mA; VCC = 1.4 V 1.03 - - V IO = 1.9 mA; VCC = 1.65 V 1.30 - - V IO = 2.3 mA; VCC = 2.3 V 1.97 - - V IO = 3.1 mA; VCC = 2.3 V 1.85 - - V IO = 2.7 mA; VCC = 3.0 V 2.67 - - V IO = 4.0 mA; VCC = 3.0 V 2.55 - - V VI at X1 input = VIH or VIL VOL LOW-level output voltage IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.1 - - V IO = 1.1 mA; VCC = 1.1 V 0.7  VCC - - V IO = 1.7 mA; VCC = 1.4 V 1.03 - - V IO = 1.9 mA; VCC = 1.65 V 1.30 - - V IO = 2.3 mA; VCC = 2.3 V 1.97 - - V IO = 3.1 mA; VCC = 2.3 V 1.85 - - V IO = 2.7 mA; VCC = 3.0 V 2.67 - - V IO = 4.0 mA; VCC = 3.0 V 2.55 - - V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3  VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.37 V IO = 1.9 mA; VCC = 1.65 V - - 0.35 V IO = 2.3 mA; VCC = 2.3 V - - 0.33 V IO = 3.1 mA; VCC = 2.3 V - - 0.45 V IO = 2.7 mA; VCC = 3.0 V - - 0.33 V IO = 4.0 mA; VCC = 3.0 V - - 0.45 V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC = 1.1 V - - 0.3  VCC V Y output; VI at X1 input = VIH or VIL X2 output; VI = GND or VCC 74AUP1Z04 Product data sheet IO = 1.7 mA; VCC = 1.4 V - - 0.37 V IO = 1.9 mA; VCC = 1.65 V - - 0.35 V IO = 2.3 mA; VCC = 2.3 V - - 0.33 V IO = 3.1 mA; VCC = 2.3 V - - 0.45 V IO = 2.7 mA; VCC = 3.0 V - - 0.33 V IO = 4.0 mA; VCC = 3.0 V - - 0.45 V All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 8 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions II X1 input input leakage current VI = EN = VCC; VCC = 0 V to 3.6 V Min Typ Max Unit - - 0.5 A - - 0.5 A EN input VI = GND to 3.6 V; VCC = 0 V to 3.6 V Ipu pull-up current X1 input; EN = VCC - - 15 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V [1] - - 0.5 A [1] - - 0.6 A - - 75 A - - 50 A VCC = 0.8 V - - - mA/V VCC = 1.1 V to 1.3 V - - 10.8 mA/V VI = GND; VCC = 0.8 V to 3.6 V IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V ICC supply current VI = GND or VCC; IO = 0 A; EN = GND; VCC = 0.8 V to 3.6 V ICC additional supply current EN input VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V gfs Rbias forward transconductance bias resistance see Figure 10 and Figure 11 VCC = 1.4 V to 1.6 V 1.8 - 21.2 mA/V VCC = 1.65 V to 1.95 V 7.5 - 29.9 mA/V VCC = 2.3 V to 2.7 V 15.0 - 38.0 mA/V VCC = 3.0 V to 3.6 V 17.8 - 39.2 mA/V 1.07 - 3.11 M 0.75  VCC - - V VCC = 0.8 V 0.75  VCC - - V VCC = 0.9 V to 1.95 V 0.70  VCC - - V VCC = 2.3 V to 2.7 V 1.6 - - V VCC = 3.0 V to 3.6 V 2.0 - - V - - 0.25  VCC V VCC = 0.8 V - - 0.25  VCC V VCC = 0.9 V to 1.95 V - - 0.30  VCC V VCC = 2.3 V to 2.7 V - - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 V EN = GND; fi = 0 Hz; VI = 0 V or VCC; see Figure 5; for frequency behavior see Figure 6 Tamb = 40 C to +125 C VIH HIGH-level input voltage X1 input VCC = 0.8 V to 3.6 V EN input VIL LOW-level input voltage X1 input VCC = 0.8 V to 3.6 V EN input 74AUP1Z04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 9 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VOH Y output; VI at X1 input = VIH or VIL HIGH-level output voltage Min Typ Max V IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.11 - - LOW-level output voltage V IO = 1.1 mA; VCC = 1.1 V 0.6  VCC - - V IO = 1.7 mA; VCC = 1.4 V 0.93 - - V IO = 1.9 mA; VCC = 1.65 V 1.17 - - V IO = 2.3 mA; VCC = 2.3 V 1.77 - - V IO = 3.1 mA; VCC = 2.3 V 1.67 - - V IO = 2.7 mA; VCC = 3.0 V 2.40 - - V IO = 4.0 mA; VCC = 3.0 V 2.30 - - V X2 output; VI = GND or VCC VOL Unit V IO = 20 A; VCC = 0.8 V to 3.6 V VCC  0.11 - - V IO = 1.1 mA; VCC = 1.1 V 0.6  VCC - - V IO = 1.7 mA; VCC = 1.4 V 0.93 - - V IO = 1.9 mA; VCC = 1.65 V 1.17 - - V IO = 2.3 mA; VCC = 2.3 V 1.77 - - V IO = 3.1 mA; VCC = 2.3 V 1.67 - - V IO = 2.7 mA; VCC = 3.0 V 2.40 - - V IO = 4.0 mA; VCC = 3.0 V 2.30 - - V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.11 V IO = 1.1 mA; VCC = 1.1 V - - 0.33  VCC V IO = 1.7 mA; VCC = 1.4 V - - 0.41 V IO = 1.9 mA; VCC = 1.65 V - - 0.39 V IO = 2.3 mA; VCC = 2.3 V - - 0.36 V IO = 3.1 mA; VCC = 2.3 V - - 0.50 V IO = 2.7 mA; VCC = 3.0 V - - 0.36 V IO = 4.0 mA; VCC = 3.0 V - - 0.50 V IO = 20 A; VCC = 0.8 V to 3.6 V - - 0.11 V IO = 1.1 mA; VCC = 1.1 V - - 0.33  VCC V Y output; VI at X1 input = VIH or VIL X2 output; VI = GND or VCC 74AUP1Z04 Product data sheet IO = 1.7 mA; VCC = 1.4 V - - 0.41 V IO = 1.9 mA; VCC = 1.65 V - - 0.39 V IO = 2.3 mA; VCC = 2.3 V - - 0.36 V IO = 3.1 mA; VCC = 2.3 V - - 0.50 V IO = 2.7 mA; VCC = 3.0 V - - 0.36 V IO = 4.0 mA; VCC = 3.0 V - - 0.50 V All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 10 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions II X1 input input leakage current VI = EN = VCC; VCC = 0 V to 3.6 V Min Typ Max Unit - - 0.75 A - - 0.75 A EN input VI = GND to 3.6 V; VCC = 0 V to 3.6 V Ipu pull-up current X1 input; EN = VCC - - 15 A IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V [1] - - 0.75 A [1] - - 0.75 A - - 75 A - - 75 A VCC = 0.8 V - - - mA/V VCC = 1.1 V to 1.3 V - - 10.8 mA/V VI = GND; VCC = 0.8 V to 3.6 V IOFF additional power-off leakage current VI or VO = 0 V to 3.6 V; VCC = 0 V to 0.2 V ICC supply current VI = GND or VCC; IO = 0 A; EN = GND; VCC = 0.8 V to 3.6 V ICC additional supply current EN input VI = VCC  0.6 V; IO = 0 A; VCC = 3.3 V forward transconductance gfs Rbias [1] bias resistance see Figure 10 and Figure 11 VCC = 1.4 V to 1.6 V 1.8 - 21.2 mA/V VCC = 1.65 V to 1.95 V 6.9 - 29.9 mA/V VCC = 2.3 V to 2.7 V 13.4 - 38.0 mA/V VCC = 3.0 V to 3.6 V 15.8 - 39.2 mA/V 1.07 - 3.11 M EN = GND; fi = 0 Hz; VI = 0 V or VCC; see Figure 5; for frequency behavior see Figure 6 Only for output Y and input EN. Rbias VCC II X1 X2 VI VO 001aai359 VO – VI R bias = ----------------II Fig 5. Test circuit for measuring bias resistance 74AUP1Z04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 11 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor 001aai159 20 Rbias (MΩ) 16 (1) 12 8 (2) 4 (3) 0 1.0 1.5 2.0 2.5 3.0 3.5 VCC (V) (1) fi = 30 kHz. (2) fi = 1 MHz. (3) fi = 10 MHz. Fig 6. Typical bias resistance versus supply voltage 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter Tamb =25 C Conditions Min Typ[1] Tamb = 40 C to +125 C Unit Max Min Max Max (85 C) (125 C) CL = 5 pF tpd propagation delay X1 to X2; see Figure 7 [2] VCC = 0.8 V - 12.8 - - - - ns VCC = 1.1 V to 1.3 V 1.2 3.0 3.9 1.2 3.9 3.9 ns VCC = 1.4 V to 1.6 V 1.0 2.2 2.6 1.0 2.7 2.7 ns VCC = 1.65 V to 1.95 V 0.8 1.9 2.3 0.8 2.4 2.5 ns VCC = 2.3 V to 2.7 V 0.7 1.6 1.9 0.7 2.0 2.0 ns VCC = 3.0 V to 3.6 V 0.7 1.4 1.6 0.7 1.7 1.7 ns - 39.2 - - - - ns X1 to Y; see Figure 8 VCC = 0.8 V 74AUP1Z04 Product data sheet [2] VCC = 1.1 V to 1.3 V 2.5 8.0 10.7 2.3 10.8 10.9 ns VCC = 1.4 V to 1.6 V 2.2 5.5 6.6 2.0 7.0 7.0 ns VCC = 1.65 V to 1.95 V 1.8 4.4 5.5 1.7 5.9 6.0 ns VCC = 2.3 V to 2.7 V 1.5 3.5 4.1 1.4 4.4 4.5 ns VCC = 3.0 V to 3.6 V 1.5 3.1 3.5 1.4 3.8 3.8 ns All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 12 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter Tamb =25 C Conditions Tamb = 40 C to +125 C Unit Min Typ[1] Max Min - 20.9 - - - - ns 1.4 4.1 5.4 1.3 5.6 5.6 ns Max Max (85 C) (125 C) CL = 10 pF tpd propagation delay X1 to X2; see Figure 7 [2] VCC = 0.8 V VCC = 1.1 V to 1.3 V VCC = 1.4 V to 1.6 V 1.3 2.9 3.6 1.2 3.8 3.8 ns VCC = 1.65 V to 1.95 V 1.2 2.5 3.0 1.1 3.2 3.2 ns VCC = 2.3 V to 2.7 V 0.9 2.0 2.4 0.8 2.5 2.5 ns 0.9 1.8 2.1 0.8 2.3 2.3 ns - 46.6 - - - - ns VCC = 1.1 V to 1.3 V 2.7 9.2 12.4 2.5 12.7 12.7 ns VCC = 1.4 V to 1.6 V 2.5 6.3 7.8 2.2 8.2 8.2 ns VCC = 1.65 V to 1.95 V 2.3 5.0 6.2 2.2 6.7 6.7 ns VCC = 2.3 V to 2.7 V 1.8 4.0 4.7 1.7 5.0 5.1 ns VCC = 3.0 V to 3.6 V 1.9 3.6 4.2 1.8 4.5 4.5 ns - 28.9 - - - - ns VCC = 1.1 V to 1.3 V 1.7 5.2 7.1 1.6 7.2 7.3 ns VCC = 1.4 V to 1.6 V 1.6 3.6 4.4 1.6 4.7 4.8 ns VCC = 1.65 V to 1.95 V 1.3 3.0 3.7 1.3 3.9 4.0 ns VCC = 2.3 V to 2.7 V 1.0 2.4 2.9 1.0 3.1 3.1 ns 1.1 2.2 2.5 1.0 2.7 2.7 ns VCC = 3.0 V to 3.6 V X1 to Y; see Figure 8 [2] VCC = 0.8 V CL = 15 pF tpd propagation delay X1 to X2; see Figure 7 [2] VCC = 0.8 V VCC = 3.0 V to 3.6 V X1 to Y; see Figure 8 VCC = 0.8 V 74AUP1Z04 Product data sheet [2] - 53.9 - - - - ns VCC = 1.1 V to 1.3 V 3.1 10.4 14.2 2.8 14.6 14.7 ns VCC = 1.4 V to 1.6 V 2.9 7.0 8.5 2.7 9.2 9.3 ns VCC = 1.65 V to 1.95 V 2.5 5.6 6.9 2.3 7.4 7.5 ns VCC = 2.3 V to 2.7 V 2.1 4.5 5.4 2.0 5.7 5.7 ns VCC = 3.0 V to 3.6 V 2.3 4.1 4.7 2.1 5.1 5.1 ns All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 13 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter Tamb =25 C Conditions Tamb = 40 C to +125 C Unit Min Typ[1] Max Min - 52.8 - - - - ns 2.4 8.5 11.8 2.3 12.2 12.4 ns Max Max (85 C) (125 C) CL = 30 pF propagation delay X1 to X2; see Figure 7 tpd [2] VCC = 0.8 V VCC = 1.1 V to 1.3 V VCC = 1.4 V to 1.6 V 2.2 5.6 6.8 2.0 7.5 7.6 ns VCC = 1.65 V to 1.95 V 2.0 4.5 5.6 1.9 6.2 6.2 ns VCC = 2.3 V to 2.7 V 1.5 3.7 4.2 1.4 4.6 4.6 ns 1.7 3.3 3.7 1.6 4.0 4.2 ns - 77.6 - - - - ns VCC = 1.1 V to 1.3 V 3.7 13.8 19.2 3.3 19.8 20.1 ns VCC = 1.4 V to 1.6 V 3.4 9.2 11.2 3.1 12.2 12.3 ns VCC = 1.65 V to 1.95 V 3.4 7.4 8.8 3.1 9.7 9.7 ns VCC = 2.3 V to 2.7 V 2.6 5.9 6.7 2.4 7.4 7.4 ns VCC = 3.0 V to 3.6 V 3.2 5.4 6.2 2.9 6.7 6.9 ns VCC = 0.8 V - 6.8 - - - - pF VCC = 1.1 V to 1.3 V - 12.0 - - - - pF VCC = 3.0 V to 3.6 V X1 to Y; see Figure 8 [2] VCC = 0.8 V CL = 5 pF, 10 pF, 15 pF and 30 pF power dissipation capacitance CPD fi = 1 MHz; EN = GND; VI = GND to VCC [3][4][5] VCC = 1.4 V to 1.6 V - 18.2 - - - - pF VCC = 1.65 V to 1.95 V - 19.2 - - - - pF VCC = 2.3 V to 2.7 V - 21.9 - - - - pF VCC = 3.0 V to 3.6 V - 24.9 - - - - pF [1] All typical values are measured at nominal VCC. [2] tpd is the same as tPLH and tPHL. [3] All specified values are the average typical values over all stated loads. [4] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of the outputs. [5] Feedback current is included in the CPD. 74AUP1Z04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 14 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor 12. Waveforms VI VM X1 input GND tPLH tPHL VOH VM X2 output VOL mnb099 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage drop that occur with the output load. Fig 7. The input (X1) to output (X2) propagation delays VI VM X1 input GND tPLH tPHL VOH VM Y output VOL mnb100 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage drop that occur with the output load. Fig 8. Table 9. The input (X1) to output (Y) propagation delays Measurement points Supply voltage Output Input VCC VM VM VI tr = tf 0.8 V to 3.6 V 0.5  VCC 0.5  VCC VCC  3.0 ns 74AUP1Z04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 15 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor VCC VEXT 5 kΩ G VI VO DUT RT CL RL 001aac521 Test data is given in Table 10. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 9. Table 10. Test circuit for measuring switching times Test data Supply voltage Load VEXT VCC CL RL[1] 0.8 V to 3.6 V 5 pF, 10 pF, 15 pF and 30 pF 5 k or 1 M [1] tPLH, tPHL tPZH, tPHZ tPZL, tPLZ open GND 2  VCC For measuring enable and disable times RL = 5 k, for measuring propagation delays, setup and hold times and pulse width RL = 1 M. 74AUP1Z04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 16 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor 001aad074 30 gfs (mA/V) 20 Rbias VCC 10 0.47 μF X 1 X2 100 μF Vi Io 0 0 1 2 3 4 VCC (V) 001aai360 Tamb = 25 C. I g fs = --------OV I fi = 1 kHz. VO is constant. Fig 10. Test set-up for measuring forward transconductance Fig 11. Typical forward transconductance as a function of supply voltage 13. Application information Crystal controlled oscillator circuits are widely used in clock pulse generators because of their excellent frequency stability and wide operating frequency range. The use of the 74AUP1Z04 provides the additional advantages of low power dissipation, stable operation over a wide range of frequency and temperature and a very small footprint. This application information describes crystal characteristics, design and testing of crystal oscillator circuits based on the 74AUP1Z04. 13.1 Crystal characteristics Figure 12 is the equivalent circuit of a quartz crystal. The reactive and resistive component of the impedance of the crystal alone and the crystal with a series and a parallel capacitance is shown in Figure 13. CX1 = CX0 LX1 RX1 001aai361 Fig 12. Equivalent circuit of a crystal 74AUP1Z04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 17 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor + resistance CX1 CX0 (1) LX1 R1 0 fr fa f reactance RX1 + CX0 (2) LX1 resistance RL CX1 0 fL fa f reactance RX1 CL + Rp resistance CX1 (3) CL CX0 LX1 0 fr fL fa f reactance RX1 001aai362 (1) resonance (2) anti-resonance (3) load resonance Fig 13. Reactance and resistance characteristics of a crystal 13.1.1 Design Figure 14 shows the recommended way to connect a crystal to the 74AUP1Z04. This circuit is basically a Pierce oscillator circuit in which the crystal is operating at its fundamental frequency and is tuned by the parallel load capacitance of C1 and C2. C1 and C2 are in series with the crystal. They should be approximately equal. R1 is the drive-limiting resistor and is set to approximately the same value as the reactance of C1 at the crystal frequency (R1 = XC1). This will result in an input to the crystal of 50 % of the rail-to-rail output of X2. This keeps the drive level into the crystal within drive specifications (the designer should verify this). Overdriving the crystal can cause damage. The internal bias resistor provides negative feedback and sets a bias point of the inverter near mid-supply, operating the 74AUP1GU04 portion in the high gain linear region. To calculate the values of C1 and C2, the designer can use the formula: C1  C2 C L = ------------------ + Cs C1 + C2 CL is the load capacitance as specified by the crystal manufacturer, Cs is the stray capacitance of the circuit (for the 74AUP1Z04 this is equal to an input capacitance of 1.5 pF). 74AUP1Z04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 18 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor 74AUP1G04 portion 74AUP1GU04 portion Rbias X1 Y X2 Xtal C2 system load R1 Csys Rsys C1 001aai363 Fig 14. Crystal oscillator configuration for the 74AUP1Z04 13.1.2 Testing After the calculations are performed for a particular crystal, the oscillator circuit should be tested. The following simple checks will verify the prototype design of a crystal controlled oscillator circuit. Perform them after laying out the board: • Test the oscillator over worst-case conditions (lowest supply voltage, worst-case crystal and highest operating temperature). Adding series and parallel resistors can simulate a worst-case crystal. • Insure that the circuit does not oscillate without the crystal. • Check the frequency stability over a supply range greater than that which is likely to occur during normal operation. • Check that the start-up time is within system requirements. As the 74AUP1Z04 isolates the system loading, once the design is optimized, the single layout may work in multiple applications for any given crystal. 74AUP1Z04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 19 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor 14. Package outline Plastic surface-mounted package; 6 leads SOT363 D E B y X A HE 6 5 v M A 4 Q pin 1 index A A1 1 2 e1 3 bp c Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w y mm 1.1 0.8 0.1 0.30 0.20 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.25 0.15 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT363 JEITA EUROPEAN PROJECTION ISSUE DATE 04-11-08 06-03-16 SC-88 Fig 15. Package outline SOT363 (SC-88) 74AUP1Z04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 20 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor SOT886 XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm b 1 2 3 4x (2) L L1 e 6 5 e1 4 e1 6x A (2) A1 D E terminal 1 index area 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 0.5 A1 b D E 0.04 0.25 1.50 1.05 0.20 1.45 1.00 0.17 1.40 0.95 e e1 0.6 0.5 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. Outline version SOT886 sot886_po References IEC JEDEC JEITA European projection Issue date 04-07-22 12-01-05 MO-252 Fig 16. Package outline SOT886 (XSON6) 74AUP1Z04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 21 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm 1 SOT891 b 3 2 4× (1) L L1 e 6 5 e1 4 e1 6× A (1) A1 D E terminal 1 index area 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max A1 max b D E e e1 L L1 mm 0.5 0.04 0.20 0.12 1.05 0.95 1.05 0.95 0.55 0.35 0.35 0.27 0.40 0.32 Note 1. Can be visible in some manufacturing processes. OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 05-04-06 07-05-15 SOT891 Fig 17. Package outline SOT891 (XSON6) 74AUP1Z04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 22 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor XSON6: extremely thin small outline package; no leads; 6 terminals; body 0.9 x 1.0 x 0.35 mm 1 SOT1115 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 scale Dimensions Unit mm 1 mm A(1) A1 b D E e e1 max 0.35 0.04 0.20 0.95 1.05 nom 0.15 0.90 1.00 0.55 min 0.12 0.85 0.95 0.3 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1115_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-07 SOT1115 Fig 18. Package outline SOT1115 (XSON6) 74AUP1Z04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 23 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor XSON6: extremely thin small outline package; no leads; 6 terminals; body 1.0 x 1.0 x 0.35 mm 1 SOT1202 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 scale Dimensions Unit mm 1 mm A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.05 1.05 0.35 0.40 nom 0.15 1.00 1.00 0.55 0.35 0.30 0.35 min 0.12 0.95 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1202_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1202 Fig 19. Package outline SOT1202 (XSON6) 74AUP1Z04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 24 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor 15. Abbreviations Table 11. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 16. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AUP1Z04 v.5 20120809 Product data sheet - 74AUP1Z04 v.4 Modifications: 74AUP1Z04 v.4 Modifications: • Package outline drawing of SOT886 (Figure 16) modified. 20111201 • Product data sheet - 74AUP1Z04 v.3 Legal pages updated. 74AUP1Z04 v.3 20100722 Product data sheet - 74AUP1Z04 v.2 74AUP1Z04 v.2 20080703 Product data sheet - 74AUP1Z04 v.1 74AUP1Z04 v.1 20061212 Product data sheet - - 74AUP1Z04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 25 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor 17. Legal information 17.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 17.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 17.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74AUP1Z04 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 26 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 17.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 18. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74AUP1Z04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 9 August 2012 © Nexperia B.V. 2017. All rights reserved 27 of 28 74AUP1Z04 Nexperia Low-power X-tal driver with enable and internal resistor 19. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 12 13 13.1 13.1.1 13.1.2 14 15 16 17 17.1 17.2 17.3 17.4 18 19 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . 12 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Application information. . . . . . . . . . . . . . . . . . 17 Crystal characteristics. . . . . . . . . . . . . . . . . . . 17 Design . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Testing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 20 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 25 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 25 Legal information. . . . . . . . . . . . . . . . . . . . . . . 26 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 26 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 26 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 26 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 27 Contact information. . . . . . . . . . . . . . . . . . . . . 27 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 09 August 2012
74AUP1Z04GF,132
物料型号:74AUP1Z04 器件简介:74AUP1Z04是一款低功耗晶体振荡器驱动器,集成了使能电路和内部偏置电阻,优化用于晶体振荡器应用。
引脚分配: - EN(1):使能输入(低电平有效) - GND(2):地(0V) - X1(3):数据输入 - X2(4):数据输出 - Vcc(5):供电电压 - Y(6):数据输出 参数特性: - 宽电源电压范围:0.8V 至 3.6V - 高抗噪声性 - ESD保护:HBM Class 3A超过5000V,MM Class A超过200V,CDM超过1000V - 低噪声过冲和下冲:<10% of Vcc - 多种封装选项 - 工作温度范围:-40°C至+85°C 和 -40°C至+125°C 功能详解:74AUP1Z04在不使用时,可以通过将$\overline{EN}$输入驱动高电平,使设备进入低功耗禁用模式。
该设备还具有部分断电应用的IOFF功能,可在断电时禁用Y输出,以防止通过设备产生有害的反向电流。
应用信息:74AUP1Z04提供低功耗、宽频率和温度范围内的稳定运行以及紧凑的占用空间,适用于晶体振荡器电路。
封装信息:提供多种封装选项,包括SC-88、XSON6、SOT363、SOT886、SOT891、SOT1115和SOT1202。
以上信息摘自74AUP1Z04的产品数据手册。
74AUP1Z04GF,132 价格&库存
很抱歉,暂时无法提供与“74AUP1Z04GF,132”相匹配的价格&库存,您可以联系我们找货
