HEF4027BT,652
HEF4027BT,652
    NEXPERIA(安世)
    SOIC-16
    双JK触发器
HEF4027BT,652 数据手册
HEF4027B Dual JK flip-flop Rev. 10 — 21 March 2016 Product data sheet 1. General description The HEF4027B is a edge-triggered dual JK flip-flop which features independent set-direct (SD), clear-direct (CD), clock (CP) inputs and outputs (Q, Q). Data is accepted when CP is LOW, and transferred to the output on the positive-going edge of the clock. The active HIGH asynchronous clear-direct (CD) and set-direct (SD) inputs are independent and override the J, K, and CP inputs. The outputs are buffered for best system performance. Schmitt trigger action makes the clock input highly tolerant of slower rise and fall times. It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. 2. Features and benefits      Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Specified from 40 C to +85 C Complies with JEDEC standard JESD 13-B 3. Applications  Registers  Counters  Control circuits 4. Ordering information Table 1. Ordering information Tamb from 40 C to +85 C. Type number HEF4027BT Package Name Description Version SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 HEF4027B Nexperia Dual JK flip-flop 5. Functional diagram ))  6'  -  &3  . 4  4  4  4  &'  ))  6'  -  &3  . &'  DDH Fig 1. Functional diagram &3 & - 4 & & & & & & & 4 . & & &' 6' Fig 2. DDH Logic diagram of one flip-flop HEF4027B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 2 of 13 HEF4027B Nexperia Dual JK flip-flop 6. Pinning information 6.1 Pinning +()% 4   9'' 4   4 &3   4 &'   &3 .   &' -   . 6'   - 966   6' DDH Fig 3. Pin configuration 6.2 Pin description Table 2. Pin description Symbol Pin Description VSS 8 ground supply voltage 1SD, 2SD 9, 7 asynchronous set-direct input (active HIGH) 1J, 2J 10, 6 synchronous input 1K, 2K 11, 5 synchronous input 1CD, 2CD 12, 4 asynchronous clear-direct input (active HIGH) 1CP, 2CP 13, 3 clock input (LOW-to-HIGH edge-triggered) 1Q, 2Q 14, 2 complement output 1Q, 2Q 15, 1 true output VDD 16 supply voltage HEF4027B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 3 of 13 HEF4027B Nexperia Dual JK flip-flop 7. Functional description Table 3. Function table[1] Inputs Outputs nSD nCD nCP nJ nK nQ nQ H L X X X H L L H X X X L H H H X X X H H L L  L L no change no change L L  H L H L L L  L H L H L L  H H nQ nQ [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care.;  = positive-going transition. 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions VDD supply voltage IIK input clamping current VI input voltage IOK output clamping current II/O input/output current IDD supply current Tstg storage temperature Tamb ambient temperature in free air Ptot total power dissipation Tamb 40 C to +85 C VI < 0.5 V or VI > VDD + 0.5 V VO < 0.5 V or VO > VDD + 0.5 V SO16 package P [1] power dissipation [1] per output Min Max Unit 0.5 +18 V - 10 0.5 VDD + 0.5 - 10 mA - 10 mA mA V - 50 mA 65 +150 C 40 +85 C - 500 mW - 100 mW For SO16 package: Ptot derates linearly with 8 mW/K above 70 C. 9. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VDD VI Conditions Min Max Unit supply voltage 3 15 V input voltage 0 VDD V Tamb ambient temperature in free air 40 +85 C t/V input transition rise and fall rate VDD = 5 V - 3.75 s/V VDD = 10 V - 0.5 s/V VDD = 15 V - 0.08 s/V HEF4027B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 4 of 13 HEF4027B Nexperia Dual JK flip-flop 10. Static characteristics Table 6. Static characteristics VSS = 0 V; VI = VSS or VDD; unless otherwise specified. Symbol Parameter Conditions VDD Tamb = 40 C Min VIH VIL VOH VOL IOH IOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage HIGH-level output current LOW-level output current II input leakage current IDD supply current CI input capacitance HEF4027B Product data sheet IO < 1 A IO < 1 A IO < 1 A Max Tamb = 25 C Tamb = 85 C Unit Min Min Max Max 5V 3.5 - 3.5 - 3.5 - V 10 V 7.0 - 7.0 - 7.0 - V 15 V 11.0 - 11.0 - 11.0 - V 5V - 1.5 - 1.5 - 1.5 V 10 V - 3.0 - 3.0 - 3.0 V 15 V - 4.0 - 4.0 - 4.0 V 5V 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - V 5V - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 V 15 V - 0.05 - 0.05 - 0.05 V VO = 2.5 V 5V - 1.7 - 1.4 - 1.1 mA VO = 4.6 V 5V - 0.52 - 0.44 - 0.36 mA VO = 9.5 V 10 V - 1.3 - 1.1 - 0.9 mA VO = 13.5 V 15 V - 3.6 - 3.0 - 2.4 mA IO < 1 A VO = 0.4 V 5V 0.52 - 0.44 - 0.36 - mA VO = 0.5 V 10 V 1.3 - 1.1 - 0.9 - mA VO = 1.5 V 15 V 3.6 - 3.0 - 2.4 - mA 15 V - 0.3 - 0.3 - 1.0 A IO = 0 A 5V - 4.0 - 4.0 - 30 A 10 V - 8.0 - 8.0 - 60 A 15 V - 16.0 - 16.0 - 120 A - - - - 7.5 - - pF All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 5 of 13 HEF4027B Nexperia Dual JK flip-flop 11. Dynamic characteristics Table 7. Dynamic characteristics VSS = 0 V; Tamb = 25 C; for test circuit see Figure 7; unless otherwise specified. Symbol Parameter tPHL tPLH HIGH to LOW propagation delay LOW to HIGH propagation delay Conditions VDD Extrapolation formula[1] CP  Q, Q; see Figure 4 5V Min Typ Max Unit 78 ns + (0.55 ns/pF)CL - 105 210 ns 10 V 29 ns + (0.23 ns/pF)CL - 40 80 ns 15 V 22 ns + (0.16 ns/pF)CL - 30 60 ns CD  Q; see Figure 4 5V 93 ns + (0.55 ns/pF)CL - 120 240 ns 10 V 33 ns + (0.23 ns/pF)CL - 45 90 ns 15 V 27 ns + (0.16 ns/pF)CL - 35 70 ns SD  Q; see Figure 4 5V 113 ns + (0.55 ns/pF)CL - 140 280 ns 10 V 44 ns + (0.23 ns/pF)CL - 55 110 ns 15 V 32 ns + (0.16 ns/pF)CL - 40 80 ns 5V 58 ns + (0.55 ns/pF)CL - 85 170 ns 10 V 27 ns + (0.23 ns/pF)CL - 35 70 ns 15 V 22 ns + (0.16 ns/pF)CL - 30 60 ns 5V 48 ns + (0.55 ns/pF)CL - 75 150 ns 10 V 24 ns + (0.23 ns/pF)CL - 35 70 ns 15 V 17 ns + (0.16 ns/pF)CL - 25 50 ns SD  Q; see Figure 4 5V 43 ns + (0.55 ns/pF)CL - 70 140 ns 10 V 19 ns + (0.23 ns/pF)CL - 30 60 ns see Figure 4 5V CP  Q, Q; see Figure 4 CD  Q; see Figure 4 17 ns + (0.16 ns/pF)CL - 25 50 ns 10 ns + (1.00 ns/pF)CL - 60 120 ns 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns 15 V 6 ns + (0.28 ns/pF)CL - 20 40 ns 15 V tt tsu th tW trec transition time set-up time hold time pulse width recovery time HEF4027B Product data sheet J, K  CP; see Figure 5 [2] 5V 50 25 - ns 10 V 30 10 - ns 15 V 20 5 - ns 5V 25 0 - ns 10 V 20 0 - ns 15 V 15 5 - ns CP LOW; minimum width see Figure 5 5V 80 40 - ns 10 V 30 15 - ns 15 V 24 12 - ns SD, CD HIGH; minimum width see Figure 6 5V 90 45 - ns 10 V 40 20 - ns 15 V 30 15 - ns SD, CD inputs; see Figure 6 5V +20 15 - ns 10 V +15 10 - ns 15 V +10 5 - ns J, K  CP; see Figure 5 All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 6 of 13 HEF4027B Nexperia Dual JK flip-flop Table 7. Dynamic characteristics …continued VSS = 0 V; Tamb = 25 C; for test circuit see Figure 7; unless otherwise specified. Symbol Parameter Conditions VDD fmax CP input; J = K = HIGH; see Figure 5 maximum frequency Extrapolation formula[1] Min Typ Max Unit 5V 4 8 - MHz 10 V 12 25 - MHz 15 V 15 30 - MHz [1] The typical values of the propagation delay and transition times are calculated from the extrapolation formulas shown (CL in pF). [2] tt is the same as tTLH and tTHL. Table 8. Dynamic power dissipation PD PD can be calculated from the formulas shown. VSS = 0 V; tr = tf  20 ns; Tamb = 25 C. Symbol PD Parameter dynamic power dissipation VDD Typical formula for PD (W) Where: 5V PD = 900  fi + (fo  CL)  VDD 10 V PD = 4500  fi + (fo  CL)  VDD2 fo = output frequency in MHz; 15 V PD = 13200  fi + (fo  CL)  CL = output load capacitance in pF; 2 fi = input frequency in MHz; VDD2 VDD = supply voltage in V; (fo  CL) = sum of the outputs. 12. Waveforms WU 9, WI  6'&'RU&3 ,1387 9 90  W3/+ 92+ W3+/  4RU4 287387 92/ 90  W7/+ W7+/ DDK VOH and VOL are typical output voltages levels that occur with the output load. Measurement points are given in Table 9. Fig 4. Waveforms showing rise, fall and transition times and propagation delays IPD[ &3,1387 W: 90 WK -.,1387 90 WVX DDH Measurement points are given in Table 9. Fig 5. Waveforms showing set-up and hold times and minimum clock pulse width HEF4027B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 7 of 13 HEF4027B Nexperia Dual JK flip-flop 9, 6',1387 90 9 W: 9, 90 &',1387 9 W: WUHF WUHF 9, 90 &3,1387 9 92+ 4287387 92/ DDH VOH and VOL are typical output voltages levels that occur with the output load. Measurement points are given in Table 9. Fig 6. Waveforms showing pulse widths and recovery times Table 9. Measurement points Supply voltage Input Output VDD VM VM 5 V to 15 V 0.5VDD 0.5VDD 9'' * 9, 92 '87 &/ 57 DDJ Test data is given in Table 10. Definitions for test circuit: DUT = Device Under Test. CL = load capacitance including jig and probe capacitance. RT = termination resistance should be equal to the output impedance Zo of the pulse generator. Fig 7. Test circuit Table 10. Test data Supply voltage Input VDD VI tr, tf CL 5 V to 15 V VSS or VDD  20 ns 50 pF HEF4027B Product data sheet Load All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 8 of 13 HEF4027B Nexperia Dual JK flip-flop 13. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H Z 0 ES   GHWDLO; PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV         ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG Fig 8. 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Package outline SOT109-1 (SO16) HEF4027B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 9 of 13 HEF4027B Nexperia Dual JK flip-flop 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes HEF4027B v.10 20160321 Product data sheet - HEF4027B v.9 Modifications: HEF4027B v.9 Modifications: • Type number HEF4027BP (SOT38-4) removed. 20111118 • • Product data sheet - HEF4027B v.8 Legal pages updated. Changes in “General description” and “Features and benefits”. HEF4027B v.8 20111010 Product data sheet - HEF4027B v.7 HEF4027B v.7 20091125 Product data sheet - HEF4027B v.6 HEF4027B v.6 20090624 Product data sheet - HEF4027B v.5 HEF4027B v.5 20081110 Product data sheet - HEF4027B v.4 HEF4027B v.4 20080703 Product specification - HEF4027B_CNV v.3 HEF4027B_CNV v.3 19950101 Product specification - HEF4027B_CNV v.2 HEF4027B_CNV v.2 19950101 Product specification - - HEF4027B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 10 of 13 HEF4027B Nexperia Dual JK flip-flop 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. HEF4027B Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 11 of 13 HEF4027B Nexperia Dual JK flip-flop Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com HEF4027B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 March 2016 © Nexperia B.V. 2017. All rights reserved 12 of 13 Nexperia HEF4027B Dual JK flip-flop 17. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 6 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Contact information. . . . . . . . . . . . . . . . . . . . . 12 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 21 March 2016
