INTEGRATED CIRCUITS
DATA SHEET
For a complete data sheet, please also download:
• The IC06 74HC/HCT/HCU/HCMOS Logic Family Specifications
• The IC06 74HC/HCT/HCU/HCMOS Logic Package Information
• The IC06 74HC/HCT/HCU/HCMOS Logic Package Outlines
74HC/HCT574
Octal D-type flip-flop; positive
edge-trigger; 3-state
Product specification
File under Integrated Circuits, IC06
December 1990
Philips Semiconductors
74HC/HCT574
FEATURES
GENERAL DESCRIPTION
• 3-state non-inverting outputs for
bus oriented applications
The 74HC/HCT574 are high-speed
Si-gate CMOS devices and are pin
compatible with low power Schottky
TTL (LSTTL). They are specified in
compliance with JEDEC standard
no. 7A.
• 8-bit positive edge-triggered
register
• Common 3-state output enable
input
• Independent register and 3-state
buffer operation
• Output capability: bus driver
• ICC category: MSI
The 74HC/HCT574 are octal D-type
flip-flops featuring separate D-type
inputs for each flip-flop and
non-inverting 3-state outputs for bus
oriented applications. A clock (CP)
and an output enable (OE) input are
common to all flip-flops.
The 8 flip-flops will store the state of
their individual D-inputs that meet the
set-up and hold time requirements on
the LOW-to-HIGH CP transition.
When OE is LOW, the contents of the
8 flip-flops are available at the
outputs.
When OE is HIGH, the outputs go to
the high impedance OFF-state.
Operation of the OE input does not
affect the state of the flip-flops.
The “574” is functionally identical to
the “564”, but has non-inverting
outputs.
the “374”, but has a different pinning.
QUICK REFERENCE DATA
GND = 0 V; Tamb = 25 °C; tr = tf = 6 ns
TYPICAL
SYMBOL
PARAMETER
CONDITIONS
CL = 15 pF; VCC = 5 V
UNIT
HC
HCT
14
15
ns
tPHL/ tPLH
propagation delay CP to Qn
fmax
maximum clock frequency
123
76
MHz
CI
input capacitance
3.5
3.5
pF
CPD
power dissipation capacitance per flip-flop
22
25
pF
notes 1 and 2
Notes
1. CPD is used to determine the dynamic power dissipation (PD in µW):
PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where:
fi = input frequency in MHz
fo = output frequency in MHz
∑ (CL × VCC2 × fo) = sum of outputs
CL = output load capacitance in pF
VCC = supply voltage in V
2. For HC the condition is VI = GND to VCC
For HCT the condition is VI = GND to VCC − 1.5 V
ORDERING INFORMATION
See “74HC/HCT/HCU/HCMOS Logic Package Information”.
December 1990
2
Octal D-type flip-flop; positive edge-trigger;
3-state
74HC/HCT574
PIN DESCRIPTION
PIN NO.
SYMBOL
NAME AND FUNCTION
1
OE
3-state output enable input (active LOW)
2, 3, 4, 5, 6, 7, 8, 9
D0 to D7
data inputs
10
GND
ground (0 V)
11
CP
clock input (LOW-to-HIGH, edge-triggered)
19, 18, 17, 16, 15, 14, 13, 12
Q0 to Q7
3-state flip-flop outputs
VCC
positive supply voltage
Fig.1 Pin configuration.
December 1990
Fig.2 Logic symbol.
3
Fig.3 IEC logic symbol.
3-state
74HC/HCT574
FUNCTION TABLE
OPERATING
MODES
INPUTS
OUTPUTS
OE
CP
Dn
INTERNAL
FLIP-FLOPS
load and read
register
L
L
l
h
L
H
L
H
load register and
disable outputs
H
H
l
h
L
H
Z
Z
Q0 to Q7
Notes
1. H = HIGH voltage level
h = HIGH voltage level one set-up time prior to the LOW-to-HIGH
CP transition
L = LOW voltage level
l = LOW voltage level on set-up time prior to the LOW-to-HIGH
CP transition
Z = HIGH impedance OFF-state
↑ = LOW-to-HIGH clock transition
Fig.4 Functional diagram.
Fig.5 Logic diagram.
December 1990
4
3-state
74HC/HCT574
DC CHARACTERISTICS FOR 74HC
For the DC characteristics see “74HC/HCT/HCU/HCMOS Logic Family Specifications”.
ICC category: MSI
AC CHARACTERISTICS FOR 74HC
GND = 0 V; tr = tf = 6 ns; CL = 50 pF
Tamb (°C)
TEST CONDITIONS
74HC
SYMBOL PARAMETER
+25
min.
−40 to +85
typ.
max.
min.
max.
−40 to +125
min.
UNIT V
CC
WAVEFORMS
(V)
max.
tPHL/ tPLH
propagation delay
CP to Qn
47
17
14
150
30
26
190
35
33
225
45
38
ns
2.0
4.5
6.0
Fig.6
tPZH/ tPZL
time OE to Qn
44
16
13
140
28
24
175
35
30
210
42
36
ns
2.0
4.5
6.0
Fig.7
tPHZ/ tPLZ
3-state output disable
time OE to Qn
39
14
11
125
25
21
155
31
26
190
38
32
ns
2.0
4.5
6.0
Fig.7
tTHL/ tTLH
output transition time
14
5
4
60
12
10
75
15
13
90
18
15
ns
2.0
4.5
6.0
Fig.6
tW
clock pulse width
HIGH or LOW
80
16
14
14
5
4
100
120
24
ns
2.0
4.5
6.0
Fig.6
tsu
set-up time
Dn to CP
60
12
10
6
2
2
75
15
13
90
18
15
ns
2.0
4.5
6.0
Fig.8
th
hold time
Dn to CP
5
5
5
5
5
5
5
5
ns
2.0
4.5
6.0
Fig.8
fmax
maximum clock pulse
frequency
6.0
30
35
37
112
133
4.8
24
28
4.0
MHz
2.0
4.5
6.0
Fig.6
December 1990
5
3-state
74HC/HCT574
DC CHARACTERISTICS FOR 74HCT
ICC category: MSI
Note to HCT types
The value of additional quiescent supply current (∆ICC) for a unit load of 1 is given in the family specifications.
To determine ∆ICC per input, multiply this value by the unit load coefficient shown in the table below.
INPUT
UNIT LOAD COEFFICIENT
Dn
OE
CP
0.5
1.25
1.5
AC CHARACTERISTICS FOR 74HCT
Tamb (°C)
TEST CONDITIONS
74HCT
SYMBOL PARAMETER
+25
min.
−40 to +85
typ.
max.
min. max.
−40 to +125
min.
UNIT V
CC
WAVEFORMS
(V)
max.
tPHL/ tPLH
propagation delay
CP to Qn
18
33
41
50
ns
4.5
Fig.6
tPZH/ tPZL
time OE to Qn
19
33
41
50
ns
4.5
Fig.7
tPHZ/ tPLZ
time OE to Qn
16
28
35
42
ns
4.5
Fig.7
tTHL/ tTLH
5
12
15
18
ns
4.5
Fig.6
tW
clock pulse width
HIGH or LOW
16
7
ns
4.5
Fig.6
tsu
set-up time
Dn to CP
12
3
15
18
ns
4.5
Fig.8
th
hold time
Dn to CP
5
−1
5
5
ns
4.5
Fig.8
fmax
maximum clock pulse
frequency
30
69
24
MHz
4.5
Fig.6
December 1990
6
3-state
74HC/HCT574
AC WAVEFORMS
(1) HC : VM = 50%; VI = GND to VCC.
HCT: VM = 1.3 V; VI = GND to 3 V.
Fig.6
Waveforms showing the clock input (CP)
pulse width, the CP input to output (Qn)
propagation delays, the output transition
times and the maximum clock pulse
frequency.
Fig.7
Waveforms showing the 3-state enable and
disable times.
PACKAGE OUTLINES
See “74HC/HCT/HCU/HCMOS Logic Package Outlines”.
The shaded areas indicate when the input is permitted
to change for predictable output performance.
Fig.8
Waveforms showing the data set-up and
hold times for Dn input to CP input.
December 1990
7
很抱歉,暂时无法提供与“74HCT574D,653”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.95274
- 5+3.22448
- 10+2.89987
- 25+2.51538
- 50+2.29259
- 100+2.19078
