74AHC273; 74AHCT273
Octal D-type flip-flop with reset; positive-edge trigger
Rev. 03 — 13 May 2008
Product data sheet
1. General description
The 74AHC273; 74AHCT273 is a high-speed Si-gate CMOS device and is pin compatible
with Low-power Schottky TTL (LSTTL). It is specified in compliance with JEDEC standard
No. 7-A.
The 74AHC273; 74AHCT273 has eight edge-triggered, D-type flip-flops with individual D
inputs and Q outputs.
The common clock (CP) and master reset (MR) inputs, load and reset (clear) all flip-flops
simultaneously.
The state of each D input, one set-up time before the LOW-to-HIGH clock transition, is
transferred to the corresponding output (Qn) of the flip-flop.
All outputs will be forced LOW, independent of clock or data inputs, by a LOW on the MR
input.
The device is useful for applications where only the true output is required and the clock
and master reset are common to all storage elements.
2. Features
n
n
n
n
n
n
n
n
n
n
Balanced propagation delays
All inputs have Schmitt-trigger actions
Inputs accept voltages higher than VCC
Ideal buffer for MOS microcontroller or memory
Common clock and master reset
Related product versions:
u 74AHC377; 74AHCT377 for clock enable version
u 74AHC373; 74AHCT373 for transparent latch version
u 74AHC374; 74AHCT374 for 3-state version
Input levels:
u For 74AHC273: CMOS level
u For 74AHCT273: TTL level
ESD protection:
u HBM EIA/JESD22-A114E exceeds 2000 V
u MM EIA/JESD22-A115-A exceeds 200 V
u CDM EIA/JESD22-C101C exceeds 1000 V
Multiple package options
Specified from −40 °C to +85 °C and from −40 °C to +125 °C
74AHC273; 74AHCT273
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
Description
Version
74AHC273D
−40 °C to +125 °C
SO20
plastic small outline package; 20 leads;
body width 7.5 mm
SOT163-1
74AHC273PW
−40 °C to +125 °C
TSSOP20
plastic thin shrink small outline package; 20 leads;
body width 4.4 mm
SOT360-1
74AHC273BQ
−40 °C to +125 °C
DHVQFN20
plastic dual in-line compatible thermal enhanced very SOT764-1
thin quad flat package; no leads; 20 terminals; body
2.5 × 4.5 × 0.85 mm
74AHCT273D
−40 °C to +125 °C
SO20
body width 7.5 mm
SOT163-1
74AHCT273PW
−40 °C to +125 °C
TSSOP20
body width 4.4 mm
SOT360-1
74AHCT273BQ
−40 °C to +125 °C
DHVQFN20
2.5 × 4.5 × 0.85 mm
74AHC273
74AHCT273
4. Functional diagram
CP
MR
11
1
C1
R
11
3
4
7
8
13
14
17
18
D0
CP
D0
Q0
D1
Q1
D2
Q2
D3
Q3
D4
Q4
D5
Q5
D6
Q6
D7
Q7
2
D1
5
6
D2
9
D3
12
D4
15
D5
16
D6
19
MR
1
Fig 1.
Logic symbol
D7
2
1D
4
5
7
6
8
9
13
12
14
15
17
16
18
19
Q0
Q1
Q2
Q3
Q4
Q5
Q6
Q7
mna764
mna763
Fig 2.
IEC logic symbol
74AHC_AHCT273_3
Product data sheet
3
Nexperia B.V. 2017. All rights reserved
2 of 18
74AHC273; 74AHCT273
Nexperia
D0
D1
D
Q
D2
D
Q
D3
D
Q
D
Q
CP
FF1
CP
FF2
CP
FF3
CP
FF4
RD
RD
RD
RD
CP
MR
Q0
D4
Q1
D5
D
Q
Q2
D6
D
Q
Q3
D7
D
Q
D
Q
CP
FF5
CP
FF6
CP
FF7
CP
FF8
RD
RD
RD
RD
Q4
Q5
Q6
Q7
001aae056
Fig 3.
Logic diagram
3
4
7
8
13
14
17
18
1
11
D0
D1
D2
D3
D4
D5
D6
D7
FF1
TO
FF8
Q0
Q1
Q2
Q3
Q4
Q5
Q6
Q7
2
5
6
9
12
15
16
19
MR
CP
001aae055
Fig 4.
Functional diagram
74AHC_AHCT273_3
Product data sheet
3 of 18
74AHC273; 74AHCT273
Nexperia
5. Pinning information
5.1 Pinning
terminal 1
index area
MR
1
1
74AHC273
74AHCT273
20 VCC
20 VCC
MR
74AHC273
74AHCT273
Q0
2
19 Q7
D0
3
18 D7
D1
4
17 D6
Q0
2
19 Q7
D0
3
18 D7
Q1
5
16 Q6
15 Q5
4
17 D6
Q2
6
5
16 Q6
D2
7
Q2
6
15 Q5
D2
7
14 D5
8
13 D4
Q3
9
12 Q4
GND 10
11 CP
8
Q3
9
13 D4
12 Q4
GND 10
D3
D3
14 D5
GND(1)
CP 11
D1
Q1
001aai067
Transparent top view
001aai066
(1) The die substrate is attached to this pad using
conductive die attach material. It can not be used as a
supply pin or input.
Fig 5.
Pin configuration SO20 and TSSOP20
Fig 6.
Pin configuration DHVQFN20
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
MR
1
master reset input (active LOW)
Q0
2
flip-flop output
D0
3
data input
D1
4
data input
Q1
5
flip-flop output
Q2
6
flip-flop output
D2
7
data input
D3
8
data input
Q3
9
flip-flop output
GND
10
ground (0 V)
CP
11
clock input (LOW-to-HIGH edge-triggered)
Q4
12
flip-flop output
D4
13
data input
D5
14
data input
Q5
15
flip-flop output
Q6
16
flip-flop output
74AHC_AHCT273_3
Product data sheet
4 of 18
74AHC273; 74AHCT273
Nexperia
Table 2.
Pin description …continued
Symbol
Pin
Description
D6
17
data input
D7
18
data input
Q7
19
flip-flop output
VCC
supply voltage
6. Functional description
Table 3.
Function table[1]
Operating mode
Input
Output
MR
CP
Dn
Qn
Reset (clear)
L
X
X
L
Load ‘1’
H
h
H
Load ‘0’
H
l
L
[1]
Control
H = HIGH voltage level;
h = HIGH voltage level one set-up time prior to the LOW-to-HIGH CP transition;
L = LOW voltage level;
l = LOW voltage level one set-up time prior to the LOW-to-HIGH CP transition;
↑ = LOW-to-HIGH;
X = don’t care.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
Conditions
Min
Max
Unit
−0.5
+7.0
V
−0.5
+7.0
V
−20
mA
−20
+20
mA
−25
+25
mA
IIK
input clamping current
VI < −0.5 V
[1]
IOK
output clamping current
VO < −0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
VO = −0.5 V to (VCC + 0.5 V)
ICC
supply current
+75
mA
IGND
ground current
−75
mA
Tstg
storage temperature
−65
+150
°C
500
mW
total power dissipation
Ptot
Tamb = −40 °C to +125 °C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO20 packages: above 70 °C the value of Ptot derates linearly at 8 mW/K.
For TSSOP20 packages: above 60 °C the value of Ptot derates linearly at 5.5 mW/K.
For DHVQFN20 packages: above 60 °C the value of Ptot derates linearly at 4.5 mW/K.
74AHC_AHCT273_3
Product data sheet
5 of 18
74AHC273; 74AHCT273
Nexperia
8. Recommended operating conditions
Table 5.
Operating conditions
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
74AHC273
VCC
supply voltage
2.0
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
∆t/∆V
input transition rise and fall rate
VCC = 3.0 V to 3.6 V
100
ns/V
VCC = 4.5 V to 5.5 V
ns/V
74AHCT273
VCC
supply voltage
4.5
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
∆t/∆V
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 °C
Conditions
−40 °C to +85 °C −40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
74AHC273
VIH
VIL
VOH
VOL
HIGH-level
input voltage
VCC = 2.0 V
1.5
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
3.85
V
LOW-level
input voltage
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 5.5 V
1.65
1.65
1.65
V
HIGH-level
VI = VIH or VIL
output voltage
IO = −50 µA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = −50 µA; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = −50 µA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = −4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = −8.0 mA; VCC = 4.5 V
3.94
3.80
3.70
V
LOW-level
VI = VIH or VIL
output voltage
IO = 50 µA; VCC = 2.0 V
0.1
0.1
V
IO = 50 µA; VCC = 3.0 V
0.1
0.1
V
IO = 50 µA; VCC = 4.5 V
0.1
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
74AHC_AHCT273_3
Product data sheet
6 of 18
74AHC273; 74AHCT273
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
25 °C
Conditions
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
Min
Typ
Max
Min
Max
Min
Max
0.1
1.0
2.0
µA
II
input leakage
current
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
4.0
40
80
µA
CI
input
capacitance
3
10
10
10
pF
CO
output
capacitance
4
pF
74AHCT273
VIH
HIGH-level
input voltage
2.0
2.0
2.0
V
VIL
LOW-level
input voltage
0.8
0.8
0.8
V
VOH
HIGH-level
VI = VIH or VIL; VCC = 4.5 V
output voltage
IO = −50 µA
4.4
4.4
4.4
V
3.94
3.80
3.70
V
0.1
0.1
V
0.36
0.44
0.55
V
0.1
1.0
2.0
µA
IO = −8.0 mA
VOL
LOW-level
output voltage
IO = 50 µA
IO = 8.0 mA
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
ICC
VCC = 5.5 V
4.0
40
80
µA
∆ICC
additional
per input pin;
supply current VI = VCC − 2.1 V; other pins
at VCC or GND; IO = 0 A;
1.35
1.5
1.5
mA
CI
input
capacitance
3
10
10
10
pF
CO
output
capacitance
4
pF
74AHC_AHCT273_3
Product data sheet
7 of 18
74AHC273; 74AHCT273
Nexperia
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 10.
Symbol Parameter
25 °C
Conditions
Min
Typ[1]
Max
Min
Max
Min
Max
CL = 15 pF
6.0
13.6
1.0
16.0
1.0
17.0
ns
CL = 50 pF
8.6
17.1
1.0
19.5
1.0
21.5
ns
4.2
9
1.0
10.5
1.0
11.5
ns
6.0
11.0
1.0
12.5
1.0
14.0
ns
CL = 15 pF
5.1
13.6
1.0
16.0
1.0
17.0
ns
CL = 50 pF
7.3
17.1
1.0
19.5
1.0
21.5
ns
CL = 15 pF
3.7
8.5
1.0
10.0
1.0
11.0
ns
CL = 50 pF
5.3
10.5
1.0
12.0
1.0
13.5
ns
CL = 15 pF
75
120
65
65
MHz
CL = 50 pF
50
75
45
45
MHz
CL = 15 pF
120
165
100
100
MHz
CL = 50 pF
80
110
70
70
MHz
5.0
6.5
6.5
ns
5.0
5.0
5.0
ns
5.0
6.0
6.0
ns
5.0
5.0
5.0
ns
3.0
3.0
3.0
ns
3.0
3.0
3.0
ns
1.0
1.0
1.0
ns
1.0
1.0
1.0
ns
74AHC273
tpd
propagation CP to Qn; see Figure 7
delay
[2]
CL = 15 pF
CL = 50 pF
MR to Qn; see Figure 8
[3]
fmax
maximum
frequency
see Figure 7
tW
pulse width
CP HIGH or LOW;
see Figure 7
MR LOW; see Figure 8
tsu
th
set-up time
hold time
Dn to CP; see Figure 9
74AHC_AHCT273_3
Product data sheet
8 of 18
74AHC273; 74AHCT273
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
trec
CPD
recovery
time
25 °C
Conditions
Min
Typ[1]
Max
Min
Max
Min
Max
2.5
2.5
2.5
ns
2.0
2.0
2.0
ns
14
pF
4.0
7.5
1.0
8.8
1.0
9.5
ns
5.8
9.2
1.0
10.5
1.0
11.5
ns
CL = 15 pF
3.9
10.0
1.0
11.6
1.0
12.5
ns
CL = 50 pF
5.6
11.0
1.0
12.6
1.0
14.0
ns
CL = 15 pF
75
120
65
65
MHz
CL = 50 pF
50
75
45
45
MHz
CP HIGH or LOW;
see Figure 7
5.0
6.5
6.5
ns
5.0
6.0
6.0
ns
MR to CP; see Figure 8
fi = 1 MHz; VI = GND to VCC
power
dissipation
capacitance
[4]
74AHCT273; VCC = 4.5 V to 5.5 V
tpd
[2]
delay
CL = 15 pF
CL = 50 pF
[3]
fmax
tW
maximum
frequency
pulse width
see Figure 7
tsu
set-up time
3.0
3.0
3.0
ns
th
hold time
1.0
1.0
1.0
ns
trec
recovery
time
2.5
2.5
2.5
ns
CPD
power
dissipation
capacitance
18
pF
[4]
[1]
Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V).
[2]
tpd is the same as tPLH and tPHL.
[3]
tpd is the same as tPHL only.
[4]
CPD is used to determine the dynamic power dissipation (PD in µW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
Σ(CL × VCC2 × fo) = sum of the outputs.
74AHC_AHCT273_3
Product data sheet
9 of 18
74AHC273; 74AHCT273
Nexperia
11. Waveforms
1/fmax
VI
CP input
VM
GND
tW
t PHL
t PLH
VOH
VM
Qn output
001aac426
VOL
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 7.
Clock pulse width, maximum frequency and input to output propagation delays
VI
VM
MR input
GND
tW
trec
VI
CP input
VM
GND
tPHL
VOH
VM
Qn output
VOL
mna464
Fig 8.
Master reset pulse width, recovery time and propagation delay
74AHC_AHCT273_3
Product data sheet
10 of 18
74AHC273; 74AHCT273
Nexperia
VI
VM
CP input
GND
tsu
tsu
th
th
VI
VM
Dn input
GND
VOH
VM
Qn output
VOL
mna202
The shaded areas indicate when the input is permitted to change for predictable output performance.
Fig 9.
Data set-up and hold times
Table 8.
Measurement points
Type
Input
Output
VM
VM
74AHC273
0.5 × VCC
0.5 × VCC
74AHCT273
1.5 V
0.5 × VCC
74AHC_AHCT273_3
Product data sheet
11 of 18
74AHC273; 74AHCT273
Nexperia
VI
negative
pulse
tW
90 %
VM
VM
10 %
GND
tr
tf
tr
VI
positive
pulse
GND
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
VO
DUT
RT
CL
001aah768
Test data is given in Table 9.
Definitions test circuit:
RT = termination resistance should be equal to output impedance Zo of the pulse generator.
CL = load capacitance including jig and probe capacitance.
Fig 10. Load circuitry for measuring switching times
Table 9.
Test data
Type
Input
Load
Test
VI
tr, tf
CL
74AHC273
VCC
≤ 3.0 ns
15 pF, 50 pF
tPLH, tPHL
74AHCT273
3.0 V
≤ 3.0 ns
15 pF, 50 pF
tPLH, tPHL
74AHC_AHCT273_3
Product data sheet
12 of 18
74AHC273; 74AHCT273
Nexperia
12. Package outline
SO20: plastic small outline package; 20 leads; body width 7.5 mm
SOT163-1
D
E
A
X
c
HE
y
v M A
Z
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
L
10
1
e
detail X
w M
bp
10 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
mm
2.65
0.3
0.1
2.45
2.25
0.25
0.49
0.36
0.32
0.23
13.0
12.6
7.6
7.4
1.27
10.65
10.00
1.4
1.1
0.4
1.1
1.0
0.25
0.25
0.1
0.01
0.019 0.013
0.014 0.009
0.51
0.49
0.30
0.29
0.05
0.419
0.043
0.055
0.394
0.016
inches
0.1
0.012 0.096
0.004 0.089
0.043
0.039
0.01
0.01
Z
(1)
0.9
0.4
0.035
0.004
0.016
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT163-1
075E04
MS-013
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig 11. Package outline SOT163-1 (SO20)
74AHC_AHCT273_3
Product data sheet
13 of 18
74AHC273; 74AHCT273
Nexperia
TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm
SOT360-1
E
D
A
X
c
HE
y
v M A
Z
11
Q
A2
(A 3)
A1
pin 1 index
A
θ
Lp
L
1
10
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
6.6
6.4
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.5
0.2
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT360-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Fig 12. Package outline SOT360-1 (TSSOP20)
74AHC_AHCT273_3
Product data sheet
14 of 18
74AHC273; 74AHCT273
Nexperia
DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT764-1
20 terminals; body 2.5 x 4.5 x 0.85 mm
A
B
D
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
2
9
y
y1 C
v M C A B
w M C
b
L
1
10
Eh
e
19
12
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
1
0.05
0.00
0.30
0.18
mm
c
D (1)
Dh
E (1)
Eh
0.2
4.6
4.4
3.15
2.85
2.6
2.4
1.15
0.85
e
0.5
e1
L
v
w
y
y1
3.5
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT764-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig 13. Package outline SOT764-1 (DHVQFN20)
74AHC_AHCT273_3
Product data sheet
15 of 18
74AHC273; 74AHCT273
Nexperia
13. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
LSTTL
Low-power Schottky Transistor-Transistor Logic
MM
Machine Model
MOS
14. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AHC_AHCT273_3
20080513
Product data sheet
74AHC_AHCT273_2
Modifications:
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Table 6: the conditions for input leakage current have been changed.
74AHC_AHCT273_2
20030721
Product specification
74AHC_AHCT273_1
74AHC_AHCT273_1
19990901
74AHC_AHCT273_3
Product data sheet
16 of 18
74AHC273; 74AHCT273
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
15.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74AHC_AHCT273_3
Product data sheet
17 of 18
Nexperia
74AHC273; 74AHCT273
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 4
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4
Functional description . . . . . . . . . . . . . . . . . . . 5
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5
Recommended operating conditions. . . . . . . . 6
Static characteristics. . . . . . . . . . . . . . . . . . . . . 6
Dynamic characteristics . . . . . . . . . . . . . . . . . . 8
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 16
Legal information. . . . . . . . . . . . . . . . . . . . . . . 17
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 17
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Contact information. . . . . . . . . . . . . . . . . . . . . 17
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18
Date of release: 13 May 2008
很抱歉,暂时无法提供与“74AHC273BQ,115”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4.352741+0.54606
- 10+3.0257410+0.37958
- 25+2.6997625+0.33869
- 100+2.34381100+0.29403
- 250+2.17404250+0.27274
- 500+2.07165500+0.25989
- 1000+2.000261000+0.25094
- 国内价格 香港价格
- 3000+1.662623000+0.20858
