74HC374; 74HCT374
Octal D-type flip-flop; positive edge-trigger; 3-state
Rev. 4 — 2 March 2021
Product data sheet
1. General description
The 74HC374; 74HCT374 is an octal positive-edge triggered D-type flip-flop with 3-state outputs.
The device features a clock (CP) and output enable (OE) inputs. The flip-flops will store the state
of their individual D-inputs that meet the set-up and hold time requirements on the LOW-to-HIGH
clock (CP) transition. A HIGH on OE causes the outputs to assume a high-impedance OFF-state.
Operation of the OE input does not affect the state of the flip-flops. Inputs also include clamp
diodes, this enables the use of current limiting resistors to interface inputs to voltages in excess of
VCC.
2. Features and benefits
Wide supply voltage range from 2.0 to 6.0 V
CMOS low power dissipation
High noise immunity
Input levels:
• For 74HC374: CMOS level
• For 74HCT374: TTL level
Octal bus interface
Non-inverting 3-state outputs
8-bit positive, edge-triggered register
Common 3-state output enable input
Independent register and 3-state buffer operation
Complies with JEDEC standards
• JESD8C (2.7 V to 3.6 V)
• JESD7A (2.0 V to 6.0 V)
Latch-up performance exceeds 100 mA per JESD 78 Class II Level B
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V
Specified from -40 °C to +85 °C and -40 °C to +125 °C
3. Ordering information
Table 1. Ordering information
Type number
Package
74HC374D
Temperature range
Name
Description
Version
−40 °C to +125 °C
SO20
plastic small outline package; 20 leads;
body width 7.5 mm
SOT163-1
−40 °C to +125 °C
SSOP20
plastic shrink small outline package; 20 leads;
body width 5.3 mm
SOT339-1
−40 °C to +125 °C
TSSOP20
plastic thin shrink small outline package; 20 leads;
body width 4.4 mm
SOT360-1
74HCT374D
74HC374DB
74HCT374DB
74HC374PW
74HCT374PW
74HC374; 74HCT374
Nexperia
4. Functional diagram
1
EN
11
11
3
4
7
8
13
14
17
18
3
CP
D0
Q0
D1
Q1
D2
Q2
D3
Q3
D4
Q4
D5
Q5
D6
Q6
D7
Q7
OE
1
Fig. 1.
2
5
D0
Q0
2
4
D1
Q1
5
7
D2
Q2
6
5
8
D3
Q3
9
13
D4
14
D5
17
D6
Q6 16
18
D7
Q7 19
6
7
6
9
8
9
12
13
12
14
15
17
16
11 CP
18
19
1 OE
15
16
19
mna891
D0
3
2
1D
4
Fig. 2.
D1
Q
Q
Q
Q
D5
D
CP
FF3
Q4 12
Q5 15
Functional diagram
D4
D
CP
FF2
Fig. 3.
D3
D
CP
FF1
3-STATE
OUTPUTS
mna892
IEC logic symbol
D2
D
CP
FF1
to
FF8
mna196
Logic symbol
D
C1
Q
D
CP
FF4
D6
Q
D
CP
FF5
D7
Q
D
CP
FF6
Q
CP
FF7
FF8
CP
OE
Q0
Q1
Q2
Q3
Q4
Q5
Q6
Q7
mna893
Fig. 4.
Logic diagram
74HC_HCT374
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 16
74HC374; 74HCT374
Nexperia
5. Pinning information
5.1. Pinning
74HC374
74HCT374
74HC374
74HCT374
OE
1
1
20 VCC
20 VCC
OE
Q0
2
19 Q7
Q0
2
19 Q7
D0
3
18 D7
D0
3
18 D7
D1
4
17 D6
D1
4
17 D6
Q1
5
16 Q6
Q1
5
16 Q6
Q2
6
15 Q5
Q2
6
15 Q5
D2
7
14 D5
D2
7
14 D5
D3
8
13 D4
D3
8
13 D4
Q3
9
12 Q4
Q3
9
12 Q4
GND 10
11 CP
GND 10
11 CP
aaa-028159
aaa-028158
Fig. 5.
Fig. 6.
Pin configuration SOT163-1 (SO20)
Pin configuration SOT339-1 (SSOP20) and
SOT360-1 (TSSOP20)
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
D0, D1, D2, D3, D4, D5, D6, D7
3, 4, 7, 8, 13, 14, 17, 18
data inputs
Q0, Q1, Q2, Q3, Q4, Q5, Q6, Q7
2, 5, 6, 9, 12, 15, 16, 19
data outputs
OE
1
output enable input (active LOW)
CP
11
clock pulse input (active rising edge)
GND
10
ground (0 V)
VCC
supply voltage
6. Functional description
Table 3. Function table
H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the LOW-to-HIGH clock transition;
L = LOW voltage level; l = LOW voltage level one set-up time prior to the LOW-to-HIGH clock transition;
Z = high-impedance OFF-state; ↑ = LOW-to-HIGH clock transition.
Operating mode
Load and read register
Load register and disable outputs
74HC_HCT374
Product data sheet
Input
Output
OE
CP
Dn
Internal
flip-flops
L
l
L
L
L
h
H
H
H
l
L
Z
H
h
H
Z
Qn
3 / 16
74HC374; 74HCT374
Nexperia
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
Unit
-0.5
+7
V
VCC
supply voltage
IIK
input clamping current
VI < -0.5 V or VI > VCC + 0.5 V
±20
mA
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
±20
mA
IO
output current
-0.5 V < VO < VCC + 0.5 V
±35
mA
ICC
supply current
70
mA
IGND
ground current
-70
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
[1]
[1]
For SOT163-1 (SO20) package: Ptot derates linearly with 12.3 mW/K above 109 °C.
For SOT339-1 (SSOP20) package: Ptot derates linearly with 10.0 mW/K above 100 °C.
For SOT360-1 (TSSOP20) package: Ptot derates linearly with 10.0 mW/K above 100 °C.
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
74HC374
74HCT374
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Δt/ΔV
input transition rise and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
-40
+25
+125
-40
+25
+125
Tamb
ambient temperature
74HC_HCT374
Product data sheet
°C
4 / 16
74HC374; 74HCT374
Nexperia
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Tamb (°C)
25
Unit
-40 to +85
-40 to +125
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
74HC374
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output voltage
LOW-level
output voltage
VI = VIH or VIL
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = -6.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = -7.8 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
IO = 20 μA; VCC = 2.0 V
0.1
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
0.1
V
IO = 6.0 mA; VCC = 4.5 V
0.15
0.26
0.33
0.4
V
IO = 7.8 mA; VCC = 6.0 V
0.16
0.26
0.33
0.4
V
VI = VIH or VIL
II
input leakage
current
VI = VCC or GND; VCC = 6.0 V
±0.1
±1.0
±1.0
μA
IOZ
OFF-state
output current
VI = VIH or VIL; VCC = 6.0 V;
VO = VCC or GND
±0.5
±5.0
±10
μA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
8.0
80
160
μA
CI
input
capacitance
3.5
pF
74HC_HCT374
Product data sheet
5 / 16
74HC374; 74HCT374
Nexperia
Symbol Parameter
Conditions
Tamb (°C)
25
Unit
-40 to +85
-40 to +125
Min
Typ
Max
Min
Max
Min
Max
74HCT374
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
0.8
V
VOH
HIGH-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
IO = -20 μA
4.4
4.5
4.4
4.4
V
IO = -6 mA
3.98
4.32
3.84
3.7
V
VOL
LOW-level
output voltage
IO = 20 μA
0.1
0.1
V
IO = 6.0 mA
0.16
0.26
0.33
0.4
V
II
input leakage
current
VI = VCC or GND; VCC = 5.5 V
±0.1
±1.0
±1.0
μA
IOZ
OFF-state
output current
VI = VIH or VIL; VCC = 5.5 V;
VO = VCC or GND
±0.5
±5.0
±10
μA
ICC
supply current
VI = VCC or GND; VCC = 5.5 V;
IO = 0 A
8.0
80
160
μA
ΔICC
additional
supply current
per input pin; VI = VCC - 2.1 V;
other inputs at VCC or GND;
VCC = 4.5 V to 5.5 V; IO = 0 A
OE input
125
450
563
613
μA
CP input
90
324
405
441
μA
Dn inputs
35
126
158
172
μA
3.5
pF
CI
input
capacitance
74HC_HCT374
Product data sheet
6 / 16
74HC374; 74HCT374
Nexperia
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 9.
Symbol Parameter
Conditions
Tamb (°C)
25
Unit
-40 to +85
-40 to +125
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
50
165
205
250
ns
VCC = 4.5 V
18
33
41
50
ns
VCC = 5.0 V; CL = 15 pF
15
ns
14
28
35
43
ns
VCC = 2.0 V
41
150
190
225
ns
VCC = 4.5 V
15
30
38
45
ns
VCC = 6.0 V
12
26
33
38
ns
VCC = 2.0 V
50
150
190
225
ns
VCC = 4.5 V
18
30
38
45
ns
VCC = 6.0 V
14
26
33
38
ns
VCC = 2.0 V
14
60
75
90
ns
VCC = 4.5 V
5
12
15
18
ns
VCC = 6.0 V
4
10
13
15
ns
VCC = 2.0 V
80
19
100
120
ns
VCC = 4.5 V
16
7
ns
VCC = 6.0 V
14
6
17
ns
VCC = 2.0 V
60
14
75
90
ns
VCC = 4.5 V
12
5
15
18
ns
VCC = 6.0 V
10
4
13
15
ns
VCC = 2.0 V
5
-6
5
5
ns
VCC = 4.5 V
5
-2
5
5
ns
VCC = 6.0 V
5
-2
5
5
ns
VCC = 2.0 V
6.0
23
4.8
4.0
MHz
VCC = 4.5 V
30
70
24
MHz
77
MHz
35
83
28
24
MHz
17
pF
74HC374
tpd
propagation
delay
CP to Qn; see Fig. 7
[1]
VCC = 6.0 V
ten
tdis
tt
tW
tsu
th
fmax
enable time
disable time
OE to Qn; see Fig. 8
[2]
[3]
transition time Qn; see Fig. 7
pulse width
set-up time
hold time
maximum
frequency
[4]
CP; HIGH or LOW; see Fig. 7
Dn to CP; see Fig. 7
CP; see Fig. 7
VCC = 5 V; CL= 15 pF
VCC = 6.0 V
CPD
power
dissipation
capacitance
74HC_HCT374
Product data sheet
per flip-flop; VI = GND to VCC
[5]
7 / 16
74HC374; 74HCT374
Nexperia
Symbol Parameter
Conditions
Tamb (°C)
25
Unit
-40 to +85
-40 to +125
Min
Typ
Max
Min
Max
Min
Max
VCC = 4.5 V
16
32
40
48
ns
13
ns
74HCT374
tpd
propagation
delay
[1]
ten
enable time
OE to Qn; VCC = 4.5 V;
see Fig. 8
[2]
16
30
38
45
ns
tdis
disable time
see Fig. 8
[3]
18
28
35
42
ns
tt
transition time Qn; VCC = 4.5 V; see Fig. 7
[4]
5
12
15
18
ns
tW
pulse width
CP; HIGH or LOW;
19
11
24
29
ns
tsu
set-up time
Dn to CP; VCC = 4.5 V;
see Fig. 7
12
7
15
18
ns
th
hold time
see Fig. 7
5
-3
5
5
ns
fmax
maximum
frequency
CP; VCC = 4.5 V; see Fig. 7
26
44
21
17
MHz
48
MHz
power
dissipation
capacitance
per flip-flop;
VI = GND to VCC - 1.5 V
17
pF
CPD
[1]
[2]
[3]
[4]
[5]
CP; VCC = 5 V; CL= 15 pF
[5]
tpd is the same as tPHL and tPLH.
ten is the same as tPZH and tPZL.
tdis is the same as tPHZ and tPLZ.
tt is the same as tTHL and tTLH.
CPD is used to determine the dynamic power dissipation (PD in μW):
2
2
PD = CPD × VCC × fi × N + ∑ (CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
∑ (CL × VCC × fo) = sum of outputs.
74HC_HCT374
Product data sheet
8 / 16
74HC374; 74HCT374
Nexperia
10.1. Waveforms and test circuit
VI
VM
Dn input
GND
th
th
tsu
1/fmax
VI
CP input
tsu
VM
GND
tW
tPHL
VOH
tPLH
90 %
90 %
VM
Qn output
10 %
VOL
10 %
tTHL
tTLH
aaa-028160
Measurement points are given in Table 8.
The shaded areas indicate when the input is permitted to change for predictable output performance.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 7.
Clock input (CP) to output (Qn) propagation delay, clock pulse width, data (Dn) to clock (CP) set-up and
hold times, output transition times (Qn) and maximum clock frequency
VI
OE input
VM
GND
tPLZ
output
LOW-to-OFF
OFF-to-LOW
tPZL
VCC
VM
VX
VOL
tPHZ
VOH
output
HIGH-to-OFF
OFF-to-HIGH
tPZH
VY
VM
GND
outputs
enabled
outputs
enabled
outputs
disabled
mna644
Fig. 8.
3-state enable and disable times
Table 8. Measurement points
Type
Input
Output
VI
VM
VM
VX
VY
74HC374
GND to VCC
0.5 x VCC
0.5 x VCC
0.1 x VCC
0.9 x VCC
74HCT374
GND to 3 V
1.3 V
1.3 V
0.1 x VCC
0.9 x VCC
74HC_HCT374
Product data sheet
9 / 16
74HC374; 74HCT374
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
DUT
VCC
VO
RT
RL
S1
open
CL
001aad983
Test data is given in Table 9.
Definitions:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator
CL = Load capacitance including jig and probe capacitance
RL = Load resistance.
S1 = Test selection switch
Fig. 9.
Test circuit for measuring switching times
Table 9. Test data
Type
Input
VI
Load
tr, tf
S1 position
CL
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
74HC374
GND to VCC 6 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74HCT374
GND to 3 V
15 pF, 50 pF
1 kΩ
open
GND
VCC
74HC_HCT374
Product data sheet
6 ns
10 / 16
74HC374; 74HCT374
Nexperia
11. Package outline
SO20: plastic small outline package; 20 leads; body width 7.5 mm
SOT163-1
D
E
A
X
c
y
HE
v M A
Z
Q
A2
A
(A 3 )
A1
pin 1 index
θ
Lp
L
1
10
e
detail X
w M
bp
10 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
mm
2.65
0.3
0.1
2.45
2.25
0.25
0.49
0.36
0.32
0.23
13.0
12.6
7.6
7.4
1.27
10.65
10.00
1.4
1.1
0.4
1.1
1.0
0.25
0.25
0.1
0.9
0.4
inches
0.1
0.012 0.096
0.004 0.089
0.01
0.019 0.013
0.014 0.009
0.51
0.49
0.30
0.29
0.05
0.419
0.043
0.055
0.394
0.016
0.043
0.039
0.01
0.01
0.004
0.035
0.016
Z
(1)
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT163-1
075E04
MS-013
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 10. Package outline SOT163-1 (SO20)
74HC_HCT374
Product data sheet
11 / 16
74HC374; 74HCT374
Nexperia
SSOP20: plastic shrink small outline package; 20 leads; body width 5.3 mm
D
SOT339-1
E
A
X
c
HE
y
v M A
Z
Q
A2
pin 1 index
A
(A 3)
A1
θ
Lp
L
1
10
bp
e
detail X
w M
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
2
0.21
0.05
1.80
1.65
0.25
0.38
0.25
0.20
0.09
7.4
7.0
5.4
5.2
0.65
7.9
7.6
1.25
1.03
0.63
0.9
0.7
0.2
0.13
0.1
0.9
0.5
8o
0o
Note
1. Plastic or metal protrusions of 0.2 mm maximum per side are not included.
OUTLINE
VERSION
SOT339-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-150
Fig. 11. Package outline SOT339-1 (SSOP20)
74HC_HCT374
Product data sheet
12 / 16
74HC374; 74HCT374
Nexperia
TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm
D
SOT360-1
E
A
X
c
HE
y
v M A
Z
11
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
10
detail X
w M
bp
e
5 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
6.6
6.4
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.5
0.2
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT360-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Fig. 12. Package outline SOT360-1 (TSSOP20)
74HC_HCT374
Product data sheet
13 / 16
74HC374; 74HCT374
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT374 v.4
20210302
Product data sheet
74HC_HCT374 v.3
Modifications:
74HC_HCT374 v.3
20180220
Modifications:
74HC_HCT374 v.2
74HC_HCT374
Product data sheet
Section 2 updated.
Section 7: Derating values for Ptot total power dissipation updated.
Product data sheet
74HC_HCT374 v.2
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
19901201
Product specification
14 / 16
74HC374; 74HCT374
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74HC_HCT374
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
15 / 16
74HC374; 74HCT374
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................3
5.1. Pinning.........................................................................3
5.2. Pin description............................................................. 3
6. Functional description................................................. 3
7. Limiting values............................................................. 4
8. Recommended operating conditions..........................4
9. Static characteristics....................................................5
10. Dynamic characteristics............................................ 7
10.1. Waveforms and test circuit........................................ 9
11. Package outline........................................................ 11
12. Abbreviations............................................................ 14
13. Revision history........................................................14
14. Legal information......................................................15
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 2 March 2021
74HC_HCT374
Product data sheet
16 / 16
