HEF4013BT-Q100J
HEF4013BT-Q100J
    NEXPERIA(安世)
    SOIC-14
    双D型触发器 SOIC14
HEF4013BT-Q100J 数据手册
HEF4013B-Q100 Dual D-type flip-flop Rev. 3 — 15 December 2015 Product data sheet 1. General description The HEF4013B-Q100 is a dual D-type flip-flop that features independent set-direct input (SD), clear-direct input (CD), clock input (CP) and outputs (Q, Q). Data is accepted when CP is LOW and is transferred to the output on the positive-going edge of the clock. The active HIGH asynchronous CD and SD inputs are independent and override the D or CP inputs. The outputs are buffered for best system performance. The Schmitt trigger action of the clock inputs, makes the circuit highly tolerant of slower clock rise and fall times. It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually ground). Connect unused inputs to VDD, VSS, or another input. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Tolerant of slow clock rise and fall times  Fully static operation  5 V, 10 V, and 15 V parametric ratings  Standardized symmetrical output characteristics  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Complies with JEDEC standard JESD 13-B 3. Applications  Counters and dividers  Registers  Toggle flip-flops HEF4013B-Q100 Nexperia Dual D-type flip-flop 4. Ordering information Table 1. Ordering information All types operate from 40 C to +125 C Type number HEF4013BT-Q100 Package Name Description Version SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 HEF4013BTT-Q100 TSSOP14 5. Functional diagram 6' '   6' ' 4  4 )) &3  4 &3  4 &' &' 6' '    6' ' 4  4 )) &3  4 &3  4 &' &'  DDJ Fig 1. Functional diagram HEF4013B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2015 © Nexperia B.V. 2017. All rights reserved 2 of 17 HEF4013B-Q100 Nexperia Dual D-type flip-flop &3 & 4 & & & & & & & ' 4 & & 6' &' DDJ Fig 2. Logic diagram (one flip-flop) HEF4013B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2015 © Nexperia B.V. 2017. All rights reserved 3 of 17 HEF4013B-Q100 Nexperia Dual D-type flip-flop 6. Pinning information 6.1 Pinning +()%4 4   9'' 4   4 &3   4 &'   &3 '   &' 6'   ' 966   6' DDD Fig 3. Pin configuration 6.2 Pin description Table 2. Pin description Symbol Pin Description 1Q, 2Q 1, 13 true output 1Q, 2Q 2, 12 complement output 1CP, 2CP 3, 11 clock input (LOW to HIGH edge-triggered) 1CD, 2CD 4, 10 asynchronous clear-direct input (active HIGH) 1D, 2D 5, 9 data input 1SD, 2SD 6, 8 asynchronous set-direct input (active HIGH) VSS 7 ground (0 V) VDD 14 supply voltage 7. Functional description Table 3. Function table[1] Control Input Output nSD nCD nCP nD nQ nQ H L X X H L L H X X L H H H X X H H L L  L L H L L  H H L [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; = LOW-to-HIGH clock transition. HEF4013B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2015 © Nexperia B.V. 2017. All rights reserved 4 of 17 HEF4013B-Q100 Nexperia Dual D-type flip-flop 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to VSS = 0 V (ground). Symbol Parameter VDD supply voltage IIK input clamping current VI input voltage IOK output clamping current II/O input/output current IDD supply current Tstg storage temperature Tamb ambient temperature Ptot total power dissipation P power dissipation Conditions VI < 0.5 V or VI > VDD + 0.5 V VO < 0.5 V or VO > VDD + 0.5 V Min Max Unit 0.5 +18 V - 10 0.5 VDD + 0.5 - 10 mA - 10 mA - 50 mA 65 +150 C 40 +125 C mA V Tamb = 40 C to +125 C SO14 [1] - 500 mW TSSOP14 [2] - 500 mW - 100 mW per output [1] For SO14 packages: above Tamb = 70 C, Ptot derates linearly with 8 mW/K. [2] For TSSOP14 packages: above Tamb = 60 C, Ptot derates linearly with 5.5 mW/K. 9. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Min Max VDD supply voltage 3 15 V VI input voltage 0 VDD V Tamb ambient temperature 40 +125 C t/V input transition rise and fall rate VDD = 5 V - 3.75 s/V VDD = 10 V - 0.5 s/V VDD = 15 V - 0.08 s/V HEF4013B_Q100 Product data sheet Conditions All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2015 © Unit Nexperia B.V. 2017. All rights reserved 5 of 17 HEF4013B-Q100 Nexperia Dual D-type flip-flop 10. Static characteristics Table 6. Static characteristics VSS = 0 V; VI = VSS or VDD; unless otherwise specified. Symbol Parameter VIH VIL VOH VOL IOH IOL HIGH-level input voltage LOW-level input voltage IO < 1 A IO < 1 A HIGH-level output voltage IO < 1 A LOW-level output voltage IO < 1 A HIGH-level output current LOW-level output current II input leakage current IDD supply current CI Conditions input capacitance HEF4013B_Q100 Product data sheet VDD Tamb = 40 C Tamb = +25 C Tamb = +85 C Tamb = +125 C Unit Min Max Min Max Min Max Min Max 5V 3.5 - 3.5 - 3.5 - 3.5 - V 10 V 7.0 - 7.0 - 7.0 - 7.0 - V 15 V 11.0 - 11.0 - 11.0 - 11.0 - V 5V - 1.5 - 1.5 - 1.5 - 1.5 V 10 V - 3.0 - 3.0 - 3.0 - 3.0 V 15 V - 4.0 - 4.0 - 4.0 - 4.0 V 5V 4.95 - 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - 14.95 - V 5V - 0.05 - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 - 0.05 V 15 V - 0.05 - 0.05 - 0.05 - 0.05 V VO = 2.5 V 5V - 1.7 - 1.4 - 1.1 - 1.1 mA VO = 4.6 V 5V - 0.64 - 0.5 - 0.36 - 0.36 mA VO = 9.5 V 10 V - 1.6 - 1.3 - 0.9 - 0.9 mA VO = 13.5 V 15 V - 4.2 - 3.4 - 2.4 - 2.4 mA VO = 0.4 V 5V 0.64 - 0.5 - 0.36 - 0.36 - mA VO = 0.5 V 10 V 1.6 - 1.3 - 0.9 - 0.9 - mA VO = 1.5 V 15 V 4.2 - 3.4 - 2.4 - 2.4 - mA 15 V - 0.1 - 0.1 - 1.0 - 1.0 A 5V - 1.0 - 1.0 - 30 - 30 A 10 V - 2.0 - 2.0 - 60 - 60 A 15 V - 4.0 - 4.0 - 120 - 120 A - - - - 7.5 - - - - pF all valid input combinations; IO = 0 A All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2015 © Nexperia B.V. 2017. All rights reserved 6 of 17 HEF4013B-Q100 Nexperia Dual D-type flip-flop 11. Dynamic characteristics Table 7. Dynamic characteristics Tamb = 25 C; unless otherwise specified. For test circuit see Figure 6. Symbol Parameter tPHL HIGH to LOW propagation delay Conditions VDD nCP to nQ, nQ; see Figure 4 Min Typ Max Unit 83 + 0.55  CL - 110 220 ns 10 V 34 + 0.23  CL - 45 90 ns 15 V 22 + 0.16  CL - 30 60 ns 73 + 0.55  CL - 100 200 ns 29 + 0.23  CL - 40 80 ns 22 + 0.16  CL - 30 60 ns 73 + 0.55  CL - 100 200 ns 29 + 0.23  CL - 40 80 ns 22 + 0.16  CL - 30 60 ns 5V 5V nSD to nQ Extrapolation formula [1] [1] 10 V 15 V nCD to nQ 5V [1] 10 V 15 V tPLH LOW to HIGH propagation delay nCP to nQ, nQ; see Figure 4 68 + 0.55  CL - 95 190 ns 29 + 0.23  CL - 40 80 ns 22 + 0.16  CL - 30 60 ns 48 + 0.55  CL - 75 150 ns 10 V 24 + 0.23  CL - 35 70 ns 15 V 17 + 0.16  CL - 25 50 ns 33 + 0.55  CL - 60 120 ns 19 + 0.23  CL - 30 60 ns 12 + 0.16  CL - 20 40 ns 10 + 1.00  CL - 60 120 ns 10 V 9 + 0.42  CL - 30 60 ns 15 V 6 + 0.28  CL - 20 40 ns 5V [1] 10 V 15 V nSD to nQ 5V 5V nCD to nQ [1] [1] 10 V 15 V tt tsu th tW transition time set-up time hold time pulse width see Figure 4 5V nD to nCP; see Figure 4 nD to nCP; see Figure 4 nCP input LOW; see Figure 4 nSD input HIGH; see Figure 5 nCD input HIGH; see Figure 5 HEF4013B_Q100 Product data sheet [1] 5V 40 20 - ns 10 V 25 10 - ns 15 V 15 5 - ns 5V 20 0 - ns 10 V 20 0 - ns 15 V 15 0 - ns 5V 60 30 - ns 10 V 30 15 - ns 15 V 20 10 - ns 5V 50 25 - ns 10 V 24 12 - ns 15 V 20 10 - ns 5V 50 25 - ns 10 V 24 12 - ns 15 V 20 10 - ns All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2015 © Nexperia B.V. 2017. All rights reserved 7 of 17 HEF4013B-Q100 Nexperia Dual D-type flip-flop Table 7. Dynamic characteristics …continued Tamb = 25 C; unless otherwise specified. For test circuit see Figure 6. Symbol Parameter Conditions VDD trec nSD input; see Figure 5 recovery time nCD input; see Figure 5 fclk(max) [1] maximum clock frequency see Figure 4 Extrapolation formula Min Typ Max Unit 5V +15 5 - ns 10 V 15 0 - ns 15 V 15 0 - ns 5V 40 25 - ns 10 V 25 10 - ns 15 V 25 10 - ns 5V 7 14 - MHz 10 V 14 28 - MHz 15 V 20 40 - MHz Typical values of the propagation delays and output transition times can be calculated with the extrapolation formulas. CL is given in pF. Table 8. Dynamic power dissipation VSS = 0 V; tr = tf  20 ns; Tamb = 25 C. Symbol Parameter PD dynamic power dissipation VDD Typical formula Where 5V PD = 850  fi + (fo  CL)  VDD W 2 fi = input frequency in MHz; 10 V PD = 3600  fi + (fo  CL)  VDD2 W fo = output frequency in MHz; 15 V PD = 9000  fi + (fo  CL)  VDD2 W CL = output load capacitance in pF; (fo  CL) = sum of the outputs; VDD = supply voltage in V. HEF4013B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2015 © Nexperia B.V. 2017. All rights reserved 8 of 17 HEF4013B-Q100 Nexperia Dual D-type flip-flop 12. Waveforms W: IFON PD[  9, 90 LQSXWQ&3 9 WVX WVX WK WI WU WK 9, 90 LQSXWQ' 9 W3/+ W3+/ WW 92+ WW 9< 90 RXWSXWQ4 9; 92/ DDK Set-up and hold times are shown as positive values but may be specified as negative values. The shaded areas indicate when the input is permitted to change for predictable output performance. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Measurement points are given in Table 9. Fig 4. Set-up time, hold time, minimum clock pulse width, propagation delays and transition times 9, 90 LQSXWQ&3 9 WUHF 9, LQSXWQ6' 9 WUHF 90 W: 9, 90 LQSXWQ&' 9 W: 92+ RXWSXWQ4 DDJ 92/ Recovery times are shown as positive values but may be specified as negative values. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Measurement points are given in Table 9. Fig 5. nSD, nCD recovery time and pulse width Table 9. Measurement points Supply voltage Input Output VDD VM VM VX VY 5 V to 15 V 0.5VDD 0.5VDD 0.1VDD 0.9VDD HEF4013B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2015 © Nexperia B.V. 2017. All rights reserved 9 of 17 HEF4013B-Q100 Nexperia Dual D-type flip-flop 9'' * 9, 92 '87 &/ 57 DDJ Test and measurement data is given in Table 10; Definitions test circuit: DUT = Device Under Test. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. Fig 6. Test circuit for measuring switching times Table 10. Test data Supply voltage Input VDD VI tr, tf CL 5 V to 15 V VSS or VDD  20 ns 50 pF HEF4013B_Q100 Product data sheet Load All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2015 © Nexperia B.V. 2017. All rights reserved 10 of 17 HEF4013B-Q100 Nexperia Dual D-type flip-flop 13. Application information ' 4 ' ))  4 &3 FORFN Fig 7. DDJ N-stage shift register 4 ' &3 FORFN 4 ' ))  ))  4 &3 4 ' 4 )) Q 4 &3 4 7W\SHIOLSIORS Fig 8. 4 )) Q 4 &3 4 ' ))  4 &3 4 ' DDJ Binary ripple up-counter; divide-by-2n 4 ' ))  &3 4 ' ))  4 &3 4 ' 4 )) Q 4 &3 4 FORFN DDJ Fig 9. Modified ring counter; divide-by-(n + 1) HEF4013B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2015 © Nexperia B.V. 2017. All rights reserved 11 of 17 HEF4013B-Q100 Nexperia Dual D-type flip-flop 14. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV        ș R R  1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 10. Package outline SOT108-1 (SO14) HEF4013B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2015 © Nexperia B.V. 2017. All rights reserved 12 of 17 HEF4013B-Q100 Nexperia Dual D-type flip-flop 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ SLQLQGH[ $   $ $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWHV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 11. Package outline SOT402-1 (TSSOP14) HEF4013B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2015 © Nexperia B.V. 2017. All rights reserved 13 of 17 HEF4013B-Q100 Nexperia Dual D-type flip-flop 15. Abbreviations Table 11. Abbreviations Acronym Description HBM Human Body Model ESD ElectroStatic Discharge MM Machine Model MIL Military 16. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes HEF4013B_Q100 v.3 20151215 Product data sheet - HEF4013B_Q100 v.2 Modifications: HEF4013B_Q100 v.2 Modifications: HEF4013B_Q100 v.1 HEF4013B_Q100 Product data sheet • Type number HEF4013BP-Q100 (SOT27-1) removed. 20130220 • Product data sheet - HEF4013B_Q100 v.1 - - HEF4013BP-Q100 (DIP14) added. 20120807 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2015 © Nexperia B.V. 2017. All rights reserved 14 of 17 HEF4013B-Q100 Nexperia Dual D-type flip-flop 17. Legal information 17.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 17.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 17.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. HEF4013B_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2015 © Nexperia B.V. 2017. All rights reserved 15 of 17 HEF4013B-Q100 Nexperia Dual D-type flip-flop No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 17.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 18. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com HEF4013B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 December 2015 © Nexperia B.V. 2017. All rights reserved 16 of 17 Nexperia HEF4013B-Q100 Dual D-type flip-flop 19. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 12 13 14 15 16 17 17.1 17.2 17.3 17.4 18 19 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Application information. . . . . . . . . . . . . . . . . . 11 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 12 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14 Legal information. . . . . . . . . . . . . . . . . . . . . . . 15 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Contact information. . . . . . . . . . . . . . . . . . . . . 16 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 15 December 2015
HEF4013BT-Q100J 价格&库存
很抱歉,暂时无法提供与“HEF4013BT-Q100J”相匹配的价格&库存,您可以联系我们找货
HEF4013BT-Q100J
    HEF4013BT-Q100J
    • 1+3.177731+0.41231
    • 10+2.2041510+0.28599
    • 25+1.9578225+0.25403
    • 100+1.69049100+0.21934
    • 250+1.56259250+0.20275
    • 500+1.48551500+0.19275
    • 1000+1.421941000+0.18450
    HEF4013BT-Q100J
      • 5+2.20860
      • 50+1.72070
      • 150+1.51160
      • 500+1.25080
      • 2500+1.13470
      • 5000+1.06480
      库存:7340
