74LVC1G175GV,125
74LVC1G175GV,125
    NEXPERIA(安世)
    TSOP6_3.1X1.7MM
    带复位的单D型触发器;正边缘触发器 TSOP6_3.1X1.7MM
74LVC1G175GV,125 数据手册
74LVC1G175 Single D-type flip-flop with reset; positive-edge trigger Rev. 8 — 3 October 2019 Product data sheet 1. General description The 74LVC1G175 is a low-power, low-voltage single positive edge triggered D-type flip-flop with individual data (D) input, clock (CP) input, master reset (MR) input, and Q output. The master reset (MR) is an asynchronous active LOW input and operates independently of the clock input. Information on the data input is transferred to the Q output on the LOW-to-HIGH transition of the clock pulse. The D input must be stable one set-up time prior to the LOW-to-HIGH clock transition for predictable operation. The inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of this device in a mixed 3.3 V and 5 V environment. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. Schmitt trigger action at all inputs makes the circuit highly tolerant of slower input rise and fall times. 2. Features and benefits • • • • • • • • • • • • Wide supply voltage range from 1.65 V to 5.5 V 5 V tolerant inputs for interfacing with 5 V logic High noise immunity Complies with JEDEC standard: • JESD8-7 (1.65 V to 1.95 V) • JESD8-5 (2.3 V to 2.7 V) • JESD8B/JESD36 (2.7 V to 3.6 V). ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V. ±24 mA output drive (VCC = 3.0 V) CMOS low power consumption Latch-up performance exceeds 250 mA Direct interface with TTL levels Inputs accept voltages up to 5 V Multiple package options Specified from -40 °C to +85 °C and -40 °C to +125 °C. 74LVC1G175 Nexperia Single D-type flip-flop with reset; positive-edge trigger 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1G175GW -40 °C to +125 °C SC-88 plastic surface-mounted package; 6 leads SOT363 74LVC1G175GV -40 °C to +125 °C SC-74 plastic surface-mounted package (SC-74; TSOP6); 6 leads SOT457 74LVC1G175GM -40 °C to +125 °C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1 × 1.45 × 0.5 mm SOT886 74LVC1G175GF -40 °C to +125 °C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1 × 1 × 0.5 mm SOT891 74LVC1G175GN -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9 × 1.0 × 0.35 mm SOT1115 74LVC1G175GS -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0 × 1.0 × 0.35 mm SOT1202 4. Marking Table 2. Marking Type number Marking code [1] 74LVC1G175GW YT 74LVC1G175GV V75 74LVC1G175GM YT 74LVC1G175GF YT 74LVC1G175GN YT 74LVC1G175GS YT [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram 6 3 1 MR 1 D FF Q 4 3 CP 6 CP D MR 001aaa468 Fig. 1. Logic symbol 74LVC1G175 Product data sheet 4 Q 001aaa469 Fig. 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 8 — 3 October 2019 © Nexperia B.V. 2019. All rights reserved 2 / 18 74LVC1G175 Nexperia Single D-type flip-flop with reset; positive-edge trigger CP C Q C C C C C C C D Fig. 3. C C MR 001aaa466 Logic diagram 6. Pinning information 6.1. Pinning 74LVC1G175 74LVC1G175 CP CP 1 6 MR GND 2 5 VCC D 3 4 Q 6 74LVC1G175 MR GND 2 5 VCC D 3 4 Q CP 1 6 MR GND 2 5 VCC D 3 4 Q 001aag508 001aag507 001aag506 Fig. 4. 1 Transparent top view Pin configuration SOT363 (SC-88) and SOT457 (SC-74) Fig. 5. Pin configuration SOT886 (XSON6) Transparent top view Fig. 6. Pin configuration SOT891, SOT1115 and SOT1202 (XSON6) 6.2. Pin description Table 3. Pin description Symbol Pin Description CP 1 clock input (LOW-to-HIGH, edge-triggered) GND 2 ground (0 V) D 3 data input Q 4 output Q VCC 5 supply voltage MR 6 master reset input (active LOW) 74LVC1G175 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 3 October 2019 © Nexperia B.V. 2019. All rights reserved 3 / 18 74LVC1G175 Nexperia Single D-type flip-flop with reset; positive-edge trigger 7. Functional description Table 4. Function table H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the LOW-to-HIGH CP transition; L = LOW voltage level; l = LOW voltage level one set-up time prior to the LOW-to-HIGH CP transition; ↑ = LOW-to-HIGH CP transition; X = don’t care. Operating mode Output Input MR CP D Q Reset (clear) L X X L Load ‘1’ H ↑ h H Load ‘0’ H ↑ l L 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +6.5 V VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO > VCC or VO < 0 V VO output voltage Active mode [1] -0.5 Power-down mode; VCC = 0 V [1] -0.5 VI < 0 V [1] -50 - -0.5 +6.5 V - ±50 mA VCC + 0.5 V +6.5 V IO output current - ±50 mA ICC supply current - 100 mA IGND ground current -100 - mA Ptot total power dissipation - 250 mW Tstg storage temperature -65 +150 °C [1] [2] VO = 0 V to VCC mA Tamb = -40 °C to +125 °C [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SOT363 (TSSOP6) packages: Ptot derates linearly with 3.7 mW/K above 83 °C. For SOT457 (TSOP6) packages: Ptot derates linearly with 4.1 mW/K above 89 °C. For SOT886 (XSON6) packages: Ptot derates linearly with 3.3 mW/K above 74 °C. For SOT891 (XSON6) packages: Ptot derates linearly with 3.3 mW/K above 74 °C. For SOT1115 (XSON6) packages: Ptot derates linearly with 3.2 mW/K above 71 °C. For SOT1202 (XSON6) packages: Ptot derates linearly with 3.3 mW/K above 74 °C. 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature Δt/ΔV input transition rise and fall rate Conditions Active mode Power-down mode; VCC = 0 V 74LVC1G175 Product data sheet Min Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V 0 - VCC V 0 - 5.5 V -40 - +125 °C VCC = 1.65 V to 2.7 V - - 20 ns/V VCC = 2.7 V to 5.5 V - - 10 ns/V All information provided in this document is subject to legal disclaimers. Rev. 8 — 3 October 2019 © Nexperia B.V. 2019. All rights reserved 4 / 18 74LVC1G175 Nexperia Single D-type flip-flop with reset; positive-edge trigger 10. Static characteristics Table 7. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ [1] Max Unit 0.65 × VCC - - V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7 × VCC - - V VCC = 1.65 V to 1.95 V - - VCC = 2.3 V to 2.7 V - - VCC = 2.7 V to 3.6 V - - VCC = 4.5 V to 5.5 V - - VCC - 0.1 - - V IO = -4 mA; VCC = 1.65 V 1.2 1.54 - V IO = -8 mA; VCC = 2.3 V 1.9 2.15 - V IO = -12 mA; VCC = 2.7 V 2.2 2.50 - V IO = -24 mA; VCC = 3.0 V 2.3 2.62 - V IO = -32 mA; VCC = 4.5 V 3.8 4.11 - V Tamb = -40 °C to +85 °C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VCC = 1.65 V to 1.95 V 0.35 × VCC V 0.7 V 0.8 V 0.3 × VCC V VI = VIH or VIL IO = -100 μA; VCC = 1.65 V to 5.5 V VI = VIH or VIL IO = 100 μA; VCC = 1.65 V to 5.5 V - - 0.10 V IO = 4 mA; VCC = 1.65 V - 0.07 0.45 V IO = 8 mA; VCC = 2.3 V - 0.12 0.30 V IO = 12 mA; VCC = 2.7 V - 0.17 0.40 V IO = 24 mA; VCC = 3.0 V - 0.33 0.55 V - 0.39 0.55 V - ±0.1 ±1 μA IO = 32 mA; VCC = 4.5 V II input leakage current VCC = 0 V to 5.5 V; VI = 5.5 V or GND IOFF power-off leakage current VCC = 0 V; VI or VO = 5.5 V - ±0.1 ±2 μA ICC supply current VCC = 1.65 V to 5.5 V; IO = 0 A; VI = 5.5 V or GND - 0.1 4 μA ΔICC additional supply current VCC = 2.3 V to 5.5 V; VI = VCC - 0.6 V; IO = 0 A - 5 500 μA CI input capacitance VCC = 3.3 V; VI = GND to VCC - 2.5 - pF 74LVC1G175 Product data sheet [2] [2] All information provided in this document is subject to legal disclaimers. Rev. 8 — 3 October 2019 © Nexperia B.V. 2019. All rights reserved 5 / 18 74LVC1G175 Nexperia Single D-type flip-flop with reset; positive-edge trigger Symbol Parameter Conditions Min Typ [1] Max Unit 0.65 × VCC - - V VCC = 2.3 V to 2.7 V 1.7 - - V VCC = 2.7 V to 3.6 V 2.0 - - V VCC = 4.5 V to 5.5 V 0.7 × VCC - - V VCC = 1.65 V to 1.95 V - - VCC = 2.3 V to 2.7 V - - VCC = 2.7 V to 3.6 V - - VCC = 4.5 V to 5.5 V - - VCC - 0.1 - - V IO = -4 mA; VCC = 1.65 V 0.95 - - V IO = -8 mA; VCC = 2.3 V 1.7 - - V IO = -12 mA; VCC = 2.7 V 1.9 - - V IO = -24 mA; VCC = 3.0 V 2.0 - - V IO = -32 mA; VCC = 4.5 V 3.4 - - V IO = 100 μA; VCC = 1.65 V to 5.5 V - - 0.10 V IO = 4 mA; VCC = 1.65 V - - 0.70 V IO = 8 mA; VCC = 2.3 V - - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.60 V IO = 24 mA; VCC = 3.0 V - - 0.80 V IO = 32 mA; VCC = 4.5 V Tamb = -40 °C to +125 °C VIH HIGH-level input voltage VIL LOW-level input voltage VOH VOL HIGH-level output voltage LOW-level output voltage VCC = 1.65 V to 1.95 V 0.35 × VCC V 0.7 V 0.8 V 0.3 × VCC V VI = VIH or VIL IO = -100 μA; VCC = 1.65 V to 5.5 V VI = VIH or VIL - - 0.80 V II input leakage current VCC = 0 V to 5.5 V; VI = 5.5 V or GND - - ±1 μA IOFF power-off leakage current VCC = 0 V; VI or VO = 5.5 V - - ±2 μA ICC supply current VCC = 1.65 V to 5.5 V; IO = 0 A; VI = 5.5 V or GND - - 4 μA ΔICC additional supply current VCC = 2.3 V to 5.5 V; VI = VCC - 0.6 V; IO = 0 A - - 500 μA [1] [2] All typical values are measured at Tamb = 25 °C. These typical values are measured at VCC = 3.3 V. 74LVC1G175 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 3 October 2019 © Nexperia B.V. 2019. All rights reserved 6 / 18 74LVC1G175 Nexperia Single D-type flip-flop with reset; positive-edge trigger 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 9. Symbol Parameter tpd propagation delay Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ [1] Max Min VCC = 1.65 V to 1.95 V 1.5 4.9 13.4 1.5 17 ns VCC = 2.3 V to 2.7 V 1.0 3.1 7.1 1.0 9.0 ns VCC = 2.7 V 1.0 3.2 7.1 1.0 9.0 ns VCC = 3.0 V to 3.6 V 1.0 3.1 5.7 0.5 7.5 ns VCC = 4.5 V to 5.5 V 1.0 2.2 4.0 0.5 5.5 ns VCC = 1.65 V to 1.95 V 1.5 4.3 12.9 1.5 17 ns VCC = 2.3 V to 2.7 V 1.0 2.8 7.0 1.0 9.0 ns VCC = 2.7 V 1.0 3.0 7.0 1.0 9.0 ns VCC = 3.0 V to 3.6 V 1.0 2.5 5.8 0.5 7.5 ns VCC = 4.5 V to 5.5 V 1.0 2.0 4.1 0.5 5.5 ns VCC = 1.65 V to 1.95 V 6.2 - - 6.2 - ns VCC = 2.3 V to 2.7 V 2.7 - - 2.7 - ns VCC = 2.7 V 2.7 - - 2.7 - ns VCC = 3.0 V to 3.6 V 2.7 1.3 - 2.7 - ns VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - ns VCC = 1.65 V to 1.95 V 6.2 - - 6.2 - ns VCC = 2.3 V to 2.7 V 2.7 - - 2.7 - ns VCC = 2.7 V 2.7 - - 2.7 - ns VCC = 3.0 V to 3.6 V 2.7 1.6 - 2.7 - ns VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - ns VCC = 1.65 V to 1.95 V 1.9 - - 1.9 - ns VCC = 2.3 V to 2.7 V 1.4 - - 1.4 - ns VCC = 2.7 V 1.3 - - 1.3 - ns VCC = 3.0 V to 3.6 V 1.2 0.4 - 1.2 - ns VCC = 4.5 V to 5.5 V 1.0 - - 1.0 - ns VCC = 1.65 V to 1.95 V 2.9 - - 2.9 - ns VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - ns VCC = 2.7 V 1.7 - - 1.7 - ns VCC = 3.0 V to 3.6 V 1.3 0.5 - 1.3 - ns VCC = 4.5 V to 5.5 V 1.1 - - 1.1 - ns CP to Q; see Fig. 7 Max [2] MR to Q; see Fig. 8 tW pulse width CP HIGH or LOW; see Fig. 7 MR LOW; see Fig. 8 trec tsu recovery time set-up time 74LVC1G175 Product data sheet MR; see Fig. 8 D to CP; see Fig. 7 All information provided in this document is subject to legal disclaimers. Rev. 8 — 3 October 2019 © Nexperia B.V. 2019. All rights reserved 7 / 18 74LVC1G175 Nexperia Single D-type flip-flop with reset; positive-edge trigger Symbol Parameter th hold time fmax maximum frequency Conditions -40 °C to +85 °C [1] [2] [3] power dissipation capacitance Unit Min Typ [1] Max Min Max VCC = 1.65 V to 1.95 V 0.0 - - 0.0 - ns VCC = 2.3 V to 2.7 V 0.3 - - 0.3 - ns VCC = 2.7 V 0.5 - - 0.5 - ns VCC = 3.0 V to 3.6 V 1.2 0.2 - 1.2 - ns VCC = 4.5 V to 5.5 V 0.5 - - 0.5 - ns VCC = 1.65 V to 1.95 V 80 125 - 80 - MHz VCC = 2.3 V to 2.7 V 175 - - 175 - MHz VCC = 2.7 V 175 - - 175 - MHz VCC = 3.0 V to 3.6 V 175 300 - 175 - MHz 200 - - 200 - MHz - 14 - - - pF D to CP; see Fig. 7 CP; see Fig. 7 VCC = 4.5 V to 5.5 V CPD -40 °C to +125 °C VI = GND to VCC; VCC = 3.3 V [3] Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively. tpd is the same as tPLH and tPHL. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in Volts; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of the outputs. 11.1. Waveforms VI VM D input GND th th tsu 1/fmax tsu VI CP input VM GND tW tPHL tPLH VOH VM Q output VOL 001aaa465 Measurement points are given in Table 9. The shaded areas indicate when the input is permitted to change for predictable output performance. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 7. The clock input (CP) to output (Q) propagation delays, the clock pulse width, the D to CP set-up, the CP to D hold times, and the maximum clock pulse frequency 74LVC1G175 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 3 October 2019 © Nexperia B.V. 2019. All rights reserved 8 / 18 74LVC1G175 Nexperia Single D-type flip-flop with reset; positive-edge trigger VI VM MR input GND tW t rec VI CP input VM GND t PHL VOH VM Q output VOL 001aaa464 Measurement points are given in Table 9. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 8. The master reset (MR) input to output (Q) propagation delays, the master reset pulse width, and the MR to CP recovery time Table 9. Measurement points Supply voltage Input Output VCC VM VM 1.65 V to 1.95 V 0.5 × VCC 0.5 × VCC 2.3 V to 2.7 V 0.5 × VCC 0.5 × VCC 2.7 V 1.5 V 1.5 V 3.0 V to 3.6 V 1.5 V 1.5 V 4.5 V to 5.5 V 0.5 × VCC 0.5 × VCC VEXT VCC G VI RL VO DUT RT CL RL mna616 Test data is given in Table 10. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 9. Test circuit for measuring switching times Table 10. Test data Supply voltage Input VCC VI tr = tf CL RL tPLH, tPHL 1.65 V to 1.95 V VCC ≤ 2.0 ns 30 pF 1 kΩ open 2.3 V to 2.7 V VCC ≤ 2.0 ns 30 pF 500 Ω open 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 4.5 V to 5.5 V VCC ≤ 2.5 ns 50 pF 500 Ω open 74LVC1G175 Product data sheet VEXT Load All information provided in this document is subject to legal disclaimers. Rev. 8 — 3 October 2019 © Nexperia B.V. 2019. All rights reserved 9 / 18 74LVC1G175 Nexperia Single D-type flip-flop with reset; positive-edge trigger 12. Package outline Plastic surface-mounted package; 6 leads SOT363 D B E y A X HE 6 5 v M A 4 Q pin 1 index A 1 2 e1 A1 3 bp c Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w y mm 1.1 0.8 0.1 0.30 0.20 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.25 0.15 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT363 JEITA EUROPEAN PROJECTION ISSUE DATE 04-11-08 06-03-16 SC-88 Fig. 10. Package outline SOT363 (SC-88) 74LVC1G175 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 3 October 2019 © Nexperia B.V. 2019. All rights reserved 10 / 18 74LVC1G175 Nexperia Single D-type flip-flop with reset; positive-edge trigger Plastic, surface-mounted package (SC-74; TSOP6); 6 leads D SOT457 B E y A X HE 6 5 v M A 4 Q A pin 1 index A1 c 1 2 Lp 3 bp e detail X w M B 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A A1 1.1 0.1 0.9 bp c D E 0.40 0.26 3.1 1.7 0.013 0.25 0.10 2.7 1.3 e 0.95 HE Lp Q 3.0 0.6 0.33 2.5 0.2 0.23 v w y 0.2 0.2 0.1 sot457_po Outline version References IEC JEDEC SOT457 JEITA European projection Issue date 06-03-16 18-11-27 SC-74 Fig. 11. Package outline SOT457 (SC-74) 74LVC1G175 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 3 October 2019 © Nexperia B.V. 2019. All rights reserved 11 / 18 74LVC1G175 Nexperia Single D-type flip-flop with reset; positive-edge trigger SOT886 XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm b 1 2 3 4x (2) L L1 e 6 5 e1 4 e1 6x A (2) A1 D E terminal 1 index area 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 0.5 A1 b D E 0.04 0.25 1.50 1.05 0.20 1.45 1.00 0.17 1.40 0.95 e e1 0.6 0.5 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. Outline version SOT886 sot886_po References IEC JEDEC JEITA European projection Issue date 04-07-22 12-01-05 MO-252 Fig. 12. Package outline SOT886 (XSON6) 74LVC1G175 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 3 October 2019 © Nexperia B.V. 2019. All rights reserved 12 / 18 74LVC1G175 Nexperia Single D-type flip-flop with reset; positive-edge trigger XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm 1 SOT891 b 3 2 4× (1) L L1 e 6 5 4 e1 e1 6× A (1) A1 D E terminal 1 index area 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max A1 max b D E e e1 L L1 mm 0.5 0.04 0.20 0.12 1.05 0.95 1.05 0.95 0.55 0.35 0.35 0.27 0.40 0.32 Note 1. Can be visible in some manufacturing processes. OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 05-04-06 07-05-15 SOT891 Fig. 13. Package outline SOT891 (XSON6) 74LVC1G175 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 3 October 2019 © Nexperia B.V. 2019. All rights reserved 13 / 18 74LVC1G175 Nexperia Single D-type flip-flop with reset; positive-edge trigger XSON6: extremely thin small outline package; no leads; 6 terminals; body 0.9 x 1.0 x 0.35 mm 1 SOT1115 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e max 0.35 0.04 0.20 0.95 1.05 nom 0.15 0.90 1.00 0.55 min 0.12 0.85 0.95 e1 0.3 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1115_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-07 SOT1115 Fig. 14. Package outline SOT1115 (XSON6) 74LVC1G175 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 3 October 2019 © Nexperia B.V. 2019. All rights reserved 14 / 18 74LVC1G175 Nexperia Single D-type flip-flop with reset; positive-edge trigger XSON6: extremely thin small outline package; no leads; 6 terminals; body 1.0 x 1.0 x 0.35 mm 1 SOT1202 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.05 1.05 0.35 0.40 nom 0.15 1.00 1.00 0.55 0.35 0.30 0.35 min 0.12 0.95 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1202_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1202 Fig. 15. Package outline SOT1202 (XSON6) 74LVC1G175 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 3 October 2019 © Nexperia B.V. 2019. All rights reserved 15 / 18 74LVC1G175 Nexperia Single D-type flip-flop with reset; positive-edge trigger 13. Abbreviations Table 11. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC1G175 v.8 20191003 Product data sheet - Modifications: • • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Table 5: Derating values for Ptot total power dissipation updated. Package outline drawing SOT457 (SC-74) updated. 74LVC1G175 v.7 20161202 Modifications: • 74LVC1G175 v.6 20131011 Modifications: • 74LVC1G175 v.5 20111206 Modifications: • 74LVC1G175 v.4 20101004 74LVC1G175 v.3 20070521 74LVC1G175 v.2 74LVC1G175 v.1 74LVC1G175 Product data sheet 74LVC1G175 v.7 Product data sheet - 74LVC1G175 v.6 Table 7: The maximum limits for leakage current and supply current have changed. Product data sheet - 74LVC1G175 v.5 Package outline drawing of SOT886 (Fig. 12) modified. Product data sheet - 74LVC1G175 v.4 Product data sheet - 74LVC1G175 v.3 Product data sheet - 74LVC1G175 v.2 20041018 Product specification - 74LVC1G175 v.1 20040318 Product specification - - Legal pages updated. All information provided in this document is subject to legal disclaimers. Rev. 8 — 3 October 2019 © Nexperia B.V. 2019. All rights reserved 16 / 18 74LVC1G175 Nexperia Single D-type flip-flop with reset; positive-edge trigger 15. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74LVC1G175 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 8 — 3 October 2019 © Nexperia B.V. 2019. All rights reserved 17 / 18 74LVC1G175 Nexperia Single D-type flip-flop with reset; positive-edge trigger Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................2 4. Marking.......................................................................... 2 5. Functional diagram.......................................................2 6. Pinning information......................................................3 6.1. Pinning.........................................................................3 6.2. Pin description............................................................. 3 7. Functional description................................................. 4 8. Limiting values............................................................. 4 9. Recommended operating conditions..........................4 10. Static characteristics..................................................5 11. Dynamic characteristics.............................................7 11.1. Waveforms................................................................. 8 12. Package outline........................................................ 10 13. Abbreviations............................................................ 16 14. Revision history........................................................16 15. Legal information......................................................17 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 3 October 2019 74LVC1G175 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 3 October 2019 © Nexperia B.V. 2019. All rights reserved 18 / 18
74LVC1G175GV,125 价格&库存
很抱歉,暂时无法提供与“74LVC1G175GV,125”相匹配的价格&库存,您可以联系我们找货
74LVC1G175GV,125
  • 1+0.92678
  • 10+0.82847
  • 25+0.76881
  • 100+0.68983
  • 250+0.66042
  • 500+0.59152
  • 1000+0.55203
  • 3000+0.53271
库存:8512
74LVC1G175GV,125
    74LVC1G175GV,125
    • 1+2.04700
    • 10+1.78800
    • 100+1.52880
    • 1000+1.29560
    库存:1379
    74LVC1G175GV,125
    • 1+1.09479
    • 100+1.05454
    • 300+1.01429
    • 500+0.97404
    • 2000+0.95391
    • 5000+0.94184
    库存:3000
    74LVC1G175GV,125
