74LVC574AD,118
74LVC574AD,118
    NEXPERIA(安世)
    SOIC20_300MIL
    具有5V容限输入/输出的八进制D型触发器;正边缘触发;三态
74LVC574AD,118 数据手册
INTEGRATED CIRCUITS 74LVC574A Octal D-type flip-flop with 5-volt tolerant inputs/outputs; positive edge-trigger (3-State) Product specification       1998 Jul 29 Philips Semiconductors Product specification Octal D-type flip-flop with 5-volt tolerant inputs/outputs; positive edge-trigger (3-State) 74LVC574A Inputs can be driven from either 3.3V or 5V devices. In 3-State operation, outputs can handle 5V. This feature allows the use of these devices as translators in a mixed 3.3V/5V environment. FEATURES • 5-volt tolerant inputs/outputs, for interfacing with 5-volt logic • Supply voltage range of 2.7V to 3.6V • Complies with JEDEC standard no. 8-1A • Inputs accept voltages up to 5.5V • CMOS low power consumption • Direct interface with TTL levels • High impedance when VCC = 0V • 8-bit positive edge-triggered register • Independent register and 3-State buffer operation • Flow-through pin-out architecture The 74LVC574A is an octal D-type flip-flop featuring separate D-type inputs for each flip-flop and 3-State outputs for bus-oriented applications. A clock (CP) and an output enable (OE) input are common to all flip-flops. The eight flip-flops will store the state of their individual D-inputs that meet the setup and hold times requirements on the LOW-to-HIGH CP transition. When OE is LOW, the contents of the eight flip-flops is available at the outputs. When OE is HIGH, the outputs go to the high impedance OFF-state. Operation of the OE input does not affect the state of the flip-flops. The ’574A’ is functionally identical to the ’374A’, but the ’374A’ has a different pin arrangement. DESCRIPTION The 74LVC574A is a high-performance, low-power, low-voltage, Si-gate CMOS device, superior to most advanced CMOS compatible TTL families. QUICK REFERENCE DATA GND = 0V; Tamb =25°C; tr = tf  2.5ns PARAMETER SYMBOL CONDITIONS CL = 50pF VCC = 3.3V TYPICAL UNIT tPHL/tPLH Propagation delay CP to Qn fmax maximum clock frequency 150 MHz CI Input capacitance 5.0 pF CPD Power dissipation capacitance per flip-flop 20 pF 4.8 Notes 1 and 2 ns NOTE: 1. CPD is used to determine the dynamic power dissipation (PD in W): PD = CPD x VCC2 x fi +  (CL x VCC2 x fo) where: fi = input frequency in MHz; CL = output load capacity in pF; fo = output frequency in MHz; VCC = supply voltage in V;  (CL x VCC2 x fo) = sum of outputs. 2. The condition is VI = GND to VCC ORDERING INFORMATION TEMPERATURE RANGE OUTSIDE NORTH AMERICA NORTH AMERICA PKG. DWG. # 20-Pin Plastic Shrink Small Outline (SO) –40°C to +85°C 74LVC574A D 74LVC574A D SOT163-1 20-Pin Plastic Shrink Small Outline (SSOP) Type II –40°C to +85°C 74LVC574A DB 74LVC574A DB SOT339-1 20-Pin Plastic Thin Shrink Small Outline (TSSOP) Type I –40°C to +85°C 74LVC574A PW 7LVC574APW DH SOT360-1 PACKAGES 1998 Jul 29 2 853-1863 19804 Philips Semiconductors Product specification Octal D-type flip-flop with 5-volt tolerant inputs/outputs; positive edge-trigger (3-State) PIN DESCRIPTION 74LVC574A LOGIC SYMBOL (IEEE/IEC) PIN NUMBER SYMBOL 1 OE FUNCTION 1 Output enable input (active-Low) C1 2, 3, 4, 5, 6, 7, 8, 9 D0-D7 Data inputs 19, 18, 17, 16, 15, 14, 13, 12 Q0-Q7 Data outputs 2 10 GND Ground (0V) 3 18 Clock input (LOW-to-HIGH, edge-triggered) 4 17 5 16 6 15 7 14 8 13 9 12 11 CP 20 VCC 11 EN Positive supply voltage PIN CONFIGURATION OE 1 20 VCC D0 2 19 Q0 D1 3 18 Q1 D2 4 17 Q2 D3 5 16 Q3 D4 6 15 Q4 D5 7 14 Q5 D6 8 13 Q6 9 12 Q7 D7 GND 10 SA00402 FUNCTIONAL DIAGRAM 2 D0 Q0 19 3 D1 Q1 18 4 D2 Q2 17 5 D3 Q3 16 6 D4 Q4 15 7 D5 Q5 14 8 D6 Q6 13 9 D7 Q7 12 11 CP 1 OE 11 CP SA00400 LOGIC SYMBOL CP 2 D0 Q0 19 3 D1 Q1 18 4 D2 Q2 17 5 D3 Q3 16 6 D4 Q4 15 7 D5 Q5 14 8 D6 Q6 13 9 D7 Q7 12 OE FF! to FF8 3-State OUTPUTS SA00403 11 1 SA00401 1998 Jul 29 19 1D 3 Philips Semiconductors Product specification Octal D-type flip-flop with 5-volt tolerant inputs/outputs; positive edge-trigger (3-State) 74LVC574A LOGIC DIAGRAM D1 D0 D D2 D Q CP D Q CP D4 D Q CP FF2 FF1 D3 D Q CP D6 D Q CP FF4 FF3 D5 D Q CP D Q CP FF6 FF5 D7 Q CP FF8 FF7 CP OE Q1 Q0 Q2 Q3 Q4 Q5 Q6 Q7 SA00404 FUNCTION TABLE INPUTS OPERATING MODES H h L l Z ° OUTPUTS INTERNAL FLIP-FLOPS OE LE Dn Load and read register L L ° ° l h L H Q0 to Q7 L H Load register and disable outputs H H ° ° l h L H Z Z = HIGH voltage level = HIGH voltage level one setup time prior to the LOW-to-HIGH CP transition = LOW voltage level = LOW voltage level one setup time prior to the LOW-to-HIGH CP transition = High impedance OFF-state = LOW-to-HIGH clock transition RECOMMENDED OPERATING CONDITIONS LIMITS SYMBOL VCC VI VO PARAMETER UNIT MIN MAX DC supply voltage (for max. speed performance) 2.7 3.6 DC supply voltage (for low-voltage applications) 1.2 3.6 DC Input voltage range 0 5.5 DC output voltage range; output HIGH or LOW state 0 VCC DC output voltage range; output 3-State 0 5.5 –40 +85 °C 0 0 20 10 ns/V V Tamb Operating ambient temperature range in free-air tr, tf Input rise and fall times 1998 Jul 29 CONDITIONS VCC = 1.2 to 2.7V VCC = 2.7 to 3.6V 4 V V Philips Semiconductors Product specification Octal D-type flip-flop with 5-volt tolerant inputs/outputs; positive edge-trigger (3-State) 74LVC574A ABSOLUTE MAXIMUM RATINGS1 In accordance with the Absolute Maximum Rating System (IEC 134) Voltages are referenced to GND (ground = 0V) PARAMETER SYMBOL VCC CONDITIONS RATING –0.5 to +6.5 V IIK DC input diode current VI t0 –50 mA VI DC input voltage Note 2 –0.5 to +6.5 V IOK DC output diode current VO uVCC or VO t 0 "50 mA DC output voltage; output HIGH or LOW state Note 2 –0.5 to VCC +0.5 DC output voltage; output 3-State Note 2 –0.5 to 6.5 DC output source or sink current VO = 0 to VCC VO IO IGND, ICC Tstg PTOT DC supply voltage UNIT Power dissipation per package – plastic mini-pack (SO) – plastic shrink mini-pack (SSOP and TSSOP) "50 mA "100 mA –65 to +150 °C 500 500 mW DC VCC or GND current Storage temperature range V above +70°C derate linearly with 8 mW/K above +60°C derate linearly with 5.5 mW/K NOTES: 1. Stresses beyond those listed may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. 2. The input and output voltage ratings may be exceeded if the input and output current ratings are observed. DC ELECTRICAL CHARACTERISTICS Over recommended operating conditions voltages are referenced to GND (ground = 0V) LIMITS SYMBOL PARAMETER TEST CONDITIONS Temp = -40°C to +85°C MIN VIH HIGH level Input voltage VIL LOW level Input voltage VOH O VCC = 1.2V VCC VCC = 2.7 to 3.6V 2.0 TYP1 VCC = 1.2V GND V 0.8 VCC = 2.7V; VI = VIH or VIL; IO = –12mA VCC*0.5 VCC = 3.0V; VI = VIH or VIL; IO = –100µA VCC*0.2 VCC = 3.0V; VI = VIH or VIL; IO = –18mA VCC*0.6 VCC = 3.0V; VI = VIH or VIL; IO = –24mA VCC*0.8 VCC VCC = 2.7V; VI = VIH or VIL; IO = 12mA VOL LOW level output voltage VCC = 3.0V; VI = VIH or VIL; IO = 100µA GND V 0.55 "5 µA VCC = 3.6V; VI = VIH or VIL; VO = 5.5V or GND 0.1 "10 µA Power off leakage supply VCC = 0.0V; VI or VO = 5.5V 0.1 "10 µA Quiescent supply current VCC = 3.6V; VI = VCC or GND; IO = 0 0.1 10 µA Additional quiescent supply current per input pin VCC = 2.7V to 3.6V; VI = VCC –0.6V; IO = 0 5 500 µA 6V; VI = 5 5V or GND VCC = 3 3.6V; 5.5V IOZ 3-State output OFF-state current Ioff ICC NOTES: 1. All typical values are at VCC = 3.3V and Tamb = 25°C. 2. The specified overdrive current at the data input forces the data input to the opposite logic input state. 1998 Jul 29 0.20 "0 1 "0.1 Input leakage current2 ∆ICC V 0.40 VCC = 3.0V; VI = VIH or VIL; IO = 24mA II MAX V VCC = 2.7 to 3.6V HIGH level output voltage UNIT 5 Philips Semiconductors Product specification Octal D-type flip-flop with 5-volt tolerant inputs/outputs; positive edge-trigger (3-State) 74LVC574A AC CHARACTERISTICS GND = 0V; tr = tf v 2.5ns; CL = 50pF; RL = 500Ω; Tamb = –40°C to +85°C. SYMBOL PARAMETER tPHL tPLH tPZH tPZL tPHZ tPLZ tW WAVEFORM Propagation delay CP to Qn 3-State output enable time OE to Qn 3-State output disable time OE to Qn Clock pulse width HIGH or LOW Setup time Dn to CP Hold time Dn to CP Maximum clock pulse frequency tSU th LIMITS VCC = 2.7V MIN MAX VCC = 3.3V ±0.3V MIN TYP1 MAX VCC = 1.2V TYP UNIT 1, 4 1.5 4.8 7.0 1.5 8.0 21 ns 2, 4 1.5 4.0 7.5 1.5 8.5 17 ns 2, 4 1.5 3.5 6.0 1.5 6.5 11 ns 1 3.4 1.7 – 3.4 – – ns 3 2.0 0.3 – 2.0 – – ns 3 1.5 –0.2 – 1.5 – – ns – 80 – – MHz fmax 1 100 NOTE: 1. Unless otherwise stated, all typical values are at VCC = 3.3V and Tamb = 25°C. AC WAVEFORMS VM = 1.5V at VCC w 2.7V; VM = 0.5 VCC at VCC t 2.7V. VOL and VOH are the typical output voltage drop that occur with the output load. VX = VOL + 0.3V at VCC w 2.7V; VX = VOL + 0.1 VCC at VCC t 2.7V VY = VOH –0.3V at VCC w 2.7V; VY = VOH – 0.1 VCC at VCC t 2.7V VI VM nOE INPUT GND tPLZ 1/fmax VI VM CP INPUT tPZL VCC VM Qn OUTPUT LOW-to-OFF OFF-to-LOW VM VM VX GND tw VOL tPHL tPLH VOH tPHZ VM Qn OUTPUT VM tPZH VOH Qn OUTPUT HIGH-to-OFF OFF-to-HIGH VOL VY VM SA00394 GND Waveform 1. Clock (CP) to output (Qn) propagation delays, the clock pulse width, output transition times and the maximum clock pulse frequency. outputs enabled SW00207 VI CP INPUT Waveform 3. 3-State enable and disable times. TEST CIRCUIT VM GND ÉÉÉÉ ÉÉÉÉÉÉÉ ÉÉ ÉÉÉÉ ÉÉÉÉÉÉÉ ÉÉ ÉÉÉÉ ÉÉÉÉÉÉÉ ÉÉ th th VI PULSE GENERATOR VM VI VM 50pF CL Test NOTE: The shaded areas indicate when the input is permitted to change for predictable output performance. SW00107 500Ω S1 VCC VI tPLH/tPHL Open t 2.7V VCC tPLZ/tPZL 2 x VCC 2.7V – 3.6V 2.7V tPHZ/tPZH GND SY00003 Waveform 2. Data setup and hold times for the Dn input to the CP input. 1998 Jul 29 500Ω VO RT VOL 2 x VCC Open GND D.U.T. GND VOH Qn OUTPUT S1 VCC tsu tsu Dn INPUT outputs enabled outputs disabled Waveform 4. Load circuitry for switching times. 6 Philips Semiconductors Product specification Octal D-type flip-flop with 5-volt tolerant inputs/outputs; positive edge-trigger (3-State) SO20: plastic small outline package; 20 leads; body width 7.5 mm 1998 Jul 29 7 74LVC574A SOT163-1 Philips Semiconductors Product specification Octal D-type flip-flop with 5-volt tolerant inputs/outputs; positive edge-trigger (3-State) SSOP20: plastic shrink small outline package; 20 leads; body width 5.3 mm 1998 Jul 29 8 74LVC574A SOT339-1 Philips Semiconductors Product specification Octal D-type flip-flop with 5-volt tolerant inputs/outputs; positive edge-trigger (3-State) TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm 1998 Jul 29 9 74LVC574A SOT360-1 Philips Semiconductors Product specification Octal D-type flip-flop with 5-volt tolerant inputs/outputs; positive edge-trigger (3-State) 74LVC574A Data sheet status Data sheet status Product status Definition [1] Objective specification Development This data sheet contains the design target or goal specifications for product development. Specification may change in any manner without notice. Preliminary specification Qualification This data sheet contains preliminary data, and supplementary data will be published at a later date. Philips Semiconductors reserves the right to make chages at any time without notice in order to improve design and supply the best possible product. Product specification Production This data sheet contains final specifications. Philips Semiconductors reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. [1] Please consult the most recently issued datasheet before initiating or completing a design. Definitions Short-form specification — The data in a short-form specification is extracted from a full data sheet with the same type number and title. For detailed information see the relevant data sheet or data handbook. Limiting values definition — Limiting values given are in accordance with the Absolute Maximum Rating System (IEC 134). Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Characteristics sections of the specification is not implied. Exposure to limiting values for extended periods may affect device reliability. Application information — Applications that are described herein for any of these products are for illustrative purposes only. Philips Semiconductors make no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Disclaimers Life support — These products are not designed for use in life support appliances, devices or systems where malfunction of these products can reasonably be expected to result in personal injury. Philips Semiconductors customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Philips Semiconductors for any damages resulting from such application. Right to make changes — Philips Semiconductors reserves the right to make changes, without notice, in the products, including circuits, standard cells, and/or software, described or contained herein in order to improve design and/or performance. Philips Semiconductors assumes no responsibility or liability for the use of any of these products, conveys no license or title under any patent, copyright, or mask work right to these products, and makes no representations or warranties that these products are free from patent, copyright, or mask work right infringement, unless otherwise specified.  Copyright Philips Electronics North America Corporation 1998 All rights reserved. Printed in U.S.A. Philips Semiconductors 811 East Arques Avenue P.O. Box 3409 Sunnyvale, California 94088–3409 Telephone 800-234-7381 print code Document order number:       yyyy mmm dd 10 Date of release: 08-98 9397-750-04514
74LVC574AD,118 价格&库存
很抱歉,暂时无法提供与“74LVC574AD,118”相匹配的价格&库存,您可以联系我们找货
74LVC574AD,118
  • 2000+1.940922000+0.24349
  • 4000+1.883184000+0.23625
  • 6000+1.854276000+0.23262
  • 10000+1.8222410000+0.22860
  • 14000+1.8035214000+0.22626
  • 20000+1.7855220000+0.22400
  • 50000+1.7467450000+0.21913
库存:1846
