74HCT173D,652
74HCT173D,652
    NEXPERIA(安世)
    SOIC16_150MIL
    四D型触发器;正边缘触发;三态
74HCT173D,652 数据手册
74HC173; 74HCT173 Quad D-type flip-flop; positive-edge trigger; 3-state Rev. 3 — 8 November 2016 Product data sheet 1. General description The 74HC173; 74HCT173 is a quad positive-edge triggered D-type flip-flop. The device features clock (CP), master reset (MR), two input enable (E1, E2) and two output enable (OE1, OE2) inputs. When the input enables are LOW, the outputs Qn will assume the state of their corresponding Dn inputs that meet the set-up and hold time requirements on the LOW-to-HIGH clock (CP) transition. A HIGH on either input enable will cause the device to go into a hold mode, outputs hold their previous state independently of clock and data inputs. A HIGH on MR forces the outputs LOW independently of clock and data inputs. A HIGH on either output enable pin causes the outputs to assume a high-impedance OFF-state. Operation of the output enable inputs does not affect the state of the flip-flops. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits  Complies with JEDEC standard no. 7A  Input levels:  For 74HC173: CMOS level  For 74HCT173: TTL level  Gated input enable for hold (do nothing) mode  Gated output enable control mode  Edge-triggered D-type register  Asynchronous master reset  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Specified from 40 C to +85 C and 40 C to +125 C 74HC173; 74HCT173 Nexperia Quad D-type flip-flop; positive-edge trigger; 3-state 3. Ordering information Table 1. Ordering information Type number 74HC173D Package Temperature range Name Description Version 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 40 C to +125 C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74HCT173D 74HC173DB 74HCT173DB 74HC173PW 4. Functional diagram  &3  ' 4   ' )) WR ))  '  ' 4  4   4   &       (1   (  (  05  2( ' ' '  ' (  (  &3  2(    2( 05 4 4 4 4       2(    Functional diagram 74HC_HCT173 Product data sheet    ' DDD DDD Fig 1. 5  Fig 2. Logic symbol All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 November 2016 DDD Fig 3. IEC logic symbol © Nexperia B.V. 2017. All rights reserved 2 of 20 74HC173; 74HCT173 Nexperia Quad D-type flip-flop; positive-edge trigger; 3-state ' ' ' ' ( ( ' &3 )) 4  ' &3 4 5' )) 4  ' &3 4 5' )) 4  ' &3 4 5' )) 4  &3 4 5' 05 2( 2( 4 4 4 4 DDD Fig 4. Logic diagram 74HC_HCT173 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 November 2016 © Nexperia B.V. 2017. All rights reserved 3 of 20 74HC173; 74HCT173 Nexperia Quad D-type flip-flop; positive-edge trigger; 3-state 5. Pinning information 5.1 Pinning +& +&7 2(   9&& 2(   05 4   ' 4   ' 4   ' 4   ' &3  +& +&7 2(  4   ' 4   ' 4   ' 4   ' &3   ( *1'   (  ( *1'   9&&  05 2(   ( DDD Fig 5. DDD Pin configuration SO16 Fig 6. Pin configuration SSOP16 and TSSOP16 5.2 Pin description Table 2. Pin description Symbol Pin Description OE1, OE2 1, 2 output enable input (active LOW) Q0, Q1, Q2, Q3 3, 4, 5, 6 3-state flip-flop output CP 7 clock input (LOW-to-HIGH, edge triggered) GND 8 ground (0 V) E1, E2 9, 10 data enable input (active LOW) D0, D1, D2, D3 14, 13, 12, 11 data input MR 15 asynchronous master reset (active HIGH) VCC 16 supply voltage 74HC_HCT173 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 November 2016 © Nexperia B.V. 2017. All rights reserved 4 of 20 74HC173; 74HCT173 Nexperia Quad D-type flip-flop; positive-edge trigger; 3-state 6. Functional description Table 3. Function table[1] Register operating mode Inputs Outputs MR CP E1 E2 Dn Qn (register) Reset (clear) H X X X X L Parallel load L  l l I L L  l l h H L X h X X qn L X X h X qn Hold (do nothing) Table 4. Function table[1] 3-state buffer operating mode Inputs Qn (register) OE1 OE2 Q0 Q1 Q2 Q3 Read L L L L L L L H L L H H H H X H X Z Z Z Z X X H Z Z Z Z Disabled [1] Outputs H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the LOW-to-HIGH CP transition; L = LOW voltage level; I = LOW voltage level one set-up time prior to the LOW-to-HIGH CP transition; qn = lower case letters indicate the state of the referenced input (or output) one set-up time prior to the LOW-to-HIGH CP transition; X = don’t care; Z = high impedance OFF-state;  = LOW-to-HIGH clock transition. 7. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VCC supply voltage IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V Min Max Unit 0.5 +7.0 V - 20 mA IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V - 20 mA IO output current 0.5 V < VO < VCC + 0.5 V - 35 mA ICC supply current - +70 mA IGND ground current 70 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation - 500 mW [1] SO16 and (T)SSOP16 package [1] For SO16 packages: above 70 C the value of Ptot derates linearly at 8 mW/K. For (T)SSOP16 packages: above 60 C the value of Ptot derates linearly at 5.5 mW/K. 74HC_HCT173 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 November 2016 © Nexperia B.V. 2017. All rights reserved 5 of 20 74HC173; 74HCT173 Nexperia Quad D-type flip-flop; positive-edge trigger; 3-state 8. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC173 Min Typ 74HCT173 Max Min Typ Unit Max VCC supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature 40 +25 +125 40 +25 +125 C t/V input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 9. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V HIGH-level VI = VIH or VIL output voltage IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = 6.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = 7.8 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V LOW-level VI = VIH or VIL output voltage IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 6.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 7.8 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V VI = VCC or GND; VCC = 6.0 V - - 0.1 - 1.0 - 1.0 A - - 0.5 - 5.0 - 10 A 74HC173 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage II input leakage current IOZ OFF-state VI = VIH or VIL; VCC = 6.0 V; output current VO = VCC or GND 74HC_HCT173 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 November 2016 © Nexperia B.V. 2017. All rights reserved 6 of 20 74HC173; 74HCT173 Nexperia Quad D-type flip-flop; positive-edge trigger; 3-state Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8 - 80 - 160 A CI input capacitance - 3.5 - - - - - pF 74HCT173 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 20 A 4.4 4.5 - 4.4 - 4.4 - V 3.98 4.32 - 3.84 - 3.7 - V IO = 6.0 mA VOL LOW-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 20 A IO = 6.0 mA 0 0.1 - 0.1 - 0.1 V 0.16 0.26 - 0.33 - 0.4 V - - 0.1 - 1.0 - 1.0 A II input leakage current IOZ OFF-state VI = VIH or VIL; VCC = 5.5 V; output current VO = VCC or GND - - 0.5 - 5.0 - 10 A ICC supply current VI = VCC or GND; VCC = 5.5 V; IO = 0 A - - 8.0 - 80 - 160 A ICC additional per input pin; VI = VCC  2.1 V; supply current other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A OE1, OE2 - 50 180 - 225 - 245 A MR - 60 216 - 270 - 294 A E1, E2 - 40 144 - 180 - 196 A Dn - 25 90 - 112.5 - 122.5 A CP - 100 360 - 450 - 490 A - 3.5 - - - - - pF CI input capacitance 74HC_HCT173 Product data sheet VI = VCC or GND; VCC = 5.5 V - All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 November 2016 © Nexperia B.V. 2017. All rights reserved 7 of 20 74HC173; 74HCT173 Nexperia Quad D-type flip-flop; positive-edge trigger; 3-state 10. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 11. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max - 55 175 - 220 - 265 ns - 20 35 - 44 - 53 ns 74HC173 tpd [1] propagation CP to Qn; see Figure 7 delay VCC = 2.0 V VCC = 4.5 V tPHL VCC = 5.0 V; CL = 15 pF - 17 - - - - - ns VCC = 6.0 V - 16 30 - 37 - 45 ns - 44 150 - 190 - 225 ns - 16 30 - 38 - 45 ns - 13 - - - - - ns - 13 26 - 33 - 38 ns VCC = 2.0 V - 52 150 - 190 - 225 ns VCC = 4.5 V - 19 30 - 38 - 45 ns - 15 26 - 33 - 38 ns VCC = 2.0 V - 52 150 - 190 - 225 ns VCC = 4.5 V - 19 30 - 38 - 45 ns - 15 26 - 33 - 38 ns High to MR to Qn; see Figure 8 LOW VCC = 2.0 V propagation VCC = 4.5 V delay VCC = 5.0 V; CL = 15 pF VCC = 6.0 V ten [2] enable time OEn to Qn; see Figure 9 VCC = 6.0 V tdis [3] disable time OEn to Qn; see Figure 9 VCC = 6.0 V tt tW transition time pulse width [4] see Figure 7 VCC = 2.0 V - 14 60 - 75 - 90 ns VCC = 4.5 V - 5 12 - 15 - 18 ns VCC = 6.0 V - 4 10 - 13 - 15 ns CP HIGH or LOW; see Figure 7 VCC = 2.0 V 80 14 - 100 - 120 - ns VCC = 4.5 V 16 5 - 20 - 24 - ns VCC = 6.0 V 14 4 - 17 - 20 - ns MR HIGH; see Figure 8 trec recovery time 74HC_HCT173 Product data sheet VCC = 2.0 V 80 14 - 100 - 120 - ns VCC = 4.5 V 16 5 - 20 - 24 - ns VCC = 6.0 V 14 4 - 17 - 20 - ns VCC = 2.0 V 60 8 - 75 - 90 - ns VCC = 4.5 V 12 3 - 15 - 18 - ns VCC = 6.0 V 10 2 - 13 - 15 - ns MR to CP; see Figure 8 All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 November 2016 © Nexperia B.V. 2017. All rights reserved 8 of 20 74HC173; 74HCT173 Nexperia Quad D-type flip-flop; positive-edge trigger; 3-state Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 11. Symbol Parameter 25 C Conditions Min tsu set-up time Typ 40 C to +85 C 40 C to +125 C Unit Max Min Max Min Max En to CP; see Figure 10 VCC = 2.0 V 100 33 - 125 - 150 - ns VCC = 4.5 V 20 12 - 25 - 30 - ns VCC = 6.0 V 17 10 - 21 - 26 - ns Dn to CP; see Figure 10 th hold time VCC = 2.0 V 60 17 - 75 - 90 - ns VCC = 4.5 V 12 6 - 15 - 18 - ns VCC = 6.0 V 10 5 - 13 - 15 - ns VCC = 2.0 V 0 17 - 0 - 0 - ns VCC = 4.5 V 0 6 - 0 - 0 - ns VCC = 6.0 V 0 5 - 0 - 0 - ns VCC = 2.0 V 1 11 - 1 - 1 - ns VCC = 4.5 V 1 4 - 1 - 1 - ns VCC = 6.0 V 1 3 - 1 - 1 - ns En to CP; see Figure 10 Dn to CP; see Figure 10 fmax maximum frequency CP; see Figure 7 VCC = 2.0 V 6 26 - 4.8 - 4 - MHz VCC = 4.5 V 30 80 - 24 - 20 - MHz - 88 - - - - - MHz 35 95 - 28 - 24 - MHz - 20 - - - - - pF - 20 40 - 50 - 60 ns VCC = 5.0 V; CL = 15 pF - 17 - - - - - ns High to MR to Qn; see Figure 8 LOW VCC = 4.5 V propagation VCC = 5.0 V; CL = 15 pF delay - 20 37 - 46 - 56 ns - 17 - - - - - ns VCC = 5.0 V; CL = 15 pF VCC = 6.0 V CPD power VI = GND to VCC; VCC = 5 V; dissipation fi = 1 MHz capacitance [5] 74HCT173 tpd tPHL [1] propagation CP to Qn; see Figure 7 delay VCC = 4.5 V ten enable time OEn to Qn; VCC = 4.5 V; see Figure 9 [2] - 20 35 - 44 - 53 ns tdis disable time OEn to Qn; VCC = 4.5 V; see Figure 9 [3] - 19 30 - 38 - 45 ns tt transition time [4] - 5 12 - 15 - 19 ns CP HIGH or LOW; VCC = 4.5 V; see Figure 7 16 7 - 20 - 24 - ns MR HIGH; VCC = 4.5 V; see Figure 8 15 6 - 19 - 22 - ns tW pulse width 74HC_HCT173 Product data sheet VCC = 4.5 V; see Figure 7 All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 November 2016 © Nexperia B.V. 2017. All rights reserved 9 of 20 74HC173; 74HCT173 Nexperia Quad D-type flip-flop; positive-edge trigger; 3-state Table 8. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 11. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max trec recovery time MR to CP; VCC = 4.5 V; see Figure 8 12 2 - 15 - 18 - ns tsu set-up time En to CP; VCC = 4.5 V; see Figure 10 22 13 - 28 - 33 - ns Dn to CP; VCC = 4.5 V; see Figure 10 12 7 - 15 - 18 - ns En to CP; VCC = 4.5 V; see Figure 10 0 6 - 0 - 0 - ns Dn to CP; VCC = 4.5 V; see Figure 10 0 3 - 0 - 0 - ns 30 80 - 24 - 20 - MHz - 88 - - - - - MHz - 20 - - - - - pF th hold time maximum frequency fmax CP; see Figure 7 VCC = 4.5 V VCC = 5.0 V; CL = 15 pF power VI = GND to VCC  1.5 V; dissipation VCC = 5 V; fi = 1 MHz capacitance CPD [1] [5] tpd is the same as tPHL and tPLH. [2] ten is the same as tPZH and tPZL. [3] tdis is the same as tPHZ and tPLZ. [4] tt is the same as tTHL and tTLH. [5] CPD is used to determine the dynamic power dissipation (PD in W): PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 74HC_HCT173 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 November 2016 © Nexperia B.V. 2017. All rights reserved 10 of 20 74HC173; 74HCT173 Nexperia Quad D-type flip-flop; positive-edge trigger; 3-state 11. Waveforms IPD[ 9, &3LQSXW 90 *1' W: W3+/ 92+ 4QRXWSXW W3/+   90 92/   W7+/ W7/+ DDD Measurement points are given in Table 9. Logic levels VOL and VOH are typical output voltage levels that occur with the output load. Fig 7. The clock (CP) to outputs (Qn) propagation delays, clock pulse width, output transition times and maximum frequency 9, 05LQSXW 90 *1' WUHF W: 9, &3LQSXW 90 *1' W3+/ 92+ 4QRXWSXW 90 92/ DDD Measurement points are given in Table 9. Logic levels VOL and VOH are typical output voltage levels that occur with the output load. Fig 8. The master reset (MR) pulse width, master reset to output (Qn) propagation delays, and the master reset to clock (CP) recovery times 74HC_HCT173 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 November 2016 © Nexperia B.V. 2017. All rights reserved 11 of 20 74HC173; 74HCT173 Nexperia Quad D-type flip-flop; positive-edge trigger; 3-state 9, 2(QLQSXW 90 *1' W3/= W3=/ 9&& RXWSXW /2:WR2)) 2))WR/2: 90 9; 92/ W3+= RXWSXW +,*+WR2)) 2))WR+,*+ W3=+ 92+ 9< 90 *1' RXWSXWV HQDEOHG RXWSXWV HQDEOHG RXWSXWV GLVDEOHG DDD Measurement points are given in Table 9. Logic levels VOL and VOH are typical output voltage levels that occur with the output load. Fig 9. 3-state enable and disable times 9, (QLQSXW 90 *1' 9, 90 'QLQSXW *1' WVX 9, &3LQSXW WVX WK WK 90 *1' DDD The shaded areas indicate when the input is permitted to change for predictable output performance. Measurement points are given in Table 9. Fig 10. The data set-up and hold times from input (En, Dn) to clock (CP) Table 9. Measurement points Type Input Output VM VM VX VY 74HC173 0.5  VCC 0.5  VCC 0.1  VCC 0.9  VCC 74HCT173 1.3 V 1.3 V 0.1  VCC 0.9  VCC 74HC_HCT173 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 November 2016 © Nexperia B.V. 2017. All rights reserved 12 of 20 74HC173; 74HCT173 Nexperia Quad D-type flip-flop; positive-edge trigger; 3-state 9, W:  QHJDWLYH SXOVH 90 9 WI WU WU WI 9,  SRVLWLYH SXOVH 9 90  90 90  W: 9&& 9&& * 9, 92 5/ 6 RSHQ '87 &/ 57 DDG Test data is given in Table 10. Test circuit definitions: RT = Termination resistance should be equal to output impedance Zo of the pulse generator CL = Load capacitance including jig and probe capacitance RL = Load resistance. S1 = Test selection switch Fig 11. Test circuit for measuring switching times Table 10. Test data Type Input VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 74HC173 VCC 6 ns 15 pF, 50 pF 1 k open GND VCC 74HCT173 3V 6 ns 15 pF, 50 pF 1 k open GND VCC 74HC_HCT173 Product data sheet Load S1 position All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 November 2016 © Nexperia B.V. 2017. All rights reserved 13 of 20 74HC173; 74HCT173 Nexperia Quad D-type flip-flop; positive-edge trigger; 3-state 12. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H Z 0 ES   GHWDLO; PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV         ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 12. Package outline SOT109-1 (SO16) 74HC_HCT173 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 November 2016 © Nexperia B.V. 2017. All rights reserved 14 of 20 74HC173; 74HCT173 Nexperia Quad D-type flip-flop; positive-edge trigger; 3-state 6623SODVWLFVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S /   GHWDLO; Z 0 ES H   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 13. Package outline SOT338-1 (SSOP16) 74HC_HCT173 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 November 2016 © Nexperia B.V. 2017. All rights reserved 15 of 20 74HC173; 74HCT173 Nexperia Quad D-type flip-flop; positive-edge trigger; 3-state 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ SLQLQGH[ $   $ $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWHV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 14. Package outline SOT403-1 (TSSOP16) 74HC_HCT173 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 November 2016 © Nexperia B.V. 2017. All rights reserved 16 of 20 74HC173; 74HCT173 Nexperia Quad D-type flip-flop; positive-edge trigger; 3-state 13. Abbreviations Table 11. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT173 v.3 20161108 Product data sheet - 74HC_HCT173 v.2 Modifications: 74HC_HCT173 v.2 74HC_HCT173 Product data sheet • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. Type numbers 74HCT173N and 74HC173N removed. 19901201 Product specification - All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 November 2016 - © Nexperia B.V. 2017. All rights reserved 17 of 20 74HC173; 74HCT173 Nexperia Quad D-type flip-flop; positive-edge trigger; 3-state 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC_HCT173 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 November 2016 © Nexperia B.V. 2017. All rights reserved 18 of 20 74HC173; 74HCT173 Nexperia Quad D-type flip-flop; positive-edge trigger; 3-state Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC_HCT173 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 8 November 2016 © Nexperia B.V. 2017. All rights reserved 19 of 20 Nexperia 74HC173; 74HCT173 Quad D-type flip-flop; positive-edge trigger; 3-state 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 5 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 6 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 8 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 14 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 17 Legal information. . . . . . . . . . . . . . . . . . . . . . . 18 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 18 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Contact information. . . . . . . . . . . . . . . . . . . . . 19 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 08 November 2016
74HCT173D,652 价格&库存
很抱歉,暂时无法提供与“74HCT173D,652”相匹配的价格&库存,您可以联系我们找货
