74ALVCH162601
18-bit universal bus transceiver with 30 Ω termination
resistor; 3-state
Rev. 2 — 13 August 2018
Product data sheet
1. General description
The 74ALVCH162601 is an 18-bit universal transceiver featuring non-inverting 3-state bus
compatible outputs in both send and receive directions. Data flow in each direction is controlled by
output enable (OEAB and OEBA), latch enable (LEAB and LEBA) and clock (CPAB and CPBA)
inputs. For A-to-B data flow, the device operates in the transparent mode when LEAB is HIGH.
When LEAB is LOW, the A data is latched if CPAB is held at a HIGH or LOW logic level. If LEAB is
LOW, the A-bus data is stored in the latch/flip-flop on the LOW-to-HIGH transition of CPAB. When
OEAB is LOW, the outputs are active. When OEAB is HIGH, the outputs are in the high-impedance
state. The clocks can be controlled with the clock-enable inputs (CEBA and CEAB).
Data flow for B-to-A is similar to that of A-to-B but uses OEBA, LEBA and CPBA.
To ensure the high impedance state during power up or power down, OEBA and OEAB should
be tied to VCC through a pullup resistor; the minimum value of the resistor is determined by the
current-sinking/current-sourcing capability of the driver.
The 74ALVCH162601 is designed with 30 Ω series resistors in both HIGH or LOW output stage.
Active bus-hold circuitry is provided to hold unused or floating data inputs at a valid logic level.
2. Features and benefits
CMOS low power consumption
MultiByte flow-through standard pin-out architecture
Low inductance multiple VCC and GND pins for minimum noise and ground bounce
Direct interface with TTL levels
Bus hold on data inputs
Integrated 30 Ω termination resistors.
Complies with JEDEC standards:
• JESD8-5 (2.3 V to 2.7 V)
• JESD8B/JESD36 (2.7 V to 3.6 V)
ESD protection:
• HBM ANSI/ESDA/JEDEC JS-001 exceeds 2000 V
• CDM JESD22-C101E exceeds 1000 V
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
74ALVCH162601DGG −40 °C to +85 °C
Name
Description
Version
TSSOP56
plastic thin shrink small outline package;
56 leads; body width 6.1 mm
SOT364-1
74ALVCH162601
Nexperia
18-bit universal bus transceiver with 30 Ω termination resistor; 3-state
4. Functional diagram
OEAB
CEAB
CPAB
1
56
55
2
LEAB
OEBA
3
5
6
8
9
10
12
13
14
15
16
17
19
23
24
26
1
2
55
55
Fig. 1.
A0
B0
A1
B1
A2
B2
A3
B3
A4
B4
A5
B5
A6
B6
A7
B7
A8
B8
A9
B9
A10
B10
A11
B11
A12
B12
A13
B13
A14
B14
A15
B15
A16
B16
A17
B17
OEAB
OEBA
LEAB
LEBA
CPAB
CPBA
CEAB
CEBA
CEBA
54
CPBA
52
LEBA
27
29
30
28
51
49
3
A0
48
47
5
A1
45
A4
42
A5
41
A6
40
A7
38
A8
37
A9
36
A10
34
A11
33
31
A12
27
A14
A13
A15
28
A16
30
A17
29
2C3
C3
G2
EN4
G5
5C6
C6
G5
3D
1
1
4
1
6D
54
52
51
8
49
9
48
10
47
12
45
13
44
14
43
15
42
16
41
17
40
19
38
21
36
23
34
24
33
26
31
A3
43
G2
6
A2
44
EN1
B0
B1
B2
B3
B4
B5
B6
B7
B8
B9
B10
B11
B12
B13
B14
B15
B16
B17
aaa-028854
aaa-028853
Logic symbol
Fig. 2.
IEC logic symbol
VCC
data input
to internal circuit
001aal733
Fig. 3.
Bus hold circuit
74ALVCH162601
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2018. All rights reserved
2 / 15
74ALVCH162601
Nexperia
CPBA
CPAB
LEBA
LEAB
CEBA
CEAB
OEBA
OEAB
CE
C1
CP
An
Bn
1D
CE
C1
CP
1D
18 identical channels
to 17 other channels
Fig. 4.
aaa-028855
Logic diagram (one section)
74ALVCH162601
Product data sheet
3 / 15
74ALVCH162601
Nexperia
5. Pinning information
5.1. Pinning
74ALVCH162601
OEAB
1
56 CEAB
LEAB
2
55 CPAB
A0
3
54 B0
GND
4
53 GND
A1
5
52 B1
A2
6
51 B2
VCC
7
50 VCC
A3
8
49 B3
A4
9
48 B4
A5 10
47 B5
GND 11
46 GND
A6 12
45 B6
A7 13
44 B7
A8 14
43 B8
A9 15
42 B9
A10 16
41 B10
A11 17
40 B11
GND 18
39 GND
A12 19
38 B12
A13 20
37 B13
A14 21
36 B14
VCC 22
35 VCC
A15 23
34 B15
A16 24
33 B16
GND 25
32 GND
A17 26
31 B17
OEBA 27
30 CPBA
LEBA 28
29 CEBA
aaa-028859
Fig. 5.
Pin configuration for TSSOP56 (SOT364-1)
74ALVCH162601
Product data sheet
4 / 15
74ALVCH162601
Nexperia
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
A0, A1, A2, A3, A4, A5, A6, A7, A8,
A9, A10, A11, A12, A13, A14, A15, A16, A17
3, 5, 6, 8, 9, 10, 12, 13, 14,
15, 16, 17, 19, 20, 21, 23, 24, 26
data inputs/outputs
B0, B1, B2, B3, B4, B5, B6, B7, B8,
B9, B10, B11, B12, B13, B14, B15, B16, B17
54, 52, 51, 49, 48, 47, 45, 44, 43,
42, 41, 40, 38, 37, 36, 34, 33, 31
data outputs/inputs
OEAB, OEBA
1, 27
A to B / B to A output enable inputs
(active LOW)
LEAB, LEBA
2, 28
A to B / B to A latch enable inputs
(active HIGH)
CPBA, CPAB
30, 55
B to A / A to B clock inputs
(active HIGH)
CEBA, CEAB
29, 56
B to A / A to B clock enable inputs
(active LOW)
GND
4, 11, 18, 25, 32, 39, 46, 53
ground (0 V)
VCC
7, 22, 35, 50
supply voltage
6. Functional description
Table 3. Function selection [1] [2]
Operating mode
Inputs
Outputs
CEAB
OEAB
LEAB
CPAB
An
Bn
Disabled
X
H
X
X
X
Z
Transparent
X
L
H
X
H
H
X
L
H
X
L
L
Hold
H
L
L
X
X
NC
Clock data & Display
L
L
L
h
H
L
L
L
l
L
L
L
L
H
X
NC
L
L
L
L
X
NC
Hold data & Display
[1]
[2]
A-to-B data flow is shown; B-to-A flow is similar but uses CEBA, OEBA, LEBA, and CPBA.
H = HIGH voltage level;
h = HIGH voltage level one set-up time prior to the enable or clock transition;
L = LOW voltage level;
l = LOW voltage level one set-up time prior to the enable or clock transition;
X = don’t care;
NC = no change
↑ = LOW-to-HIGH enable or clock transition;
Z = high-impedance OFF-state.
74ALVCH162601
Product data sheet
5 / 15
74ALVCH162601
Nexperia
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
VCC
supply voltage
VI
input voltage
VO
output voltage
IIK
input clamping current
VI < 0 V
IOK
output clamping current
IO (sink/source)
output sink or source current
ICC
Min
Max
Unit
-0.5
+4.6
V
[1]
-0.5
+4.6
V
[1]
-0.5
VCC + 0.5 V
-50
mA
VO > VCC or VO < 0 V
±50
mA
VO = 0 V to VCC
±50
mA
supply current
100
mA
IGND
ground current
-100
mA
Tstg
storage temperature
−65
+150
°C
Ptot
total power dissipation
600
mW
[1]
[2]
Tamb = −40 °C to +85 °C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For TSSOP56 packages: above 55 °C derate linearly with 8 mW/K.
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
VCC
supply voltage
Min
Typ
Max
Unit
for low-voltage applications
1.2
2.5
3.6
V
for maximum speed performance at CL = 30 pF
2.3
3.3
2.7
V
for maximum speed performance at CL = 50 pF
3.0
2.4
3.6
V
VCC
V
VI
input voltage
VO
output voltage
Tamb
ambient temperature
Δt/ΔV
input transition rise and VCC = 2.3 V to 3.0 V
fall rate
VCC = 3.0 V to 3.6 V
74ALVCH162601
Product data sheet
in free air
VCC
V
−40
+85
°C
ns/V
ns/V
6 / 15
74ALVCH162601
Nexperia
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions. Tamb = −40 °C to +85 °C; Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Min
Typ [1]
Max
VIH
HIGH-level input
voltage
VCC = 2.3 to 2.7 V
1.7
1.2
V
VCC = 2.7 to 3.6 V
2.0
1.5
V
LOW-level input
voltage
VCC = 2.3 to 2.7 V
1.2
0.7
V
VCC = 2.7 to 3.6 V
1.5
0.8
V
HIGH-level output
voltage
VI = VIH or VIL
IO = -100 μA; VCC = 2.3 V to 3.6 V
VCC - 0.2
VCC
V
IO = -4 mA; VCC = 2.3 V
VCC - 0.4
VCC - 0.11
V
IO = -6 mA; VCC = 2.3 V
VCC - 0.6
VCC - 0.17
V
IO = -4 mA; VCC = 2.7 V
VCC - 0.5
VCC - 0.09
V
IO = -8 mA; VCC = 2.7 V
VCC - 0.7
VCC - 0.19
V
IO = -6 mA; VCC = 3.0 V
VCC - 0.6
VCC - 0.13
V
IO = -12 mA; VCC = 3.0 V
VCC - 1.0
VCC - 0.27
V
IO = 100 μA; VCC = 2.3 V to 3.6 V
GND
0.20
V
IO = 4 mA; VCC = 2.3 V
0.07
0.40
V
IO = 6 mA; VCC = 2.3 V
0.11
0.55
V
IO = 4 mA; VCC = 2.7 V
0.06
0.40
V
IO = 8 mA; VCC = 2.7 V
0.13
0.60
V
IO = 6 mA; VCC = 3.0 V
0.09
0.55
V
IO = 12 mA; VCC = 3.0 V
0.19
0.80
V
0.1
5
μA
45
μA
VIL
VOH
VOL
LOW-level output
voltage
Unit
VI = VIH or VIL
II
input leakage current VI = VCC or GND; VCC = 2.3 V to 3.6 V
IBHL
bus hold LOW
current
VCC = 2.3 V; VI = 0.7 V
VCC = 3.0 V; VI = 0.8 V
75
150
μA
IBHH
bus hold HIGH
current
VCC = 2.3 V; VI = 1.7 V
-45
μA
VCC = 3.0 V; VI = 2.0 V
-75
-175
μA
IBHLO
bus hold LOW
overdrive current
VCC = 3.6 V
500
μA
IBHHO
bus hold HIGH
overdrive current
VCC = 3.6 V
-500
μA
IOZ
OFF-state output
current
VCC = 2.3 V to 3.6 V; VI = VIH or VIL;
VO = VCC or GND
0.1
10
μA
ICC
supply current
VCC = 2.3 to 3.6 V; VI = VCC or GND; IO = 0 A
0.2
40
μA
ΔICC
additional supply
current
per data I/O pin; VI = VCC - 0.6 V; IO = 0 A;
150
750
μA
CI
input capacitance
4.0
pF
CI/O
input/output
capacitance
8.0
pF
[1]
All typical values are measured at Tamb = 25 °C.
74ALVCH162601
Product data sheet
7 / 15
74ALVCH162601
Nexperia
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V). Tamb = −40 °C to +85 °C; For test circuit, see Fig. 10.
Symbol
Parameter
Conditions
tpd
propagation delay
An to Bn; Bn to An; Fig. 6
VCC = 2.7 V
5.3
ns
5.2
ns
4.5
ns
1.0
4.5
6.0
ns
4.3
5.9
ns
1.5
3.5
5.1
ns
1.5
4.7
6.4
ns
4.5
6.3
ns
1.6
3.7
5.5
ns
1.6
3.9
6.1
ns
3.9
6.7
ns
1.6
3.1
5.7
ns
1.8
2.6
5.7
ns
3.2
5.3
ns
1.8
2.9
4.8
ns
VCC = 2.3 V to 2.7 V
2.3
−0.2
ns
VCC = 2.7 V
2.4
0.0
ns
2.1
−0.2
ns
1.3
0.1
ns
VCC = 2.7 V
1.2
−0.2
ns
1.1
0.3
ns
2.0
−0.4
ns
VCC = 2.7 V
2.0
−0.7
ns
1.7
−0.2
ns
[2]
CPAB to Bn; CPBA to An; Fig. 7
[2]
VCC = 2.7 V
OEAB to Bn; OEBA to An; Fig. 8
[2]
VCC = 2.7 V
[2]
VCC = 2.7 V
set-up time
4.0
3.1
VCC = 2.7 V
tsu
1.3
3.9
disable time
Unit
LEAB to Bn; LEBA to An; Fig. 7
tdis
Max
1.6
enable time
Typ [1]
[2]
ten
Min
An to CPAB; Bn to CPBA; Fig. 9
An to LEAB; Bn to LEBA; Fig. 9
CEAB to CPAB; CEBA to CPBA;
74ALVCH162601
Product data sheet
8 / 15
74ALVCH162601
Nexperia
Symbol
Parameter
Conditions
Min
Typ [1]
Max
th
hold time
Unit
1.2
0.3
ns
VCC = 2.7 V
1.1
0.3
ns
1.0
−0.1
ns
1.3
0.2
ns
VCC = 2.7 V
1.6
0.1
ns
1.4
0.1
ns
1.1
0.4
ns
VCC = 2.7 V
1.2
0.6
ns
1.1
0.4
ns
3.3
1.6
ns
VCC = 2.7 V
3.3
0.7
ns
3.3
0.9
ns
3.3
2.0
ns
VCC = 2.7 V
3.3
1.2
ns
3.3
0.9
ns
150
190
MHz
VCC = 2.7 V
150
190
MHz
150
240
MHz
outputs enabled
21
pF
outputs disabled
3
pF
tw
pulse width
LEAB HIGH; LEBA HIGH; Fig. 7
CPAB HIGH or LOW;
CPBA HIGH or LOW; Fig. 7
fmax
maximum frequency
CPD
[1]
[2]
[3]
power dissipation
capacitance
CPAB, CPBA; Fig. 7
per latch; VI = GND to VCC
[3]
Typical values are measured at Tamb = 25 °C
Typical values for VCC = 2.3 V to 2.7 V are measured at VCC = 2.5 V
Typical values for VCC = 3.0 V to 3.6 V are measured at VCC = 3.3 V
tpd is the same as tPHL and tPLH;
ten is the same as tPZH and tPZL;
tdis is the same as tPHZ and tPLZ.
CPD is used to determine the dynamic power dissipation (PD in μW):
2
2
PD = CPD x VCC x fi x N + ∑(CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
∑(CL x VCC x fo) = sum of outputs.
74ALVCH162601
Product data sheet
9 / 15
74ALVCH162601
Nexperia
10.1. Waveforms and test circuit
VI
An, Bn
input
VM
VM
tPHL
tPLH
GND
VOH
Bn, An
output
VM
VM
VOL
001aal734
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 6.
The input (An, Bn) to output (Bn, An) propagation delays.
1/fmax
LEBA, LEAB
CPBA, CPAB
input
VI
VM
VM
VM
GND
tW
tPHL
tPLH
VOH
An, Bn
output
VM
VM
VOL
aaa-028857
Fig. 7.
Latch enable input (LEAB, LEBA) and clock input (CPAB, CPBA) to output (Bn, An) propagation delays;
clock (CPAB, CPBA) pulse width and clock (CPAB, CPBA) maximum frequency
VI
OEAB, OEBA
input
VM
VM
GND
tPLZ
An, Bn output
LOW-to-OFF
OFF-to-LOW
tPZL
VCC
VM
VX
VOL
tPHZ
An, Bn output
HIGH-to-OFF
OFF-to-HIGH
VOH
tPZH
VY
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
aaa-028033
Fig. 8.
3-state enable and disable times.
74ALVCH162601
Product data sheet
10 / 15
74ALVCH162601
Nexperia
An, Bn
input
VI
VM
VM
VM
VM
GND
tsu
VI
CPAB, CPBA,
LEAB, LEBA
input GND
th
tsu
th
VM
VM
aaa-028858
The shaded areas indicate when the input is permitted to change for predictable output performance.
Fig. 9.
Data set-up and hold times for An and Bn inputs to LEAB, LEBA, CPAB or CPBA inputs.
Table 8. Measurement points
Supply voltage
Input
Output
VCC
VI
VM
VM
VX
VY
2.3 V to 2.7 V
VCC
0.5 VCC
0.5 VCC
VOL + 0.15 V
VOH - 0.15 V
2.7 V
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
3.0 V to 3.6 V
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
001aae331
Test data is given in Table 9.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 10. Test circuit for measuring switching times
Table 9. Test data
Supply voltage
Input
VCC
VI
tr, tf
CL
RL
tPLH, tPHL
tPLZ, tPZL
tPHZ, tPZH
2.3 V to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
2 × VCC
GND
2.7 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
2 × VCC
GND
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
2 × VCC
GND
74ALVCH162601
Product data sheet
Load
VEXT
11 / 15
74ALVCH162601
Nexperia
11. Package outline
TSSOP56: plastic thin shrink small outline package; 56 leads; body width 6.1 mm
SOT364-1
E
D
A
X
c
HE
y
v M A
Z
56
29
Q
A2
(A 3 )
A1
pin 1 index
A
θ
Lp
L
1
28
w M
bp
e
detail X
2.5
5 mm
scale
DIMENSIONS (mm are the original dimensions).
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z
θ
mm
1.2
0.15
0.05
1.05
0.85
0.25
0.28
0.17
0.2
0.1
14.1
13.9
6.2
6.0
0.5
8.3
7.9
1
0.8
0.4
0.50
0.35
0.25
0.08
0.1
0.5
0.1
8
o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT364-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Fig. 11. Package outline SOT364-1 (TSSOP56)
74ALVCH162601
Product data sheet
12 / 15
74ALVCH162601
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74ALVCH162601 v.2
20180813
Product data sheet
74ALVCH162601 v.1
Modifications:
74ALVCH162601 v.1
74ALVCH162601
Product data sheet
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
19991014
Product specification
13 / 15
74ALVCH162601
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74ALVCH162601
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
14 / 15
74ALVCH162601
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................4
5.1. Pinning.........................................................................4
5.2. Pin description............................................................. 5
6. Functional description................................................. 5
7. Limiting values............................................................. 6
8. Recommended operating conditions..........................6
9. Static characteristics....................................................7
10. Dynamic characteristics............................................ 8
10.1. Waveforms and test circuit...................................... 10
11. Package outline........................................................ 12
12. Abbreviations............................................................ 13
13. Revision history........................................................13
14. Legal information......................................................14
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 13 August 2018
74ALVCH162601
Product data sheet
15 / 15
