74AHC373D,118
74AHC373D,118
    NEXPERIA(安世)
    SOIC20_300MIL
    八进制D型透明锁;3-状态
74AHC373D,118 数据手册
74AHC373 Octal D-type transparant latch; 3-state Rev. 4 — 5 March 2019 Product data sheet 1. General description The 74AHC373 is a high-speed Si-gate CMOS device and is pin compatible with Low-power Schottky TTL (LSTTL). It is specified in compliance with JEDEC standard No. 7-A. The 74AHC373 consists of eight D-type transparent latches featuring separate D-type inputs for each latch and 3-state true outputs for bus oriented applications. A latch enable input (LE) and an output enable input (OE) are common to all latches. When pin LE is HIGH, data at the Dn inputs enters the latches. In this condition the latches are transparent, i.e. a latch output will change state each time its corresponding Dn input changes. When pin LE is LOW, the latches store the information that is present at the Dn inputs, after a set-up time preceding the HIGH-to-LOW transition of LE. When pin OE is LOW, the contents of the 8 latches are available at the outputs. When pin OE is HIGH, the outputs go to the high-impedance OFF-state. Operation of the OE input does not affect the state of the latches. The 74AHC373 is functionally identical to the 74AHC573; 74AHCT573, but has a different pin arrangement. 2. Features and benefits • • • • • • • • Balanced propagation delays All inputs have a Schmitt-trigger action Common 3-state output enable input Inputs accepts voltages higher than VCC Functionally identical to the 74AHC573; 74AHCT573 Input levels at CMOS input level ESD protection: • HBM EIA/JESD22-A114E exceeds 2000 V • MM EIA/JESD22-A115-A exceeds 200 V • CDM EIA/JESD22-C101C exceeds 1000 V Specified from -40 °C to +85 °C and from -40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AHC373D -40 °C to +125 °C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 74AHC373PW -40 °C to +125 °C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 74AHC373 Nexperia Octal D-type transparant latch; 3-state 4. Functional diagram D0 D1 D2 D3 D4 D5 D6 D7 3 4 7 8 13 14 17 18 LATCH 1 TO 8 3-STATE OUTPUTS Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 2 5 6 9 12 15 16 19 LE 11 OE 1 001aae050 Fig. 1. Functional diagram 1 OE LE 11 3 4 7 8 13 14 17 18 LE D0 Q0 D1 Q1 D2 Q2 D3 Q3 D4 Q4 D5 Q5 D6 Q6 D7 OE Q7 1 Fig. 2. 5 D1 6 D2 9 D4 15 D5 16 D6 19 D7 Q 7 6 8 9 13 12 14 15 17 16 18 19 D2 D Q Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 001aae049 Fig. 3. D1 D 5 001aae048 Logic symbol D0 2 1D 4 D3 12 C1 3 D0 2 EN 11 D3 D Q IEC logic symbol D4 D Q D5 D Q D6 D Q D7 D Q D Q LATCH 1 LATCH 2 LATCH 3 LATCH 4 LATCH 5 LATCH 6 LATCH 7 LATCH 8 LE LE LE LE LE LE LE LE LE LE LE LE LE LE LE LE LE OE Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 001aae052 Fig. 4. Logic diagram 74AHC373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 5 March 2019 © Nexperia B.V. 2019. All rights reserved 2 / 13 74AHC373 Nexperia Octal D-type transparant latch; 3-state LE LE LE D Q LE Fig. 5. 001aae051 Logic diagram (one latch) 5. Pinning information 5.1. Pinning 74AHC373 OE 1 20 VCC Q0 2 19 Q7 D0 3 18 D7 D1 4 17 D6 Q1 5 16 Q6 Q2 6 15 Q5 D2 7 14 D5 D3 8 13 D4 Q3 9 12 Q4 GND 10 11 LE 001aai132 Fig. 6. Pin configuration SOT163-1 (SO20) and SOT360-1 (TSSOP20) 5.2. Pin description Table 2. Pin description Symbol Pin Description OE 1 3-state output enable input (active LOW) Q0, Q1, Q2, Q3, Q4, Q5, Q6, Q7 2, 5, 6, 9, 12, 15, 16, 19 3-state latch output D0, D1, D2, D3, D4, D5, D6, D7 3, 4, 7, 8, 13, 14, 17, 18 data input GND 10 ground (0 V) LE 11 latch enable input (active HIGH) VCC 20 supply voltage 74AHC373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 5 March 2019 © Nexperia B.V. 2019. All rights reserved 3 / 13 74AHC373 Nexperia Octal D-type transparant latch; 3-state 6. Functional description Table 3. Function table H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the HIGH-to-LOW LE transition; L = LOW voltage level; l = LOW voltage level one set-up time prior to the HIGH-to-LOW LE transition; X = don’t care; Z = high-impedance OFF-state. Operating mode Input Control Output LE Dn Internal latch Enable and read register (transparent mode) L H L L L H H H Latch and read register L l L L h H H X X Z X X Z OE Latch register and disable outputs L H X Q0 to Q7 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +7.0 V V VCC supply voltage VI input voltage -0.5 +7.0 IIK input clamping current VI < -0.5 V [1] -20 - mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V [1] -20 +20 mA IO output current VO = -0.5 V to (VCC + 0.5 V) -25 +25 mA ICC supply current - +75 mA IGND ground current -75 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW Min Typ Max Unit 2.0 5.0 5.5 V [1] [2] Tamb = -40 °C to +125 °C [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SO20 packages: above 70 °C the value of Ptot derates linearly at 8 mW/K. For TSSOP20 packages: above 60 °C the value of Ptot derates linearly at 5.5 mW/K. 8. Recommended operating conditions Table 5. Operating conditions Symbol Parameter Conditions VCC supply voltage VI input voltage 0 - 5.5 V VO output voltage 0 - VCC V Tamb ambient temperature Δt/ΔV input transition rise and fall rate 74AHC373 Product data sheet -40 +25 +125 °C VCC = 3.0 V to 3.6 V - - 100 ns/V VCC = 4.5 V to 5.5 V - - 20 ns/V All information provided in this document is subject to legal disclaimers. Rev. 4 — 5 March 2019 © Nexperia B.V. 2019. All rights reserved 4 / 13 74AHC373 Nexperia Octal D-type transparant latch; 3-state 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 - - 1.5 - 1.5 - V VCC = 3.0 V 2.1 - - 2.1 - 2.1 - V VCC = 5.5 V 3.85 - - 3.85 - 3.85 - V VCC = 2.0 V - - 0.5 - 0.5 - 0.5 V VCC = 3.0 V - - 0.9 - 0.9 - 0.9 V VCC = 5.5 V - - 1.65 - 1.65 - 1.65 V IO = -50 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -50 μA; VCC = 3.0 V 2.9 3.0 - 2.9 - 2.9 - V IO = -50 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -4.0 mA; VCC = 3.0 V 2.58 - - 2.48 - 2.40 - V IO = -8.0 mA; VCC = 4.5 V 3.94 - - 3.80 - 3.70 - V IO = 50 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 μA; VCC = 3.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 3.0 V - - 0.36 - 0.44 - 0.55 V IO = 8.0 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V ±10.0 μA VI = VIH or VIL VI = VIH or VIL IOZ OFF-state VI = VIH or VIL; output current VO = VCC or GND; VCC = 5.5 V - - ±0.25 - ±2.5 - II input leakage VI = VCC or GND; current VCC = 0 V to 5.5 V - - 0.1 - 1.0 - 2.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 4.0 - 40 - 80 μA CI input capacitance VI = VCC or GND - 3 10 - 10 - 10 pF CO output capacitance - 4 - - - - 10 pF 74AHC373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 5 March 2019 © Nexperia B.V. 2019. All rights reserved 5 / 13 74AHC373 Nexperia Octal D-type transparant latch; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 11. Symbol Parameter tpd propagation delay Conditions 25 °C enable time tdis disable time tW pulse width tsu set-up time th hold time CPD [1] [2] [3] [4] [5] power dissipation capacitance -40 °C to +125 °C Unit Min Typ [1] Max Min Max Min Max VCC = 3.0 V to 3.6 V; CL = 15 pF - 6.0 11.4 1.0 13.5 1.0 14.5 ns VCC = 3.0 V to 3.6 V; CL = 50 pF - 7.8 14.9 1.0 17.0 1.0 19.0 ns VCC = 4.5 V to 5.5 V; CL = 15 pF - 4.0 7.2 1.0 8.5 1.0 9.0 VCC = 4.5 V to 5.5 V; CL = 50 pF - 5.3 9.2 1.0 10.5 1.0 11.5 ns VCC = 3.0 V to 3.6 V; CL = 15 pF - 6.3 11.0 1.0 13.0 1.0 14.0 ns VCC = 3.0 V to 3.6 V; CL = 50 pF - 8.3 14.5 1.0 16.5 1.0 18.5 ns VCC = 4.5 V to 5.5 V; CL = 15 pF - 4.3 7.2 1.0 8.5 1.0 9.0 VCC = 4.5 V to 5.5 V; CL = 50 pF - 5.6 9.7 1.0 11.1 1.0 12.5 ns VCC = 3.0 V to 3.6 V; CL = 15 pF - 5.6 11.4 1.0 13.5 1.0 14.5 ns VCC = 3.0 V to 3.6 V; CL = 50 pF - 7.5 14.9 1.0 17.0 1.0 19.0 ns VCC = 4.5 V to 5.5 V; CL = 15 pF - 3.8 8.1 1.0 9.5 1.0 10.5 ns VCC = 4.5 V to 5.5 V; CL = 50 pF - 5.2 10.1 1.0 11.5 1.0 13.0 ns VCC = 3.0 V to 3.6 V; CL = 15 pF - 5.6 10.0 1.0 12.0 1.0 13.0 ns VCC = 3.0 V to 3.6 V; CL = 50 pF - 9.2 13.3 1.0 15.0 1.0 17.0 ns VCC = 4.5 V to 5.5 V; CL = 15 pF - 4.3 7.2 1.0 8.5 1.0 9.5 VCC = 4.5 V to 5.5 V; CL = 50 pF - 6.4 9.2 1.0 10.5 1.0 11.5 ns VCC = 3.0 V to 3.6 V 5.0 - - 5.0 - 5.0 - ns VCC = 4.5 V to 5.5 V 5.0 - - 5.0 - 5.0 - ns VCC = 3.0 V to 3.6 V 4.0 - - 4.0 - 4.0 - ns VCC = 4.5 V to 5.5 V 4.0 - - 4.0 - 4.0 - ns VCC = 3.0 V to 3.6 V 1.0 - - 1.0 - 1.0 - ns VCC = 4.5 V to 5.5 V 1.0 - - 1.0 - 1.0 - ns - 10 - - - - - pF Dn to Qn; see Fig. 7 [2] LE to Qn; see Fig. 8 ten -40 °C to +85 °C ns [2] OE to Qn; see Fig. 9 ns [3] OE to Qn; see Fig. 9 [4] ns LE HIGH or LOW; see Fig. 8 Dn to LE; see Fig. 10 Dn to LE; see Fig. 10 fi = 1 MHz; VI = GND to VCC [5] Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V). tpd is the same as tPHL and tPLH. ten is the same as tPZH and tPZL. tdis is the same as tPHZ and tPLZ. 2 2 CPD is used to determine the dynamic power dissipation (PD in μW). PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; 2 N = number of inputs switching; Σ(CL × VCC × fo) = sum of the outputs. 74AHC373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 5 March 2019 © Nexperia B.V. 2019. All rights reserved 6 / 13 74AHC373 Nexperia Octal D-type transparant latch; 3-state 10.1. Waveforms and test circuit VI VM Dn input GND tPLH tPHL VOH VM Qn output mna811 VOL Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 7. Data input to output propagation delays 1/fmax VI LE input VM GND tW t PHL t PLH VOH VM Qn output VOL mna812 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 8. Latch enable pulse width and input to output propagation delays VI OE input VM GND t PLZ Qn output LOW-to-OFF OFF-to-LOW t PZL VCC VM VX VOL t PZH t PHZ Qn output HIGH-to-OFF OFF-to-HIGH VOH VY VM GND outputs enabled outputs disabled outputs enabled mna813 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 9. Enable and disable times 74AHC373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 5 March 2019 © Nexperia B.V. 2019. All rights reserved 7 / 13 74AHC373 Nexperia Octal D-type transparant latch; 3-state VI VM Dn input GND th th t su t su VI LE input VM GND mna814 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. The shaded areas indicate when the input is permitted to change for predicable output performance. Fig. 10. Data set-up and hold times Table 8. Measurement points Input Output VM VM VX VY 0.5 × VCC 0.5 × VCC VOL + 0.3 V VOH - 0.3 V VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VCC VO RL RT S1 open CL 001aad983 Test data is given in Table 9. Definitions test circuit: RT = termination resistance should be equal to output impedance Zo of the pulse generator. CL = load capacitance including jig and probe capacitance. RL = load resistance. S1 = test selection switch. Fig. 11. Test circuit for measuring switching times Table 9. Test data Input Load VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ VCC ≤ 3.0 ns 15 pF, 50 pF 1 kΩ open GND VCC 74AHC373 Product data sheet S1 position All information provided in this document is subject to legal disclaimers. Rev. 4 — 5 March 2019 © Nexperia B.V. 2019. All rights reserved 8 / 13 74AHC373 Nexperia Octal D-type transparant latch; 3-state 11. Package outline SO20: plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 D E A X c y HE v M A Z 20 11 Q A2 A (A 3 ) A1 pin 1 index θ Lp L 1 10 e detail X w M bp 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 13.0 12.6 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.9 0.4 inches 0.1 0.012 0.096 0.004 0.089 0.01 0.019 0.013 0.014 0.009 0.51 0.49 0.30 0.29 0.05 0.419 0.043 0.055 0.394 0.016 0.043 0.039 0.01 0.01 0.004 0.035 0.016 Z (1) θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT163-1 075E04 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig. 12. Package outline SOT163-1 (SO20) 74AHC373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 5 March 2019 © Nexperia B.V. 2019. All rights reserved 9 / 13 74AHC373 Nexperia Octal D-type transparant latch; 3-state TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm D SOT360-1 E A X c HE y v M A Z 11 20 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 10 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 6.6 6.4 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT360-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Fig. 13. Package outline SOT360-1 (TSSOP20) 74AHC373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 5 March 2019 © Nexperia B.V. 2019. All rights reserved 10 / 13 74AHC373 Nexperia Octal D-type transparant latch; 3-state 12. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model LSTTL Low-power Schottky Transistor-Transistor Logic MM Machine Model 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AHC373 v.4 20190305 Product data sheet - Modifications: • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type numbers 74AHCT373D (SOT163-1) and 74AHCT373PW (SOT360-1) removed. 74AHC_AHCT373_3 20080520 Modifications: • • • 74AHC_AHCT373_3 Product data sheet - 74AHC_AHCT373_2 The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. Legal texts have been adapted to the new company name where appropriate. Table 6: conditions for the input leakage current have been changed. 74AHC_AHCT373_2 19991123 Product specification - 74AHC_AHCT373_1 74AHC_AHCT373_1 19981211 Product specification - - 74AHC373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 5 March 2019 © Nexperia B.V. 2019. All rights reserved 11 / 13 74AHC373 Nexperia Octal D-type transparant latch; 3-state 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74AHC373 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 4 — 5 March 2019 © Nexperia B.V. 2019. All rights reserved 12 / 13 74AHC373 Nexperia Octal D-type transparant latch; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 3 6. Functional description................................................. 4 7. Limiting values............................................................. 4 8. Recommended operating conditions..........................4 9. Static characteristics....................................................5 10. Dynamic characteristics............................................ 6 10.1. Waveforms and test circuit........................................ 7 11. Package outline.......................................................... 9 12. Abbreviations............................................................ 11 13. Revision history........................................................11 14. Legal information......................................................12 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 5 March 2019 74AHC373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 5 March 2019 © Nexperia B.V. 2019. All rights reserved 13 / 13
74AHC373D,118 价格&库存
很抱歉,暂时无法提供与“74AHC373D,118”相匹配的价格&库存,您可以联系我们找货
74AHC373D,118
  • 2000+1.995452000+0.24999
  • 4000+1.936724000+0.24263
  • 6000+1.907306000+0.23895
  • 10000+1.8747110000+0.23486
  • 14000+1.8556614000+0.23248
  • 20000+1.8373420000+0.23018
库存:1942
74AHC373D,118
  • 1+4.995011+0.62577
  • 10+3.5166610+0.44057
  • 25+3.1501525+0.39465
  • 100+2.74408100+0.34378
  • 250+2.55096250+0.31958
  • 500+2.43434500+0.30497
  • 1000+2.372251000+0.29720
库存:1942
