74HC4060D,652
74HC4060D,652
    NEXPERIA(安世)
    SOIC-16
    带振荡器的14级二进制纹波计数器
74HC4060D,652 数据手册
74HC4060; 74HCT4060 14-stage binary ripple counter with oscillator Rev. 5 — 8 May 2020 Product data sheet 1. General description The 74HC4060; 74HCT4060 is a 14-stage ripple-carry counter/divider and oscillator with three oscillator terminals (RS, RTC and CTC), ten buffered parallel outputs (Q3 to Q9 and Q11 to Q13) and an overriding asynchronous master reset (MR). The oscillator configuration allows design of either RC or crystal oscillator circuits. The oscillator may be replaced by an external clock signal at input RS. In this case, keep the oscillator pins (RTC and CTC) floating. The counter advances on the HIGH-to-LOW transition of RS. A HIGH level on MR clears all counter stages and forces all outputs LOW, independent of the other input conditions. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits • • • • • • • All active components on chip RC or crystal oscillator configuration Complies with JEDEC standard no. 7 A Input levels: • For 74HC4060: CMOS level • For 74HCT4060: TTL level ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V Multiple package options Specified from -40 °C to +85 °C and from -40 °C to +125 °C 3. Applications • • • • Control counters Timers Frequency dividers Time-delay circuits 74HC4060; 74HCT4060 Nexperia 14-stage binary ripple counter with oscillator 4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version -40 °C to +125 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74HC4060DB -40 °C to +125 °C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 74HC4060PW -40 °C to +125 °C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74HC4060BQ -40 °C to +125 °C DHVQFN16 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 16 terminals; body 2.5 × 3.5 × 0.85 mm 74HC4060D 74HCT4060D 74HCT4060BQ SOT763-1 5. Functional diagram 10 9 CTR14 RTC CTC 11 12 RS MR Q3 7 Q4 5 Q5 4 Q6 6 Q7 14 Q8 13 Q9 15 Q11 1 Q12 2 Q13 3 !G CTC 9 Logic symbol 11 RS 6 11 12 MR 14 12 MR 4 AND 9 15 11 1 6 + 14 CT 13 CT = 0 13 9 15 11 1 2 3 13 (a) (b) 3 001aai468 IEC logic symbol 9 CTC CP MR 14-STAGE BINARY COUNTER Q3 7 Fig. 3. CT 13 RTC 12 4 + 7 5 RTC 2 Fig. 2. RS 3 5 CT = 0 10 11 7 10 001aai467 Fig. 1. CTR14 3 Q4 5 Q5 4 Q6 6 Q7 14 Q8 13 Q9 15 Q11 Q12 Q13 1 2 3 001aai113 Functional diagram 74HC_HCT4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 May 2020 © Nexperia B.V. 2020. All rights reserved 2 / 20 74HC4060; 74HCT4060 Nexperia 14-stage binary ripple counter with oscillator CTC FF 1 RTC RS FF 4 CP FF 10 CP Q CP Q MR FF 12 MR CP CP Q MR Q MR Q3 FF 14 Q MR Q9 MR Q11 Q13 001aai114 Fig. 4. Logic diagram 6. Pinning information 6.1. Pinning 1 16 VCC terminal 1 index area 74HC4060 74HCT4060 Q12 2 15 Q9 Q11 1 16 VCC Q13 3 14 Q7 Q12 2 15 Q9 Q5 4 13 Q8 Q13 3 14 Q7 Q4 5 Q6 6 Q3 7 12 MR 4 13 Q8 Q4 5 12 MR 8 9 Q6 6 11 RS GND CTC VCC(1) Q5 Q3 7 10 RTC GND 8 9 11 RS 10 RTC 001aai469 Transparent top view (1) This is not a supply pin. There is no electrical or mechanical requirement to solder the pad. In case soldered, the solder land should remain floating or connected to VCC CTC 001aai115 Fig. 5. Q11 74HC4060 74HCT4060 Pin configuration SOT109-1 (SO16), SOT338-1 (SSOP16) and SOT403-1 (TSSOP16) Fig. 6. Pin configuration SOT763-1 (DHVQFN16) 6.2. Pin description Table 2. Pin description Symbol Pin Description Q11, Q12, Q13 1, 2, 3 counter output Q3, Q4, Q5, Q6, Q7, Q8, Q9 7, 5, 4, 6, 14, 13, 15 counter output GND 8 ground (0 V) CTC 9 external capacitor connection RTC 10 external resistor connection RS 11 clock input /oscillator pin MR 12 master reset input (active HIGH) VCC 16 supply voltage 74HC_HCT4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 May 2020 © Nexperia B.V. 2020. All rights reserved 3 / 20 74HC4060; 74HCT4060 Nexperia 14-stage binary ripple counter with oscillator 7. Functional description 1 2 4 8 16 32 64 128 256 512 1024 2048 4096 8192 16384 RS MR Q3 Q4 Q5 Q6 Q7 Q8 Q9 Q11 Q12 Q13 001aai117 Fig. 7. Timing diagram 8. Limiting values Table 3. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit VCC supply voltage -0.5 +7 V IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V [1] - ±20 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V [1] - ±20 mA IO output current -0.5 V < VO < VCC + 0.5 V - ±25 mA ICC supply current - 50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [2] Tamb = -40 °C to +125 °C [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C. For SOT338-1 (SSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C. For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C. For SOT763-1 (DHVQFN16) package: Ptot derates linearly with 11.2 mW/K above 106 °C. 74HC_HCT4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 May 2020 © Nexperia B.V. 2020. All rights reserved 4 / 20 74HC4060; 74HCT4060 Nexperia 14-stage binary ripple counter with oscillator 9. Recommended operating conditions Table 4. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC4060 74HCT4060 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 - +125 -40 - +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 10. Static characteristics Table 5. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max MR input HIGH-level input voltage VCC = 2.0 V 1.5 1.3 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.1 - 4.2 - 4.2 - V VCC = 2.0 V 1.7 - - 1.7 - 1.7 - V VCC = 4.5 V 3.6 - - 3.6 - 3.6 - V VCC = 6.0 V 74HC4060 VIH RS input VIL 4.8 - - 4.8 - 4.8 - V MR input LOW-level input voltage VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V VCC = 2.0 V - - 0.3 - 0.3 - 0.3 V VCC = 4.5 V - - 0.9 - 0.9 - 0.9 V VCC = 6.0 V - - 1.2 - 1.2 - 1.2 V RS input 74HC_HCT4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 May 2020 © Nexperia B.V. 2020. All rights reserved 5 / 20 74HC4060; 74HCT4060 Nexperia 14-stage binary ripple counter with oscillator Symbol Parameter VOH HIGH-level output voltage Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -2.6 mA; VCC = 4.5 V 3.98 - - 3.84 - 3.7 - V IO = -3.3 mA; VCC = 6.0 V 5.48 - - 5.34 - 5.2 - V IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -0.65 mA; VCC = 4.5 V 3.98 - - 3.84 - 3.7 - V IO = -0.85 mA; VCC = 6.0 V 5.48 - - 5.34 - 5.2 - V IO = -3.2 mA; VCC = 4.5 V 3.98 - - 3.84 - 3.7 - V IO = -4.2 mA; VCC = 6.0 V 5.48 - - 5.34 - 5.2 - V IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 3.98 - - 3.84 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.48 - - 5.34 - 5.2 - V IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 2.6 mA; VCC = 4.5 V - - 0.26 - 0.33 - 0.4 V IO = 3.3 mA; VCC = 6.0 V - - 0.26 - 0.33 - 0.4 V IO = 3.2 mA; VCC = 4.5 V - - 0.26 - 0.33 - 0.4 V IO = 4.2 mA; VCC = 6.0 V - - 0.26 - 0.33 - 0.4 V IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - - 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - - 0.26 - 0.33 - 0.4 V RTC output; RS = MR = GND RTC output; RS = MR = VCC CTC output; RS = VIH; MR = VIL VI = VIH or VIL; except RTC output VI = VIH or VIL; except RTC and CTC outputs VOL LOW-level output voltage RTC output; RS = VCC; MR = GND CTC output; RS = VIL; MR = VIH VI = VIH or VIL; except RTC output VI = VIH or VIL; except RTC and CTC outputs 74HC_HCT4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 May 2020 © Nexperia B.V. 2020. All rights reserved 6 / 20 74HC4060; 74HCT4060 Nexperia 14-stage binary ripple counter with oscillator Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Min Typ Max Min Max Min Max Unit II input leakage VI = VCC or GND; VCC = 6.0 V current - - ±0.1 - ±1.0 - ±1.0 μA ICC supply current - - 8.0 - 80 - 160 μA CI input capacitance - 3.5 - - - - - pF 2.0 - - 2.0 - 2.0 - V 3.6 - - 3.6 - 3.6 - V - - 0.8 - 0.8 - 0.8 V - - 0.9 - 0.9 - 0.9 V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -0.65 mA; VCC = 4.5 V 3.98 - - 3.84 - 3.7 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -2.6 mA; VCC = 4.5 V 3.98 - - 3.84 - 3.7 - V 3.98 - - 3.84 - 3.7 - V 4.4 4.5 - 4.4 - 4.4 - V 3.98 - - 3.84 - 3.7 - V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 2.6 mA; VCC = 4.5 V - - 0.26 - 0.33 - 0.4 V - - 0.26 - 0.33 - 0.4 V - 0 0.1 - 0.1 - 0.1 V - - 0.26 - 0.33 - 0.4 V VI = VCC or GND; IO = 0 A; VCC = 6.0 V 74HCT4060 VIH MR input; VCC = 4.5 V to 5.5 V HIGH-level input voltage RS input; V = 4.5 V CC [1] VIL MR input; VCC = 4.5 V to 5.5 V LOW-level input voltage RS input; V = 4.5 V CC [1] VOH HIGH-level output voltage RTC output; RS = MR = VCC RTC output; RS = MR = GND CTC output; RS = VIH; MR = VIL IO = -3.2 mA; VCC = 4.5 V VI = VIH or VIL; except RTC output IO = -20 μA; VCC = 4.5 V VI = VIH or VIL; except RTC and CTC outputs IO = -4.0 mA; VCC = 4.5 V VOL LOW-level output voltage RTC output; RS = VCC; MR = GND CTC output; RS = VIL; MR = VIH IO = 3.2 mA; VCC = 4.5 V VI = VIH or VIL; except RTC output IO = 20 μA; VCC = 4.5 V VI = VIH or VIL; except RTC and CTC outputs IO = 4.0 mA; VCC = 4.5 V II input leakage VI = VCC or GND; VCC = 5.5 V current - - ±0.1 - ±1.0 - ±1.0 μA ICC supply current VI = VCC or GND; VCC = 5.5 V; IO = 0 A - - 8.0 - 80 - 160 μA ΔICC additional supply current per input pin; VI = VCC - 2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A - 40 144 - 180 - 196 μA CI input capacitance - 3.5 - - - - - pF [1] For HCT4060, only input MR (pin 12) has TTL input switching levels. 74HC_HCT4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 May 2020 © Nexperia B.V. 2020. All rights reserved 7 / 20 74HC4060; 74HCT4060 Nexperia 14-stage binary ripple counter with oscillator 11. Dynamic characteristics Table 6. Dynamic characteristics GND = 0 V; CL = 50 pF unless otherwise specified; for test circuit see Fig. 11. Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max - 99 300 - 375 - 450 ns VCC = 4.5 V - 36 60 - 75 - 90 ns VCC = 5.0 V; CL = 15 pF - 31 - - - - - ns - 29 51 - 64 - 77 ns VCC = 2.0 V - 22 80 - 100 - 120 ns VCC = 4.5 V - 8 16 - 20 - 24 ns VCC = 5.0 V; CL = 15 pF - 6 - - - - - ns VCC = 6.0 V - 6 14 - 17 - 20 ns - 55 175 - 220 - 265 ns - 20 35 - 44 - 53 ns - 17 - - - - - ns - 16 30 - 37 - 45 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns VCC = 2.0 V 80 17 - 100 - 120 - ns VCC = 4.5 V 16 6 - 20 - 24 - ns VCC = 6.0 V 14 5 - 17 - 20 - ns VCC = 2.0 V 80 25 - 100 - 120 - ns VCC = 4.5 V 16 9 - 20 - 24 - ns VCC = 6.0 V 14 7 - 17 - 20 - ns VCC = 2.0 V 100 28 - 125 - 150 - ns VCC = 4.5 V 20 10 - 25 - 30 - ns VCC = 6.0 V 17 8 - 21 - 26 - ns 74HC4060 tpd propagation RS to Q3; see Fig. 8 delay VCC = 2.0 V [1] VCC = 6.0 V Qn to Qn+1; see Fig. 9 tPHL [2] MR to Qn; see Fig. 10 HIGH to LOW VCC = 2.0 V propagation VCC = 4.5 V delay VCC = 5.0 V; CL = 15 pF VCC = 6.0 V tt tW transition time Qn; see Fig. 8 [3] pulse width RS (HIGH or LOW); see Fig. 8 MR (HIGH); see Fig. 10 trec recovery time 74HC_HCT4060 Product data sheet MR to RS; see Fig. 10 All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 May 2020 © Nexperia B.V. 2020. All rights reserved 8 / 20 74HC4060; 74HCT4060 Nexperia 14-stage binary ripple counter with oscillator Symbol Parameter fmax Conditions 25 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 6 26 - 4.8 - 4 - MHz VCC = 4.5 V 30 80 - 24 - 20 - MHz - 87 - - - - - MHz 35 95 - 28 - 24 - MHz - 40 - - - - - pF - 33 66 - 83 - 99 ns - 31 - - - - - ns VCC = 4.5 V - 8 16 - 20 - 24 ns VCC = 5.0 V; CL = 15 pF - 6 - - - - - ns MR to Qn; see Fig. 10 HIGH to LOW VCC = 4.5 V propagation VCC = 5.0 V; CL = 15 pF delay - 21 44 - 55 - 66 ns - 18 - - - - - ns - 7 15 - 19 - 22 ns 16 6 - 20 - 24 - ns 16 6 - 20 - 24 - ns 26 13 - 33 - 39 - ns 30 80 - 24 - 20 - MHz - 88 - - - - - MHz - 40 - - - - - pF maximum frequency RS; see Fig. 8 VCC = 5.0 V; CL = 15 pF VCC = 6.0 V CPD -40 °C to +85 °C power VI = GND to VCC; VCC = 5 V; dissipation fi = 1 MHz capacitance [4] 74HCT4060 propagation RS to Q3; see Fig. 8 delay VCC = 4.5 V tpd [1] VCC = 5.0 V; CL = 15 pF Qn to Qn+1; see Fig. 9 tPHL tt transition time [2] Qn; see Fig. 8 [3] VCC = 4.5 V pulse width RS (HIGH or LOW); see Fig. 8 tW VCC = 4.5 V MR (HIGH); see Fig. 10 VCC = 4.5 V trec fmax recovery time MR to RS; see Fig. 10 maximum frequency RS; see Fig. 8 VCC = 4.5 V VCC = 4.5 V VCC = 5.0 V; CL = 15 pF CPD [1] [2] [3] [4] power VI = GND to VCC - 1.5 V; dissipation VCC = 5 V; fi = 1 MHz capacitance [4] tpd is the same as tPHL and tPLH. Qn+1 is the next Qn output. tt is the same as tTHL and tTLH. CPD is used to determine the dynamic power dissipation (PD in μW): 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of outputs. 74HC_HCT4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 May 2020 © Nexperia B.V. 2020. All rights reserved 9 / 20 74HC4060; 74HCT4060 Nexperia 14-stage binary ripple counter with oscillator 11.1. Waveforms and test circuit 1/fmax VI RS input VM GND tW tPHL VOH tPLH 90 % 90 % VM Q3 output 10 % VOL 10 % tTHL tTLH 001aai118 Measurement points are given in Table 7. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 8. Waveforms showing the clock (RS) to output (Q3) propagation delays, the clock pulse width, the output transition times and the maximum clock frequency VOH Qn output VM VOL tPLH VOH tPHL VM Qn+1 output VOL 001aai120 Measurement points are given in Table 7. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 9. Waveforms showing the output Qn to output Qn+1 propagation delays VI MR input VM GND tW trec VI RS input VM GND VOH tPHL VM Qn output VOL 001aai119 Measurement points are given in Table 7. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 10. Waveforms showing the master reset (MR) pulse width, the master reset to output (Qn) propagation delays and the master reset to clock (RS) recovery time 74HC_HCT4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 May 2020 © Nexperia B.V. 2020. All rights reserved 10 / 20 74HC4060; 74HCT4060 Nexperia 14-stage binary ripple counter with oscillator Table 7. Measurement points Type Input Output VM VM 74HC4060 0.5 × VCC 0.5 × VCC 74HCT4060 1.3 V 1.3 V VI negative pulse VM tf tr tr VI GND VM 10 % GND positive pulse tW 90 % tf 90 % VM VM 10 % tW VCC G VI DUT VO RT CL 001aah768 Test data is given in Table 8. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. Fig. 11. Test circuit for measuring switching times Table 8. Test data Type Load Input VI tr, tf CL 74HC4060 VCC 6 ns 15 pF, 50 pF 74HCT4060 3V 6 ns 15 pF, 50 pF 12. RC oscillator 12.1. Timing component limitations The oscillator frequency is mainly determined by RtCt, provided R2 ≈ 2Rt and R2C2 50 pF, up to any practical value and 10 kΩ < Rt < 1 MΩ. In order to avoid start-up problems, Rt ≥ 1 kΩ. 12.2. Typical crystal oscillator circuit In Fig. 13, R2 is the power limiting resistor. For starting and maintaining oscillation a minimum transconductance is necessary, so R2 should not be too large. A practical value for R2 is 2.2 kΩ. MR (from logic) 74HC4060 74HCT4060 11 RS Rbias Rbias RTC 10 560 kΩ VDD 100 kΩ to 1MΩ 0.47 pF R2 2.2 kΩ C3 22 pF to 37 pF VI (fi = 1 kHz) output A IO 001aai123 gfs = ΔIO / ΔVI at VO is constant; MR = LOW. See also Fig. 15. Fig. 13. External component connection for a crystal oscillator Product data sheet input GND C2 100 pF 001aai122 74HC_HCT4060 100 µF Fig. 14. Test set-up for measuring forward transconductance All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 May 2020 © Nexperia B.V. 2020. All rights reserved 12 / 20 74HC4060; 74HCT4060 Nexperia 14-stage binary ripple counter with oscillator 001aai124 14 (1) gfs (mA/V) (2) 10 (3) 6 2 0 2 4 VCC (V) 6 (1) Maximum. (2) Typical. (3) Minimum. Tamb = 25 °C. Fig. 15. Typical forward transconductance as function of the supply voltage 001aai125 105 fosc (Hz) 001aai127 105 fosc (Hz) Rt 104 104 Ct 103 103 102 102 10 103 104 105 Rt (Ω) 106 10 10- 4 VCC = 2.0 V to 6.0 V; Tamb = 25 °C. For Rt curve: Ct = 1 nF; R2 = 2 × Rt. Product data sheet 10- 2 Ct (µF) 10- 1 VCC = 2.0 V to 6.0 V; Tamb = 25 °C. For Ct curve: Rt = 100 kΩ; R2 = 200 kΩ. Fig. 16. RC oscillator frequency as a function of Rt 74HC_HCT4060 10- 3 Fig. 17. RC oscillator frequency as a function of Ct All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 May 2020 © Nexperia B.V. 2020. All rights reserved 13 / 20 74HC4060; 74HCT4060 Nexperia 14-stage binary ripple counter with oscillator 13. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig. 18. Package outline SOT109-1 (SO16) 74HC_HCT4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 May 2020 © Nexperia B.V. 2020. All rights reserved 14 / 20 74HC4060; 74HCT4060 Nexperia 14-stage binary ripple counter with oscillator SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm D SOT338-1 E A X c y HE v M A Z 9 16 Q A2 A (A 3) A1 pin 1 index θ Lp L 8 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.00 0.55 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT338-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Fig. 19. Package outline SOT338-1 (SSOP16) 74HC_HCT4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 May 2020 © Nexperia B.V. 2020. All rights reserved 15 / 20 74HC4060; 74HCT4060 Nexperia 14-stage binary ripple counter with oscillator TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm D SOT403-1 E A X c y HE v M A Z 9 16 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 8 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 20. Package outline SOT403-1 (TSSOP16) 74HC_HCT4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 May 2020 © Nexperia B.V. 2020. All rights reserved 16 / 20 74HC4060; 74HCT4060 Nexperia 14-stage binary ripple counter with oscillator DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT763-1 16 terminals; body 2.5 x 3.5 x 0.85 mm B D A A E A1 c detail X terminal 1 index area terminal 1 index area C e1 e b 2 7 y y1 C v M C A B w M C L 1 8 Eh e 16 9 15 10 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 3.6 3.4 2.15 1.85 2.6 2.4 1.15 0.85 0.5 2.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT763-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig. 21. Package outline SOT763-1 (DHVQFN16) 74HC_HCT4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 May 2020 © Nexperia B.V. 2020. All rights reserved 17 / 20 74HC4060; 74HCT4060 Nexperia 14-stage binary ripple counter with oscillator 14. Abbreviations Table 9. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 15. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT4060 v.5 20200508 Product data sheet - Modifications: • • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type number 74HCT4060DB (SSOP16/SOT338-1) removed. Table 3: Derating values for Ptot total power dissipation updated. 74HC_HCT4060 v.4 20160210 Modifications: • • 74HC_HCT4060 v.3 20080714 Modifications: • • • • • 74HC_HCT4060_CNV v.2 74HC_HCT4060 Product data sheet 74HC_HCT4060 v.4 Product data sheet - 74HC_HCT4060 v.3 Type numbers 74HC4060N and 74HCT4060N (SOT38-4) removed. Table 5: HIGH and LOW input levels added for 74HCT4060. (errata) Product data sheet - 74HC_HCT4060_CNV v.2 The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. Legal texts have been adapted to the new company name where appropriate. Section 4: DHVQFN16 package added. Section 8: derating values added for DHVQFN16 package. Section 13: outline drawing added for DHVQFN16 package. 19970901 Product specification - All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 May 2020 - © Nexperia B.V. 2020. All rights reserved 18 / 20 74HC4060; 74HCT4060 Nexperia 14-stage binary ripple counter with oscillator 16. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74HC_HCT4060 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 May 2020 © Nexperia B.V. 2020. All rights reserved 19 / 20 74HC4060; 74HCT4060 Nexperia 14-stage binary ripple counter with oscillator Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Ordering information....................................................2 5. Functional diagram.......................................................2 6. Pinning information......................................................3 6.1. Pinning.........................................................................3 6.2. Pin description............................................................. 3 7. Functional description................................................. 4 8. Limiting values............................................................. 4 9. Recommended operating conditions..........................5 10. Static characteristics..................................................5 11. Dynamic characteristics.............................................8 11.1. Waveforms and test circuit.......................................10 12. RC oscillator............................................................. 11 12.1. Timing component limitations.................................. 11 12.2. Typical crystal oscillator circuit................................ 12 13. Package outline........................................................ 14 14. Abbreviations............................................................ 18 15. Revision history........................................................18 16. Legal information......................................................19 © Nexperia B.V. 2020. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 8 May 2020 74HC_HCT4060 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 May 2020 © Nexperia B.V. 2020. All rights reserved 20 / 20
74HC4060D,652 价格&库存
很抱歉,暂时无法提供与“74HC4060D,652”相匹配的价格&库存,您可以联系我们找货
