74HC161D,653
74HC161D,653
    NEXPERIA(安世)
    SOIC-16
    可预置同步4位二进制计数器;异步复位
74HC161D,653 数据手册
INTEGRATED CIRCUITS DATA SHEET For a complete data sheet, please also download: • The IC06 74HC/HCT/HCU/HCMOS Logic Family Specifications • The IC06 74HC/HCT/HCU/HCMOS Logic Package Information • The IC06 74HC/HCT/HCU/HCMOS Logic Package Outlines 74HC/HCT161 Presettable synchronous 4-bit binary counter; asynchronous reset Product specification File under Integrated Circuits, IC06 December 1990 Philips Semiconductors Product specification Presettable synchronous 4-bit binary counter; asynchronous reset 74HC/HCT161 input (PE) disables the counting action and causes the data at the data inputs (D0 to D3) to be loaded into the counter on the positive-going edge of the clock (providing that the set-up and hold time requirements for PE are met). Preset takes place regardless of the levels at count enable inputs (CEP and CET). FEATURES • Synchronous counting and loading • Two count enable inputs for n-bit cascading • Positive-edge triggered clock • Asynchronous reset A LOW level at the master reset input (MR) sets all four outputs of the flip-flops (Q0 to Q3) to LOW level regardless of the levels at CP, PE, CET and CEP inputs (thus providing an asynchronous clear function). • Output capability: standard • ICC category: MSI GENERAL DESCRIPTION The look-ahead carry simplifies serial cascading of the counters. Both count enable inputs (CEP and CET) must be HIGH to count. The CET input is fed forward to enable the terminal count output (TC). The TC output thus enabled will produce a HIGH output pulse of a duration approximately equal to a HIGH level output of Q0. This pulse can be used to enable the next cascaded stage. The 74HC/HCT161 are high-speed Si-gate CMOS devices and are pin compatible with low power Schottky TTL (LSTTL). They are specified in compliance with JEDEC standard no. 7A. The 74HC/HCT161 are synchronous presettable binary counters which feature an internal look-ahead carry and can be used for high-speed counting. Synchronous operation is provided by having all flip-flops clocked simultaneously on the positive-going edge of the clock (CP). The outputs (Q0 to Q3) of the counters may be preset to a HIGH or LOW level. A LOW level at the parallel enable The maximum clock frequency for the cascaded counters is determined by the CP to TC propagation delay and CEP to CP set-up time, according to the following formula: 1 fmax = --------------------------------------------------------------------------------------------------t P(max) (CP to TC) + t SU (CEP to CP) QUICK REFERENCE DATA GND = 0 V; Tamb = 25 °C; tr = tf = 6 ns Notes TYPICAL SYMBOL PARAMETER CONDITIONS UNIT HC tPHL/ tPLH propagation delay CP to Qn CP to TC MR to Qn MR to TC CET to TC CL = 15 pF; VCC = 5 V HCT 19 21 20 20 10 20 24 25 26 14 ns ns ns ns ns fi = input frequency in MHz fo = output frequency in MHz fmax maximum clock frequency 44 45 MHz CI input capacitance 3.5 3.5 pF CPD power dissipation capacitance per package 33 35 pF notes 1 and 2 1. CPD is used to determine the dynamic power dissipation (PD in µW): PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where: ∑ (CL × VCC2 × fo) = sum of outputs CL = output load capacitance in pF VCC = supply voltage in V 2. For HC the condition is VI = GND to VCC For HCT the condition is VI = GND to VCC − 1.5 V December 1990 2 Philips Semiconductors Product specification Presettable synchronous 4-bit binary counter; asynchronous reset 74HC/HCT161 ORDERING INFORMATION See “74HC/HCT/HCU/HCMOS Logic Package Information”. PIN DESCRIPTION PIN NO. SYMBOL NAME AND FUNCTION 1 MR asynchronous master reset (active LOW) 2 CP clock input (LOW-to-HIGH, edge-triggered) 3, 4, 5, 6 D0 to D3 data inputs 7 CEP count enable input 8 GND ground (0 V) 9 PE parallel enable input (active LOW) 10 CET count enable carry input 14, 13, 12, 11 Q0 to Q3 flip-flop outputs 15 TC terminal count output 16 VCC positive supply voltage Fig.1 Pin configuration. December 1990 Fig.2 Logic symbol. 3 Fig.3 IEC logic symbol. Philips Semiconductors Product specification Presettable synchronous 4-bit binary counter; asynchronous reset 74HC/HCT161 Fig.4 Functional diagram. FUNCTION TABLE INPUTS OUTPUTS OPERATING MODE MR CP CEP CET PE Dn Qn TC reset (clear) L X X X X X L L parallel load H H ↑ ↑ X X X X I I I h L H (1) count H ↑ h h h X count (1) hold (do nothing) H H X X I X X I h h X X qn qn (1) Note 1. The TC output is HIGH when CET is HIGH and the counter is at terminal count (HHHH). H = HIGH voltage level h = HIGH voltage level one set-up time prior to the LOW-to-HIGH CP transition L = LOW voltage level I = LOW voltage level one set-up time prior to the LOW-to-HIGH CP transition q = lower case letters indicate the state of the referenced output one set-up time prior to the LOW-to-HIGH CP transition X = don’t care ↑ = LOW-to-HIGH CP transition December 1990 4 L L Philips Semiconductors Product specification Presettable synchronous 4-bit binary counter; asynchronous reset 74HC/HCT161 Fig.5 State diagram. Fig.6 Typical timing sequence: reset outputs to zero; preset to binary twelve; count to thirteen, fourteen, fifteen, zero, one and two; inhibit. December 1990 5 Philips Semiconductors Product specification Presettable synchronous 4-bit binary counter; asynchronous reset 74HC/HCT161 Fig.7 Logic diagram. December 1990 6 Philips Semiconductors Product specification Presettable synchronous 4-bit binary counter; asynchronous reset 74HC/HCT161 DC CHARACTERISTICS FOR 74HC For the DC characteristics see “74HC/HCT/HCU/HCMOS Logic Family Specifications”. Output capability: standard ICC category: MSI AC CHARACTERISTICS FOR 74HC GND = 0 V; tr = tf = 6 ns; CL = 50 pF Tamb (°C) TEST CONDITIONS 74HC SYMBOL PARAMETER +25 min. typ. −40 to +85 max. min. max. −40 to +125 min. UNIT VCC WAVEFORMS (V) max. tPHL/ tPLH propagation delay CP to Qn 61 22 18 190 38 32 240 48 41 285 57 48 ns 2.0 4.5 6.0 Fig.8 tPHL/ tPLH propagation delay CP to TC 69 25 20 215 43 37 270 54 46 325 65 55 ns 2.0 4.5 6.0 Fig.8 tPHL propagation delay MR to Qn 63 23 18 210 42 36 265 53 45 315 63 54 ns 2.0 4.5 6.0 Fig.9 tPHL propagation delay MR to TC 63 23 18 220 44 37 275 55 47 330 66 56 ns 2.0 4.5 6.0 Fig.9 tPHL/ tPLH propagation delay CET to TC 33 12 10 150 30 26 190 38 33 225 45 38 ns 2.0 4.5 6.0 Fig.10 tTHL/ tTLH output transition time 19 7 6 75 15 13 95 19 16 110 22 19 ns 2.0 4.5 6.0 Figs 8 and 10 tW clock pulse width HIGH or LOW 80 16 14 22 8 6 100 20 17 120 24 20 ns 2.0 4.5 6.0 Fig.8 tW master reset pulse width; LOW 80 16 14 19 7 6 100 20 17 120 24 20 ns 2.0 4.5 6.0 Fig.9 trem removal time MR to CP 100 20 17 19 7 6 125 25 21 150 30 26 ns 2.0 4.5 6.0 Fig.9 tsu set-up time Dn to CP 80 16 14 25 9 7 100 20 17 120 24 20 ns 2.0 4.5 6.0 Fig.11 tsu set-up time PE to CP 100 20 17 30 11 9 125 25 21 150 30 26 ns 2.0 4.5 6.0 Fig.11 December 1990 7 Philips Semiconductors Product specification Presettable synchronous 4-bit binary counter; asynchronous reset 74HC/HCT161 Tamb (°C) TEST CONDITIONS 74HC SYMBOL PARAMETER +25 min. typ. −40 to +85 max. −40 to +125 min. max. min. UNIT VCC WAVEFORMS (V) max. tsu set-up time CEP, CET to CP 170 34 29 47 17 14 215 43 37 255 51 43 ns 2.0 4.5 6.0 Fig.12 th hold time Dn, PE, CEP, CET to CP 0 0 0 −14 −5 −4 0 0 0 0 0 0 ns 2.0 4.5 6.0 Figs 11 and 12 fmax maximum clock pulse 4.6 frequency 23 27 13 40 48 3.6 18 21 3.0 15 18 MHz 2.0 4.5 6.0 Fig.8 December 1990 8 Philips Semiconductors Product specification Presettable synchronous 4-bit binary counter; asynchronous reset 74HC/HCT161 DC CHARACTERISTICS FOR 74HCT For the DC characteristics see “74HC/HCT/HCU/HCMOS Logic Family Specifications”. Output capability: standard ICC category: MSI Note to HCT types The value of additional quiescent supply current (∆ICC) for a unit load of 1 is given in the family specifications. To determine ∆ICC per input, multiply this value by the unit load coefficient shown in the table below. INPUT UNIT LOAD COEFFICIENT MR 0.95 CP 1.10 CEP 0.25 Dn 0.25 CET 0.75 PE 0.30 AC CHARACTERISTICS FOR 74HCT GND = 0 V; tr = tf = 6 ns; CL = 50 pF Tamb (°C) TEST CONDITIONS 74HCT SYMBOL PARAMETER +25 min. −40 to +85 typ. max. min. max. −40 to +125 min. UNIT VCC (V) WAVEFORMS max. tPHL/ tPLH propagation delay CP to Qn 23 43 54 65 ns 4.5 Fig.8 tPHL/ tPLH propagation delay CP to TC 28 48 60 72 ns 4.5 Fig.8 tPHL propagation delay MR to Qn 29 46 58 69 ns 4.5 Fig.9 tPHL propagation delay MR to TC 30 51 64 77 ns 4.5 Fig.9 tPHL/ tPLH propagation delay CET to TC 17 35 44 53 ns 4.5 Fig.10 tTHL/ tTLH output transition time 7 15 19 22 ns 4.5 Figs 8 and 10 tW clock pulse width HIGH or LOW 16 7 20 24 ns 4.5 Fig.8 tW master reset pulse width; LOW 20 10 25 30 ns 4.5 Fig.9 trem removal time MR to CP 20 6 25 30 ns 4.5 Fig.9 December 1990 9 Philips Semiconductors Product specification Presettable synchronous 4-bit binary counter; asynchronous reset 74HC/HCT161 Tamb (°C) TEST CONDITIONS 74HCT SYMBOL PARAMETER +25 min. typ. −40 to +85 max. min. max. −40 to +125 min. UNIT VCC (V) WAVEFORMS max. tsu set-up time Dn to CP 18 8 23 27 ns 4.5 Fig.11 tsu set-up time PE to CP 30 17 38 45 ns 4.5 Fig.11 tsu set-up time CEP, CET to CP 40 17 50 60 ns 4.5 Fig.12 th hold time Dn, PE, CEP, CET to CP 0 −7 0 0 ns 4.5 Figs 11 and 12 fmax maximum clock pulse 23 frequency 41 18 15 MHz 4.5 Fig.8 December 1990 10 Philips Semiconductors Product specification Presettable synchronous 4-bit binary counter; asynchronous reset 74HC/HCT161 AC WAVEFORMS (1) HC : VM = 50%; VI = GND to VCC. HCT: VM = 1.3 V; VI = GND to 3 V. Fig.8 Waveforms showing the clock (CP) to outputs (Qn, TC) propagation delays, the clock pulse width, the output transition times and the maximum clock frequency. (1) HC : VM = 50%; VI = GND to VCC. HCT: VM = 1.3 V; VI = GND to 3 V. Fig.9 Waveforms showing the master reset (MR) pulse width, the master reset to output (Qn, TC) propagation delays and the master reset to clock (CP) removal time. (1) HC : VM = 50%; VI = GND to VCC. HCT: VM = 1.3 V; VI = GND to 3 V. Fig.10 Waveforms showing the input (CET) to output (TC) propagation delays and output transition times. December 1990 11 Philips Semiconductors Product specification Presettable synchronous 4-bit binary counter; asynchronous reset 74HC/HCT161 The shaded areas indicate when the input is permitted to change for predictable output performance. (1) HC : VM = 50%; VI = GND to VCC. HCT: VM = 1.3 V; VI = GND to 3 V. Fig.11 Waveforms showing the set-up and hold times for the input (Dn) and parallel enable input PE. The shaded areas indicate when the input is permitted to change for predictable output performance. (1) HC : VM = 50%; VI = GND to VCC. HCT: VM = 1.3 V; VI = GND to 3 V. Fig.12 Waveforms showing the CEP and CET set-up and hold times. PACKAGE OUTLINES See “74HC/HCT/HCU/HCMOS Logic Package Outlines”. December 1990 12 This datasheet has been download from: www.datasheetcatalog.com Datasheets for electronics components.
74HC161D,653 价格&库存
很抱歉,暂时无法提供与“74HC161D,653”相匹配的价格&库存,您可以联系我们找货
74HC161D,653
    74HC161D,653
    • 1+3.56030
    • 30+3.46901
    • 100+3.28643
    • 500+3.10385
    • 1000+3.01257
    74HC161D,653
    • 2500+1.249712500+0.15672
    • 5000+1.211675000+0.15195
    • 7500+1.192657500+0.14956
    • 12500+1.1715412500+0.14692
    • 17500+1.1592217500+0.14537
    • 25000+1.1473525000+0.14388
    • 62500+1.1218262500+0.14068
    库存:11127
    74HC161D,653
    • 1+2.898701+0.36350
    • 10+1.7608010+0.22080
    • 100+1.52120100+0.19080
    • 200+1.40140200+0.17580
    • 500+1.32960500+0.16680
    • 1000+1.269701000+0.15930
    • 2500+1.197802500+0.15020
    • 5000+1.166705000+0.14630
    库存:5175
