74HC40103D,653
74HC40103D,653
    NEXPERIA(安世)
    SOIC-16
    8位同步二进制下行计数器
74HC40103D,653 数据手册
74HC40103 8-bit synchronous binary down counter Rev. 5 — 21 April 2016 Product data sheet 1. General description The 74HC40103 is an 8-bit synchronous down counter. It has control inputs for enabling or disabling the clock (CP), for clearing the counter to its maximum count and for presetting the counter either synchronously or asynchronously. In normal operation, the counter is decremented by one count on each positive-going transition of the clock (CP). Counting is inhibited when the terminal enable input (TE) is HIGH. The terminal count output (TC) goes LOW when the count reaches zero if TE is LOW, and remains LOW for one full clock period. When the synchronous preset enable input (PE) is LOW, data at the jam input (P0 to P7) is clocked into the counter on the next positive-going clock transition regardless of the state of TE. When the asynchronous preset enable input (PL) is LOW, data at the jam input (P0 to P7) is asynchronously forced into the counter regardless of the state of PE, TE, or CP. The jam inputs (P0 to P7) represent a single 8-bit binary word. When the master reset input (MR) is LOW, the counter is asynchronously cleared to its maximum count (decimal 255) regardless of the state of any other input. If all control inputs except TE are HIGH at the time of zero count, the counters will jump to the maximum count, giving a counting sequence of 256 clock pulses long. Device may be cascaded using the TE input and the TC output, in either a synchronous or ripple mode. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits       Cascadable Synchronous or asynchronous preset Low-power dissipation Complies with JEDEC standard no. 7A CMOS input levels ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +80 C and from 40 C to +125 C 3. Applications     Divide-by-n counters Programmable timers Interrupt timers Cycle/program counters. 74HC40103 Nexperia 8-bit synchronous binary down counter 4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74HC40103D 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74HC40103PW 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; SOT403-1 body width 4.4 mm 5. Functional diagram  7& 3   3  3   3   3    3   &3  3   3    3( 3/ 7( 05    Functional diagram 74HC40103 Product data sheet  3 3 3 3 7& 3  3 3 3 3(   05  DDE DDE Fig 1.  &3 3/ 7( Fig 2. Logic symbol All information provided in this document is subject to legal disclaimers. Rev. 5 — 21 April 2016 © Nexperia B.V. 2017. All rights reserved 2 of 23 74HC40103 Nexperia 8-bit synchronous binary down counter &75  &7   &*  *  (1   &      &7    &7     DDE Fig 3. IEC logic symbol &3 05 7( 3( 3/ 3 3 3 3 3 3 3 3 7& FRXQW                    DDE Fig 4. Timing diagram 74HC40103 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 21 April 2016 © Nexperia B.V. 2017. All rights reserved 3 of 23 xxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxx x x x xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxx xx xx xxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxx xxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxx x x xxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxx xxx 3/ &3 7& 05 3 3 - - 3 - Rev. 5 — 21 April 2016 - 3/ - 05 ))  3( 3/ ))  - - 3/ ))  - - 3/ ))  - - 3/ ))  - - 3/ ))  4 4 &3 3/ ))  3( 7( - 05 4 &3 3( 7( 3 05 4 &3 3( 7( 3 05 4 &3 3( 7( 3 05 4 &3 3( 7( 3 05 4 &3 3( 7( - 05 4 &3 3 &3 3/ ))  3( 7( 7( WRRWKHU IOLSIORSV 7( Fig 5. Logic diagram DDE 74HC40103 4 of 23 8-bit synchronous binary down counter All information provided in this document is subject to legal disclaimers. 05 Nexperia 74HC40103 Product data sheet 3( 74HC40103 Nexperia 8-bit synchronous binary down counter 6. Pinning information 6.1 Pinning &3   9&& 05   3( 7(   7& 3   3  3   3 3   3 3   3 *1'   3/ DDE Fig 6. Pin configuration 6.2 Pin description Table 2. Pin description Symbol Pin Description CP 1 clock input (LOW-to-HIGH, edge-triggered) MR 2 asynchronous master reset input (active LOW) TE 3 terminal enable input (active LOW) P0 4 jam input 0 P1 5 jam input 1 P2 6 jam input 2 P3 7 jam input 3 GND 8 ground (0 V) PL 9 asynchronous preset enable input (active LOW) P4 10 jam input 4 P5 11 jam input 5 P5 12 jam input 6 P7 13 jam input 7 TC 14 terminal count output (active LOW) PE 15 synchronous preset enable input (active LOW) VCC 16 positive supply voltage 74HC40103 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 21 April 2016 © Nexperia B.V. 2017. All rights reserved 5 of 23 74HC40103 Nexperia 8-bit synchronous binary down counter 7. Functional description 7.1 Function table Function table[1] Table 3. Control inputs PE Preset mode Action[2] MR PL TE L X X X asynchronous clear to maximum count H L X X asynchronous preset asynchronously H L X synchronous preset on next LOW-to HIGH clock transition H L synchronous count down H synchronous inhibit counter [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care. [2] Clock connected to CP. Synchronous operation: changes occur on the LOW-to-HIGH CP transition. Jam inputs: MSD = P7, LSD = P0. 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions input clamping current VI < 0.5 V or VI > VCC + 0.5 V [1] IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] IO output current VO = 0.5 V to VCC + 0.5 V ICC IIK Min Max Unit 0.5 +7 V - 20 mA - 20 mA - 25 mA supply current - +50 mA IGND ground current 50 - mA Tstg storage temperature Ptot total power dissipation 65 +150 C SO16 package [2] - 500 mW TSSOP16 packages [3] - 500 mW [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SO16 package: above 70 C, Ptot derates linearly with 8 mW/K. [3] For TSSOP16 package: above 60 C, Ptot derates linearly with 5.5 mW/K. 74HC40103 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 21 April 2016 © Nexperia B.V. 2017. All rights reserved 6 of 23 74HC40103 Nexperia 8-bit synchronous binary down counter 9. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VO output voltage t/V input transition rise and fall rates Tamb Conditions Min Typ Max Unit 2.0 5.0 6.0 V 0 - VCC V 0 - VCC V VCC = 2.0 V - - 625 ns VCC = 4.5 V - 1.67 139 ns VCC = 6.0 V - - 83 ns 40 - +125 C ambient temperature 10. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit HIGH-level input voltage VCC = 2.0 V 1.5 1.2 - V Tamb = 25 C VIH VIL VOH VOL LOW-level input voltage HIGH-level output voltage LOW-level output voltage VCC = 4.5 V 3.15 2.4 - V VCC = 6.0 V 4.2 3.2 - V VCC = 2.0 V - 0.8 0.5 V VCC = 4.5 V - 2.1 1.35 V VCC = 6.0 V - 2.8 1.8 V IO = 20 A; VCC = 2.0 V 1.9 2.0 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - V VI = VIH or VIL IO = 20 A; VCC = 6.0 V 5.9 6.0 - V IO = 4 mA; VCC = 4.5 V 3.98 4.32 - V IO = 5.2 mA; VCC = 6.0 V 5.48 5.81 - V VI = VIH or VIL IO = 20 A; VCC = 2.0 V - 0 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 V IO = 4 mA; VCC = 4.5 V - 0.15 0.26 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 V II input leakage current VI = VCC or GND; VCC = 6.0 V - - 0.1 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 A CI input capacitance - 3.5 - pF 74HC40103 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 21 April 2016 © Nexperia B.V. 2017. All rights reserved 7 of 23 74HC40103 Nexperia 8-bit synchronous binary down counter Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VCC = 2.0 V 1.5 - - VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 - - V IO = 20 A; VCC = 4.5 V 4.4 - - V Tamb = 40 C to +85 C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage V VI = VIH or VIL IO = 20 A; VCC = 6.0 V 5.9 - - V IO = 4 mA; VCC = 4.5 V 3.84 - - V IO = 5.2 mA; VCC = 6.0 V 5.34 - - V VI = VIH or VIL IO = 20 A; VCC = 2.0 V - - 0.1 V IO = 20 A; VCC = 4.5 V - - 0.1 V IO = 20 A; VCC = 6.0 V - - 0.1 V IO = 4 mA; VCC = 4.5 V - - 0.33 V IO = 5.2 mA; VCC = 6.0 V - - 0.33 V II input leakage current VI = VCC or GND; VCC = 6.0 V - - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 80 A Tamb = 40 C to +125 C VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage 74HC40103 Product data sheet VCC = 2.0 V 1.5 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.2 - - V VCC = 2.0 V - - 0.5 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 - - V IO = 20 A; VCC = 4.5 V 4.4 - - V IO = 20 A; VCC = 6.0 V 5.9 - - V IO = 4 mA; VCC = 4.5 V 3.7 - - V IO = 5.2 mA; VCC = 6.0 V 5.2 - - V VI = VIH or VIL All information provided in this document is subject to legal disclaimers. Rev. 5 — 21 April 2016 © Nexperia B.V. 2017. All rights reserved 8 of 23 74HC40103 Nexperia 8-bit synchronous binary down counter Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VOL LOW-level output voltage VI = VIH or VIL IO = 20 A; VCC = 2.0 V - - 0.1 V IO = 20 A; VCC = 4.5 V - - 0.1 V IO = 20 A; VCC = 6.0 V - - 0.1 V IO = 4 mA; VCC = 4.5 V - - 0.4 V IO = 5.2 mA; VCC = 6.0 V - - 0.4 V II input leakage current VI = VCC or GND; VCC = 6.0 V - - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 160 A 11. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; tr = tf = 6 ns; CL = 50 pF; see Figure 13. Symbol Parameter Conditions Min Typ Max Unit VCC = 2.0 V - 96 300 ns VCC = 4.5 V - 35 60 ns VCC = 6.0 V - 28 51 ns VCC = 5.0 V; CL = 15 pF - 30 - ns VCC = 2.0 V - 50 175 ns VCC = 4.5 V - 18 35 ns VCC = 6.0 V - 14 30 ns VCC = 2.0 V - 102 315 ns VCC = 4.5 V - 37 63 ns VCC = 6.0 V - 30 53 ns VCC = 2.0 V - 83 275 ns VCC = 4.5 V - 30 55 ns - 24 47 ns VCC = 2.0 V - 19 75 ns VCC = 4.5 V - 7 15 ns VCC = 6.0 V - 6 13 ns Tamb = 25 C tpd propagation delay CP to TC; see Figure 7 [1] TE to TC; see Figure 8 PL to TC; see Figure 9 tPHL HIGH to LOW propagation delay MR to TC; see Figure 9 VCC = 6.0 V tt transition time 74HC40103 Product data sheet [2] see Figure 8 All information provided in this document is subject to legal disclaimers. Rev. 5 — 21 April 2016 © Nexperia B.V. 2017. All rights reserved 9 of 23 74HC40103 Nexperia 8-bit synchronous binary down counter Table 7. Dynamic characteristics …continued GND = 0 V; tr = tf = 6 ns; CL = 50 pF; see Figure 13. Symbol Parameter Conditions Min Typ Max tW pulse width CP HIGH or LOW; see Figure 7 Unit VCC = 2.0 V 165 22 - ns VCC = 4.5 V 33 8 - ns VCC = 6.0 V 28 6 - ns VCC = 2.0 V 125 39 - ns VCC = 4.5 V 25 14 - ns VCC = 6.0 V 21 11 - ns VCC = 2.0 V 125 33 - ns VCC = 4.5 V 25 12 - ns VCC = 6.0 V 21 10 - ns VCC = 2.0 V 50 14 - ns VCC = 4.5 V 10 5 - ns VCC = 6.0 V 9 4 - ns VCC = 2.0 V 75 22 - ns VCC = 4.5 V 15 8 - ns VCC = 6.0 V 13 6 - ns VCC = 2.0 V 150 44 - ns VCC = 4.5 V 30 16 - ns VCC = 6.0 V 26 13 - ns VCC = 2.0 V 75 22 - ns VCC = 4.5 V 15 8 - ns VCC = 6.0 V 13 6 - ns VCC = 2.0 V 0 14 - ns VCC = 4.5 V 0 5 - ns VCC = 6.0 V 0 4 - ns VCC = 2.0 V 0 30 - ns VCC = 4.5 V 0 11 - ns VCC = 6.0 V 0 9 - ns VCC = 2.0 V 0 17 - ns VCC = 4.5 V 0 6 - ns VCC = 6.0 V 0 5 - ns MR LOW; see Figure 9 PL LOW; see Figure 9 trec tsu recovery time set-up time MR to CP, PL to CP; see Figure 10 PE to CP; see Figure 11 TE to CP; see Figure 12 Pn to CP; see Figure 11 th hold time PE to CP; see Figure 11 TE to CP; see Figure 12 Pn to CP; see Figure 11 74HC40103 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 21 April 2016 © Nexperia B.V. 2017. All rights reserved 10 of 23 74HC40103 Nexperia 8-bit synchronous binary down counter Table 7. Dynamic characteristics …continued GND = 0 V; tr = tf = 6 ns; CL = 50 pF; see Figure 13. Symbol Parameter Conditions Min Typ Max Unit fmax maximum frequency see Figure 7 VCC = 2.0 V 3.0 10 - MHz VCC = 4.5 V 15 29 - MHz VCC = 6.0 V 18 35 - MHz - 32 - MHz - 24 - pF VCC = 2.0 V - - 375 ns VCC = 4.5 V - - 75 ns VCC = 6.0 V - - 64 ns VCC = 2.0 V - - 220 ns VCC = 4.5 V - - 44 ns VCC = 6.0 V - - 37 ns VCC = 2.0 V - - 395 ns VCC = 4.5 V - - 79 ns VCC = 6.0 V - - 40 ns VCC = 2.0 V - - 345 ns VCC = 4.5 V - - 69 ns VCC = 6.0 V - - 59 ns VCC = 2.0 V - - 95 ns VCC = 4.5 V - - 19 ns VCC = 6.0 V - - 16 ns VCC = 2.0 V 205 - - ns VCC = 4.5 V 41 - - ns VCC = 6.0 V 35 - - ns VCC = 2.0 V 155 - - ns VCC = 4.5 V 31 - - ns VCC = 6.0 V 26 - - ns VCC = 2.0 V 155 - - ns VCC = 4.5 V 31 - - ns VCC = 6.0 V 26 - - ns VCC = 5.0 V; CL = 15 pF CPD power dissipation capacitance VI = GND to VCC [3] CP to TC; see Figure 7 [1] Tamb = 40 C to +85 C tpd propagation delay TE to TC; see Figure 8 PL to TC; see Figure 9 tPHL tt tW HIGH to LOW propagation delay transition time pulse width MR to TC; see Figure 9 [2] see Figure 8 CP HIGH or LOW; see Figure 7 MR LOW; see Figure 9 PL LOW; see Figure 9 74HC40103 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 21 April 2016 © Nexperia B.V. 2017. All rights reserved 11 of 23 74HC40103 Nexperia 8-bit synchronous binary down counter Table 7. Dynamic characteristics …continued GND = 0 V; tr = tf = 6 ns; CL = 50 pF; see Figure 13. Symbol Parameter Conditions trec recovery time MR to CP, PL to CP; see Figure 10 tsu set-up time Min Typ Max Unit VCC = 2.0 V 65 - - VCC = 4.5 V 13 - - ns VCC = 6.0 V 11 - - ns VCC = 2.0 V 95 - - ns VCC = 4.5 V 19 - - ns VCC = 6.0 V 16 - - ns VCC = 2.0 V 190 - - ns VCC = 4.5 V 38 - - ns VCC = 6.0 V 33 - - ns VCC = 2.0 V 95 - - ns VCC = 4.5 V 19 - - ns VCC = 6.0 V 16 - - ns VCC = 2.0 V 0 - - ns VCC = 4.5 V 0 - - ns VCC = 6.0 V 0 - - ns VCC = 2.0 V 0 - - ns VCC = 4.5 V 0 - - ns VCC = 6.0 V 0 - - ns VCC = 2.0 V 0 - - ns VCC = 4.5 V 0 - - ns VCC = 6.0 V 0 - - ns VCC = 2.0 V 2.4 - - MHz VCC = 4.5 V 12 - - MHz VCC = 6.0 V 14 - - MHz ns PE to CP; see Figure 11 TE to CP; see Figure 12 Pn to CP; see Figure 11 th hold time PE to CP; see Figure 11 TE to CP; see Figure 12 Pn to CP; see Figure 11 fmax maximum frequency 74HC40103 Product data sheet see Figure 7 All information provided in this document is subject to legal disclaimers. Rev. 5 — 21 April 2016 © Nexperia B.V. 2017. All rights reserved 12 of 23 74HC40103 Nexperia 8-bit synchronous binary down counter Table 7. Dynamic characteristics …continued GND = 0 V; tr = tf = 6 ns; CL = 50 pF; see Figure 13. Symbol Parameter Conditions Min Typ Max Unit Tamb = 40 C to +125 C tpd propagation delay CP to TC; see Figure 7 [1] VCC = 2.0 V - - 450 ns VCC = 4.5 V - - 90 ns VCC = 6.0 V - - 77 ns TE to TC; see Figure 8 VCC = 2.0 V - - 265 ns VCC = 4.5 V - - 53 ns VCC = 6.0 V - - 45 ns PL to TC; see Figure 9 tPHL HIGH to LOW propagation delay VCC = 2.0 V - - 475 ns VCC = 4.5 V - - 95 ns VCC = 6.0 V - - 81 ns VCC = 2.0 V - - 415 ns VCC = 4.5 V - - 83 ns - - 71 ns MR to TC; see Figure 9 VCC = 6.0 V tt tW transition time pulse width [2] see Figure 8 VCC = 2.0 V - - 110 ns VCC = 4.5 V - - 22 ns VCC = 6.0 V - - 19 ns VCC = 2.0 V 250 - - ns VCC = 4.5 V 50 - - ns VCC = 6.0 V 43 - - ns VCC = 2.0 V 190 - - ns VCC = 4.5 V 38 - - ns VCC = 6.0 V 32 - - ns VCC = 2.0 V 190 - - ns VCC = 4.5 V 38 - - ns VCC = 6.0 V 32 - - ns VCC = 2.0 V 75 - - ns VCC = 4.5 V 15 - - ns VCC = 6.0 V 13 - - ns CP HIGH or LOW; see Figure 7 MR LOW; see Figure 9 PL LOW; see Figure 9 trec recovery time 74HC40103 Product data sheet MR to CP, PL to CP; see Figure 10 All information provided in this document is subject to legal disclaimers. Rev. 5 — 21 April 2016 © Nexperia B.V. 2017. All rights reserved 13 of 23 74HC40103 Nexperia 8-bit synchronous binary down counter Table 7. Dynamic characteristics …continued GND = 0 V; tr = tf = 6 ns; CL = 50 pF; see Figure 13. Symbol Parameter Conditions Min Typ Max tsu set-up time PE to CP; see Figure 11 Unit VCC = 2.0 V 110 - - ns VCC = 4.5 V 22 - - ns VCC = 6.0 V 19 - - ns VCC = 2.0 V 225 - - ns VCC = 4.5 V 45 - - ns VCC = 6.0 V 38 - - ns VCC = 2.0 V 110 - - ns VCC = 4.5 V 22 - - ns VCC = 6.0 V 19 - - ns VCC = 2.0 V 0 - - ns VCC = 4.5 V 0 - - ns VCC = 6.0 V 0 - - ns VCC = 2.0 V 0 - - ns VCC = 4.5 V 0 - - ns VCC = 6.0 V 0 - - ns VCC = 2.0 V 0 - - ns VCC = 4.5 V 0 - - ns VCC = 6.0 V 0 - - ns VCC = 2.0 V 2.0 - - MHz VCC = 4.5 V 10 - - MHz VCC = 6.0 V 12 - - MHz TE to CP; see Figure 12 Pn to CP; see Figure 11 hold time th PE to CP; see Figure 11 TE to CP; see Figure 12 Pn to CP; see Figure 11 maximum frequency fmax [1] tpd is the same as tPHL, tPLH. [2] tt is the same as tTHL, tTLH. [3] see Figure 7 CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 74HC40103 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 21 April 2016 © Nexperia B.V. 2017. All rights reserved 14 of 23 74HC40103 Nexperia 8-bit synchronous binary down counter 12. Waveforms IPD[ &3LQSXW 7(LQSXW 90 W: W3+/ W3/+ 7&RXWSXW 90 W3+/ 7&RXWSXW 90 W7+/ W7/+ W3/+ 90 W7+/ W7/+ DDE DDE VM = 0.5  VI Fig 7. VM = 0.5  VI Waveforms showing the clock input (CP) to TC propagation delays, the clock pulse width, the output transition times and the maximum clock pulse frequency 3Q3/05 LQSXW Fig 8. Waveforms showing the TE to TC propagation delays 3/05 LQSXW 90 90 W: W: W3+/ 7&RXWSXW W3/+ WUHF &3LQSXW 90 90 DDE DDE VM = 0.5  VI Fig 9. VM = 0.5  VI Waveforms showing PL, MR, Pn to TC propagation delays 74HC40103 Product data sheet Fig 10. Waveforms showing removal time for MR and PL All information provided in this document is subject to legal disclaimers. Rev. 5 — 21 April 2016 © Nexperia B.V. 2017. All rights reserved 15 of 23 74HC40103 Nexperia 8-bit synchronous binary down counter 3WR3 LQSXW 3(LQSXW 90 VWDEOH WVX WK WVX WK 7(RU3( LQSXW 90 90 WVX &3LQSXW &3LQSXW 90 WK 90 DDE DDE VM = 0.5  VI The shaded areas indicate when the input is permitted to change for predictable output performance. VM = 0.5  VI Fig 11. Waveforms showing hold and set-up times for Pn, PE to CP Fig 12. Waveforms showing hold and set-up times for MR or PE to CP 9&& 38/6( *(1(5$725 9, 92 '87 57 &/ PQD Test data is given in Table 8. Definitions for test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. Fig 13. Test circuit for measuring switching times Table 8. Test data Supply Input Load VCC VI tr, tf CL 2.0 V VCC 6 ns 50 pF 4.5 V VCC 6 ns 50 pF 6.0 V VCC 6 ns 50 pF 5.0 V VCC 6 ns 15 pF 74HC40103 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 21 April 2016 © Nexperia B.V. 2017. All rights reserved 16 of 23 74HC40103 Nexperia 8-bit synchronous binary down counter 13. Application information 9&& 9&& 3 7& Nȍ 7( WLPHRXW 3( 1  3/ W 05 3 VWDUW &3 *1' I,1 DDE Fig 14. Programmable timer 9&& 3 7& I287 I,1 1 7( 3( 1  3/ 05 3 &3 I,1 *1' DDE Fig 15. Divide-by-N counter 74HC40103 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 21 April 2016 © Nexperia B.V. 2017. All rights reserved 17 of 23 74HC40103 Nexperia 8-bit synchronous binary down counter 14. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H Z 0 ES   GHWDLO; PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV         ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 16. Package outline SOT109-1 (SO16) 74HC40103 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 21 April 2016 © Nexperia B.V. 2017. All rights reserved 18 of 23 74HC40103 Nexperia 8-bit synchronous binary down counter 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ SLQLQGH[ $   $ $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWHV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 17. Package outline SOT403-1 (TSSOP16) 74HC40103 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 21 April 2016 © Nexperia B.V. 2017. All rights reserved 19 of 23 74HC40103 Nexperia 8-bit synchronous binary down counter 15. Abbreviations Table 9. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 16. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC40103 v.5 20160421 Product data sheet - 74HC40103 v.4 Modifications: 74HC40103 v.4 Modifications: 74HC40103 v.3 Modifications: • Type number 74HC40103DB (SOT338-1) removed. 20160127 • Product data sheet - 74HC40103 v.3 Type number 74HC40103N (SOT38-4) removed. 20041112 Product data sheet - 74HC_HCT40103_CNV v.2 • The format of this data sheet has been redesigned to comply with the current presentation and information standard of Philips Semiconductors. • • Removed type number 74HCT40103. Inserted family specification. 74HC_HCT40103_CNV v.2 19970918 Product specification - 74HC_HCT40103 v.1 74HC_HCT40103 v.1 19901201 Product specification - - 74HC40103 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 21 April 2016 © Nexperia B.V. 2017. All rights reserved 20 of 23 74HC40103 Nexperia 8-bit synchronous binary down counter 17. Legal information 17.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 17.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 17.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC40103 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 5 — 21 April 2016 © Nexperia B.V. 2017. All rights reserved 21 of 23 74HC40103 Nexperia 8-bit synchronous binary down counter Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 17.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 18. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC40103 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 21 April 2016 © Nexperia B.V. 2017. All rights reserved 22 of 23 Nexperia 74HC40103 8-bit synchronous binary down counter 19. Contents 1 2 3 4 5 6 6.1 6.2 7 7.1 8 9 10 11 12 13 14 15 16 17 17.1 17.2 17.3 17.4 18 19 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 5 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 5 Functional description . . . . . . . . . . . . . . . . . . . 6 Function table . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 6 Recommended operating conditions. . . . . . . . 7 Static characteristics. . . . . . . . . . . . . . . . . . . . . 7 Dynamic characteristics . . . . . . . . . . . . . . . . . . 9 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Application information. . . . . . . . . . . . . . . . . . 17 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 18 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 20 Legal information. . . . . . . . . . . . . . . . . . . . . . . 21 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 21 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 21 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 22 Contact information. . . . . . . . . . . . . . . . . . . . . 22 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 23 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 21 April 2016
74HC40103D,653 价格&库存
很抱歉,暂时无法提供与“74HC40103D,653”相匹配的价格&库存,您可以联系我们找货
74HC40103D,653
  • 1+7.691701+0.99285
  • 10+5.5382410+0.71488
  • 25+4.9894425+0.64404
  • 100+4.38267100+0.56572
  • 250+4.09464250+0.52854
  • 500+3.92072500+0.50609
  • 1000+3.902581000+0.50375
库存:4651
74HC40103D,653
  • 1+6.04300
  • 10+4.47020
  • 100+3.83160
  • 1000+3.19300
库存:1
