74HC393; 74HCT393
Dual 4-bit binary ripple counter
Rev. 6 — 3 December 2015
Product data sheet
1. General description
The 74HC393; 7474HCT393 is a dual 4-stage binary ripple counter. Each counter
features a clock input (nCP), an overriding asynchronous master reset input (nMR) and 4
buffered parallel outputs (nQ0 to nQ3). The counter advances on the HIGH-to-LOW
transition of nCP. A HIGH on nMR clears the counter stages and forces the outputs LOW,
independent of the state of nCP. Inputs include clamp diodes. This enables the use of
current limiting resistors to interface inputs to voltages in excess of VCC.
2. Features and benefits
Input levels:
For 74HC393: CMOS level
For 74HCT393: TTL level
Complies with JEDEC standard no. 7A
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V.
Two 4-bit binary counters with individual clocks
Divide by any binary module up to 28 in one package
Two master resets to clear each 4-bit counter individually
3. Ordering information
Table 1.
Type number Package
74HC393D
Temperature range Name
Description
Version
40 C to +125 C
SO14
plastic small outline package; 14 leads; body width 3.9 mm SOT108-1
40 C to +125 C
SSOP14
plastic shrink small outline package; 14 leads; body width
5.3 mm
SOT337-1
40 C to +125 C
TSSOP14
plastic thin shrink small outline package; 14 leads; body
width 4.4 mm
SOT402-1
40 C to +125 C
DHVQFN14 plastic dual in-line compatible thermal enhanced very thin
quad flat package; no leads; 14 terminals;
body 2.5 3 0.85 mm
74HCT393D
74HC393DB
74HCT393DB
74HC393PW
74HCT393PW
74HC393BQ
74HCT393BQ
SOT762-1
74HC393; 74HCT393
Nexperia
4. Functional diagram
4
&75
&3
4
4
4
4
05
&75
&3
4
4
4
05
Fig 2.
&3
05
%,7
%,1$5
很抱歉,暂时无法提供与“74HCT393D,653”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.68280
- 10+2.99160
- 30+2.70000
- 100+2.33280
- 500+2.16000
- 1000+2.06280
- 国内价格 香港价格
- 2500+1.731922500+0.21698
- 5000+1.682115000+0.21074
- 7500+1.657207500+0.20761
- 12500+1.6295612500+0.20415
- 17500+1.6134117500+0.20213
- 25000+1.5978825000+0.20018
