HEF4521BT,653
HEF4521BT,653
    NEXPERIA(安世)
    SOIC16_150MIL
    24级分频器和振荡器
HEF4521BT,653 数据手册
HEF4521B 24-stage frequency divider and oscillator Rev. 7 — 30 March 2016 Product data sheet 1. General description The HEF4521B consists of a chain of 24 toggle flip-flops with an overriding asynchronous master reset input (MR), and an input circuit that allows three modes of operation. The single inverting stage (A2 to Y2) functions as: a crystal oscillator, an input buffer for an external oscillator or in combination with A1 as an RC oscillator. The crystal oscillator operates in Low-power mode when pins VSS1 and VDD1 are supplied via external resistors. Each flip-flop divides the frequency of the previous flip-flop by two, consequently the HEF4521B counts up to 224 = 16777216. The counting advances on the HIGH-to-LOW transition of the clock (A2). The outputs from each of the last seven stages (218 to 224) are available for additional flexibility. It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. 2. Features and benefits       Low power crystal oscillator operation Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Specified from 40 C to +85 C Complies with JEDEC standard JESD 13-B 3. Ordering information Table 1. Ordering information All types operate from 40 C to +85 C. Type number HEF4521BT Package Name Description Version SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 HEF4521B Nexperia 24-stage frequency divider and oscillator 4. Functional diagram
HEF4521BT,653 价格&库存
很抱歉,暂时无法提供与“HEF4521BT,653”相匹配的价格&库存,您可以联系我们找货
HEF4521BT,653
  • 2500+2.599352500+0.31384
  • 5000+2.530575000+0.30554
  • 7500+2.496137500+0.30138
  • 12500+2.4579612500+0.29677
  • 17500+2.4356617500+0.29408
  • 25000+2.4142225000+0.29149
库存:816
HEF4521BT,653
  • 1+7.59405
  • 3+7.33413
  • 10+6.47171
  • 25+5.78058
  • 29+3.86171
  • 78+3.65089
  • 1000+3.53830
  • 2500+3.51075
库存:1448
HEF4521BT,653
  • 1+8.02390
库存:10
HEF4521BT,653
  • 1323+2.582901323+0.31185
库存:5000
HEF4521BT,653
HEF4521BT,653
  • 1+7.558381+0.91257
  • 10+5.4438810+0.65728
  • 25+4.9051425+0.59223
  • 100+4.31321100+0.52076
  • 250+4.03010250+0.48658
  • 500+3.85958500+0.46600
  • 1000+3.719201000+0.44905
库存:816
