74HC590BQ,115
74HC590BQ,115
    NEXPERIA(安世)
    QFN16_2.5X3.5MM_EP
    带输出寄存器的8位二进制计数器;3-state
74HC590BQ,115 数据手册
74HC590 8-bit binary counter with output register; 3-state Rev. 3 — 24 February 2016 Product data sheet 1. General description The 74HC590 is an 8-bit binary counter with a storage register and 3-state outputs. The storage register has parallel (Q0 to Q7) outputs. The binary counter features master reset counter (MRC) and count enable (CE) inputs. The counter and storage register have separate positive edge triggered clock (CPC and CPR) inputs. If both clocks are connected together, the counter state is always one count ahead of the register. Internal circuitry prevents clocking from the clock enable. A ripple carry output (RCO) is provided for cascading. Cascading is accomplished by connecting RCO of the first stage to CE of the second stage. Cascading for larger count chains can be accomplished by connecting RCO of each stage to the counter clock (CPC) input of the following stage. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits      Counter and register have independent clock inputs Counter has master reset Complies with JEDEC standard no. 7A Multiple package options Input levels:  For 74HC590: CMOS level  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  CDM JESD22-C101C exceeds 2000 V  Specified from 40 C to +85 C and from 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74HC590D 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74HC590PW 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm 74HC590BQ 40 C to +125 C DHVQFN16 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 16 terminals; body 2.5  3.5  0.85 mm SOT403-1 SOT763-1 74HC590 Nexperia 8-bit binary counter with output register; 3-state 4. Functional diagram  &(  &3& %,7%,1$5 VCC + 0.5 V [1] IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] IO output current VO = 0.5 V to VCC + 0.5 V - 35 mA ICC supply current - 70 mA IGND ground current 70 - mA Tstg storage temperature 65 +150 C SO16 package - 500 mW TSSOP16 package - 500 mW Min Typ Max Unit 2.0 5.0 6.0 V Tamb = 40 C to +125 C total power dissipation Ptot [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SO16 packages: Ptot derates linearly with 8 mW/K above 70 C. For TSSOP16 packages: Ptot derates linearly with 5.5 mW/K above 60 C. For DHVQFN16 packages: Ptot derates linearly with 8 mW/K above 60 C. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage 0 - VCC V VO output voltage 0 - VCC V t/V input transition rise and fall rate Tamb Conditions VCC = 2.0 V - - 625 ns/V VCC = 4.5 V - 1.67 139 ns/V VCC = 6.0 V - - 83 ns/V 40 - +125 ambient temperature 74HC590 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 February 2016 © C Nexperia B.V. 2017. All rights reserved 6 of 20 74HC590 Nexperia 8-bit binary counter with output register; 3-state 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions Min VIH VIL VOH HIGH-level input voltage LOW-level input voltage Typ 40 C to +85 C 40 C to +125 C Unit Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = 4 mA; VCC = 4.5 V 4.18 4.31 - 4.13 - 4.1 - V IO = 5.2 mA; VCC = 6.0 V 5.68 5.80 - 5.63 - 5.6 - V IO = 6.0 mA; VCC = 4.5 V 4.18 4.31 - 4.13 - 4.1 - V IO = 7.8 mA; VCC = 6.0 V 5.68 5.80 - 5.63 - 5.6 - V HIGH-level VI = VIH or VIL output voltage all outputs RCO standard output Qn bus driver output VOL LOW-level VI = VIH or VIL output voltage all outputs IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4 mA; VCC = 4.5 V - 0.17 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.18 0.26 - 0.33 - 0.4 V IO = 6.0 mA; VCC = 4.5 V - 0.17 0.26 - 0.33 - 0.4 V IO = 7.8 mA; VCC = 6.0 V - 0.18 0.26 - 0.33 - 0.4 V RCO standard output Qn bus driver output II input leakage current VI = VCC or GND; VCC = 6.0 V - - 0.1 - 1.0 - 1.0 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 6.0 V - - 0.5 - 5.0 - 10 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 4.0 - 40 - 80 A CI input capacitance - 3.5 - - - - - pF 74HC590 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 February 2016 © Nexperia B.V. 2017. All rights reserved 7 of 20 74HC590 Nexperia 8-bit binary counter with output register; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics GND (ground = 0 V); for test circuit see Figure 14. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max tpd propagation delay CPC to RCO; see Figure 8 Min Max Min Max [1] VCC = 2.0 V - 52 150 - 190 - 230 ns VCC = 4.5 V - 19 30 - 38 - 45 ns VCC = 6.0 V - 15 26 - 33 - 40 ns VCC = 2.0 V - 50 140 - 175 - 210 ns VCC = 4.5 V - 17 28 - 35 - 42 ns VCC = 6.0 V - 14 24 - 30 - 36 ns - 53 130 - 165 - 200 ns - 18 26 - 33 - 40 ns - 14 22 - 28 - 34 ns VCC = 2.0 V - 28 105 - 130 - 160 ns VCC = 4.5 V - 13 21 - 26 - 32 ns - 11 18 - 22 - 27 ns VCC = 2.0 V - 28 105 - 130 - 160 ns VCC = 4.5 V - 13 21 - 26 - 32 ns VCC = 6.0 V - 11 18 - 22 - 27 ns VCC = 2.0 V 100 24 - 125 - 145 - ns VCC = 4.5 V 20 9 - 25 - 29 - ns VCC = 6.0 V 17 8 - 21 - 25 - ns VCC = 2.0 V 75 28 - 95 - 110 - ns VCC = 4.5 V 15 8 - 19 - 22 - ns VCC = 6.0 V 13 6 - 16 - 19 - ns VCC = 2.0 V 100 46 - 125 - 150 - ns VCC = 4.5 V 20 14 - 25 - 30 - ns VCC = 6.0 V 17 10 - 21 - 26 - ns VCC = 2.0 V 100 44 - 125 - 150 - ns VCC = 4.5 V 20 11 - 25 - 30 - ns VCC = 6.0 V 17 9 - 21 - 26 - ns CPR to Qn; see Figure 9 tPLH LOW to HIGH MRC to RCO; see Figure 10 propagation VCC = 2.0 V delay VCC = 4.5 V VCC = 6.0 V ten enable time OE to Qn; see Figure 11 [2] VCC = 6.0 V tdis tW disable time pulse width OE to Qn; see Figure 11 [3] CPC and CPR; HIGH or LOW; see Figure 8 and Figure 9 MRC; LOW; see Figure 10 tsu set-up time CPC to CPR; see Figure 13 CE to CPC; see Figure 12 74HC590 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 February 2016 © Nexperia B.V. 2017. All rights reserved 8 of 20 74HC590 Nexperia 8-bit binary counter with output register; 3-state Table 7. Dynamic characteristics …continued GND (ground = 0 V); for test circuit see Figure 14. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max th hold time recovery time trec maximum frequency fmax power dissipation capacitance [1] Min Max VCC = 2.0 V 0 - - 0 - 0 - ns VCC = 4.5 V 0 - - 0 - 0 - ns VCC = 6.0 V 0 - - 0 - 0 - ns MRC to CPC; see Figure 10 VCC = 2.0 V 75 28 - 95 - 110 - ns VCC = 4.5 V 15 7 - 19 - 22 - ns VCC = 6.0 V 13 6 - 16 - 19 - ns VCC = 2.0 V 6.6 16 - 5.2 - 4.4 - MHz VCC = 4.5 V 33 52 - 26 - 22 - MHz 39 61 - 31 - 26 - MHz - 44 - - - - - pF CPC or CPR; see Figure 8 and Figure 9 [4] VI = GND to VCC tpd is the same as tPHL, tPLH. [2] ten is the same as tPZH and tPZL. [3] tdis is the same as tPLZ and tPHZ. [4] Max CE to CPC; see Figure 12 VCC = 6.0 V CPD Min CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 74HC590 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 February 2016 © Nexperia B.V. 2017. All rights reserved 9 of 20 74HC590 Nexperia 8-bit binary counter with output register; 3-state 11. Waveforms IPD[ 9, &3&LQSXW 90 *1' W: W3/+ W3+/ 92+ 5&2RXWSXW 90 92/ DDF Measurement points are given in Table 8. VOL and VOH are the typical output voltage levels that occur with the output load. Fig 8. Table 8. Waveforms showing the propagation delays from the counter clock input (CPC) to ripple carry (RCO) output and the CPC pulse width Measurement points Type Input 74HC590 Output VI VM VM VCC 0.5VCC 0.5VCC IPD[ 9, &35LQSXW 90 *1' W: W3/+ W3+/ 92+ 4QRXWSXW 90 92/ DDF Measurement points are given in Table 8. VOL and VOH are the typical output voltage levels that occur with the output load. Fig 9. Waveforms showing the propagation delays from the register clock input (CPR) to output (Qn) and the register clock pulse width 74HC590 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 February 2016 © Nexperia B.V. 2017. All rights reserved 10 of 20 74HC590 Nexperia 8-bit binary counter with output register; 3-state W: 9, 05&LQSXW 90 *1' W3/+ 92+ 90 5&2RXWSXW 92/ WUHF 9, 90 &3&LQSXW *1' DDF Measurement points are given in Table 8. VOL and VOH are the typical output voltage levels that occur with the output load. Fig 10. Waveforms showing the propagation delays from the master reset counter input (MRC) to output (RCO), the MRC pulse width and recovery time 9, 2(LQSXW 90 *1' RXWSXW 9&& W3/= W3=/ 90 /2:WR2)) 2))WR/2: 92/  W3+= RXWSXW 92+ +,*+WR2)) 2))WR+,*+ *1' W3=+  90 RXWSXWV HQDEOHG RXWSXWV GLVDEOHG RXWSXWV HQDEOHG DDF Measurement points are given in Table 8. VOL and VOH are the typical output voltage levels that occur with the output load. Fig 11. Waveforms showing the 3-state enable and disable times 74HC590 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 February 2016 © Nexperia B.V. 2017. All rights reserved 11 of 20 74HC590 Nexperia 8-bit binary counter with output register; 3-state 9, 90 &(LQSXW *1' WVX WK WVX WK 92+ &3&LQSXW 90 92/ DDF Measurement points are given in Table 8. VOL and VOH are the typical output voltage levels that occur with the output load. Fig 12. Waveforms showing the set-up and hold times for the count enable input (CE) to the counter clock input (CPC) 9, 90 &3&LQSXW *1' WVX WK 92+ &35LQSXW 90 92/ DDF Measurement points are given in Table 8. VOL and VOH are the typical output voltage levels that occur with the output load. Fig 13. Waveforms showing the set-up and hold times for the counter clock input (CPC) to the register clock input (CPR) 74HC590 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 February 2016 © Nexperia B.V. 2017. All rights reserved 12 of 20 74HC590 Nexperia 8-bit binary counter with output register; 3-state 9, W:  QHJDWLYH SXOVH 90 9 WI WU WU WI 9,  SRVLWLYH SXOVH 9 90  90 90  W: 9&& 9&& * 9, 92 5/ 6 RSHQ '87 &/ 57 DDG Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig 14. Test circuit for measuring switching times Table 9. Test data Supply voltage Input VCC VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 2.0 V to 6.0 V VCC 6 ns 50 pF 1 k open GND VCC 74HC590 Product data sheet Load Switch position All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 February 2016 © Nexperia B.V. 2017. All rights reserved 13 of 20 74HC590 Nexperia 8-bit binary counter with output register; 3-state 12. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H Z 0 ES   GHWDLO; PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV         ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 15. Package outline SOT109-1 (SO16) 74HC590 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 February 2016 © Nexperia B.V. 2017. All rights reserved 14 of 20 74HC590 Nexperia 8-bit binary counter with output register; 3-state 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ SLQLQGH[ $   $ $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWHV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 16. Package outline SOT403-1 (TSSOP16) 74HC590 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 February 2016 © Nexperia B.V. 2017. All rights reserved 15 of 20 74HC590 Nexperia 8-bit binary counter with output register; 3-state '+94)1SODVWLFGXDOLQOLQHFRPSDWLEOHWKHUPDOHQKDQFHGYHU\WKLQTXDGIODWSDFNDJHQROHDGV 627 WHUPLQDOVERG\[[PP % ' $ $ $ ( F GHWDLO; WHUPLQDO LQGH[DUHD WHUPLQDO LQGH[DUHD & H H E   \ \ & Y 0 & $ % Z 0 & /   (K H     'K ;   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 PP $   PD[ $ E      F '   'K (   (K          H / Y Z \ \        H  1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& -(,7$ 627  02  (8523($1 352-(&7,21 ,668('$7(    Fig 17. Package outline SOT763-1 (DHVQFN16) 74HC590 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 February 2016 © Nexperia B.V. 2017. All rights reserved 16 of 20 74HC590 Nexperia 8-bit binary counter with output register; 3-state 13. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC590 v.3 20160224 Product data sheet - 74HC590 v.2 Modifications: 74HC590 v.2 Modifications: 74HC590 v.1 74HC590 Product data sheet • Type number 74HC590N (SOT38-4) removed. 20090428 Product data sheet - 74HC590 v.1 • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • • Legal texts have been adapted to the new company name where appropriate. Quick reference data incorporated in to Section 9 and Section 10. Added type number 74HC590N (DIP16 package) 20050330 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 February 2016 - © Nexperia B.V. 2017. All rights reserved 17 of 20 74HC590 Nexperia 8-bit binary counter with output register; 3-state 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC590 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 February 2016 © Nexperia B.V. 2017. All rights reserved 18 of 20 74HC590 Nexperia 8-bit binary counter with output register; 3-state Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC590 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 24 February 2016 © Nexperia B.V. 2017. All rights reserved 19 of 20 Nexperia 74HC590 8-bit binary counter with output register; 3-state 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 5 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 6 Recommended operating conditions. . . . . . . . 6 Static characteristics. . . . . . . . . . . . . . . . . . . . . 7 Dynamic characteristics . . . . . . . . . . . . . . . . . . 8 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 14 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 17 Legal information. . . . . . . . . . . . . . . . . . . . . . . 18 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 18 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Contact information. . . . . . . . . . . . . . . . . . . . . 19 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 24 February 2016
74HC590BQ,115 价格&库存
很抱歉,暂时无法提供与“74HC590BQ,115”相匹配的价格&库存,您可以联系我们找货
74HC590BQ,115
  • 1+4.514461+0.58273
  • 10+3.1847310+0.41109
  • 25+2.8451825+0.36726
  • 100+2.47440100+0.31940
  • 250+2.29664250+0.29645
  • 500+2.18975500+0.28266
  • 1000+2.122351000+0.27396
74HC590BQ,115
  • 3000+1.992923000+0.25725
  • 6000+1.939706000+0.25038
  • 9000+1.913049000+0.24694
  • 15000+1.8835215000+0.24313
  • 21000+1.8662521000+0.24090
  • 30000+1.8496530000+0.23876
