74HC4020DB,112
74HC4020DB,112
    NEXPERIA(安世)
    SSOP-16_6.2X5.3MM
    14级二进制纹波计数器
74HC4020DB,112 数据手册
74HC4020; 74HCT4020 14-stage binary ripple counter Rev. 7 — 18 June 2020 Product data sheet 1. General description The 74HC4020; 74HCT4020 is a 14-stage binary ripple counter with a clock input (CP), an overriding asynchronous master reset input (MR) and 12 buffered parallel outputs (Q0, and Q3 to Q13). The counter advances on the HIGH-to-LOW transition of CP. A HIGH on MR clears all counter stages and forces all outputs LOW, independent of the state of CP. Each counter stage is a static toggle flip-flop. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits • • • • • • • • • Wide supply voltage range from 2.0 V to 6.0 V CMOS low power dissipation High noise immunity Latch-up performance exceeds 100 mA per JESD 78 Class II Level B Complies with JEDEC standards: • JESD8C (2.7 V to 3.6 V) • JESD7A (2.0 V to 6.0 V) Input levels: • For 74HC4020: CMOS level • For 74HCT4020: TTL level ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V Multiple package options Specified from -40 °C to +85 °C and from -40 °C to +125 °C 3. Applications • • • Frequency dividing circuits Time delay circuits Control counters 74HC4020; 74HCT4020 Nexperia 14-stage binary ripple counter 4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version -40 °C to +125 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 74HC4020DB -40 °C to +125 °C SSOP16 plastic shrink small outline package; 16 leads; body width 5.3 mm SOT338-1 74HC4020PW -40 °C to +125 °C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 -40 °C to +125 °C DHVQFN16 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 16 terminals; body 2.5 × 3.5 × 0.85 mm SOT763-1 74HC4020D 74HCT4020D 74HCT4020PW 74HC4020BQ 74HCT4020BQ 5. Functional diagram CP MR 10 11 T 14-STAGE COUNTER CD 9 7 5 4 6 13 12 14 15 1 2 3 Q0 Q3 Q4 Q5 Q6 Q7 Q8 Q9 Q10 Q11 Q12 Q13 001aal201 Fig. 1. Functional diagram 10 11 CP MR 9 10 + Q3 7 11 CT = 0 Q4 5 5 Q5 4 4 Q6 6 6 Q7 13 Q8 12 Q9 14 14 Q10 15 15 Q11 1 1 Q12 2 Q13 3 Logic symbol 74HC_HCT4020 Product data sheet 0 9 7 13 CT 12 2 13 3 001aal203 001aal202 Fig. 2. CTR14 Q0 Fig. 3. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 7 — 18 June 2020 © Nexperia B.V. 2020. All rights reserved 2 / 17 74HC4020; 74HCT4020 Nexperia 14-stage binary ripple counter FF T 1 CP RD Q FF T 2 Q RD Q Q FF T 3 RD Q FF T 4 Q RD Q Q FF T 6 Q RD Q MR Q0 Q3 Q13 001aal204 Fig. 4. Logic diagram 6. Pinning information 6.1. Pinning 1 terminal 1 index area Q12 2 15 Q10 Q13 3 14 Q9 Q5 4 13 Q7 Q4 5 12 Q8 Q6 6 11 MR Q3 7 10 CP GND 8 9 3 14 Q9 Q5 4 13 Q7 Q4 5 12 Q8 Q6 6 Q3 7 VCC(1) 11 MR 10 CP 001aal206 Transparent top view (1) This is not a supply pin. There is no electrical or mechanical requirement to solder the pad. In case soldered, the solder land should remain floating or connected to VCC. Q0 001aal205 Fig. 5. Q13 9 16 VCC 15 Q10 Q0 1 2 8 Q11 Q12 GND 74HC4020 74HCT4020 16 VCC Q11 74HC4020 74HCT4020 Pin configuration SOT109-1 (SO16) , SOT338-1 (SSOP16) and SOT403-1 (TSSOP16) Fig. 6. Pin configuration SOT763-1 (DHVQFN16) 6.2. Pin description Table 2. Pin description Symbol Pin Description Q0, Q3 to Q13 9, 7, 5, 4, 6, 13, 12, 14, 15, 1, 2, 3 output GND 8 ground (0 V) CP 10 clock input (HIGH-to-LOW, edge-triggered) MR 11 master reset input (active HIGH) VCC 16 positive supply voltage 74HC_HCT4020 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 18 June 2020 © Nexperia B.V. 2020. All rights reserved 3 / 17 74HC4020; 74HCT4020 Nexperia 14-stage binary ripple counter 7. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; ↑ = LOW-to-HIGH clock transition; ↓ = HIGH-to-LOW clock transition. Output Input CP MR Q0, Q3 to Q13 ↑ L no change ↓ L count X H L 7.1. Timing diagram CP input 1 2 4 8 16 32 64 128 256 512 1024 2048 4096 8192 16384 MR input Q0 Q3 Q4 Q5 Q6 Q7 Q8 Q9 Q10 Q11 Q12 Q13 001aal207 Fig. 7. Timing diagram 74HC_HCT4020 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 18 June 2020 © Nexperia B.V. 2020. All rights reserved 4 / 17 74HC4020; 74HCT4020 Nexperia 14-stage binary ripple counter 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Min Max VCC supply voltage -0.5 +7 V IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V - ±20 mA IOK IO output clamping current VI < -0.5 V or VI > VCC + 0.5 V - ±20 mA output current -0.5 V < VO < VCC + 0.5 V - ±25 mA ICC supply current - ±50 mA IGND ground current - ±50 mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] Conditions Tamb = -40 °C to +125 °C [1] Unit For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C. For SOT338-1 (SSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C. For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C. For SOT763-1 (DHVQFN16) package: Ptot derates linearly with 11.2 mW/K above 106 °C. 9. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions 74HC4020 Min Typ 74HCT4020 Max Min Typ Unit Max VCC supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V -40 +25 +125 -40 +25 Tamb ambient temperature 74HC_HCT4020 Product data sheet except for Schmitt trigger inputs All information provided in this document is subject to legal disclaimers. Rev. 7 — 18 June 2020 © +125 °C Nexperia B.V. 2020. All rights reserved 5 / 17 74HC4020; 74HCT4020 Nexperia 14-stage binary ripple counter 10. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 VCC = 4.5 V 3.15 2.4 - 1.5 - 3.15 - 1.5 - V - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V 74HC4020 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V VI = VIH or VIL HIGH-level output voltage IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V VI = VIH or VIL LOW-level output voltage IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V - - ±0.1 - ±1 - ±1 μA II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 μA CI input capacitance - 3.5 - - - - - pF 74HC_HCT4020 Product data sheet VI = VCC or GND; VCC = 6.0 V All information provided in this document is subject to legal disclaimers. Rev. 7 — 18 June 2020 © Nexperia B.V. 2020. All rights reserved 6 / 17 74HC4020; 74HCT4020 Nexperia 14-stage binary ripple counter Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max 74HCT4020 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH VI = VIH or VIL; VCC = 4.5 V HIGH-level output voltage IO = -20 μA 4.4 4.5 - 4.4 - 4.4 - V 3.98 4.32 - 3.84 - 3.7 - V - 0 0.1 - 0.1 - 0.1 V - 0.15 0.26 - 0.33 - 0.4 V - - ±0.1 - ±1 - ±1 μA - - 8.0 - 80 - 160 μA pin MR - 110 396 - 495 - 539 μA pin CP - 85 306 - 383 - 417 μA - 3.5 - - - - - pF IO = -4.0 mA VOL VI = VIH or VIL; VCC = 4.5 V LOW-level output voltage IO = 20 μA; VCC = 4.5 V IO = 4.0 mA; VCC = 4.5 V II input leakage current ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V ΔICC VI = VCC - 2.1 V; IO = 0 A; additional supply current other inputs at VCC or GND; VCC = 4.5 V to 5.5 V CI VI = VCC or GND; VCC = 5.5 V input capacitance 11. Dynamic characteristics Table 7. Dynamic characteristics GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Fig. 10 Symbol Parameter Conditions 25 °C Min -40 °C to +85 °C -40 °C to +125 °C Unit Typ Max Min Max Min Max 74HC4020 tpd propagation delay CP to Q0; see Fig. 8 [1] VCC = 2.0 V - 39 140 - 175 - 210 ns VCC = 4.5 V - 14 28 - 35 - 42 ns VCC = 5.0 V; CL = 15 pF - 11 - - - - - ns VCC = 6.0 V - 11 24 - 30 - 36 ns VCC = 2.0 V - 22 75 - 95 - 110 ns VCC = 4.5 V - 8 15 - 19 - 22 ns VCC = 5.0 V; CL = 15 pF - 6 - - - - - ns VCC = 6.0 V - 6 13 - 16 - 19 ns - 55 170 - 215 - 225 ns - 20 34 - 43 - 51 ns VCC = 5.0 V; CL = 15 pF - 17 - - - - - ns VCC = 6.0 V - 16 29 - 37 - 43 ns Qn to Qn+1; see Fig. 9 tPHL HIGH to LOW MR to Qn; see Fig. 8 propagation VCC = 2.0 V delay VCC = 4.5 V 74HC_HCT4020 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 18 June 2020 © Nexperia B.V. 2020. All rights reserved 7 / 17 74HC4020; 74HCT4020 Nexperia 14-stage binary ripple counter Symbol Parameter Conditions 25 °C Min tt tW transition time Qn; see Fig. 8 -40 °C to +85 °C -40 °C to +125 °C Unit Typ Max Min Max Min Max [2] VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns VCC = 2.0 V 80 14 - 100 - 120 - ns VCC = 4.5 V 16 4 - 20 - 24 - ns VCC = 6.0 V 14 3 - 17 - 20 - ns VCC = 2.0 V 80 17 - 100 - 120 - ns VCC = 4.5 V 16 6 - 20 - 24 - ns VCC = 6.0 V 14 5 - 17 - 20 - ns VCC = 2.0 V 50 6 - 65 - 75 - ns VCC = 4.5 V 10 2 - 13 - 15 - ns VCC = 6.0 V 9 2 - 11 - 13 - ns VCC = 2.0 V 6.0 30 - 4.8 - 4.0 - MHz VCC = 4.5 V 30 92 - 24 - 20 - MHz - 101 - - - - - MHz 35 109 - 28 - 24 - MHz - 19 - - - - - pF VCC = 4.5 V - 18 36 - 45 - 54 ns VCC = 5.0 V; CL = 15 pF - 15 - - - - - ns VCC = 4.5 V - 8 15 - 19 - 22 ns VCC = 5.0 V; CL = 15 pF - 6 - - - - - ns HIGH to LOW MR to Qn; see Fig. 8 propagation VCC = 4.5 V delay VCC = 5.0 V; CL = 15 pF - 22 45 - 56 - 68 ns - 19 - - - - - ns - 7 15 - 19 - 22 ns 20 7 - 25 - 30 - ns 20 8 - 25 - 30 - ns 10 2 - 13 - 15 - ns pulse width CP HIGH or LOW; see Fig. 8 MR HIGH; see Fig. 8 trec fmax recovery time MR to CP; see Fig. 8 maximum frequency see Fig. 8 VCC = 5.0 V; CL = 15 pF VCC = 6.0 V CPD power dissipation capacitance [3] 74HCT4020 tpd propagation delay CP to Q0; see Fig. 8 [1] Qn to Qn+1; see Fig. 9 tPHL tt transition time Qn; see Fig. 8 tW pulse width [2] VCC = 4.5 V CP HIGH or LOW; see Fig. 8 VCC = 4.5 V MR HIGH; see Fig. 8 VCC = 4.5 V trec recovery time MR to CP; see Fig. 8 VCC = 4.5 V 74HC_HCT4020 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 18 June 2020 © Nexperia B.V. 2020. All rights reserved 8 / 17 74HC4020; 74HCT4020 Nexperia 14-stage binary ripple counter Symbol Parameter Conditions 25 °C Min fmax maximum frequency [1] [2] [3] Typ Max Min Max Min Max see Fig. 8 VCC = 4.5 V VCC = 5.0 V; CL = 15 pF CPD -40 °C to +85 °C -40 °C to +125 °C Unit power dissipation capacitance [3] 25 47 - 20 - 17 - MHz - 52 - - - - - MHz - 20 - - - - - pF tpd is the same as tPHL and tPLH. tt is the same as tTHL and tTLH. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi + Σ (CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; 2 Σ (CL x VCC x fo) = sum of outputs; CL = output load capacitance in pF; VCC = supply voltage in V. 11.1. Waveforms and test circuit VI VM MR input tW trec VI 1/fmax VM CP input tPHL Q0 or Qn output tPLH 90 % tW tPHL 90 % 10 % VM 10 % tTLH tTHL 001aad590 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 8. Clock timing, propagation delays and pulse widths 74HC_HCT4020 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 18 June 2020 © Nexperia B.V. 2020. All rights reserved 9 / 17 74HC4020; 74HCT4020 Nexperia 14-stage binary ripple counter VOH Qn output VM VOL tPLH VOH tPHL VM Qn+1 output VOL 001aai120 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 9. Waveforms showing the output Qn to output Qn+1 propagation delays Table 8. Measurement points Type Input Output VM VM 74HC4020 0.5 x VCC 0.5 x VCC 74HCT4020 1.3 V 1.3 V VI negative pulse VM VI GND VM 10 % GND positive pulse tW 90 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VO RT CL 001aah768 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. Fig. 10. Test circuit for measuring switching times Table 9. Test data Type Load Input VI tr, tf CL 74HC4020 VCC 6 ns 15 pF, 50 pF 74HCT4020 3V 6 ns 15 pF, 50 pF 74HC_HCT4020 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 18 June 2020 © Nexperia B.V. 2020. All rights reserved 10 / 17 74HC4020; 74HCT4020 Nexperia 14-stage binary ripple counter 12. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig. 11. Package outline SOT109-1 (SO16) 74HC_HCT4020 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 18 June 2020 © Nexperia B.V. 2020. All rights reserved 11 / 17 74HC4020; 74HCT4020 Nexperia 14-stage binary ripple counter SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm D SOT338-1 E A X c y HE v M A Z 9 16 Q A2 A (A 3) A1 pin 1 index θ Lp L 8 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.00 0.55 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT338-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Fig. 12. Package outline SOT338-1 (SSOP16) 74HC_HCT4020 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 18 June 2020 © Nexperia B.V. 2020. All rights reserved 12 / 17 74HC4020; 74HCT4020 Nexperia 14-stage binary ripple counter TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm D SOT403-1 E A X c y HE v M A Z 9 16 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 8 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 13. Package outline SOT403-1 (TSSOP16) 74HC_HCT4020 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 18 June 2020 © Nexperia B.V. 2020. All rights reserved 13 / 17 74HC4020; 74HCT4020 Nexperia 14-stage binary ripple counter DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT763-1 16 terminals; body 2.5 x 3.5 x 0.85 mm B D A A E A1 c detail X terminal 1 index area terminal 1 index area C e1 e b 2 7 y y1 C v M C A B w M C L 1 8 Eh e 16 9 15 10 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 3.6 3.4 2.15 1.85 2.6 2.4 1.15 0.85 0.5 2.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT763-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig. 14. Package outline SOT763-1 (DHVQFN16) 74HC_HCT4020 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 18 June 2020 © Nexperia B.V. 2020. All rights reserved 14 / 17 74HC4020; 74HCT4020 Nexperia 14-stage binary ripple counter 13. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT4020 v.7 20200618 Product data sheet - 74HC_HCT4020 v.6 Modifications: • • • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type number 74HCT4020DB (SOT338-1/SSOP16) removed. Section 1 and Section 2 updated. Table 4: Derating values for Ptot total power dissipation have been updated. 74HC_HCT4020 v.6 20160203 Modifications: • 74HC_HCT4020 v.5 20120806 Modifications: • 74HC_HCT4020 v.4 20111213 Modifications: • 74HC_HCT4020 v.3 20100120 74HC_HCT4020 v.2 19970901 74HC_HCT4020 Product data sheet Product data sheet - 74HC_HCT4020 v.5 Type numbers 74HC4020N and 74HCT4020N (SOT38-4) removed. Product data sheet - 74HC_HCT4020 v.4 - 74HC_HCT4020 v.3 Product data sheet - 74HC_HCT4020 v.2 Product specification - - Measurement points added to Fig. 8 (errata). Product data sheet Legal pages updated. All information provided in this document is subject to legal disclaimers. Rev. 7 — 18 June 2020 © Nexperia B.V. 2020. All rights reserved 15 / 17 74HC4020; 74HCT4020 Nexperia 14-stage binary ripple counter 15. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74HC_HCT4020 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 7 — 18 June 2020 © Nexperia B.V. 2020. All rights reserved 16 / 17 74HC4020; 74HCT4020 Nexperia 14-stage binary ripple counter Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Ordering information....................................................2 5. Functional diagram.......................................................2 6. Pinning information......................................................3 6.1. Pinning.........................................................................3 6.2. Pin description............................................................. 3 7. Functional description................................................. 4 7.1. Timing diagram............................................................ 4 8. Limiting values............................................................. 5 9. Recommended operating conditions..........................5 10. Static characteristics..................................................6 11. Dynamic characteristics.............................................7 11.1. Waveforms and test circuit........................................ 9 12. Package outline........................................................ 11 13. Abbreviations............................................................ 15 14. Revision history........................................................15 15. Legal information......................................................16 © Nexperia B.V. 2020. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 18 June 2020 74HC_HCT4020 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 18 June 2020 © Nexperia B.V. 2020. All rights reserved 17 / 17
74HC4020DB,112
物料型号: - 74HC4020 - 74HCT4020
器件简介: 74HC4020和74HCT4020是一个14级二进制递增计数器,具有时钟输入(CP)、异步主复位输入(MR)和12个缓冲并行输出(Q0至Q13)。计数器在CP的高到低转换时递增。MR上的高电平会清除所有计数器阶段并使所有输出强制为低,与CP的状态无关。每个计数器阶段都是一个静态触发器。输入包括钳位二极管,这使得可以使用限流电阻将输入接口至超过VCC的电压。
参数特性: - 宽电源电压范围:2.0V至6.0V - CMOS低功耗 - 高抗扰度 - 锁存性能超过100mA每JESD 78 Class II Level B - 符合JEDEC标准 - ESD保护:HBM JESD22-A114F超过2000V,MM JESD22-A115-A超过200V - 多种封装选项 - 规定在-40°C至+85°C和-40°C至+125°C的温度范围内
功能详解: - 计数器在CP的高到低边沿触发时递增。 - MR输入的高电平会清除计数器并使所有输出为低。 - 每个计数器阶段都是一个静态触发器。
应用信息: - 频率分割电路 - 时间延迟电路 - 控制计数器
封装信息: - 74HC4020D:SO16封装 - 74HCT4020D - 74HC4020DB:SSOP16封装 - 74HC4020PW:TSSOP16封装 - 74HCT4020PW - 74HC4020BQ:DHVQFN16封装 - 74HCT4020BQ
引脚分配和描述: - Q0至Q13:输出引脚 - GND:地(0V) - CP:时钟输入(高到低边沿触发) - MR:主复位输入(高电平有效) - Vcc:正电源电压
74HC4020DB,112 价格&库存
很抱歉,暂时无法提供与“74HC4020DB,112”相匹配的价格&库存,您可以联系我们找货
74HC4020DB,112
  • 3+3.65329
  • 10+3.22328
  • 25+2.72260
  • 39+2.71062
  • 107+2.56209
  • 156+2.46268
库存:133
74HC4020DB,112
    • 307+2.88615
    库存:944
