IP4786CZ32S,118
IP4786CZ32S,118
    NEXPERIA(安世)
    HXQFN32_4X4MM_EP
    DVI和HDMI接口ESD和过流保护,DDC/CEC缓冲,热插拔检测和反向驱动保护
IP4786CZ32S,118 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia IP4786CZ32S DVI and HDMI interface ESD and overcurrent protection, DDC/CEC buffering, hot plug detect and backdrive protection Rev. 3 — 7 January 2015 Product data sheet 1. General description The IP4786CZ32S is designed to protect High-Definition Multimedia Interface (HDMI) transmitter host interfaces. It includes HDMI 5 V overcurrent / overvoltage protection, Display Data Channel (DDC) buffering and decoupling, Hot Plug Detect (HPD), backdrive protection, Consumer Electronic Control (CEC) buffering and decoupling, and 12 kV contact ElectroStatic Discharge (ESD) protection for all external I/Os in accordance with the IEC 61000-4-2, level 4 standard. The IP4786CZ32S incorporates Transmission Line Clamping (TLC) technology on the high-speed Transition-Minimized Differential Signaling (TMDS) lines to simplify routing and help reduce impedance discontinuities. All TMDS lines are protected by an impedance-matched diode configuration that minimizes impedance discontinuities caused by typical shunt diodes. The enhanced 60 mA overcurrent / overvoltage linear regulator guarantees HDMI-compliant 5 V output voltage levels with up to 6.5 V inputs. The DDC lines use a new buffering concept which decouples the internal capacitive load from the external capacitive load for use with standard Complementary Metal Oxide Semiconductor (CMOS) or Low Voltage Transistor-Transistor Logic (LVTTL) I/O cells down to 1.8 V. This buffering also redrives the DDC and CEC signals, allowing the use of longer or cheaper HDMI cables with a higher capacitance. The internal hot plug detect module simplifies the application of the HDMI transmitter to control the hot plug signal. All lines provide appropriate integrated pull-ups and pull-downs for HDMI compliance and backdrive protection to guarantee that HDMI interface signals are not pulled down if the system is powered down or enters Standby mode. Only a single external capacitor is required for operation. 2. Features and benefits     HDMI 2.0 and all backward compatible standards are supported 6.0 Gbps TMDS Bit Rate (600 Mcsc TMDS Character Rate) compatible Supports Ultra High-Definition (UHD) 4K (2160p) 60 Hz display modes Impedance matched 100  differential transmission line ESD protection for TMDS lines (10 ). No Printed-Circuit Board (PCB) pre-compensation required  Simplified flow-through routing utilizing less overall PCB space  DDC capacitive decoupling between system side and HDMI connector side and buffering to drive cable with high capacitive load (> 700 pF/25 m)  All external I/O lines with ESD protection of at least 12 kV, exceeding the IEC 61000-4-2, level 4 standard IP4786CZ32S NXP Semiconductors DVI and HDMI interface ESD and overcurrent protection     Hot plug detect module CEC buffering and isolation, with integrated backdrive-protected 26 k pull-up Robust ESD protection without degradation after repeated ESD strikes Highest integration in a small footprint, PCB level, optimized RF routing, 32-pin HVQFN leadless package 3. Applications  The IP4786CZ32S can be used for a wide range of HDMI source devices, consumer and computing electronics:  Tablet and notebook PCs  Portable Media Players  Digital Still Cameras (DSC)  High-Definition (HD) and Standard-Definition (SD) Blu-ray and DVD players  Set-top boxes (STB)  PC graphic cards  Game consoles  HDMI picture performance quality enhancer modules  Digital Visual Interface (DVI) 4. Ordering information Table 1. Ordering information Type number Package Name IP4786CZ32S IP4786CZ32S Product data sheet Description Version HXQFN32 plastic thermal enhanced extremely thin quad flat SOT1318-1 package; no leads; 32 terminals; body 4  4  0.5 mm All information provided in this document is subject to legal disclaimers. Rev. 3 — 7 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 2 of 35 IP4786CZ32S NXP Semiconductors DVI and HDMI interface ESD and overcurrent protection 5. Functional diagram TMDS_D2+_SYS TMDS_D2+_CON ESD TMDS_D2–_SYS TMDS_D2–_CON TMDS_D1+_SYS TMDS_D1+_CON TMDS_D1–_SYS TMDS_D1–_CON TMDS_D0+_SYS TMDS_D0+_CON TMDS_D0–_SYS TMDS_D0–_CON TMDS_CK+_SYS TMDS_CK+_CON TMDS_CK–_SYS TMDS_CK–_CON VCC(5V0) ESD 3.3 V VOLTAGE REGULATOR VCC(SYS) ESD CEC driver 10 kΩ 26 kΩ CEC_SYS CEC_CON ESD HDMI_5V0_CON VCC(SYS) ESD DDC driver 3.65 kΩ 1.85 kΩ DDC_CLK_SYS DDC_CLK_CON VCC(SYS) ESD HDMI_5V0_CON ESD DDC driver 3.65 kΩ 1.85 kΩ DDC_DAT_SYS DDC_DAT_CON Hot plug ESD ESD HOTPLUG_DET_SYS HOTPLUG_DET_CON 100 kΩ 100 kΩ ESD ESD HDMI_5V0_CON VCC(5V0) ESD ESD_BYPASS CURRENT LIMITER VCC(SYS) main clamp VCC(5V0) ESD ESD enable enLim enRef POWER MANAGEMENT UNIT CEC_STBY enCEC VCC(SYS) VCC(SYS) 100 kΩ VCC(5V0) ESD ibias 1..n vref 1..m CURRENT-/VOLTAGEREFERENCES Fig 1. IP4786CZ32S Product data sheet n m UTILITY_CON 100 kΩ aaa-013776 Functional diagram All information provided in this document is subject to legal disclaimers. Rev. 3 — 7 January 2015 © NXP Semiconductors N.V. 2015. All rights reserved. 3 of 35 IP4786CZ32S NXP Semiconductors DVI and HDMI interface ESD and overcurrent protection 6. Pinning information  &(&B&21  9&& 6
IP4786CZ32S,118 价格&库存
很抱歉,暂时无法提供与“IP4786CZ32S,118”相匹配的价格&库存,您可以联系我们找货
