HEF4014BT-Q100J
HEF4014BT-Q100J
    NEXPERIA(安世)
    SOIC-16
    8位静态移位寄存器 SOIC16_150MIL 3~15V
HEF4014BT-Q100J 数据手册
HEF4014B-Q100 8-bit static shift register Rev. 2 — 17 October 2018 Product data sheet 1. General description The HEF4014B-Q100 is a fully synchronous edge-triggered 8-bit static shift register with eight synchronous parallel inputs (D0 to D7). It has a synchronous serial data input (DS), a synchronous parallel enable input (PE) and a LOW-to-HIGH edge-triggered clock input (CP). It also has buffered parallel outputs from the last three stages (Q5 to Q7). Operation is synchronous and the device is edge-triggered on the LOW-to-HIGH transition of CP. Each register stage is of a D-type master-slave flip-flop type. When PE is HIGH, data is loaded into the register from D0 to D7 on the LOW-to-HIGH transition of CP. When PE is LOW, data is shifted to the first position from DS. All the data in the register is shifted one position to the right on the LOW-to-HIGH transition of CP. The Schmitt trigger action of the clock input makes the HEF4014B-Q100 highly tolerant of slower clock rise and fall times. It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 3) and is suitable for use in automotive applications. 2. Features and benefits • • • • • • • Automotive product qualification in accordance with AEC-Q100 (Grade 3) • Specified from -40 °C to +85 °C Tolerant of slow clock rise and fall times Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics ESD protection: • MIL-STD-833, method 3015 exceeds 2000 V • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω) Complies with JEDEC standard JESD 13-B 3. Applications • • • Parallel-to-serial converter Serial data queueing General-purpose register 4. Ordering information Table 1. Ordering information Type number Package HEF4014BT-Q100 Temperature range Name Description Version -40 °C to +85 °C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 HEF4014B-Q100 Nexperia 8-bit static shift register 5. Functional diagram 7 6 5 4 13 14 15 1 D0 D1 D2 D3 D4 D5 D6 D7 9 PE 11 DS 0D CP 10 CP 1D 2D 3D 4D 5D 6D SHIFT REGISTER 8 BITS 7D Q5 Q6 Q7 2 12 3 001aae556 Fig. 1. Functional diagram PE D0 D5 D DS Q FF 0 CP D6 D Q D7 D FF 5 Q D FF 6 CP Q FF 7 CP CP CP Q5 Q6 Q7 001aae558 Fig. 2. Logic diagram HEF4014B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 October 2018 © Nexperia B.V. 2018. All rights reserved 2 / 12 HEF4014B-Q100 Nexperia 8-bit static shift register 6. Pinning information 6.1. Pinning HEF4014B-Q100 D7 1 16 VDD Q5 2 15 D6 Q7 3 14 D5 D3 4 13 D4 D2 5 12 Q6 D1 6 11 DS D0 7 10 CP VSS 8 9 PE aaa-006544 Fig. 3. Pin configuration SOT109-1 (SO16) 6.2. Pin description Table 2. Pin description Symbol Pin Description Q5 to Q7 2, 12, 3 output D0 to D7 7, 6, 5, 4, 13, 14, 15, 1 parallel data input VSS 8 ground supply voltage PE 9 parallel enable input CP 10 clock input (LOW-to-HIGH edge-triggered) DS 11 serial data input VDD 16 supply voltage HEF4014B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 October 2018 © Nexperia B.V. 2018. All rights reserved 3 / 12 HEF4014B-Q100 Nexperia 8-bit static shift register 7. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; nD = HIGH or LOW; ↑ = LOW-to-HIGH clock transition; ↓ = HIGH-to-LOW clock transition; Number of clock transitions Inputs Outputs CP DS PE Q5 Q6 Q7 1 ↑ 1D L X X X 2 ↑ 2D L X X X 3 ↑ 3D L X X X 6 ↑ X L 1D X X 7 ↑ X L 2D 1D X 8 ↑ X L 3D 2D 1D ↓ X X no change no change no change ↑ X H D5 D6 D7 ↓ X X no change no change no change Serial operation Parallel operation 1 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit -0.5 +18 V - ±10 mA VDD supply voltage IIK input clamping current VI input voltage IOK output clamping current - ±10 mA II/O input/output current - ±10 mA IDD supply current - 50 mA Tstg storage temperature -65 +150 °C Tamb ambient temperature -40 +85 °C Ptot total power dissipation Tamb = -40 °C to +85 °C - 500 mW P power dissipation per output - 100 mW [1] VI < -0.5 V or VI > VDD + 0.5 V -0.5 VO < -0.5 V or VO > VDD + 0.5 V [1] VDD + 0.5 V For SO16 package: Ptot derates linearly with 8 mW/K above 70 °C. HEF4014B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 October 2018 © Nexperia B.V. 2018. All rights reserved 4 / 12 HEF4014B-Q100 Nexperia 8-bit static shift register 9. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit VDD supply voltage 3 - 15 V VI input voltage 0 - VDD V Tamb ambient temperature in free air -40 - +85 °C Δt/ΔV input transition rise and fall rate VDD = 5 V - - 3.75 μs/V VDD = 10 V - - 0.5 μs/V VDD = 15 V - - 0.08 μs/V 10. Static characteristics Table 6. Static characteristics VSS = 0 V; VI = VSS or VDD unless otherwise specified. Symbol Parameter VIH VIL VOH VOL IOH IOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage HIGH-level output current LOW-level output current II input leakage current IDD supply current CI input capacitance HEF4014B_Q100 Product data sheet Conditions VDD Tamb = -40 °C Tamb = +25 °C Tamb = +85 °C Unit Min Max Min Max Min Max 5V 3.5 - 3.5 - 3.5 - V 10 V 7.0 - 7.0 - 7.0 - V 15 V 11.0 - 11.0 - 11.0 - V 5V - 1.5 - 1.5 - 1.5 V 10 V - 3.0 - 3.0 - 3.0 V 15 V - 4.0 - 4.0 - 4.0 V 5V 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - V 5V - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 V 15 V - 0.05 - 0.05 - 0.05 V VO = 2.5 V 5V - -1.7 - -1.4 - -1.1 mA VO = 4.6 V 5V - -0.52 - -0.44 - -0.36 mA VO = 9.5 V 10 V - -1.3 - -1.1 - -0.9 mA VO = 13.5 V 15 V - -3.6 - -3.0 - -2.4 mA VO = 0.4 V 5V 0.52 - 0.44 - 0.36 - mA VO = 0.5 V 10 V 1.3 - 1.1 - 0.9 - mA VO = 1.5 V 15 V 3.6 - 3.0 - 2.4 - mA 15 V - ±0.3 - ±0.3 - ±1.0 μA 5V - 20 - 20 - 150 μA 10 V - 40 - 40 - 300 μA 15 V - 80 - 80 - 600 μA - - - - 7.5 - - pF |IO| < 1 μA |IO| < 1 μA |IO| < 1 μA |IO| < 1 μA IO = 0 A All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 October 2018 © Nexperia B.V. 2018. All rights reserved 5 / 12 HEF4014B-Q100 Nexperia 8-bit static shift register 11. Dynamic characteristics Table 7. Dynamic characteristics Tamb = 25 °C; VSS = 0 V. Symbol Parameter Conditions VDD Extrapolation formula [1] tPHL HIGH to LOW propagation delay CP to Qn; see Fig. 4 5V LOW to HIGH propagation delay CP to Qn; see Fig. 4 tPLH tt transition time tW pulse width tsu set-up time Qn output; see Fig. 4 PE to CP; see Fig. 5 Dn to CP; see Fig. 5 hold time PE to CP; see Fig. 5 DS to CP; see Fig. 5 Dn to CP; see Fig. 5 fclk(max) [1] [2] maximum clock frequency Typ Max Unit 103 ns + (0.55 ns/pF)CL - 130 260 ns 10 V 44 ns + (0.23 ns/pF)CL - 55 110 ns 15 V 32 ns + (0.16 ns/pF)CL - 40 80 ns 5V 88 ns + (0.55 ns/pF)CL - 115 230 ns 10 V 39 ns + (0.23 ns/pF)CL - 50 100 ns 15 V 32 ns + (0.16 ns/pF)CL - 40 80 ns [2] 10 ns + (1.00 ns/pF)CL - 60 120 ns 5V 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns 15 V 6 ns + (0.28 ns/pF)CL - 20 40 ns 70 35 - ns 30 15 - ns 24 12 - ns 5V 40 10 - ns 10 V 25 5 - ns 15 V 15 0 - ns 5V +35 -5 - ns 10 V +25 -5 - ns 5V CP input; minimum width; 10 V see Fig. 5 15 V DS to CP; see Fig. 5 th Min see Fig. 5 15 V 25 0 - ns 5V +35 -5 - ns 10 V +25 -5 - ns 15 V 25 0 - ns 5V +25 -5 - ns 10 V 20 0 - ns 15 V 15 0 - ns 5V 30 15 - ns 10 V 20 10 - ns 15 V 15 7 - ns 5V 30 15 - ns 10 V 20 10 - ns 15 V 15 7 - ns 5V 6 13 - MHz 10 V 15 30 - MHz 15 V 20 40 - MHz The typical values of the propagation delay and transition times are calculated from the extrapolation formulas shown (CL in pF). tt is the same as tTHL and tTLH. HEF4014B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 October 2018 © Nexperia B.V. 2018. All rights reserved 6 / 12 HEF4014B-Q100 Nexperia 8-bit static shift register Table 8. Dynamic power dissipation PD PD can be calculated from the formulas shown. VSS = 0 V; tr = tf ≤ 20 ns; Tamb = 25 °C. Symbol Parameter PD dynamic power dissipation VDD Typical formula for PD (μW) Where: 5V PD = 900 × fi + ∑(fo × CL) × 10 V PD = 4300 × fi + ∑(fo × CL) × VDD 15 V PD = 12000 × fi + ∑(fo × CL) × VDD 2 VDD fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VDD = supply voltage in V; ∑(CL × fo) = sum of the outputs. 2 2 11.1. Waveforms and test circuit VI VM CP input VSS tPHL VOH 90 % Qn output VOL tPLH VM 10 % tt tt 001aaj456 Measurement points are given in Table 9. Fig. 4. CP to Qn propagation delays and output transition times VI 50 % CP input VSS tsu th 50 % 50 % tsu th 50 % 50 % VI D input VSS 50 % 50 % tW tr 50 % fclk(max) tf tsu VI PE input th 50 % VSS 50 % tsu th 50 % 50 % VI DS input VSS 001aae559 The shaded areas indicate where change is permitted for predictable output performance. Set-up and hold times are shown as positive values but may be specified as negative values. Measurement points are given in Table 9. Fig. 5. Minimum clock pulse width, and set-up and hold times for PE to CP, DS to CP, and D to CP Table 9. Measurement points Supply voltage Input Output VDD VM VM 5 V to 15 V 0.5VDD 0.5VDD HEF4014B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 October 2018 © Nexperia B.V. 2018. All rights reserved 7 / 12 HEF4014B-Q100 Nexperia 8-bit static shift register VDD G VI VO DUT CL RT 001aag182 Test data is given in Table 10; Definitions for test circuit: DUT = Device Under Test. CL = load capacitance including jig and probe capacitance. RT = termination resistance should be equal to the output impedance Zo of the pulse generator. Fig. 6. Test circuit for measuring switching times Table 10. Test data Supply voltage Input VDD VI tr, tf CL 5 V to 15 V VSS or VDD ≤ 20 ns 50 pF HEF4014B_Q100 Product data sheet Load All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 October 2018 © Nexperia B.V. 2018. All rights reserved 8 / 12 HEF4014B-Q100 Nexperia 8-bit static shift register 12. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig. 7. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT109-1 (SO16) HEF4014B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 October 2018 © Nexperia B.V. 2018. All rights reserved 9 / 12 HEF4014B-Q100 Nexperia 8-bit static shift register 13. Abbreviations Table 11. Abbreviations Acronym Description ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model 14. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes HEF4014B_Q100 v.2 20181017 Product data sheet - Modifications: • • HEF4014B_Q100 v.1 HEF4014B_Q100 Product data sheet HEF4014B_Q100 v.1 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. 20130227 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 October 2018 - © Nexperia B.V. 2018. All rights reserved 10 / 12 HEF4014B-Q100 Nexperia 8-bit static shift register equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 15. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or HEF4014B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 October 2018 © Nexperia B.V. 2018. All rights reserved 11 / 12 HEF4014B-Q100 Nexperia 8-bit static shift register Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Ordering information....................................................1 5. Functional diagram.......................................................2 6. Pinning information......................................................3 6.1. Pinning.........................................................................3 6.2. Pin description............................................................. 3 7. Functional description................................................. 4 8. Limiting values............................................................. 4 9. Recommended operating conditions..........................5 10. Static characteristics..................................................5 11. Dynamic characteristics.............................................6 11.1. Waveforms and test circuit........................................ 7 12. Package outline.......................................................... 9 13. Abbreviations............................................................ 10 14. Revision history........................................................10 15. Legal information......................................................11 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 17 October 2018 HEF4014B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 October 2018 © Nexperia B.V. 2018. All rights reserved 12 / 12
HEF4014BT-Q100J 价格&库存
很抱歉,暂时无法提供与“HEF4014BT-Q100J”相匹配的价格&库存,您可以联系我们找货
HEF4014BT-Q100J
  • 1+5.107271+0.63983
  • 10+3.6209410+0.45363
  • 25+3.2400825+0.40592
  • 100+2.82126100+0.35345
  • 250+2.62183250+0.32846
  • 500+2.50180500+0.31342
  • 1000+2.436671000+0.30527
库存:2443
HEF4014BT-Q100J
  • 2500+2.031392500+0.25449
库存:2443
