HEF4894B-Q100
12-stage shift-and-store register LED driver
Rev. 1 — 12 July 2012
Product data sheet
1. General description
The HEF4894B-Q100 is a 12-stage serial shift register. It has a storage latch associated
with each stage for strobing data from the serial input (D) to the parallel LED driver outputs
(QP0 to QP11). Data is shifted on positive-going clock (CP) transitions. The data in each
shift register stage is transferred to the storage register when the strobe (STR) input is
HIGH. Data in the storage register appears at the output whenever the output enable (OE)
input signal is HIGH.
Two serial outputs (QS1 and QS2) are available for cascading a number of
HEF4894B-Q100 devices. Serial data is available at QS1 on positive-going clock edges to
allow high-speed operation in cascaded systems with a fast clock rise time. The same
serial data is available at QS2 on the next negative going clock edge. This is used for
cascading HEF4894B-Q100 devices when the clock has a slow rise time.
It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS
(usually ground). Unused inputs must be connected to VDD, VSS, or another input.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
ESD protection:
MIL-STD-833, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pf, R = 0 )
Complies with JEDEC standard JESD 13-B
HEF4894B-Q100
Nexperia
3. Ordering information
Table 1.
All types operate from 40 C to +125 C.
Type number
Package
Name
Description
Version
HEF4894BT-Q100
SO20
plastic small outline package; 20 leads; body width 7.5 mm
SOT163-1
HEF4894BTT-Q100
TSSOP20
plastic thin shrink small outline package; 20 leads; body width 4.4 mm
SOT360-1
4. Functional diagram
2
3
1
CP
STR
QS1
11
QS2
12
QP0
4
QP1
5
QP2
6
QP3
7
QP4
8
QP5
9
QP6
18
D
QP7
17
QP8
16
QP9
15
QP10
14
QP11
13
OE
19
Fig 1.
001aai639
Logic Symbol
D
CP
2
12
12-STAGE SHIFT REGISTER
3
11
STR
OE
1
QS1
12-BIT STORAGE REGISTER
19
OPEN-DRAIN OUTPUTS
4
5
QP0
6
7
QP2
QP1
Fig 2.
QS2
8
9
QP4
QP3
18
17
QP6
QP5
16
15
QP8
QP7
14
13
QP10
QP9
QP11 001aag118
Functional diagram
HEF4894B_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 18
HEF4894B-Q100
Nexperia
STAGE 0
D
D
Q
STAGE 1 TO 10
D
Q10S
STAGE 11
D
FF0
D
FF11
CP
QS1
Q
Q
QS2
LATCH
CP
LE
CP
D
D
Q
Q
LATCH
LATCH
LE
LE
STR
OE
QP0 QP1
Fig 3.
QP11
QP10
001aag119
Logic diagram
5. Pinning information
5.1 Pinning
HEF4894B-Q100
STR
1
20 VDD
D
2
19 OE
CP
3
18 QP6
QP0
4
17 QP7
QP1
5
16 QP8
QP2
6
15 QP9
QP3
7
14 QP10
QP4
8
13 QP11
QP5
9
12 QS2
VSS 10
11 QS1
aaa-003548
Fig 4.
Pin configuration
HEF4894B_Q100
Product data sheet
3 of 18
HEF4894B-Q100
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
D
2
serial input
QP0 to QP11
4, 5, 6, 7, 8, 9, 18, 17, 16, 15, 14, 13
parallel output
QS1
11
serial output
QS2
12
serial output
CP
3
clock input
STR
1
strobe input
OE
19
output enable input
VDD
supply voltage
VSS
10
ground (0 V)
6. Functional description
Table 3.
Function table[1]
At the positive clock edge the information in the 10th register stage is transferred to the 11th register stage and the QS output
Control
Input
Parallel output
Serial output
CP
OE
STR
D
QP0
QPn
QS1[2]
QS2[3]
L
X
X
Z
Z
Q10S
no change
L
X
X
Z
Z
no change
Q11S
H
L
X
no change
no change
Q10S
no change
H
H
L
Z
QPn 1
Q10S
no change
H
H
H
L
QPn1
Q10S
no change
H
H
H
no change
no change
no change
Q11S
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care; = LOW-to-HIGH clock transition; = HIGH-to-LOW clock transition;
Z = high-impedance OFF-state.
[2]
Q10S = the data in register stage 10 before the LOW to HIGH clock transition.
[3]
Q11S = the data in register stage 11 before the HIGH to LOW clock transition.
HEF4894B_Q100
Product data sheet
4 of 18
HEF4894B-Q100
Nexperia
clock input
data input
strobe input
output enable
input
internal Q0S
(FF 1)
QP0 output
internal Q10S
(FF 11)
QP10 output
serial QS1
output
serial QS2
output
001aag121
Fig 5.
Timing diagram
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VDD
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
II
input leakage current
IO
output current
Conditions
Min
Max
0.5
VI < 0.5 V or VI > VDD + 0.5 V
+18
10
0.5
QSn outputs; VO < 0.5 V or VO > VDD + 0.5
V
QPn outputs; VO < 0.5 V
VDD + 0.5
Unit
V
mA
V
10
mA
40
mA
10
mA
QSn outputs
10
mA
QPn outputs
40
mA
Tstg
storage temperature
65
+150
C
Tamb
ambient temperature
40
+125
C
Ptot
total power dissipation
Tamb = 40 C to +125 C
SO20 and TSSOP20 package
P
[1]
power dissipation
per output
[1]
500
mW
100
mW
For SO20 package: Ptot derates linearly with 8 mW/K above 70 C.
For TSSOP20 package: Ptot derates linearly with 5.5 mW/K above 60 C.
HEF4894B_Q100
Product data sheet
5 of 18
HEF4894B-Q100
Nexperia
8. Recommended operating conditions
Table 5.
Symbol
Parameter
VDD
VI
Conditions
Min
Typ
Max
Unit
supply voltage
3
15
V
input voltage
VDD
V
Tamb
ambient temperature
in free air
40
+125
C
t/V
input transition rise and fall rate
VDD = 5 V
3.75
s/V
VDD = 10 V
0.5
s/V
VDD = 15 V
0.08
s/V
9. Static characteristics
Table 6.
VSS = 0 V; VI = VSS or VDD; unless otherwise specified.
Symbol Parameter
VIH
VIL
VOH
VOL
Conditions
HIGH-level
input voltage
IO < 1 A
LOW-level
input voltage
IO < 1 A
HIGH-level
output voltage
LOW-level
output voltage
IOL
II
HIGH-level
output current
LOW-level
output current
input leakage
current
HEF4894B_Q100
Product data sheet
Tamb = 40 C Tamb = +25 C Tamb = +85 C Tamb = +125 C Unit
Min
Max
Min
Max
Min
Max
Min
Max
5V
3.5
3.5
3.5
3.5
V
10 V
7.0
7.0
7.0
7.0
V
15 V
11.0
11.0
11.0
11.0
V
5V
1.5
1.5
1.5
1.5
V
10 V
3.0
3.0
3.0
3.0
V
15 V
4.0
4.0
4.0
4.0
V
5V
4.95
4.95
4.95
4.95
V
10 V
9.95
9.95
9.95
9.95
V
15 V
14.95
14.95
14.95
14.95
V
5V
0.05
0.05
0.05
0.05
V
10 V
0.05
0.05
0.05
0.05
V
15 V
0.05
0.05
0.05
0.05
V
5V
0.75
0.75
1.5
1.5
V
10 V
0.75
0.75
1.5
1.5
V
15 V
0.75
0.75
1.5
1.5
V
VO = 2.5 V
5V
1.7
1.4
1.1
1.1
mA
VO = 4.6 V
5V
0.64
0.5
0.36
0.36 mA
VO = 9.5 V
10 V
1.6
1.3
0.9
0.9
mA
VO = 13.5 V 15 V
4.2
3.4
2.4
2.4
mA
QSn outputs;
IO < 1 A
QSn outputs;
IO < 1 A
QPn outputs;
IO < 20 mA
IOH
VDD
QSn outputs
QSn outputs
VO = 0.4 V
5V
0.64
0.5
0.36
0.36
mA
VO = 0.5 V
10 V
1.6
1.3
0.9
0.9
mA
VO = 1.5 V
15 V
4.2
3.2
2.4
2.4
mA
15 V
0.1
0.1
1.0
1.0
A
6 of 18
HEF4894B-Q100
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
IOZ
IDD
CI
OFF-state
output current
supply current
Conditions
VDD
QPn output
is HIGH;
VO = 15 V
Min
Max
Min
Max
Min
Max
Min
Max
5V
2
2
15
15
A
10 V
2
2
15
15
A
15 V
2
2
15
15
A
5V
5
5
150
150
A
10 V
10
10
300
300
A
15 V
600
A
7.5
pF
Extrapolation formula
Min
Typ
Max
IO = 0 A
input
capacitance
10. Dynamic characteristics
Table 7.
VSS = 0 V; Tamb = 25 C unless otherwise specified. For test circuit see Figure 10.
Symbol Parameter
tPHL
HIGH to LOW
propagation delay
Conditions
CP to QS1;
see Figure 6
CP to QS2;
see Figure 6
tPLH
LOW to HIGH
propagation delay
CP to QS1;
see Figure 6
CP to QS2;
see Figure 6
tPZL
OFF-state to LOW
propagation delay
CP to QPn;
see Figure 6
STR to QPn;
see Figure 7
tPLZ
LOW to OFF-state
propagation delay
CP to QPn;
see Figure 6 and 7
STR to QPn;
see Figure 7
HEF4894B_Q100
Product data sheet
VDD
5V
[1]
Unit
132 ns + (0.55 ns/pF)CL
160
320
ns
10 V
53 ns + (0.23 ns/pF)CL
65
130
ns
15 V
37 ns + (0.16 ns/pF)CL
45
90
ns
5V
92 ns + (0.55 ns/pF)CL
120
240
ns
10 V
39 ns + (0.23 ns/pF)CL
50
100
ns
15 V
32 ns + (0.16 ns/pF)CL
40
80
ns
102 ns + (0.55 ns/pF)CL
130
260
ns
44 ns + (0.23 ns/pF)CL
55
110
ns
15 V
40
80
ns
5V
130
260
ns
10 V
49 ns + (0.23 ns/pF)CL
60
120
ns
15 V
45
90
ns
5V
10 V
[1]
5V
240
480
ns
10 V
80
160
ns
15 V
55
110
ns
5V
140
280
ns
10 V
70
140
ns
15 V
55
110
ns
5V
170
340
ns
10 V
75
150
ns
15 V
60
120
ns
5V
100
200
ns
10 V
40
100
ns
15 V
35
70
ns
7 of 18
HEF4894B-Q100
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
ten
Conditions
VDD
OE to QPn;
see Figure 8
5V
[2]
10 V
15 V
OE to QPn;
see Figure 8
tdis
5V
[2]
10 V
15 V
transition time
tt
pulse width
tW
QS1, QS2;
see Figure 6
5V
set-up time
hold time
th
fclk(max)
[1]
maximum clock
frequency
Typ
Max
Unit
100
200
ns
55
110
ns
50
100
ns
80
160
ns
40
80
ns
30
60
ns
35 ns + (1.00 ns/pF)CL
85
170
ns
10 V
19 ns + (0.42 ns/pF)CL
40
80
ns
15 V
16 ns + (0.28 ns/pF)CL
30
60
ns
CP; LOW and HIGH; 5 V
see Figure 6
10 V
60
30
ns
30
15
ns
15 V
24
12
ns
5V
80
40
ns
10 V
60
30
ns
15 V
24
12
ns
5V
60
30
ns
10 V
ns
15 V
15
5
ns
STR; HIGH;
see Figure 7
tsu
[1][3]
Min
D to CP;
see Figure 9
D to CP;
see Figure 9
CP; see Figure 6
5V
+5
15
ns
10 V
ns
15 V
ns
5V
5
10
MHz
10 V
11
22
MHz
15 V
14
28
MHz
The typical values of the propagation delay and transition times are calculated from the extrapolation formulas shown (CL in pF).
[2]
ten is the same as tPZL and tdis is the same as tPLZ.
[3]
tt is the same as tTLH and tTHL.
Table 8.
Dynamic power dissipation
PD can be calculated from the formulas shown. VSS = 0 V; tr = tf 20 ns; Tamb = 25 C.
Symbol Parameter
PD
dynamic power
dissipation
HEF4894B_Q100
Product data sheet
VDD
Typical formula
Where
5V
PD = 1200 fi + (fo CL) VDD W
10 V
PD = 5550 fi + (fo CL) VDD W
15 V
PD = 15000 fi + (fo CL) VDD2 W
2
2
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
(fo CL) = sum of the outputs;
VDD = supply voltage in V.
8 of 18
HEF4894B-Q100
Nexperia
11. Waveforms
1/fclk(max)
VI
VM
CP input
VSS
tW
tW
tPLZ
tPZL
VDD
VY
QPn output
VX
VOL
tPLH
VOH
tPHL
90 %
VM
QS1 output
VOL
10 %
tTHL
tTLH
tPLH
VOH
tPHL
90 %
VM
QS2 output
10 %
VOL
tTLH
tTHL
001aag222
Parallel output measurement points are given in Table 9.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig 6.
Propagation delay clock (CP) to output (QPn, QS1, QS2), clock pulse width and
maximum clock frequency
Table 9.
Measurement points
Supply
Input
Output
VDD
VM
VM
VX
VY
5 V to 15 V
0.5VDD
0.5VDD
0.1VO
0.9VO
VI
VM
CP input
VSS
VI
STR input
VM
VSS
VDD
tW
tPLZ
tPZL
VY
QPn output
VOL
VX
001aag802
Measurement points are given in Table 9.
VOL is the typical output voltage level that occurs with the output load.
Fig 7.
Strobe (STR) to output (QPn) propagation delays and the strobe pulse width
HEF4894B_Q100
Product data sheet
9 of 18
HEF4894B-Q100
Nexperia
VI
OE input
VM
VSS
tPLZ
tPZL
VDD
output
LOW to OFF-state
OFF-state to LOW
VOL
VY
VX
outputs
enabled
outputs
disabled
outputs
enabled
001aag803
Fig 8.
Enable and disable times for input OE
VI
CP input
VM
VSS
tsu
tsu
th
th
VI
VM
D input
VSS
VDD
QPn output
VOL
001aag805
VOL is a typical output voltage level that occurs with the output load.
The shaded areas indicate when the input is permitted to change for predictable output performance.
Fig 9.
Set-up and hold times for the data input (D)
HEF4894B_Q100
Product data sheet
10 of 18
HEF4894B-Q100
Nexperia
VI
90 %
input pulse
VSS
10 %
tf
tr
VEXT
VDD
G
VI
VO
RL
DUT
CL
RT
001aag804
Test data is given in Table 10.
Definitions for test circuit:
DUT - Device Under Test;
RL = Load resistance;
CL = load capacitance;
RT = Termination resistance should be equal to output impedance of Zo of the pulse generator;
VEXT = External voltage for measuring switching times.
Fig 10. Test circuit for measuring switching times
Table 10.
Test data
Supply
Input
VDD
VI
tr, tf
tPLZ, tPZL
tPLH, tPHL
CL
RL
5 V to 15 V
VDD
20 ns
VDD
open
50 pF
1 k
HEF4894B_Q100
Product data sheet
VEXT
Load
11 of 18
HEF4894B-Q100
Nexperia
12. Application information
Application example: serial-to-parallel data converting LED driver.
9''
9''
43 43
9''
2(
3:0GLPPHU
LQSXW
675
43 43
+()%4
46
&3
43 43
9''
966
2(
675
+()%4
43 43
46
&3
966
&21752/$1'
6
很抱歉,暂时无法提供与“HEF4894BT-Q100,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+21.69720
- 10+18.63000
- 30+16.81560
- 100+14.96880
- 500+14.11560
- 1000+13.73760
- 国内价格 香港价格
- 2000+9.710052000+1.26207
- 4000+9.494004000+1.23399
- 6000+9.385856000+1.21993
- 国内价格 香港价格
- 1+18.785601+2.44167
- 10+13.8934510+1.80581
- 25+12.6679625+1.64653
- 100+11.32161100+1.47154
- 250+10.67867250+1.38797
- 500+10.64782500+1.38396
