74AXP1T34GMH
74AXP1T34GMH
    NEXPERIA(安世)
    XSON6_1.45x1MM
    电压电平 转换器 单向 1 电路 1 通道 6-XSON,SOT886(1.45x1)
74AXP1T34GMH 数据手册
74AXP1T34 Dual supply translating buffer Rev. 1 — 22 December 2015 Product data sheet 1. General description The 74AXP1T34 is a dual supply translating buffer. It features one input (A), an output (Y) and dual supply pins (VCCI and VCCO). The inputs are referenced to VCCI and the output is referenced to VCCO. All inputs can be connected directly to VCCI or GND. VCCI can be supplied at any voltage between 0.7 V and 2.75 V and VCCO can be supplied at any voltage between 1.2 V and 5.5 V. This feature allows voltage level translation. Schmitt-trigger action at all inputs makes the circuit tolerant of slower input rise and fall times. This device ensures very low static and dynamic power consumption across the entire supply range and is fully specified for partial power down applications using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging backflow current through the device when it is powered down. 2. Features and benefits  Wide supply voltage range:  VCCI: 0.7 V to 2.75 V  VCCO: 1.2 V to 5.5 V  Low input capacitance; CI = 0.6 pF (typical)  Low output capacitance; CO = 1.8 pF (typical)  Low dynamic power consumption; CPD = 0.4 pF at VCCI = 1.2 V (typical)  Low dynamic power consumption; CPD = 7.1 pF at VCCO = 3.3 V (typical)  Low static power consumption; ICCI = 0.5 A (85 C maximum)  Low static power consumption; ICCO = 1.8 A (85 C maximum)  High noise immunity  Complies with JEDEC standard:  JESD8-12A.01 (1.1 V to 1.3 V; A input)  JESD8-11A.01 (1.4 V to 1.6 V)  JESD8-7A (1.65 V to 1.95 V)  JESD8-5A.01 (2.3 V to 2.7 V)  JESD8-C (2.7 V to 3.6 V; Y output)  JESD12-6 (4.5 V to 5.5 V; Y output)  ESD protection:  HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2 kV  CDM JESD22-C101E exceeds 1000 V  Latch-up performance exceeds 100 mA per JESD78D Class II  Inputs accept voltages up to 2.75 V 74AXP1T34 Nexperia Dual supply translating buffer     Low noise overshoot and undershoot < 10% of VCCO IOFF circuitry provides partial power-down mode operation Multiple package options Specified from 40 C to +85 C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AXP1T34GW 40 C to +85 C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 74AXP1T34GM 40 C to +85 C XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1  1.45  0.5 mm 74AXP1T34GN 40 C to +85 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74AXP1T34GS 40 C to +85 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 74AXP1T34GX 40 C to +85 C X2SON5 X2SON5: plastic thermal enhanced extremely thin small outline package; no leads; 5 terminals; body 0.8  0.8  0.35 mm SOT1226 4. Marking Table 2. Marking Marking code[1] Type number 74AXP1T34GW rQ 74AXP1T34GM rQ 74AXP1T34GN rQ 74AXP1T34GS rQ 74AXP1T34GX rQ [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram $  $ < <  9&&, DDF Fig 1. Logic symbol 74AXP1T34 Product data sheet 9&&2 DDD Fig 2. Logic diagram All information provided in this document is subject to legal disclaimers. . Rev. 1 — 22 December 2015 2 of 21 © Nexperia B.V. 2017. All rights reserved 74AXP1T34 Nexperia Dual supply translating buffer 6. Pinning information 6.1 Pinning $;37 $;37 $;37 9&&,  $  *1'      9&&2 $   QF *1'   < <  $ DDD Fig 4. Pin configuration SOT886, SOT1115 and SOT1202 (XSON6)  9&&2  <  *1' DDD 7UDQVSDUHQWWRSYLHZ Pin configuration SOT353-1 (TSSOP5)  9&&, 9&&2 DDD Fig 3. 9&&, 7UDQVSDUHQWWRSYLHZ Fig 5. Pin configuration SOT1226 (X2SON5) 6.2 Pin description Table 3. Pin description Symbol Pin Description TSSOP5 and X2SON5 XSON6 VCCI 1 1 input supply voltage A 2 2 data input A GND 3 3 ground (0 V) Y 4 4 data output Y n.c. - 5 not connected VCCO 5 6 output supply voltage Input Output 7. Functional description Table 4. Function table[1] Supply voltage VCCI VCCO A Y 0.7 V to 2.75 V 1.2 V to 5.5 V L L 0.7 V to 2.75 V 1.2 V to 5.5 V H H GND 1.2 V to 5.5 V X Z 0.7 V to 2.75 V GND X Z GND GND X Z [1] H = HIGH voltage level; L = LOW voltage level. 74AXP1T34 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 1 — 22 December 2015 3 of 21 © Nexperia B.V. 2017. All rights reserved 74AXP1T34 Nexperia Dual supply translating buffer 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCCI VCCO IIK input clamping current Conditions Min Max Unit input supply voltage 0.5 3.3 V output supply voltage 0.5 6.0 V 50 - [1] 0.5 3.3 50 - [1][2] 0.5 VCCO + 0.5 V [1] 0.5 6.0 V - 25 mA VI < 0 V VI input voltage IOK output clamping current VO < 0 V VO output voltage Active mode Power-down or 3-state mode VO = 0 V to VCCO mA V mA IO output current ICCI input supply current - 50 mA ICCO output supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C - 250 mW Tamb = 40 C to +85 C total power dissipation Ptot [3] [1] The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] VCCO + 0.5 V should not exceed 6.0 V. [3] For SOT353-1 package: above 75 C the value of Ptot derates linearly with 3.3 mW/K. For SOT886 package: above 75 C the value of Ptot derates linearly with 3.3 mW/K. For SOT1115 package: above 70 C the value of Ptot derates linearly with 3.2 mW/K. For SOT1202 package: above 75 C the value of Ptot derates linearly with 3.3 mW/K. For SOT1226 package: above 70 C the value of Ptot derates linearly with 3.1 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCCI Min Max Unit input supply voltage 0.7 2.75 V VCCO output supply voltage 1.2 5.5 V VI input voltage VO output voltage Tamb ambient temperature t/V input transition rise and fall rate 74AXP1T34 Product data sheet Conditions 0 2.75 V Active mode 0 VCCO V Power-down or 3-state mode 0 5.5 V 40 +85 C 0 200 ns/V VCCI = 0.7 V to 2.75 V All information provided in this document is subject to legal disclaimers. . Rev. 1 — 22 December 2015 4 of 21 © Nexperia B.V. 2017. All rights reserved 74AXP1T34 Nexperia Dual supply translating buffer 10. Static characteristics Table 7. Static characteristics At recommended operating conditions, unless otherwise specified; voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = 40 C to +85 C Conditions Min HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage 0.75VCCI - - - V VCCI = 1.1 V to 1.95 V 0.65VCCI - - - V VCCI = 2.3 V to 2.7 V 1.6 - - - V VCCI = 0.75 V to 0.85 V - - 0.25VCCI 0.25VCCI V VCCI = 1.1 V to 1.95 V - - 0.35VCCI 0.35VCCI V - - 0.7 0.7 V - 1.05 - - V IO = 3 mA; VCCO = 1.4 V 1.05 - - - V IO = 4.5 mA; VCCO = 1.65 V 1.2 - - - V IO = 8 mA; VCCO = 2.3 V 1.7 - - - V IO = 10 mA; VCCO = 3.0 V 2.2 - - - V 3.7 - - - V - 0.18 - - V IO = 3 mA; VCCO = 1.4 V - - 0.35 0.35 V IO = 4.5 mA; VCCO = 1.65 V - - 0.45 0.45 V IO = 8 mA; VCCO = 2.3 V - - 0.7 0.7 V IO = 10 mA; VCCO = 3.0 V - - 0.8 0.8 V - - 0.8 0.8 V - 0.001 0.1 0.5 A - 0.001 0.1 0.5 A IO = 2 mA; VCCO = 1.2 V [1] IO = 12 mA; VCCO = 4.5 V LOW-level output voltage VOL Typ 25 C Max 25 C Max 85 C VCCI = 0.75 V to 0.85 V VCCI = 2.3 V to 2.7 V VOH Unit IO = 2 mA; VCCO = 1.2 V [1] IO = 12 mA; VCCO = 4.5 V [1] II input leakage current VI = 0 V to 2.75 V; VCCI = 0 V to 2.75 V IOZ OFF-state output current VO = 0 V to 5.5 V; VCCO = 1.2 V to 5.5 V IOFF power-off leakage current inputs; VI = 0 V to 2.75 V; VCCI = 0 V; VCCO = 0 V to 5.5 V [1] - 0.01 0.1 0.5 A output; VO = 0 V to 5.5 V; VCCO = 0 V; VCCI = 0 V to 2.75 V; VI = 0 V to 2.75 V [1] - 0.01 0.1 0.5 A inputs; VI = 0 V or 2.75 V; VCCI = 0 V to 0.1 V; VCCO = 0 V to 5.5 V [1] - 0.02 0.1 0.5 A output; VO = 0 V or 5.5 V; VCCO = 0 V to 0.1 V; VCCI = 0 V to 2.75 V; VI = 0 V or 2.75 V [1] - 0.02 0.1 0.5 A IOFF [1] additional power-off leakage current Typical values are measured at VCCI = VCCO = 1.2 V unless otherwise specified. 74AXP1T34 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 1 — 22 December 2015 5 of 21 © Nexperia B.V. 2017. All rights reserved 74AXP1T34 Nexperia Dual supply translating buffer Table 8. Static characteristics supply current At recommended operating conditions, unless otherwise specified; voltages are referenced to GND (ground = 0 V). Symbol Parameter ICCI input supply current ICCO output supply current Tamb = 40 C to +85 C Conditions Max 85 C [1] 1 100 10 300 nA VCCI = 1.3 V to 2.75 V [2] 1 100 20 500 nA VCCI = 2.75 V; VCCO = 0 V 1 100 20 500 nA VCCI = 0 V; VCCO = 5.5 V 1 100 1 100 nA 0.001 1.0 0.01 1.2 A 0.8 1.5 1.0 1.8 A VCCI = 2.75 V; VCCO = 0 V 0.001 0.1 0.003 0.2 A VCCI = 0 V; VCCO = 3.6 V 0.2 0.6 0.3 0.8 A VCCI = 0 V; VCCO = 5.5 V 0.4 0.8 0.5 1.0 A VI = VCCI  0.5 V; VCCI = 2.5 V 2 100 14 150 A VI = 0 V or VCCI; IO = 0 A; see Table 9 [1] [3] [1] Typical values are measured at VCCI = VCCO = 1.2 V. [2] Typical values are measured at VCCI = VCCO = 2.5 V. [3] Typical values are measured at VCCI = 1.2 V and VCCO = 5.0 V. Table 9. Typ 85 C VCCI = 0.7 V to 1.3 V VCCO = 3.6 V to 5.5 V additional input supply current Max 25 C VI = 0 V or VCCI; VCCO = 1.2 V to 3.6 V ICCI Unit Typ 25 C Typical output supply current (ICCO ) VCCI VCCO 0V 1.2 V 1.5 V 1.8 V 2.5 V 3.3 V 5.0 V 0V 0 1 5 20 100 200 400 nA 0.8 V 1 10 150 200 300 500 800 nA 1.2 V 1 1 5 200 300 500 800 nA 1.5 V 1 1 5 100 300 500 800 nA 1.8 V 1 1 5 100 300 500 800 nA 2.5 V 1 1 5 100 100 500 800 nA 74AXP1T34 Product data sheet Unit All information provided in this document is subject to legal disclaimers. . Rev. 1 — 22 December 2015 6 of 21 © Nexperia B.V. 2017. All rights reserved 74AXP1T34 Nexperia Dual supply translating buffer 11. Dynamic characteristics Table 10. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 13; for wave form see Figure 6. Symbol Parameter Conditions VCCO 1.5 V  0.1 V 1.2 V Typ[1] Unit Min Typ[1] 1.8 V  0.15 V Max Min Typ[1] Max Tamb = 25 C propagation A to Y delay VCCI = 0.75 V to 0.85 V tpd [2] 22 3 16 61 3 15 57 ns VCCI = 1.1 V to 1.3 V 16.2 3.1 10.3 19.8 2.8 8.2 15.8 ns VCCI = 1.4 V to 1.6 V 15.4 2.8 9.5 18.2 2.5 7.4 13.2 ns VCCI = 1.65 V to 1.95 V 15.0 2.7 9.1 17.4 2.4 7.0 11.9 ns VCCI = 2.3 V to 2.7 V 14.7 2.5 8.7 16.9 2.2 6.6 11.1 ns 22 3 16 136 3 15 133 ns VCCI = 1.1 V to 1.3 V 16.2 3.1 10.3 19.8 2.8 8.2 15.8 ns VCCI = 1.4 V to 1.6 V 15.4 2.8 9.5 18.2 2.5 7.4 13.2 ns VCCI = 1.65 V to 1.95 V 15.0 2.7 9.1 17.4 2.4 7.0 11.9 ns 14.7 2.5 8.7 16.9 2.2 6.6 11.1 ns - 1.0 - - 1.0 - - ns Tamb = 40 C to +85 C propagation A to Y delay VCCI = 0.75 V to 0.85 V tpd [2] VCCI = 2.3 V to 2.7 V transition time tt [1] VCCI = 0.75 V to 2.7 V [3] Typical values are measured at nominal supply voltages and Tamb = +25 C. [2] tpd is the same as tPLH and tPHL. [3] tt is the same as tTHL and tTLH. 74AXP1T34 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 1 — 22 December 2015 7 of 21 © Nexperia B.V. 2017. All rights reserved 74AXP1T34 Nexperia Dual supply translating buffer Table 11. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 13; for wave form see Figure 6. Symbol Parameter Conditions VCCO 2.5 V  0.2 V Min Unit 3.3 V  0.3 V Typ[1] Max Min 5.0 V  0.5 V Typ[1] Max Min Typ[1] Max Tamb = 25 C propagation A to Y delay VCCI = 0.75 V to 0.85 V tpd [2] 2 13 57 2 13 65 2 14 77 ns VCCI = 1.1 V to 1.3 V 2.4 6.5 10.8 2.2 5.9 9.5 2.1 5.6 9.0 ns VCCI = 1.4 V to 1.6 V 2.1 5.7 9.1 2.0 5.1 8.2 1.9 4.8 7.7 ns VCCI = 1.65 V to 1.95 V 2.0 5.3 8.7 1.8 4.7 7.7 1.8 4.4 7.3 ns VCCI = 2.3 V to 2.7 V 1.9 4.9 8.1 1.7 4.3 7.1 1.6 4.0 6.6 ns Tamb = 40 C to +85 C propagation A to Y delay VCCI = 0.75 V to 0.85 V tpd [2] 2 13 152 2 13 179 2 14 210 ns VCCI = 1.1 V to 1.3 V 2.4 6.5 10.8 2.2 5.9 9.5 2.1 5.6 9.0 ns VCCI = 1.4 V to 1.6 V 2.1 5.7 9.1 2.0 5.1 8.2 1.9 4.8 7.7 ns VCCI = 1.65 V to 1.95 V 2.0 5.3 8.7 1.8 4.7 7.7 1.8 4.4 7.3 ns 1.9 4.9 8.1 1.7 4.3 7.1 1.6 4.0 6.6 ns 1.0 - - 1.0 - - 1.0 - - ns VCCI = 2.3 V to 2.7 V transition time tt [1] VCCI = 0.75 V to 2.7 V [3] Typical values are measured at nominal supply voltages and tamb = +25 C. [2] tpd is the same as tPLH and tPHL. [3] tt is the same as tTHL and tTLH. 74AXP1T34 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 1 — 22 December 2015 8 of 21 © Nexperia B.V. 2017. All rights reserved 74AXP1T34 Nexperia Dual supply translating buffer Table 12. Typical dynamic characteristics at Tamb = 25 C Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 13; for wave form see Figure 6. Symbol Parameter CPD power dissipation capacitance Conditions VCCO Unit 1.2 V 1.5 V 1.8 V 2.5 V 3.3 V 5.0 V VCCI = 0.8 V 0.4 0.4 0.4 0.4 0.4 0.4 pF VCCI = 1.2 V 0.4 0.4 0.4 0.4 0.4 0.4 pF VCCI = 1.5 V 0.5 0.5 0.5 0.5 0.5 0.5 pF VCCI = 1.8 V 0.5 0.5 0.5 0.5 0.5 0.5 pF 0.7 0.7 0.7 0.7 0.7 0.7 pF VCCI = 0.8 V 6.7 6.8 6.8 6.9 7.5 9.5 pF VCCI = 1.2 V 6.8 6.9 7.0 7.0 7.1 7.6 pF VCCI = 1.5 V 6.9 6.9 6.9 7.0 7.1 7.6 pF VCCI = 1.8 V 6.9 6.9 6.9 7.0 7.2 7.6 pF VCCI = 2.5 V 6.9 7.0 7.0 7.0 7.2 7.6 pF fi = 1 MHz; RL =  ; VI = 0 V to VCCI [1] [2] input supply VCCI = 2.5 V [3] output supply CI input capacitance VI = 0 V or VCCI; VCCI = 0 V to 2.7 V 0.6 0.6 0.6 0.6 0.6 0.6 pF CO output capacitance VO = 0 V; VCCO = 0 V 1.8 1.8 1.8 1.8 1.8 1.8 pF [1] CPD is used to determine the dynamic power dissipation (PD in W). [2] Power dissipated from input supply (VCCI) PD = CPD  VCCI2  fi  N where: CPD = power dissipation capacitance of the input supply. VCCI = input supply voltage in V; fi = input frequency in MHz; N = number of inputs switching; [3] Power dissipated from output supply (VCCO) PD = (CL + CPD)  VCCO2  fo where: CL = load capacitance in pF; CPD = power dissipation capacitance of the output supply. VCCO = output supply voltage in V; fo = output frequency in MHz; 74AXP1T34 Product data sheet All information provided in this document is subject to legal disclaimers. . Rev. 1 — 22 December 2015 9 of 21 © Nexperia B.V. 2017. All rights reserved 74AXP1T34 Nexperia Dual supply translating buffer 11.1 Waveforms and graphs 9, $LQSXW 90 90 9 W3+/ 92+ W3/+
74AXP1T34GMH 价格&库存
很抱歉,暂时无法提供与“74AXP1T34GMH”相匹配的价格&库存,您可以联系我们找货
74AXP1T34GMH
  • 1+3.282371+0.41121
  • 10+2.2795410+0.28558
  • 25+2.0239925+0.25357
  • 100+1.74765100+0.21895
  • 250+1.61548250+0.20239
  • 500+1.53581500+0.19241
  • 1000+1.470091000+0.18417
库存:1740
