74AVC2T45GN,115
74AVC2T45GN,115
    NEXPERIA(安世)
    XSON8_1.2X1MM
    电压电平 转换器 双向 1 电路 2 通道 500Mbps 8-XSON(1.2x1)
74AVC2T45GN,115 数据手册
74AVC2T45 Dual-bit, dual-supply voltage level translator/transceiver; 3-state Rev. 9 — 25 September 2018 Product data sheet 1. General description The 74AVC2T45 is a dual-bit, dual-supply transceiver that enables bidirectional level translation. It features two data input-output ports (nA and nB), a direction control input (DIR) and dual-supply pins (VCC(A) and VCC(B)). Both VCC(A) and VCC(B) can be supplied at any voltage between 0.8 V and 3.6 V making the device suitable for translating between any of the low voltage nodes (0.8 V, 1.2 V, 1.5 V, 1.8 V, 2.5 V and 3.3 V). Pins nA and DIR are referenced to VCC(A) and pins nB are referenced to VCC(B). A HIGH on DIR allows transmission from nA to nB and a LOW on DIR allows transmission from nB to nA. The device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing any damaging backflow current through the device when it is powered down. In Suspend mode when either VCC(A) or VCC(B) are at GND level, both A and B are in the high-impedance OFF-state. 2. Features and benefits • • • • • • • • • • • • Wide supply voltage range: • VCC(A): 0.8 V to 3.6 V • VCC(B): 0.8 V to 3.6 V High noise immunity Complies with JEDEC standards: • JESD8-12 (0.8 V to 1.3 V) • JESD8-11 (0.9 V to 1.65 V) • JESD8-7 (1.2 V to 1.95 V) • JESD8-5 (1.8 V to 2.7 V) • JESD8-B (2.7 V to 3.6 V) ESD protection: • HBM JESD22-A114F Class 3B exceeds 8000 V • MM JESD22-A115-A exceeds 200 V • CDM JESD22-C101C exceeds 1000 V Maximum data rates: • 500 Mbit/s (1.8 V to 3.3 V translation) • 320 Mbit/s (
74AVC2T45GN,115 价格&库存
很抱歉,暂时无法提供与“74AVC2T45GN,115”相匹配的价格&库存,您可以联系我们找货
74AVC2T45GN,115
  • 1+3.712131+0.47917
  • 10+2.5653310+0.33114
  • 25+2.2859025+0.29507
  • 100+1.97727100+0.25523
  • 250+1.83095250+0.23634
  • 500+1.74265500+0.22495
  • 1000+1.670281000+0.21560
库存:1789
74AVC2T45GN,115
  • 5000+1.501825000+0.19386
  • 10000+1.4646510000+0.18906
  • 15000+1.4460315000+0.18666
  • 25000+1.4254225000+0.18400
  • 35000+1.4133635000+0.18244
  • 50000+1.4017650000+0.18094
库存:1789
