74AVC2T45
Dual-bit, dual-supply voltage level translator/transceiver;
3-state
Rev. 9 — 25 September 2018
Product data sheet
1. General description
The 74AVC2T45 is a dual-bit, dual-supply transceiver that enables bidirectional level translation.
It features two data input-output ports (nA and nB), a direction control input (DIR) and dual-supply
pins (VCC(A) and VCC(B)). Both VCC(A) and VCC(B) can be supplied at any voltage between 0.8 V
and 3.6 V making the device suitable for translating between any of the low voltage nodes
(0.8 V, 1.2 V, 1.5 V, 1.8 V, 2.5 V and 3.3 V). Pins nA and DIR are referenced to VCC(A) and pins nB
are referenced to VCC(B). A HIGH on DIR allows transmission from nA to nB and a LOW on DIR
allows transmission from nB to nA.
The device is fully specified for partial power-down applications using IOFF. The IOFF circuitry
disables the output, preventing any damaging backflow current through the device when it is
powered down. In Suspend mode when either VCC(A) or VCC(B) are at GND level, both A and B are
in the high-impedance OFF-state.
2. Features and benefits
Wide supply voltage range:
• VCC(A): 0.8 V to 3.6 V
• VCC(B): 0.8 V to 3.6 V
High noise immunity
Complies with JEDEC standards:
• JESD8-12 (0.8 V to 1.3 V)
• JESD8-11 (0.9 V to 1.65 V)
• JESD8-7 (1.2 V to 1.95 V)
• JESD8-5 (1.8 V to 2.7 V)
• JESD8-B (2.7 V to 3.6 V)
ESD protection:
• HBM JESD22-A114F Class 3B exceeds 8000 V
• MM JESD22-A115-A exceeds 200 V
• CDM JESD22-C101C exceeds 1000 V
Maximum data rates:
• 500 Mbit/s (1.8 V to 3.3 V translation)
• 320 Mbit/s (
很抱歉,暂时无法提供与“74AVC2T45GS,115”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.323601+0.42330
- 10+2.2740010+0.28960
- 50+1.8659050+0.23760
- 100+1.74920100+0.22280
- 2500+1.725902500+0.21980
- 5000+1.201105000+0.15300
- 国内价格 香港价格
- 1+3.086661+0.38670
- 10+2.1055110+0.26378
- 25+1.8693925+0.23420
- 100+1.61069100+0.20179
- 250+1.48741250+0.18634
- 500+1.41320500+0.17705
- 1000+1.351951000+0.16937
- 2500+1.338352500+0.16767
- 国内价格
- 1+3.36093
- 10+2.30224
- 25+2.03336
- 100+1.89893
- 国内价格 香港价格
- 5000+1.248305000+0.15639
- 10000+1.2162310000+0.15237
- 15000+1.2001715000+0.15036
- 25000+1.1823725000+0.14813
- 35000+1.1719735000+0.14683
- 50000+1.1619750000+0.14557
