74LVC2T45-Q100;
74LVCH2T45-Q100
Dual supply translating transceiver; 3-state
Rev. 1 — 22 February 2013
Product data sheet
1. General description
The 74LVC2T45-Q100; 74LVCH2T45-Q100 are dual bit, dual supply translating
transceivers with 3-state outputs that enable bidirectional level translation. They feature
two 2-bits input-output ports (nA and nB), a direction control input (DIR) and dual supply
pins (VCC(A) and VCC(B)). Both VCC(A) and VCC(B) can be supplied with any voltage between
1.2 V and 5.5 V. This feature makes the device suitable for translating between any of the
low voltage nodes (1.2 V, 1.5 V, 1.8 V, 2.5 V, 3.3 V and 5.0 V). Pins nA and DIR are
referenced to VCC(A) and pins nB are referenced to VCC(B). A HIGH on DIR allows
transmission from nA to nB and a LOW on DIR allows transmission from nB to nA.
The devices are fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing any damaging backflow current through the
device when it is powered down. In suspend mode when either VCC(A) or VCC(B) are at
GND level, both A port and B port are in the high-impedance OFF-state.
Active bus hold circuitry in the 74LVCH2T45-Q100 holds unused or floating data inputs at
a valid logic level.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Wide supply voltage range:
VCC(A): 1.2 V to 5.5 V
VCC(B): 1.2 V to 5.5 V
High noise immunity
Complies with JEDEC standards:
JESD8-7 (1.2 V to 1.95 V)
JESD8-5 (1.8 V to 2.7 V)
JESD8C (2.7 V to 3.6 V)
JESD36 (4.5 V to 5.5 V)
ESD protection:
MIL-STD-883, method 3015 Class 3A exceeds 4000 V
HBM JESD22-A114F Class 3A exceeds 4000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
Nexperia
Maximum data rates:
420 Mbps (3.3 V to 5.0 V translation)
210 Mbps (translate to 3.3 V))
140 Mbps (translate to 2.5 V)
75 Mbps (translate to 1.8 V)
60 Mbps (translate to 1.5 V)
Suspend mode
Latch-up performance exceeds 100 mA per JESD 78 Class II
24 mA output drive (VCC = 3.0 V)
Inputs accept voltages up to 5.5 V
Low power consumption: 16 A maximum ICC
IOFF circuitry provides partial Power-down mode operation
Multiple package options
3. Ordering information
Table 1.
Type number
74LVC2T45DC-Q100
74LVCH2T45DC-Q100
Package
Temperature range
Name
Description
Version
40 C to +125 C
VSSOP8
plastic very thin shrink small outline package;
8 leads; body width 2.3 mm
SOT765-1
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74LVC2T45DC-Q100
V45
74LVCH2T45DC-Q100
X45
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
74LVC_LVCH2T45_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 29
Nexperia
5. Functional diagram
DIR
5
DIR
1A
2
1A
7
1B
1B
2A
3
2A
6
2B
2B
VCC(A)
VCC(B)
VCC(A)
001aag577
Fig 1.
VCC(B)
001aag578
Logic symbol
Fig 2.
Logic diagram
6. Pinning information
6.1 Pinning
/9&74
/9&+74
9&&$
9&&%
*1'
',5
DDD
Fig 3.
Pin configuration SOT765-1
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
VCC(A)
1
supply voltage A (port A and DIR)
1A
2
data input or output
2A
3
GND
4
ground (0 V)
DIR
5
direction control
2B
6
1B
7
VCC(B)
8
supply voltage B (port B)
74LVC_LVCH2T45_Q100
Product data sheet
3 of 29
Nexperia
7. Functional description
Table 4.
Function table[1]
Supply voltage
Input
Input/output[2]
VCC(A), VCC(B)
DIR
nA
nB
1.2 V to 5.5 V
L
nA = nB
input
1.2 V to 5.5 V
H
input
nB = nA
GND[3]
X
Z
Z
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
[2]
The input circuit of the data I/O is always active.
[3]
When either VCC(A) or VCC(B) is at GND level, the device goes into suspend mode.
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC(A)
supply voltage A
VCC(B)
supply voltage B
IIK
input clamping current
VI
input voltage
IOK
output clamping current
output voltage
VO
Conditions
VI < 0 V
[1]
Min
Max
Unit
0.5
+6.5
V
0.5
+6.5
V
50
mA
0.5
+6.5
V
mA
50
[1][2][3]
0.5
VCCO + 0.5
V
Suspend or 3-state mode
[1]
0.5
+6.5
V
[2]
50
mA
100
mA
VO < 0 V
Active mode
IO
output current
VO = 0 V to VCCO
ICC
supply current
ICC(A) or ICC(B)
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
250
mW
total power dissipation
Ptot
[1]
Tamb = 40 C to +125 C
[4]
The minimum input voltage ratings and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
VCCO is the supply voltage associated with the output port.
[3]
VCCO + 0.5 V should not exceed 6.5 V.
[4]
For VSSOP8 packages: above 110 C the value of Ptot derates linearly with 8.0 mW/K.
74LVC_LVCH2T45_Q100
Product data sheet
4 of 29
Nexperia
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC(A)
Conditions
Min
Max
Unit
supply voltage A
1.2
5.5
V
VCC(B)
supply voltage B
1.2
5.5
V
VI
input voltage
V
VO
output voltage
VCCO
V
V
40
+125
C
Active mode
[1]
ambient temperature
Tamb
t/V
input transition rise and fall rate
VCCI = 1.2 V
[2]
ns/V
VCCI = 1.4 V to 1.95 V
ns/V
VCCI = 2.3 V to 2.7 V
ns/V
VCCI = 3 V to 3.6 V
10
ns/V
VCCI = 4.5 V to 5.5 V
5
ns/V
[1]
[2]
VCCI is the supply voltage associated with the input port.
10. Static characteristics
Table 7.
Typical static characteristics at Tamb = 25 C
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VOH
HIGH-level output voltage
Conditions
LOW-level output voltage
Typ
Max
Unit
[1]
1.09
V
[1]
0.07
V
1
A
VI = VIH or VIL
IO = 3 mA; VCCO = 1.2 V
VOL
Min
VI = VIH or VIL
II
input leakage current
DIR input; VI = 0 V to 5.5 V;
VCCI = 1.2 V to 5.5 V
[2]
IBHL
bus hold LOW current
A or B port; VI = 0.42 V; VCCI = 1.2 V
[2]
19
A
A or B port; VI = 0.78 V; VCCI = 1.2 V
[2]
19
A
19
A
IBHH
bus hold HIGH current
IBHLO
bus hold LOW overdrive
current
A or B port; VCCI = 1.2 V
[2][3]
IBHHO
bus hold HIGH overdrive
current
[2][3]
19
A
IOZ
OFF-state output current
A or B port; VO = 0 V or VCCO;
VCCO = 1.2 V to 5.5 V
[1]
1
A
IOFF
power-off leakage current
A port; VI or VO = 0 V to 5.5 V;
VCC(A) = 0 V; VCC(B) = 1.2 V to 5.5 V
1
A
B port; VI or VO = 0 V to 5.5 V;
VCC(B) = 0 V; VCC(A) = 1.2 V to 5.5 V
1
A
CI
input capacitance
DIR input; VI = 0 V or 3.3 V;
VCC(A) = VCC(B) = 3.3 V
2.2
pF
CI/O
input/output capacitance
A and B port; suspend mode;
VO = 3.3 V or 0 V; VCC(A) = VCC(B) = 3.3 V
6.0
pF
74LVC_LVCH2T45_Q100
Product data sheet
5 of 29
Nexperia
[1]
[2]
VCCI is the supply voltage associated with the data input port.
[3]
To guarantee the node switches, an external driver must source/sink at least IBHLO/IBHHO when the input is in the range VIL to VIH.
Table 8.
Symbol Parameter
VIH
HIGH-level
input voltage
40 C to +85 C
Conditions
Min
Max
40 C to +125 C
Min
Max
Unit
[1]
data input
VCCI = 1.2 V
0.8VCCI
0.8VCCI
V
0.65VCCI
0.65VCCI
V
1.7
1.7
V
VCCI = 3.0 V to 3.6 V
2.0
2.0
V
0.7VCCI
0.7VCCI
V
VCCI = 1.2 V
0.8VCC(A)
0.8VCC(A)
V
0.65VCC(A)
0.65VCC(A)
V
DIR input
1.7
1.7
V
2.0
2.0
V
0.7VCC(A)
0.7VCC(A)
V
VIL
LOW-level
input voltage
[1]
data input
VCCI = 1.2 V
0.2VCCI
0.2VCCI
V
0.35VCCI
0.35VCCI
V
0.7
0.7
V
0.8
0.8
V
0.3VCCI
0.3VCCI
V
VCCI = 1.2 V
0.2VCC(A)
0.2VCC(A) V
0.35VCC(A)
0.35VCC(A) V
DIR input
VOH
HIGH-level
output voltage
74LVC_LVCH2T45_Q100
Product data sheet
0.7
0.7
V
0.8
0.8
V
0.3VCC(A)
VCCO 0.1
VCCO 0.1
V
IO = 6 mA; VCCO = 1.4 V
1.0
1.0
V
IO = 8 mA; VCCO = 1.65 V
1.2
1.2
V
IO = 12 mA; VCCO = 2.3 V
1.9
1.9
V
IO = 24 mA; VCCO = 3.0 V
2.4
2.4
V
IO = 32 mA; VCCO = 4.5 V
3.8
3.8
V
0.3VCC(A) V
VI = VIH
IO = 100 A;
VCCO = 1.2 V to 4.5 V
[2]
6 of 29
Nexperia
Table 8.
Static characteristics …continued
Symbol Parameter
VOL
LOW-level
output voltage
40 C to +85 C
Conditions
Min
Max
Min
Max
IO = 100 A;
0.1
0.1
V
0.3
0.3
V
0.45
0.45
V
VI = VIL
0.3
0.3
V
0.55
0.55
V
0.55
0.55
V
2
10
A
15
10
A
25
A
input leakage
current
IBHL
bus hold LOW A or B port
current
VI = 0.49 V; VCCI = 1.4 V
[1]
VI = 0.58 V; VCCI = 1.65 V
VI = 0.70 V; VCCI = 2.3 V
45
45
A
VI = 0.80 V; VCCI = 3.0 V
100
80
A
100
100
A
VI = 1.35 V; VCCI = 4.5 V
bus hold HIGH A or B port
current
VI = 0.91 V; VCCI = 1.4 V
[1]
15
10
A
VI = 1.07 V; VCCI = 1.65 V
25
A
VI = 1.60 V; VCCI = 2.3 V
45
45
A
VI = 2.00 V; VCCI = 3.0 V
100
80
A
100
100
A
125
125
A
200
200
A
VCCI = 2.7 V
300
300
A
VCCI = 3.6 V
500
500
A
900
900
A
125
125
A
200
200
A
VCCI = 2.7 V
300
300
A
VCCI = 3.6 V
500
500
A
900
900
A
2
10
A
VI = 3.15 V; VCCI = 4.5 V
IBHLO
[1][3]
overdrive
VCCI = 1.6 V
current
VCCI = 1.95 V
VCCI = 5.5 V
IBHHO
[1][3]
overdrive
VCCI = 1.6 V
current
VCCI = 1.95 V
VCCI = 5.5 V
IOZ
OFF-state
output current
74LVC_LVCH2T45_Q100
Product data sheet
Unit
[2]
II
IBHH
40 C to +125 C
[2]
7 of 29
Nexperia
Table 8.
Symbol Parameter
IOFF
power-off
leakage
current
ICC
supply current
40 C to +85 C
Conditions
40 C to +125 C
Unit
Min
Max
Min
Max
VCC(A) = 0 V;
2
10
A
VCC(B) = 0 V;
2
10
A
VCC(A), VCC(B) = 1.2 V to 5.5 V
8
8
A
VCC(A), VCC(B) = 1.65 V to 5.5 V
3
3
A
VCC(A) = 5.5 V; VCC(B) = 0 V
2
2
A
VCC(A) = 0 V; VCC(B) = 5.5 V
2
2
A
8
8
A
A port; VI = 0 V or VCCI; IO = 0 A
[1]
B port; VI = 0 V or VCCI; IO = 0 A
3
3
A
VCC(B) = 0 V; VCC(A) = 5.5 V
2
2
A
VCC(B) = 5.5 V; VCC(A) = 0 V
2
2
A
16
16
A
4
4
A
50
75
A
50
75
A
50
75
A
A plus B port (ICC(A) + ICC(B));
IO = 0 A; VI = 0 V or VCCI
ICC
additional
per input;
supply current VCC(A), VCC(B) = 3.0 V to 5.5 V
A port; A port at VCC(A) 0.6 V;
DIR at VCC(A); B port = open
[4]
DIR input; DIR at VCC(A) 0.6 V;
A port at VCC(A) or GND;
B port = open
B port; B port at VCC(B) 0.6 V;
DIR at GND; A port = open
[1]
[2]
[4]
[3]
[4]
For non-bus hold parts only (74LVC2T45-Q100).
74LVC_LVCH2T45_Q100
Product data sheet
8 of 29
Nexperia
11. Dynamic characteristics
Table 9.
Typical dynamic characteristics at VCC(A) = 1.2 V and Tamb = 25 C
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6; for waveforms see Figure 4 and Figure 5.
Symbol Parameter
tPLH
tPHL
tPHZ
tPLZ
tPZH
tPZL
[1]
Conditions
VCC(B)
Unit
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
5.0 V
LOW to HIGH
propagation delay
A to B
10.6
8.1
7.0
5.8
5.3
5.1
ns
B to A
10.6
9.5
9.0
8.5
8.3
8.2
ns
HIGH to LOW
propagation delay
A to B
10.1
7.1
6.0
5.3
5.2
5.4
ns
B to A
10.1
8.6
8.1
7.8
7.6
7.6
ns
HIGH to OFF-state
propagation delay
DIR to A
9.4
9.4
9.4
9.4
9.4
9.4
ns
DIR to B
12.0
9.4
9.0
7.8
8.4
7.9
ns
LOW to OFF-state
propagation delay
DIR to A
7.1
7.1
7.1
7.1
7.1
7.1
ns
OFF-state to HIGH
propagation delay
OFF-state to LOW
propagation delay
DIR to B
9.5
7.8
7.7
6.9
7.6
7.0
ns
DIR to A
[1]
20.1
17.3
16.7
15.4
15.9
15.2
ns
DIR to B
[1]
17.7
15.2
14.1
12.9
12.4
12.2
ns
DIR to A
[1]
22.1
18.0
17.1
15.6
16.0
15.5
ns
DIR to B
[1]
19.5
16.5
15.4
14.7
14.6
14.8
ns
tPZH and tPZL are calculated values using the formula shown in Section 14.4 “Enable times”.
Table 10. Typical dynamic characteristics at VCC(B) = 1.2 V and Tamb = 25 C
Symbol Parameter
tPLH
tPHL
tPHZ
tPLZ
tPZH
tPZL
[1]
Conditions
VCC(A)
Unit
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
5.0 V
LOW to HIGH
propagation delay
A to B
10.6
9.5
9.0
8.5
8.3
8.2
ns
B to A
10.6
8.1
7.0
5.8
5.3
5.1
ns
HIGH to LOW
propagation delay
A to B
10.1
8.6
8.1
7.8
7.6
7.6
ns
B to A
10.1
7.1
6.0
5.3
5.2
5.4
ns
HIGH to OFF-state
propagation delay
DIR to A
9.4
6.5
5.7
4.1
4.1
3.0
ns
DIR to B
12.0
6.1
5.4
4.6
4.3
4.0
ns
LOW to OFF-state
propagation delay
DIR to A
7.1
4.9
4.5
3.2
3.4
2.5
ns
DIR to B
9.5
7.3
6.6
5.9
5.7
5.6
ns
DIR to A
[1]
20.1
15.4
13.6
11.7
11.0
10.7
ns
DIR to B
[1]
17.7
14.4
13.5
11.7
11.7
10.7
ns
DIR to A
[1]
22.1
13.2
11.4
9.9
9.5
9.4
ns
DIR to B
[1]
19.5
15.1
13.8
11.9
11.7
10.6
ns
OFF-state to HIGH
propagation delay
OFF-state to LOW
propagation delay
74LVC_LVCH2T45_Q100
Product data sheet
9 of 29
Nexperia
Table 11. Typical power dissipation capacitance at VCC(A) = VCC(B) and Tamb = 25 C [1][2]
Symbol Parameter
CPD
[1]
power dissipation
capacitance
Conditions
VCC(A) and VCC(B)
Unit
1.8 V
2.5 V
3.3 V
5.0 V
A port: (direction A to B);
B port: (direction B to A)
2
3
3
4
pF
A port: (direction B to A);
B port: (direction A to B)
15
16
16
18
pF
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of the outputs.
[2]
fi = 10 MHz; VI = GND to VCC; tr = tf = 1 ns; CL = 0 pF; RL = .
Table 12. Dynamic characteristics for temperature range 40 C to +85 C
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6; for wave forms see Figure 4 and Figure 5.
Symbol Parameter
Conditions
VCC(B)
Unit
1.5 V 0.1 V 1.8 V 0.15 V 2.5 V 0.2 V 3.3 V 0.3 V 5.0 V 0.5 V
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
VCC(A) = 1.4 V to 1.6 V
tPLH
LOW to HIGH
propagation delay
A to B
2.8
21.3
2.4
17.6
2.0
13.5
1.7
11.8
1.6
10.5 ns
B to A
2.8
21.3
2.6
19.1
2.3
14.9
2.3
12.4
2.2
12.0 ns
tPHL
HIGH to LOW
propagation delay
A to B
2.6
19.3
2.2
15.3
1.8
11.8
1.7
10.9
1.7
10.8 ns
B to A
2.6
19.3
2.4
17.3
2.3
13.2
2.2
11.3
2.3
11.0
3.0
18.7 ns
ns
tPHZ
HIGH to OFF-state DIR to A
propagation delay DIR to B
3.0
18.7
3.0
18.7
3.0
18.7
3.0
18.7
3.5
24.8
3.5
23.6
3.0
11.0
3.3
11.3
2.8
10.3 ns
tPLZ
LOW to OFF-state
propagation delay
2.4
11.4
2.4
11.4
2.4
11.4
2.4
11.4
2.4
11.4
ns
9.4
ns
tPZH
tPZL
DIR to A
DIR to B
2.8
18.3
3.0
17.2
2.5
9.4
3.0
10.1
2.5
OFF-state to HIGH DIR to A
[1]
39.6
36.3
24.3
22.5
21.4 ns
[1]
32.7
29.0
24.9
23.2
21.9 ns
OFF-state to LOW
propagation delay
DIR to A
[1]
44.1
40.9
24.2
22.6
21.3 ns
DIR to B
[1]
38.0
34.0
30.5
29.6
29.5 ns
VCC(A) = 1.65 V to 1.95 V
tPLH
tPHL
tPHZ
tPLZ
LOW to HIGH
propagation delay
A to B
2.6
19.1
2.2
17.7
2.2
9.3
1.7
7.2
1.4
6.8
B to A
2.4
17.6
2.2
17.7
2.3
16.0
2.1
15.5
1.9
15.1 ns
HIGH to LOW
propagation delay
A to B
2.4
17.3
2.0
14.3
1.6
8.5
1.8
7.1
1.7
7.0
B to A
2.2
15.3
2.0
14.3
2.1
12.9
2.0
12.6
1.8
12.2 ns
2.9
17.1
2.9
17.1
2.9
17.1
2.9
17.1
2.9
17.1 ns
3.2
24.1
3.2
21.9
2.7
11.5
3.0
10.3
2.5
8.2
LOW to OFF-state
propagation delay
DIR to A
2.4
10.5
2.4
10.5
2.4
10.5
2.4
10.5
2.4
10.5 ns
DIR to B
2.5
17.6
2.6
16.0
2.2
9.2
2.7
8.4
2.4
7.1
74LVC_LVCH2T45_Q100
Product data sheet
ns
ns
ns
ns
10 of 29
Nexperia
Table 12. Dynamic characteristics for temperature range 40 C to +85 C …continued
Symbol Parameter
Conditions
VCC(B)
Unit
tPZH
tPZL
Min
Max
Min
Max
Min
Max
Min
Max
Min
[1]
Max
35.2
33.7
25.2
23.9
22.2 ns
[1]
29.6
28.2
19.8
17.7
17.3 ns
OFF-state to LOW
propagation delay
DIR to A
[1]
39.4
36.2
24.4
22.9
20.4 ns
DIR to B
[1]
34.4
31.4
25.6
24.2
24.1 ns
VCC(A) = 2.3 V to 2.7 V
LOW to HIGH
propagation delay
A to B
2.3
17.9
2.3
16.0
1.5
8.5
1.3
6.2
1.1
4.8
ns
B to A
2.0
13.5
2.2
9.3
1.5
8.5
1.4
8.0
1.0
7.5
ns
tPHL
HIGH to LOW
propagation delay
A to B
2.3
15.8
2.1
12.9
1.4
7.5
1.3
5.4
0.9
4.6
ns
tPHZ
tPLH
B to A
11.8
1.9
8.5
1.4
7.5
1.3
7.0
0.9
6.2
ns
8.1
2.1
8.1
2.1
8.1
2.1
8.1
2.1
8.1
ns
3.0
22.5
3.0
21.4
2.5
11.0
2.8
9.3
2.3
6.9
ns
1.7
5.8
1.7
5.8
1.7
5.8
1.7
5.8
1.7
5.8
ns
5.8
ns
tPLZ
LOW to OFF-state
propagation delay
2.3
14.6
2.5
13.2
2.0
9.0
2.5
8.4
1.8
tPZH
[1]
28.1
22.5
17.5
16.4
13.3 ns
[1]
23.7
21.8
14.3
12.0
10.6 ns
OFF-state to LOW
propagation delay
DIR to A
[1]
34.3
29.9
18.5
16.3
13.1 ns
DIR to B
[1]
23.9
21.0
15.6
13.5
12.7 ns
tPZL
DIR to A
1.8
2.1
DIR to B
VCC(A) = 3.0 V to 3.6 V
tPLH
tPHL
tPHZ
tPLZ
tPZH
tPZL
LOW to HIGH
propagation delay
A to B
2.3
17.1
2.1
15.5
1.4
8.0
0.8
5.6
0.7
4.4
ns
B to A
1.7
11.8
1.7
7.2
1.3
6.2
0.7
5.6
0.6
5.4
ns
HIGH to LOW
propagation delay
A to B
2.2
15.6
2.0
12.6
1.3
7.0
0.8
5.0
0.7
4.0
ns
B to A
1.7
10.9
1.8
7.1
1.3
5.4
0.8
5.0
0.7
4.5
ns
2.3
7.3
2.3
7.3
2.3
7.3
2.3
7.3
2.7
7.3
ns
2.9
18.0
2.9
16.5
2.3
10.1
2.7
8.6
2.2
6.3
ns
LOW to OFF-state
propagation delay
DIR to A
2.0
5.6
2.0
5.6
2.0
5.6
2.0
5.6
2.0
5.6
ns
DIR to B
2.3
13.6
2.4
12.5
1.9
7.8
2.3
7.1
1.7
4.9
ns
[1]
25.4
19.7
14.0
12.7
10.3 ns
[1]
22.7
21.1
13.6
11.2
10.0 ns
OFF-state to LOW
propagation delay
DIR to A
[1]
28.9
23.6
15.5
13.6
10.8 ns
DIR to B
[1]
22.9
19.9
14.3
12.3
11.3
ns
15.1
1.0
7.5
0.7
5.4
0.5
3.9
ns
VCC(A) = 4.5 V to 5.5 V
tPLH
LOW to HIGH
propagation delay
A to B
2.2
16.6
1.9
B to A
1.6
10.5
1.4
6.8
1.0
4.8
0.7
4.4
0.5
3.9
ns
tPHL
HIGH to LOW
propagation delay
A to B
2.3
15.3
1.8
12.2
1.0
6.2
0.7
4.5
0.5
3.5
ns
B to A
1.7
10.8
1.7
7.0
0.9
4.6
0.7
4.0
0.5
3.5
ns
1.7
5.4
1.7
5.4
1.7
5.4
1.7
5.4
1.7
5.4
ns
2.9
17.3
2.9
16.1
2.3
9.7
2.7
8.0
2.5
5.7
ns
tPHZ
74LVC_LVCH2T45_Q100
Product data sheet
11 of 29
Nexperia
Symbol Parameter
Conditions
VCC(B)
Unit
Min
tPLZ
tPZH
tPZL
[1]
LOW to OFF-state
propagation delay
Max
Min
Max
Min
Max
Min
Max
Min
Max
DIR to A
1.4
3.7
1.4
3.7
1.3
3.7
1.0
3.7
0.9
3.7
ns
DIR to B
2.3
13.1
2.4
12.1
1.9
7.4
2.3
7.0
1.8
4.5
ns
[1]
23.6
18.9
12.2
11.4
8.4
ns
[1]
20.3
18.8
11.2
9.1
7.6
ns
OFF-state to LOW
propagation delay
DIR to A
[1]
28.1
23.1
14.3
12.0
9.2
ns
DIR to B
[1]
20.7
17.6
11.6
9.9
8.9
ns
Table 13. Dynamic characteristics for temperature range 40 C to +125 C
Symbol Parameter
Conditions
VCC(B)
Unit
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
tPLH
tPHL
tPHZ
tPLZ
tPZH
tPZL
LOW to HIGH
propagation delay
A to B
2.5
23.5
2.1
19.4
1.8
14.9
1.5
13.0
1.4
11.6
B to A
2.5
23.5
2.3
21.1
2.0
16.4
2.0
13.7
1.9
13.2 ns
HIGH to LOW
propagation delay
A to B
2.3
21.3
1.9
16.9
1.6
13.0
1.5
12.0
1.5
11.9
B to A
2.3
21.3
2.1
19.1
2.0
14.6
1.9
12.5
2.0
12.1 ns
2.7
20.6
2.7
20.6
2.7
20.6
2.7
20.6
2.7
20.6 ns
3.1
27.3
3.1
26.0
2.7
12.1
2.9
12.5
2.5
11.4
DIR to A
2.1
12.6
2.1
12.6
2.1
12.6
2.1
12.6
2.1
12.6 ns
DIR to B
2.5
20.2
2.7
19.0
2.2
10.4
2.7
11.2
2.2
10.4 ns
[1]
43.7
40.1
26.8
24.9
23.6 ns
[1]
36.1
32.0
27.5
25.6
24.2 ns
OFF-state to LOW
propagation delay
DIR to A
[1]
48.6
45.1
26.7
25.0
23.5 ns
DIR to B
[1]
41.9
37.5
33.6
32.6
32.5 ns
19.5
1.9
10.3
1.5
8.0
1.2
7.5
LOW to OFF-state
propagation delay
ns
ns
ns
tPLH
LOW to HIGH
propagation delay
A to B
2.3
21.1
1.9
B to A
2.1
19.4
1.9
19.5
2.0
17.6
1.8
17.1
1.7
16.7 ns
tPHL
HIGH to LOW
propagation delay
A to B
2.1
19.1
1.8
15.8
1.4
9.4
1.6
7.9
1.5
7.7
B to A
1.9
16.9
1.8
15.8
1.8
14.2
1.8
13.9
1.6
13.5 ns
2.6
18.9
2.6
18.9
2.6
18.9
2.6
18.9
2.6
18.9 ns
2.8
26.6
2.8
24.1
2.4
12.7
2.7
11.4
2.2
9.1
ns
2.1
11.6
2.1
11.6
2.1
11.6
2.1
11.6
2.1
11.6
ns
7.9
ns
tPHZ
tPLZ
LOW to OFF-state
propagation delay
tPZH
DIR to A
DIR to B
74LVC_LVCH2T45_Q100
Product data sheet
ns
ns
2.2
19.4
2.3
17.6
1.9
10.2
2.4
9.3
2.1
[1]
38.8
37.1
27.8
26.4
24.6 ns
[1]
32.7
31.1
21.9
19.6
19.1 ns
12 of 29
Nexperia
Table 13. Dynamic characteristics for temperature range 40 C to +125 C …continued
Symbol Parameter
Conditions
VCC(B)
Unit
tPZL
OFF-state to LOW
propagation delay
Min
Max
Min
Max
Min
Max
Min
Max
Min
DIR to A
[1]
Max
43.5
39.9
26.9
25.3
22.6 ns
DIR to B
[1]
38.0
34.7
28.3
26.8
26.6 ns
tPLH
LOW to HIGH
propagation delay
A to B
2.0
19.7
2.0
17.6
1.3
9.4
1.1
6.9
0.9
5.3
ns
B to A
1.8
14.9
1.9
10.3
1.3
9.4
1.2
8.8
0.9
8.3
ns
tPHL
HIGH to LOW
propagation delay
A to B
2.0
17.4
1.8
14.2
1.2
8.3
1.1
6.0
0.8
5.1
ns
B to A
1.6
13.0
1.7
9.4
1.2
8.3
1.1
7.7
0.8
6.9
ns
1.8
9.0
1.8
9.0
1.8
9.0
1.8
9.0
1.8
9.0
ns
2.7
24.8
2.7
23.6
2.2
12.1
2.5
10.3
2.0
7.6
ns
1.5
6.4
1.5
6.4
1.5
6.4
1.5
6.4
1.5
6.4
ns
6.4
ns
tPHZ
tPLZ
LOW to OFF-state
propagation delay
tPZH
tPZL
DIR to A
DIR to B
2.0
16.1
2.2
14.6
1.8
9.9
2.2
9.3
1.6
[1]
31.0
24.9
19.3
18.1
[1]
26.1
24.0
15.8
13.3
11.7
OFF-state to LOW
propagation delay
DIR to A
[1]
37.8
33.0
20.4
18.0
14.5 ns
DIR to B
[1]
26.4
23.2
17.3
15.0
14.1 ns
14.7 ns
ns
tPLH
tPHL
tPHZ
tPLZ
tPZH
tPZL
LOW to HIGH
propagation delay
A to B
2.0
18.9
1.8
17.1
1.2
8.8
0.7
6.2
0.6
4.9
ns
B to A
1.5
13.0
1.5
8.0
1.1
6.9
0.6
6.2
0.5
6.0
ns
HIGH to LOW
propagation delay
A to B
1.9
17.2
1.8
13.9
1.1
7.7
0.7
5.5
0.6
4.4
ns
B to A
1.5
12.0
1.6
7.9
1.1
6.0
0.7
5.5
0.6
5.0
ns
LOW to OFF-state
propagation delay
DIR to A
DIR to B
2.0
8.1
2.0
8.1
2.0
8.1
2.0
8.1
2.4
8.1
ns
2.6
19.8
2.6
18.2
2.0
11.2
2.4
9.5
1.9
7.0
ns
1.8
6.2
1.8
6.2
1.8
6.2
1.8
6.2
1.8
6.2
ns
2.0
15.0
2.1
13.8
1.7
8.6
2.0
7.9
1.5
5.4
ns
[1]
28.0
21.8
15.5
14.1
11.4
ns
[1]
25.1
23.3
15.0
12.4
11.1
ns
OFF-state to LOW
propagation delay
DIR to A
[1]
31.8
26.1
17.2
15.0
12.0 ns
DIR to B
[1]
25.3
22.0
15.8
13.6
12.5 ns
LOW to HIGH
propagation delay
A to B
1.9
18.3
1.7
16.7
0.9
8.3
0.6
6.0
0.4
4.3
ns
B to A
1.4
11.6
1.2
7.5
0.9
5.3
0.6
4.9
0.4
4.3
ns
tPHL
HIGH to LOW
propagation delay
A to B
2.0
16.9
1.6
13.5
0.9
6.9
0.6
5.0
0.4
3.9
ns
tPHZ
tPLH
tPLZ
LOW to OFF-state
propagation delay
74LVC_LVCH2T45_Q100
Product data sheet
B to A
1.5
11.9
1.5
7.7
0.8
5.1
0.6
4.4
0.4
3.9
ns
1.5
6.0
1.5
6.0
1.5
6.0
1.5
6.0
1.5
6.0
ns
2.6
19.1
2.6
17.8
2.0
10.7
2.4
8.8
2.2
6.3
ns
DIR to A
1.2
4.1
1.2
4.1
1.1
4.1
0.9
4.1
0.8
4.1
ns
DIR to B
2.0
14.5
2.1
13.4
1.7
8.2
2.0
7.7
1.6
5.0
ns
13 of 29
Nexperia
Symbol Parameter
Conditions
VCC(B)
Unit
tPZH
tPZL
[1]
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
[1]
26.1
20.9
13.5
12.6
9.3
ns
[1]
22.4
20.8
12.4
10.1
8.4
ns
OFF-state to LOW
propagation delay
DIR to A
[1]
31.0
25.5
15.8
13.2
10.2 ns
DIR to B
[1]
22.9
19.5
12.9
11.0
9.9
ns
12. Waveforms
VI
VM
nA, nB input
GND
tPLH
tPHL
VOH
VM
nB, nA output
001aaj644
VOL
Measurement points are given in Table 14.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig 4.
The data input (A, B) to output (B, A) propagation delay times
VI
DIR input
VM
GND
t PLZ
output
LOW-to-OFF
OFF-to-LOW
t PZL
VCCO
VM
VX
VOL
t PHZ
VOH
t PZH
VY
output
HIGH-to-OFF
OFF-to-HIGH
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
001aae968
Fig 5.
Enable and disable times
74LVC_LVCH2T45_Q100
Product data sheet
14 of 29
Nexperia
Table 14.
Measurement points
Supply voltage
Input[1]
Output[2]
VCC(A), VCC(B)
VM
VM
VX
VY
1.2 V to 1.6 V
0.5VCCI
0.5VCCO
VOL + 0.1 V
VOH 0.1 V
1.65 V to 2.7 V
0.5VCCI
0.5VCCO
VOL + 0.15 V
VOH 0.15 V
3.0 V to 5.5 V
0.5VCCI
0.5VCCO
VOL + 0.3 V
VOH 0.3 V
[1]
[2]
tW
VI
90 %
negative
pulse
VM
VM
10 %
0V
tf
tr
tr
tf
VI
90 %
positive
pulse
VM
VM
10 %
0V
tW
VEXT
VCC
VI
RL
VO
G
DUT
RT
RL
CL
001aae331
Test data is given in Table 15.
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance.
VEXT = External voltage for measuring switching times.
Fig 6.
Table 15.
Test circuit for measuring switching times
Test data
Supply voltage
Input
VCC(A), VCC(B)
VI[1]
t/V[2]
CL
RL
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ[3]
1.2 V to 5.5 V
VCCI
1.0 ns/V
15 pF
2 k
open
GND
2VCCO
[1]
Load
VEXT
[2]
dV/dt 1.0 V/ns.
[3]
74LVC_LVCH2T45_Q100
Product data sheet
15 of 29
Nexperia
13. Typical propagation delay characteristics
001aai907
14
tPHL
(ns)
12
001aai908
14
tPLH
(ns)
12
(1)
(1)
10
10
(2)
8
(2)
8
(3)
6
(3)
(4)
(5)
(6)
6
(4)
(5)
(6)
4
4
2
2
10
15
35
30
CL (pF)
a. HIGH to LOW propagation delay (A to B)
001aai909
14
tPHL
(ns)
12
10
15
35
30
CL (pF)
b. LOW to HIGH propagation delay (A to B)
001aai910
14
tPLH
(ns)
12
(1)
(1)
10
(2)
(3)
10
8
(4)
(5)
(6)
8
(2)
(3)
(4)
(5)
6
6
4
4
2
2
10
15
35
30
CL (pF)
c. HIGH to LOW propagation delay (B to A)
10
15
35
30
CL (pF)
d. LOW to HIGH propagation delay (B to A)
(1) VCC(B) = 1.2 V.
(2) VCC(B) = 1.5 V.
(3) VCC(B) = 1.8 V.
(4) VCC(B) = 2.5 V.
(5) VCC(B) = 3.3 V.
(6) VCC(B) = 5.0 V.
Fig 7.
Typical propagation delay versus load capacitance; Tamb = 25 C; VCC(A) = 1.2 V
74LVC_LVCH2T45_Q100
Product data sheet
16 of 29
Nexperia
001aai911
14
tPHL
(ns)
12
001aai912
14
tPLH
(ns)
12
(1)
10
10
(1)
8
8
(2)
(2)
(3)
6
6
(3)
(4)
(5)
(6)
(4)
4
4
(5)
2
2
(6)
10
15
35
30
CL (pF)
001aai913
14
tPHL
(ns)
12
10
10
15
35
30
CL (pF)
001aai914
14
tPLH
(ns)
12
10
(1)
8
(1)
8
6
(2)
(3)
(4)
6
(2)
(3)
(4)
(5)
(5)
(6)
(6)
4
4
2
2
10
15
35
30
CL (pF)
10
15
35
30
CL (pF)
(1) VCC(B) = 1.2 V.
(2) VCC(B) = 1.5 V.
(3) VCC(B) = 1.8 V.
(4) VCC(B) = 2.5 V.
(5) VCC(B) = 3.3 V.
(6) VCC(B) = 5.0 V.
Fig 8.
Typical propagation delay versus load capacitance; Tamb = 25 C; VCC(A) = 1.5 V
74LVC_LVCH2T45_Q100
Product data sheet
17 of 29
Nexperia
001aai915
14
tPHL
(ns)
12
001aai916
14
tPLH
(ns)
12
(1)
10
10
(1)
8
8
(2)
(2)
6
6
(3)
4
(4)
(5)
(6)
(3)
(4)
4
(5)
(6)
2
2
10
15
35
30
CL (pF)
001aai917
14
tPHL
(ns)
12
10
10
15
35
30
CL (pF)
001aai918
14
tPLH
(ns)
12
10
8
8
(1)
(1)
6
4
(2)
(3)
(4)
(5)
(6)
6
(2)
(3)
(4)
(5)
(6)
4
2
2
10
15
35
30
CL (pF)
10
15
35
30
CL (pF)
(1) VCC(B) = 1.2 V.
(2) VCC(B) = 1.5 V.
(3) VCC(B) = 1.8 V.
(4) VCC(B) = 2.5 V.
(5) VCC(B) = 3.3 V.
(6) VCC(B) = 5.0 V.
Fig 9.
Typical propagation delay versus load capacitance; Tamb = 25 C; VCC(A) = 1.8 V
74LVC_LVCH2T45_Q100
Product data sheet
18 of 29
Nexperia
001aai919
14
tPHL
(ns)
12
10
001aai920
14
tPLH
(ns)
12
(1)
10
(1)
8
8
(2)
(2)
6
6
(3)
(3)
4
(4)
(5)
(6)
4
(4)
(5)
(6)
2
2
10
15
35
30
CL (pF)
001aai921
14
tPHL
(ns)
12
8
(2)
(3)
(4)
(5)
(6)
35
30
CL (pF)
001aai922
(1)
6
(1)
2
15
14
tPLH
(ns)
12
10
4
10
10
6
5
(2)
(3)
(4)
(5)
(6)
4
2
10
15
35
30
CL (pF)
10
15
35
30
CL (pF)
(1) VCC(B) = 1.2 V.
(2) VCC(B) = 1.5 V.
(3) VCC(B) = 1.8 V.
(4) VCC(B) = 2.5 V.
(5) VCC(B) = 3.3 V.
(6) VCC(B) = 5.0 V.
Fig 10. Typical propagation delay versus load capacitance; Tamb = 25 C; VCC(A) = 2.5 V
74LVC_LVCH2T45_Q100
Product data sheet
19 of 29
Nexperia
001aai923
14
tPHL
(ns)
12
10
001aai924
14
tPLH
(ns)
12
10
(1)
(1)
8
8
(2)
(2)
6
6
(3)
(3)
4
4
(4)
(5)
(6)
2
(4)
(5)
(6)
2
10
15
35
30
CL (pF)
001aai925
14
tPHL
(ns)
12
8
(2)
(3)
(4)
(5)
(6)
4
2
35
30
CL (pF)
001aai926
14
tPLH
(ns)
12
10
(1)
10
10
6
5
6
(1)
4
(2)
(3)
2
(4)
(5)
(6)
10
15
35
30
CL (pF)
10
15
35
30
CL (pF)
(1) VCC(B) = 1.2 V.
(2) VCC(B) = 1.5 V.
(3) VCC(B) = 1.8 V.
(4) VCC(B) = 2.5 V.
(5) VCC(B) = 3.3 V.
(6) VCC(B) = 5.0 V.
Fig 11. Typical propagation delay versus load capacitance; Tamb = 25 C; VCC(A) = 3.3 V
74LVC_LVCH2T45_Q100
Product data sheet
20 of 29
Nexperia
001aai927
14
tPHL
(ns)
12
10
001aai928
14
tPLH
(ns)
12
10
(1)
(1)
8
8
(2)
6
(2)
6
(3)
(3)
4
4
(4)
(5)
(6)
2
(4)
(5)
(6)
2
10
15
35
30
CL (pF)
001aai929
14
tPHL
(ns)
12
10
15
35
30
CL (pF)
001aai930
14
tPLH
(ns)
12
10
10
8
8
6
(1)
6
4
(2)
(3)
4
(2)
(3)
2
(4)
(5)
(6)
2
(4)
(5)
(6)
10
15
35
30
CL (pF)
10
15
35
30
CL (pF)
(1) VCC(B) = 1.2 V.
(2) VCC(B) = 1.5 V.
(3) VCC(B) = 1.8 V.
(4) VCC(B) = 2.5 V.
(5) VCC(B) = 3.3 V.
(6) VCC(B) = 5.0 V.
Fig 12. Typical propagation delay versus load capacitance; Tamb = 25 C; VCC(A) = 5 V
74LVC_LVCH2T45_Q100
Product data sheet
21 of 29
Nexperia
14. Application information
14.1 Unidirectional logic level-shifting application
The circuit given in Figure 13 is an example of the 74LVC2T45-Q100; 74LVCH2T45-Q100
being used in a unidirectional logic level-shifting application.
9&&
9&&
9&&
9&&$
9&&%
9&&
/9&74
/9&+74
9&&
*1'
',5
V\VWHP
9&&
V\VWHP
DDD
Fig 13. Unidirectional logic level-shifting application
Table 16.
Description of unidirectional logic level-shifting application
Pin
Name
Function
Description
1
VCC(A)
VCC1
supply voltage of system-1 (1.2 V to 5.5 V)
2
1A
OUT
output level depends on VCC1 voltage
3
2A
OUT
4
GND
GND
device GND
5
DIR
DIR
the GND (LOW level) determines B port to A port direction
6
2B
IN
input threshold value depends on VCC2 voltage
7
1B
IN
8
VCC(B)
VCC2
supply voltage of system-2 (1.2 V to 5.5 V)
14.2 Bidirectional logic level-shifting application
Figure 14 shows the 74LVC2T45-Q100; 74LVCH2T45-Q100 being used in a bidirectional
logic level-shifting application. Since the device does not have an output enable pin, the
system designer should take precautions to avoid bus contention between system-1 and
system-2 when changing directions.
74LVC_LVCH2T45_Q100
Product data sheet
22 of 29
Nexperia
9&&
9&&
,2
9&&
9&&$
38//83'2:1
*1'
9&&%
9&&
38//83'2:1
,2
/9&74
/9&+74
',5
',5&75/
',5&75/
V\VWHP
V\VWHP
DDD
Pull-up or pull-down only needed for 74LVC2T45-Q100.
Fig 14. Bidirectional logic level-shifting application
Table 17 provides a sequence that illustrates data transmission from system-1 to
system-2 and then from system-2 to system-1.
Description of bidirectional logic level-shifting application[1]
Table 17.
State
DIR CTRL
I/O-1
I/O-2
Description
1
H
output
input
system-1 data to system-2
2
H
Z
Z
system-2 is getting ready to send data to system-1. I/O-1 and I/O-2
are disabled. The bus-line state depends on bus hold
3
L
Z
Z
DIR bit is set LOW. I/O-1 and I/O-2 are still disabled. The bus-line
4
L
input
output
system-2 data to system-1
[1]
14.3 Power-up considerations
The device is designed such that no special power-up sequence is required other than
GND being applied first.
Table 18.
Typical total supply current (ICC(A) + ICC(B))
VCC(A)
VCC(B)
Unit
0V
1.8 V
2.5 V
3.3 V
5.0 V
0V
很抱歉,暂时无法提供与“74LVCH2T45DC-Q100H”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.99600
- 10+3.26160
- 30+2.89440
- 100+2.52720
- 500+1.73880
- 1000+1.63080
