74LVC2T45-Q100;
74LVCH2T45-Q100
Dual supply translating transceiver; 3-state
Rev. 3 — 28 January 2019
Product data sheet
1. General description
The 74LVC2T45-Q100; 74LVCH2T45-Q100 are dual bit, dual supply translating transceivers with
3-state outputs that enable bidirectional level translation. They feature two 2-bits input-output ports
(nA and nB), a direction control input (DIR) and dual supply pins (VCC(A) and VCC(B)). Both VCC(A)
and VCC(B) can be supplied at any voltage between 1.2 V and 5.5 V making the device suitable for
translating between any of the low voltage nodes (1.2 V, 1.5 V, 1.8 V, 2.5 V, 3.3 V and 5.0 V). Pins
nA and DIR are referenced to VCC(A) and pins nB are referenced to VCC(B). A HIGH on DIR allows
transmission from nA to nB and a LOW on DIR allows transmission from nB to nA.
The devices are fully specified for partial power-down applications using IOFF. The IOFF circuitry
disables the output, preventing any damaging backflow current through the device when it is
powered down. In suspend mode when either VCC(A) or VCC(B) are at GND level, both A port and
B port are in the high-impedance OFF-state.
Active bus hold circuitry in the 74LVCH2T45-Q100 holds unused or floating data inputs at a valid
logic level.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
Wide supply voltage range:
• VCC(A): 1.2 V to 5.5 V
• VCC(B): 1.2 V to 5.5 V
High noise immunity
Complies with JEDEC standards:
• JESD8-7 (1.2 V to 1.95 V)
• JESD8-5 (1.8 V to 2.7 V)
• JESD8C (2.7 V to 3.6 V)
• JESD36 (4.5 V to 5.5 V)
ESD protection:
• MIL-STD-883, method 3015 Class 3A exceeds 4000 V
• HBM JESD22-A114F Class 3A exceeds 4000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω)
Maximum data rates:
• 420 Mbps (3.3 V to 5.0 V translation)
• 210 Mbps (translate to 3.3 V))
• 140 Mbps (translate to 2.5 V)
• 75 Mbps (translate to 1.8 V)
• 60 Mbps (translate to 1.5 V)
Suspend mode
Latch-up performance exceeds 100 mA per JESD 78 Class II
±24 mA output drive (VCC = 3.0 V)
Inputs accept voltages up to 5.5 V
Low power consumption: 16 μA maximum ICC
Nexperia
IOFF circuitry provides partial Power-down mode operation
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range Name
Description
Version
-40 °C to +125 °C
VSSOP8
plastic very thin shrink small outline package;
8 leads; body width 2.3 mm
SOT765-1
74LVC2T45GT-Q100
-40 °C to +125 °C
XSON8
plastic extremely thin small outline package;
no leads; 8 terminals; body 1 × 1.95 × 0.5 mm
SOT833-1
74LVC2T45GS-Q100
-40 °C to +125 °C
XSON8
extremely thin small outline package; no leads;
8 terminals; body 1.35 × 1.0 × 0.35 mm
SOT1203
74LVC2T45DC-Q100
74LVCH2T45DC-Q100
4. Marking
Table 2. Marking
Type number
Marking code [1]
74LVC2T45DC-Q100
V45
74LVCH2T45DC-Q100
X45
74LVC2T45GT-Q100
V45
74LVC2T45GS-Q100
V5
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
DIR
1A
5
DIR
2
1A
7
2A
1B
1B
3
2A
6
VCC(A)
2B
2B
VCC(B)
VCC(A)
001aag577
Fig. 1.
Logic symbol
74LVC_LVCH2T45_Q100
Product data sheet
VCC(B)
001aag578
Fig. 2.
Logic diagram
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2019. All rights reserved
2 / 30
Nexperia
6. Pinning information
6.1. Pinning
74LVC2T45
74LVCH2T45
VCC(A)
1
8
VCC(B)
1A
2
7
1B
2A
3
6
2B
GND
4
5
DIR
74LVC2T45
74LVCH2T45
VCC(A)
1
8
VCC(B)
1A
2
7
1B
2A
3
6
2B
GND
4
5
DIR
001aai905
Transparent top view
001aai904
Fig. 3.
Pin configuration SOT765-1 (VSSOP8)
Fig. 4.
Pin configuration SOT833-1 and SOT1203
(XSON8)
6.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
VCC(A)
1
supply voltage A (port A and DIR)
1A
2
data input or output
2A
3
GND
4
ground (0 V)
DIR
5
direction control
2B
6
1B
7
VCC(B)
8
supply voltage B (port B)
7. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
Supply voltage
Input
Input/output [1]
VCC(A), VCC(B)
DIR
nA
nB
1.2 V to 5.5 V
L
nA = nB
input
1.2 V to 5.5 V
H
input
nB = nA
GND [2]
X
Z
Z
[1]
[2]
The input circuit of the data I/O is always active.
When either VCC(A) or VCC(B) is at GND level, the device goes into suspend mode.
74LVC_LVCH2T45_Q100
Product data sheet
3 / 30
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
Unit
VCC(A)
supply voltage A
-0.5
+6.5
V
VCC(B)
supply voltage B
-0.5
+6.5
V
IIK
input clamping current
VI
input voltage
IOK
output clamping current
VO < 0 V
VO
output voltage
Active mode
VI < 0 V
[1]
-50
-0.5
+6.5
-50
[1][2][3]
-0.5
Suspend or 3-state mode
[1]
-0.5
[2]
mA
V
mA
VCCO + 0.5 V
+6.5
V
±50
mA
100
mA
IO
output current
VO = 0 V to VCCO
ICC
supply current
ICC(A) or ICC(B)
IGND
ground current
-100
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
250
mW
[1]
[2]
[3]
[4]
Tamb = -40 °C to +125 °C
[4]
The minimum input voltage ratings and output voltage ratings may be exceeded if the input and output current ratings are observed.
VCCO is the supply voltage associated with the output port.
VCCO + 0.5 V should not exceed 6.5 V.
For VSSOP8 packages: above 110 °C the value of Ptot derates linearly with 8.0 mW/K.
For XSON8 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 6. Recommended operating conditions
Symbol Parameter
Conditions
Min
Max
Unit
VCC(A)
supply voltage A
1.2
5.5
V
VCC(B)
supply voltage B
1.2
5.5
V
VI
input voltage
V
VO
output voltage
VCCO
V
V
-40
+125
°C
ns/V
VCCI = 1.4 V to 1.95 V
ns/V
VCCI = 2.3 V to 2.7 V
ns/V
VCCI = 3 V to 3.6 V
10
ns/V
VCCI = 4.5 V to 5.5 V
5
ns/V
Active mode
[1]
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
[1]
[2]
VCCI = 1.2 V
[2]
VCCI is the supply voltage associated with the input port.
74LVC_LVCH2T45_Q100
Product data sheet
4 / 30
Nexperia
10. Static characteristics
Table 7. Typical static characteristics at Tamb = 25 °C
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ
Max
VOH
HIGH-level output voltage
VI = VIH or VIL; IO = -3 mA; VCCO = 1.2 V
VOL
LOW-level output voltage
II
Unit
[1]
1.09
V
VI = VIH or VIL; IO = 3 mA; VCCO = 1.2 V
[1]
0.07
V
input leakage current
DIR input; VI = 0 V to 5.5 V;
VCCI = 1.2 V to 5.5 V
[2]
±1
μA
IBHL
bus hold LOW current
A or B port; VI = 0.42 V; VCCI = 1.2 V
[2]
19
μA
IBHH
bus hold HIGH current
A or B port; VI = 0.78 V; VCCI = 1.2 V
[2]
-19
μA
IBHLO
bus hold LOW overdrive current A or B port; VCCI = 1.2 V
[2][3]
19
μA
IBHHO
bus hold HIGH overdrive current A or B port; VCCI = 1.2 V
[2][3]
-19
μA
IOZ
OFF-state output current
A or B port; VO = 0 V or VCCO;
VCCO = 1.2 V to 5.5 V
[1]
±1
μA
IOFF
power-off leakage current
A port; VI or VO = 0 V to 5.5 V;
VCC(A) = 0 V; VCC(B) = 1.2 V to 5.5 V
±1
μA
B port; VI or VO = 0 V to 5.5 V;
VCC(B) = 0 V; VCC(A) = 1.2 V to 5.5 V
±1
μA
CI
input capacitance
DIR input; VI = 0 V or 3.3 V;
VCC(A) = VCC(B) = 3.3 V
2.2
pF
CI/O
input/output capacitance
A and B port; suspend mode;
VO = 3.3 V or 0 V; VCC(A) = VCC(B) = 3.3 V
6.0
pF
[1]
[2]
[3]
VCCI is the supply voltage associated with the data input port.
To guarantee the node switches, an external driver must source/sink at least IBHLO/IBHHO when the input is in the range VIL to VIH.
Table 8. Static characteristics
Symbol Parameter
Conditions
VIH
data input
HIGH-level
input voltage
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Max
Min
Max
VCCI = 1.2 V
0.8VCCI
0.8VCCI
V
0.65VCCI
0.65VCCI
V
1.7
1.7
V
VCCI = 3.0 V to 3.6 V
2.0
2.0
V
0.7VCCI
0.7VCCI
V
VCCI = 1.2 V
0.8VCC(A)
0.8VCC(A)
V
0.65VCC(A)
0.65VCC(A)
V
1.7
1.7
V
2.0
2.0
V
0.7VCC(A)
0.7VCC(A)
V
[1]
DIR input
74LVC_LVCH2T45_Q100
Product data sheet
5 / 30
Nexperia
Symbol Parameter
Conditions
-40 °C to +85 °C
Min
VIL
LOW-level input data input
voltage
VCCI = 1.2 V
-40 °C to +125 °C
Max
Min
Unit
Max
[1]
0.2VCCI
0.2VCCI
V
0.35VCCI
0.35VCCI
V
0.7
0.7
V
0.8
0.8
V
0.3VCCI
0.3VCCI
V
VCCI = 1.2 V
0.2VCC(A)
0.2VCC(A) V
0.35VCC(A)
0.35VCC(A) V
0.7
0.7
V
0.8
0.8
V
0.3VCC(A)
VCCO - 0.1
V
DIR input
VOH
VOL
HIGH-level
output voltage
LOW-level
output voltage
IO = -100 μA;
VCCO = 1.2 V to 4.5 V
[2] VCCO - 0.1
IO = -6 mA; VCCO = 1.4 V
1.0
1.0
V
IO = -8 mA; VCCO = 1.65 V
1.2
1.2
V
IO = -12 mA; VCCO = 2.3 V
1.9
1.9
V
IO = -24 mA; VCCO = 3.0 V
2.4
2.4
V
IO = -32 mA; VCCO = 4.5 V
3.8
3.8
V
IO = 100 μA;
0.1
0.1
V
IO = 6 mA; VCCO = 1.4 V
0.3
0.3
V
IO = 8 mA; VCCO = 1.65 V
0.45
0.45
V
IO = 12 mA; VCCO = 2.3 V
0.3
0.3
V
IO = 24 mA; VCCO = 3.0 V
0.55
0.55
V
IO = 32 mA; VCCO = 4.5 V
0.55
0.55
V
±2
±10
μA
VI = 0.49 V; VCCI = 1.4 V
15
10
μA
VI = 0.58 V; VCCI = 1.65 V
25
μA
VI = 0.70 V; VCCI = 2.3 V
45
45
μA
VI = 0.80 V; VCCI = 3.0 V
100
80
μA
100
100
μA
VI = 0.91 V; VCCI = 1.4 V
-15
-10
μA
VI = 1.07 V; VCCI = 1.65 V
-25
-20
μA
VI = 1.60 V; VCCI = 2.3 V
-45
-45
μA
VI = 2.00 V; VCCI = 3.0 V
-100
-80
μA
VI = 3.15 V; VCCI = 4.5 V
-100
-100
μA
VI = VIL
[2]
II
input leakage
current
IBHL
bus hold LOW
current
A or B port
[1]
VI = 1.35 V; VCCI = 4.5 V
IBHH
bus hold HIGH
current
74LVC_LVCH2T45_Q100
Product data sheet
0.3VCC(A) V
VI = VIH
A or B port
[1]
6 / 30
Nexperia
Symbol Parameter
IBHLO
IBHHO
bus hold LOW
overdrive
current
bus hold HIGH
overdrive
current
Conditions
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Max
Min
Max
VCCI = 1.6 V
125
125
μA
VCCI = 1.95 V
200
200
μA
VCCI = 2.7 V
300
300
μA
VCCI = 3.6 V
500
500
μA
VCCI = 5.5 V
900
900
μA
VCCI = 1.6 V
-125
-125
μA
VCCI = 1.95 V
-200
-200
μA
VCCI = 2.7 V
-300
-300
μA
VCCI = 3.6 V
-500
-500
μA
-900
-900
μA
±2
±10
μA
A or B port
[1][3]
A or B port
[1][3]
VCCI = 5.5 V
IOZ
OFF-state
output current
IOFF
power-off
leakage current VCC(A) = 0 V; VCC(B) = 1.2 V to 5.5 V
±2
±10
μA
±2
±10
μA
VCC(A), VCC(B) = 1.2 V to 5.5 V
8
8
μA
VCC(A), VCC(B) = 1.65 V to 5.5 V
3
3
μA
VCC(A) = 5.5 V; VCC(B) = 0 V
2
2
μA
VCC(A) = 0 V; VCC(B) = 5.5 V
-2
-2
μA
8
8
μA
3
3
μA
VCC(B) = 0 V; VCC(A) = 5.5 V
-2
-2
μA
VCC(B) = 5.5 V; VCC(A) = 0 V
2
2
μA
16
16
μA
4
4
μA
50
75
μA
50
75
μA
50
75
μA
ICC
supply current
A port; VI = 0 V or VCCI; IO = 0 A
[2]
[1]
B port; VI = 0 V or VCCI; IO = 0 A
A plus B port (ICC(A) + ICC(B));
IO = 0 A; VI = 0 V or VCCI
ΔICC
additional
supply current
per input;
VCC(A), VCC(B) = 3.0 V to 5.5 V
A port; A port at VCC(A) - 0.6 V;
DIR at VCC(A); B port = open
[4]
DIR input; DIR at VCC(A) - 0.6 V;
A port at VCC(A) or GND;
B port = open
B port; B port at VCC(B) - 0.6 V;
DIR at GND; A port = open
[1]
[2]
[3]
[4]
[4]
For non bus hold parts only (74LVC2T45-Q100).
74LVC_LVCH2T45_Q100
Product data sheet
7 / 30
Nexperia
11. Dynamic characteristics
Table 9. Typical dynamic characteristics at VCC(A) = 1.2 V and Tamb = 25 °C
Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 7; for waveforms see Fig. 5 and Fig. 6.
Symbol Parameter
Conditions
VCC(B)
Unit
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
5.0 V
tPLH
LOW to HIGH
propagation delay
A to B
10.6
8.1
7.0
5.8
5.3
5.1
ns
B to A
10.6
9.5
9.0
8.5
8.3
8.2
ns
tPHL
HIGH to LOW
propagation delay
A to B
10.1
7.1
6.0
5.3
5.2
5.4
ns
B to A
10.1
8.6
8.1
7.8
7.6
7.6
ns
HIGH to OFF-state
propagation delay
DIR to A
9.4
9.4
9.4
9.4
9.4
9.4
ns
DIR to B
12.0
9.4
9.0
7.8
8.4
7.9
ns
LOW to OFF-state
propagation delay
DIR to A
7.1
7.1
7.1
7.1
7.1
7.1
ns
DIR to B
9.5
7.8
7.7
6.9
7.6
7.0
ns
OFF-state to HIGH
propagation delay
DIR to A
[1]
20.1
17.3
16.7
15.4
15.9
15.2
ns
DIR to B
[1]
17.7
15.2
14.1
12.9
12.4
12.2
ns
OFF-state to LOW
propagation delay
DIR to A
[1]
22.1
18.0
17.1
15.6
16.0
15.5
ns
DIR to B
[1]
19.5
16.5
15.4
14.7
14.6
14.8
ns
tPHZ
tPLZ
tPZH
tPZL
[1]
tPZH and tPZL are calculated values using the formula shown in Section 13.4.
Table 10. Typical dynamic characteristics at VCC(B) = 1.2 V and Tamb = 25 °C
Symbol Parameter
Conditions
VCC(A)
Unit
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
5.0 V
LOW to HIGH
propagation delay
A to B
10.6
9.5
9.0
8.5
8.3
8.2
ns
B to A
10.6
8.1
7.0
5.8
5.3
5.1
ns
tPHL
HIGH to LOW
propagation delay
A to B
10.1
8.6
8.1
7.8
7.6
7.6
ns
B to A
10.1
7.1
6.0
5.3
5.2
5.4
ns
tPHZ
HIGH to OFF-state
propagation delay
DIR to A
9.4
6.5
5.7
4.1
4.1
3.0
ns
DIR to B
12.0
6.1
5.4
4.6
4.3
4.0
ns
LOW to OFF-state
propagation delay
DIR to A
7.1
4.9
4.5
3.2
3.4
2.5
ns
DIR to B
9.5
7.3
6.6
5.9
5.7
5.6
ns
OFF-state to HIGH
propagation delay
DIR to A
[1]
20.1
15.4
13.6
11.7
11.0
10.7
ns
DIR to B
[1]
17.7
14.4
13.5
11.7
11.7
10.7
ns
OFF-state to LOW
propagation delay
DIR to A
[1]
22.1
13.2
11.4
9.9
9.5
9.4
ns
DIR to B
[1]
19.5
15.1
13.8
11.9
11.7
10.6
ns
tPLH
tPLZ
tPZH
tPZL
[1]
74LVC_LVCH2T45_Q100
Product data sheet
8 / 30
Nexperia
Table 11. Typical power dissipation capacitance at VCC(A) = VCC(B) and Tamb = 25 °C
Symbol Parameter
Conditions
1.8 V
2.5 V
3.3 V
5.0 V
CPD
A port: (direction A to B);
B port: (direction B to A)
2
3
3
4
pF
15
16
16
18
pF
[1]
[2]
power dissipation
capacitance[1] [2]
VCC(A) and VCC(B)
Unit
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL × VCC × fo) = sum of the outputs.
fi = 10 MHz; VI = GND to VCC; tr = tf = 1 ns; CL = 0 pF; RL = ∞ Ω.
Table 12. Dynamic characteristics for temperature range -40 °C to +85 °C
Symbol Parameter
Conditions
VCC(B)
Unit
1.5 V ± 0.1 V 1.8 V ± 0.15 V 2.5 V ± 0.2 V 3.3 V ± 0.3 V 5.0 V ± 0.5 V
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
VCC(A) = 1.4 V to 1.6 V
tPLH
LOW to HIGH
propagation delay
A to B
2.8
21.3
2.4
17.6
2.0
13.5
1.7
11.8
1.6
10.5 ns
B to A
2.8
21.3
2.6
19.1
2.3
14.9
2.3
12.4
2.2
12.0 ns
tPHL
HIGH to LOW
propagation delay
A to B
2.6
19.3
2.2
15.3
1.8
11.8
1.7
10.9
1.7
10.8 ns
B to A
2.6
19.3
2.4
17.3
2.3
13.2
2.2
11.3
2.3
11.0 ns
HIGH to OFF-state
propagation delay
DIR to A
3.0
18.7
3.0
18.7
3.0
18.7
3.0
18.7
3.0
18.7 ns
DIR to B
3.5
24.8
3.5
23.6
3.0
11.0
3.3
11.3
2.8
10.3 ns
LOW to OFF-state
propagation delay
DIR to A
2.4
11.4
2.4
11.4
2.4
11.4
2.4
11.4
2.4
11.4 ns
DIR to B
2.8
18.3
3.0
17.2
2.5
9.4
3.0
10.1
2.5
9.4
OFF-state to HIGH
propagation delay
DIR to A
[1]
39.6
36.3
24.3
22.5
21.4 ns
DIR to B
[1]
32.7
29.0
24.9
23.2
21.9 ns
OFF-state to LOW
propagation delay
DIR to A
[1]
44.1
40.9
24.2
22.6
21.3 ns
DIR to B
[1]
38.0
34.0
30.5
29.6
29.5 ns
tPHZ
tPLZ
tPZH
tPZL
74LVC_LVCH2T45_Q100
Product data sheet
ns
9 / 30
Nexperia
Symbol Parameter
Conditions
VCC(B)
Unit
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
VCC(A) = 1.65 V to 1.95 V
LOW to HIGH
propagation delay
A to B
2.6
19.1
2.2
17.7
2.2
9.3
1.7
7.2
1.4
6.8
B to A
2.4
17.6
2.2
17.7
2.3
16.0
2.1
15.5
1.9
15.1 ns
HIGH to LOW
propagation delay
A to B
2.4
17.3
2.0
14.3
1.6
8.5
1.8
7.1
1.7
7.0
B to A
2.2
15.3
2.0
14.3
2.1
12.9
2.0
12.6
1.8
12.2 ns
HIGH to OFF-state
propagation delay
DIR to A
2.9
17.1
2.9
17.1
2.9
17.1
2.9
17.1
2.9
17.1 ns
DIR to B
3.2
24.1
3.2
21.9
2.7
11.5
3.0
10.3
2.5
8.2
LOW to OFF-state
propagation delay
DIR to A
2.4
10.5
2.4
10.5
2.4
10.5
2.4
10.5
2.4
10.5 ns
DIR to B
2.5
17.6
2.6
16.0
2.2
9.2
2.7
8.4
2.4
7.1
tPZH
OFF-state to HIGH
propagation delay
DIR to A
[1]
35.2
33.7
25.2
23.9
22.2 ns
DIR to B
[1]
29.6
28.2
19.8
17.7
17.3 ns
tPZL
OFF-state to LOW
propagation delay
DIR to A
[1]
39.4
36.2
24.4
22.9
20.4 ns
DIR to B
[1]
34.4
31.4
25.6
24.2
24.1 ns
16.0
1.5
8.5
1.3
6.2
1.1
4.8
ns
tPLH
tPHL
tPHZ
tPLZ
ns
ns
ns
ns
VCC(A) = 2.3 V to 2.7 V
tPLH
LOW to HIGH
propagation delay
A to B
2.3
17.9
2.3
B to A
2.0
13.5
2.2
9.3
1.5
8.5
1.4
8.0
1.0
7.5
ns
tPHL
HIGH to LOW
propagation delay
A to B
2.3
15.8
2.1
12.9
1.4
7.5
1.3
5.4
0.9
4.6
ns
B to A
1.8
11.8
1.9
8.5
1.4
7.5
1.3
7.0
0.9
6.2
ns
HIGH to OFF-state
propagation delay
DIR to A
2.1
8.1
2.1
8.1
2.1
8.1
2.1
8.1
2.1
8.1
ns
DIR to B
3.0
22.5
3.0
21.4
2.5
11.0
2.8
9.3
2.3
6.9
ns
LOW to OFF-state
propagation delay
DIR to A
1.7
5.8
1.7
5.8
1.7
5.8
1.7
5.8
1.7
5.8
ns
DIR to B
2.3
14.6
2.5
13.2
2.0
9.0
2.5
8.4
1.8
5.8
ns
OFF-state to HIGH
propagation delay
DIR to A
[1]
28.1
22.5
17.5
16.4
13.3 ns
DIR to B
[1]
23.7
21.8
14.3
12.0
10.6 ns
OFF-state to LOW
propagation delay
DIR to A
[1]
34.3
29.9
18.5
16.3
13.1 ns
DIR to B
[1]
23.9
21.0
15.6
13.5
12.7 ns
tPHZ
tPLZ
tPZH
tPZL
VCC(A) = 3.0 V to 3.6 V
LOW to HIGH
propagation delay
A to B
2.3
17.1
2.1
15.5
1.4
8.0
0.8
5.6
0.7
4.4
ns
B to A
1.7
11.8
1.7
7.2
1.3
6.2
0.7
5.6
0.6
5.4
ns
tPHL
HIGH to LOW
propagation delay
A to B
2.2
15.6
2.0
12.6
1.3
7.0
0.8
5.0
0.7
4.0
ns
B to A
1.7
10.9
1.8
7.1
1.3
5.4
0.8
5.0
0.7
4.5
ns
tPHZ
HIGH to OFF-state
propagation delay
DIR to A
2.3
7.3
2.3
7.3
2.3
7.3
2.3
7.3
2.7
7.3
ns
DIR to B
2.9
18.0
2.9
16.5
2.3
10.1
2.7
8.6
2.2
6.3
ns
LOW to OFF-state
propagation delay
DIR to A
2.0
5.6
2.0
5.6
2.0
5.6
2.0
5.6
2.0
5.6
ns
DIR to B
2.3
13.6
2.4
12.5
1.9
7.8
2.3
7.1
1.7
4.9
ns
OFF-state to HIGH
propagation delay
DIR to A
[1]
25.4
19.7
14.0
12.7
10.3 ns
DIR to B
[1]
22.7
21.1
13.6
11.2
10.0 ns
OFF-state to LOW
propagation delay
DIR to A
[1]
28.9
23.6
15.5
13.6
10.8 ns
DIR to B
[1]
22.9
19.9
14.3
12.3
11.3 ns
tPLH
tPLZ
tPZH
tPZL
74LVC_LVCH2T45_Q100
Product data sheet
10 / 30
Nexperia
Symbol Parameter
Conditions
VCC(B)
Unit
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
VCC(A) = 4.5 V to 5.5 V
LOW to HIGH
propagation delay
A to B
2.2
16.6
1.9
15.1
1.0
7.5
0.7
5.4
0.5
3.9
ns
B to A
1.6
10.5
1.4
6.8
1.0
4.8
0.7
4.4
0.5
3.9
ns
HIGH to LOW
propagation delay
A to B
2.3
15.3
1.8
12.2
1.0
6.2
0.7
4.5
0.5
3.5
ns
B to A
1.7
10.8
1.7
7.0
0.9
4.6
0.7
4.0
0.5
3.5
ns
HIGH to OFF-state
propagation delay
DIR to A
1.7
5.4
1.7
5.4
1.7
5.4
1.7
5.4
1.7
5.4
ns
DIR to B
2.9
17.3
2.9
16.1
2.3
9.7
2.7
8.0
2.5
5.7
ns
LOW to OFF-state
propagation delay
DIR to A
1.4
3.7
1.4
3.7
1.3
3.7
1.0
3.7
0.9
3.7
ns
DIR to B
2.3
13.1
2.4
12.1
1.9
7.4
2.3
7.0
1.8
4.5
ns
tPZH
OFF-state to HIGH
propagation delay
DIR to A
[1]
23.6
18.9
12.2
11.4
8.4
ns
DIR to B
[1]
20.3
18.8
11.2
9.1
7.6
ns
tPZL
OFF-state to LOW
propagation delay
DIR to A
[1]
28.1
23.1
14.3
12.0
9.2
ns
DIR to B
[1]
20.7
17.6
11.6
9.9
8.9
ns
tPLH
tPHL
tPHZ
tPLZ
[1]
Table 13. Dynamic characteristics for temperature range -40 °C to +125 °C
Symbol Parameter
Conditions
VCC(B)
Unit
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
LOW to HIGH
propagation delay
A to B
2.5
23.5
2.1
19.4
1.8
14.9
1.5
13.0
1.4
11.6 ns
B to A
2.5
23.5
2.3
21.1
2.0
16.4
2.0
13.7
1.9
13.2 ns
tPHL
HIGH to LOW
propagation delay
A to B
2.3
21.3
1.9
16.9
1.6
13.0
1.5
12.0
1.5
11.9 ns
B to A
2.3
21.3
2.1
19.1
2.0
14.6
1.9
12.5
2.0
12.1 ns
tPHZ
HIGH to OFF-state
propagation delay
DIR to A
2.7
20.6
2.7
20.6
2.7
20.6
2.7
20.6
2.7
20.6 ns
DIR to B
3.1
27.3
3.1
26.0
2.7
12.1
2.9
12.5
2.5
11.4 ns
LOW to OFF-state
propagation delay
DIR to A
2.1
12.6
2.1
12.6
2.1
12.6
2.1
12.6
2.1
12.6 ns
DIR to B
2.5
20.2
2.7
19.0
2.2
10.4
2.7
11.2
2.2
10.4 ns
OFF-state to HIGH
propagation delay
DIR to A
[1]
43.7
40.1
26.8
24.9
23.6 ns
DIR to B
[1]
36.1
32.0
27.5
25.6
24.2 ns
OFF-state to LOW
propagation delay
DIR to A
[1]
48.6
45.1
26.7
25.0
23.5 ns
DIR to B
[1]
41.9
37.5
33.6
32.6
32.5 ns
tPLH
tPLZ
tPZH
tPZL
74LVC_LVCH2T45_Q100
Product data sheet
11 / 30
Nexperia
Symbol Parameter
Conditions
VCC(B)
Unit
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
LOW to HIGH
propagation delay
A to B
2.3
21.1
1.9
19.5
1.9
10.3
1.5
8.0
1.2
7.5
B to A
2.1
19.4
1.9
19.5
2.0
17.6
1.8
17.1
1.7
16.7 ns
HIGH to LOW
propagation delay
A to B
2.1
19.1
1.8
15.8
1.4
9.4
1.6
7.9
1.5
7.7
B to A
1.9
16.9
1.8
15.8
1.8
14.2
1.8
13.9
1.6
13.5 ns
HIGH to OFF-state
propagation delay
DIR to A
2.6
18.9
2.6
18.9
2.6
18.9
2.6
18.9
2.6
18.9 ns
DIR to B
2.8
26.6
2.8
24.1
2.4
12.7
2.7
11.4
2.2
9.1
LOW to OFF-state
propagation delay
DIR to A
2.1
11.6
2.1
11.6
2.1
11.6
2.1
11.6
2.1
11.6 ns
DIR to B
2.2
19.4
2.3
17.6
1.9
10.2
2.4
9.3
2.1
7.9
tPZH
OFF-state to HIGH
propagation delay
DIR to A
[1]
38.8
37.1
27.8
26.4
24.6 ns
DIR to B
[1]
32.7
31.1
21.9
19.6
19.1 ns
tPZL
OFF-state to LOW
propagation delay
DIR to A
[1]
43.5
39.9
26.9
25.3
22.6 ns
DIR to B
[1]
38.0
34.7
28.3
26.8
26.6 ns
tPLH
tPHL
tPHZ
tPLZ
ns
ns
ns
ns
tPLH
LOW to HIGH
propagation delay
A to B
2.0
19.7
2.0
17.6
1.3
9.4
1.1
6.9
0.9
5.3
ns
B to A
1.8
14.9
1.9
10.3
1.3
9.4
1.2
8.8
0.9
8.3
ns
tPHL
HIGH to LOW
propagation delay
A to B
2.0
17.4
1.8
14.2
1.2
8.3
1.1
6.0
0.8
5.1
ns
B to A
1.6
13.0
1.7
9.4
1.2
8.3
1.1
7.7
0.8
6.9
ns
HIGH to OFF-state
propagation delay
DIR to A
1.8
9.0
1.8
9.0
1.8
9.0
1.8
9.0
1.8
9.0
ns
DIR to B
2.7
24.8
2.7
23.6
2.2
12.1
2.5
10.3
2.0
7.6
ns
LOW to OFF-state
propagation delay
DIR to A
1.5
6.4
1.5
6.4
1.5
6.4
1.5
6.4
1.5
6.4
ns
DIR to B
2.0
16.1
2.2
14.6
1.8
9.9
2.2
9.3
1.6
6.4
ns
OFF-state to HIGH
propagation delay
DIR to A
[1]
31.0
24.9
19.3
18.1
14.7 ns
DIR to B
[1]
26.1
24.0
15.8
13.3
11.7 ns
OFF-state to LOW
propagation delay
DIR to A
[1]
37.8
33.0
20.4
18.0
14.5 ns
DIR to B
[1]
26.4
23.2
17.3
15.0
14.1 ns
tPHZ
tPLZ
tPZH
tPZL
LOW to HIGH
propagation delay
A to B
2.0
18.9
1.8
17.1
1.2
8.8
0.7
6.2
0.6
4.9
ns
B to A
1.5
13.0
1.5
8.0
1.1
6.9
0.6
6.2
0.5
6.0
ns
tPHL
HIGH to LOW
propagation delay
A to B
1.9
17.2
1.8
13.9
1.1
7.7
0.7
5.5
0.6
4.4
ns
B to A
1.5
12.0
1.6
7.9
1.1
6.0
0.7
5.5
0.6
5.0
ns
tPHZ
HIGH to OFF-state
propagation delay
DIR to A
2.0
8.1
2.0
8.1
2.0
8.1
2.0
8.1
2.4
8.1
ns
DIR to B
2.6
19.8
2.6
18.2
2.0
11.2
2.4
9.5
1.9
7.0
ns
LOW to OFF-state
propagation delay
DIR to A
1.8
6.2
1.8
6.2
1.8
6.2
1.8
6.2
1.8
6.2
ns
DIR to B
2.0
15.0
2.1
13.8
1.7
8.6
2.0
7.9
1.5
5.4
ns
OFF-state to HIGH
propagation delay
DIR to A
[1]
28.0
21.8
15.5
14.1
11.4 ns
DIR to B
[1]
25.1
23.3
15.0
12.4
11.1 ns
OFF-state to LOW
propagation delay
DIR to A
[1]
31.8
26.1
17.2
15.0
12.0 ns
DIR to B
[1]
25.3
22.0
15.8
13.6
12.5 ns
tPLH
tPLZ
tPZH
tPZL
74LVC_LVCH2T45_Q100
Product data sheet
12 / 30
Nexperia
Symbol Parameter
Conditions
VCC(B)
Unit
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
LOW to HIGH
propagation delay
A to B
1.9
18.3
1.7
16.7
0.9
8.3
0.6
6.0
0.4
4.3
ns
B to A
1.4
11.6
1.2
7.5
0.9
5.3
0.6
4.9
0.4
4.3
ns
HIGH to LOW
propagation delay
A to B
2.0
16.9
1.6
13.5
0.9
6.9
0.6
5.0
0.4
3.9
ns
B to A
1.5
11.9
1.5
7.7
0.8
5.1
0.6
4.4
0.4
3.9
ns
HIGH to OFF-state
propagation delay
DIR to A
1.5
6.0
1.5
6.0
1.5
6.0
1.5
6.0
1.5
6.0
ns
DIR to B
2.6
19.1
2.6
17.8
2.0
10.7
2.4
8.8
2.2
6.3
ns
LOW to OFF-state
propagation delay
DIR to A
1.2
4.1
1.2
4.1
1.1
4.1
0.9
4.1
0.8
4.1
ns
DIR to B
2.0
14.5
2.1
13.4
1.7
8.2
2.0
7.7
1.6
5.0
ns
tPZH
OFF-state to HIGH
propagation delay
DIR to A
[1]
26.1
20.9
13.5
12.6
9.3
ns
DIR to B
[1]
22.4
20.8
12.4
10.1
8.4
ns
tPZL
OFF-state to LOW
propagation delay
DIR to A
[1]
31.0
25.5
15.8
13.2
10.2 ns
DIR to B
[1]
22.9
19.5
12.9
11.0
9.9
tPLH
tPHL
tPHZ
tPLZ
[1]
ns
74LVC_LVCH2T45_Q100
Product data sheet
13 / 30
Nexperia
11.1. Waveforms and test circuit
VI
VM
nA, nB input
GND
tPHL
tPLH
VOH
nB, nA output
VM
001aaj644
VOL
Measurement points are given in Table 14.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 5.
The data input (A, B) to output (B, A) propagation delay times
VI
DIR input
VM
GND
t PLZ
output
LOW-to-OFF
OFF-to-LOW
t PZL
VCCO
VM
VX
VOL
t PHZ
output
HIGH-to-OFF
OFF-to-HIGH
VOH
t PZH
VY
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
001aae968
Fig. 6.
Enable and disable times
Table 14. Measurement points
Supply voltage
Input [1]
Output [2]
VCC(A), VCC(B)
VM
VM
VX
VY
1.2 V to 1.6 V
0.5VCCI
0.5VCCO
VOL + 0.1 V
VOH - 0.1 V
1.65 V to 2.7 V
0.5VCCI
0.5VCCO
VOL + 0.15 V
VOH - 0.15 V
3.0 V to 5.5 V
0.5VCCI
0.5VCCO
VOL + 0.3 V
VOH - 0.3 V
[1]
[2]
74LVC_LVCH2T45_Q100
Product data sheet
14 / 30
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
001aae331
Test data is given in Table 15.
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance.
VEXT = External voltage for measuring switching times.
Fig. 7.
Test circuit for measuring switching times
Table 15. Test data
Supply voltage
Input
VCC(A), VCC(B)
VI [1]
Δt/ΔV [2]
CL
RL
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ [3]
1.2 V to 5.5 V
VCCI
≤ 1.0 ns/V
15 pF
2 kΩ
open
GND
2VCCO
[1]
[2]
[3]
Load
VEXT
dV/dt ≥ 1.0 V/ns.
74LVC_LVCH2T45_Q100
Product data sheet
15 / 30
Nexperia
12. Typical propagation delay characteristics
001aai907
14
tPHL
(ns)
12
(1)
10
001aai908
14
tPLH
(ns)
12
(1)
10
(2)
8
(2)
8
(3)
6
(3)
(4)
(5)
(6)
6
(4)
(5)
(6)
4
4
2
2
10
15
30
35
CL (pF)
a. HIGH to LOW propagation delay (A to B)
001aai909
14
tPHL
(ns)
12
(1)
8
(4)
(5)
(6)
8
6
6
4
4
2
2
5
10
15
30
35
CL (pF)
c. HIGH to LOW propagation delay (B to A)
10
15
30
35
CL (pF)
001aai910
14
tPLH
(ns)
12
(2)
(3)
b. LOW to HIGH propagation delay (A to B)
10
(2)
(3)
(4)
(5)
(6)
10
15
30
35
CL (pF)
d. LOW to HIGH propagation delay (B to A)
(1) VCC(B) = 1.2 V.
(2) VCC(B) = 1.5 V.
(3) VCC(B) = 1.8 V.
(4) VCC(B) = 2.5 V.
(5) VCC(B) = 3.3 V.
(6) VCC(B) = 5.0 V.
Fig. 8.
Typical propagation delay versus load capacitance; Tamb = 25 °C; VCC(A) = 1.2 V
74LVC_LVCH2T45_Q100
Product data sheet
16 / 30
Nexperia
001aai911
14
tPHL
(ns)
12
001aai912
14
tPLH
(ns)
12
(1)
10
10
(1)
8
8
(2)
(2)
6
(3)
6
(3)
(4)
(5)
(6)
(4)
4
4
(5)
2
(6)
10
15
30
35
CL (pF)
001aai913
14
tPHL
(ns)
12
10
10
15
30
35
CL (pF)
001aai914
14
tPLH
(ns)
12
10
(1)
8
(1)
8
6
(2)
(3)
(4)
6
(2)
(3)
(4)
(5)
(5)
(6)
4
2
4
2
10
15
30
35
CL (pF)
10
15
30
35
CL (pF)
(1) VCC(B) = 1.2 V.
(2) VCC(B) = 1.5 V.
(3) VCC(B) = 1.8 V.
(4) VCC(B) = 2.5 V.
(5) VCC(B) = 3.3 V.
(6) VCC(B) = 5.0 V.
Fig. 9.
Typical propagation delay versus load capacitance; Tamb = 25 °C; VCC(A) = 1.5 V
74LVC_LVCH2T45_Q100
Product data sheet
17 / 30
Nexperia
001aai915
14
tPHL
(ns)
12
10
(1)
10
(1)
8
8
(2)
6
(3)
(4)
4
(5)
(6)
2
001aai916
14
tPLH
(ns)
12
10
15
6
(3)
4
(4)
(5)
(6)
2
30
35
CL (pF)
001aai917
14
tPHL
(ns)
12
(2)
10
10
15
001aai918
14
tPLH
(ns)
12
10
8
8
(1)
(1)
6
(2)
(3)
(4)
(5)
(6)
6
(2)
(3)
(4)
(5)
(6)
4
4
2
35
CL (pF)
2
10
15
30
35
CL (pF)
10
15
30
35
CL (pF)
(1) VCC(B) = 1.2 V.
(2) VCC(B) = 1.5 V.
(3) VCC(B) = 1.8 V.
(4) VCC(B) = 2.5 V.
(5) VCC(B) = 3.3 V.
(6) VCC(B) = 5.0 V.
Fig. 10. Typical propagation delay versus load capacitance; Tamb = 25 °C; VCC(A) = 1.8 V
74LVC_LVCH2T45_Q100
Product data sheet
18 / 30
Nexperia
001aai919
14
tPHL
(ns)
12
10
001aai920
14
tPLH
(ns)
12
(1)
10
(1)
8
8
(2)
(2)
6
6
(3)
(3)
4
2
10
15
2
30
35
CL (pF)
001aai921
14
tPHL
(ns)
12
8
(3)
(4)
(5)
(6)
10
15
10
15
(1)
(2)
(3)
(4)
(5)
(6)
4
2
30
35
CL (pF)
30
35
CL (pF)
001aai922
6
(1)
2
5
14
tPLH
(ns)
12
10
4
10
6
(4)
(5)
(6)
4
(4)
(5)
(6)
10
15
30
35
CL (pF)
(1) VCC(B) = 1.2 V.
(2) VCC(B) = 1.5 V.
(3) VCC(B) = 1.8 V.
(4) VCC(B) = 2.5 V.
(5) VCC(B) = 3.3 V.
(6) VCC(B) = 5.0 V.
Fig. 11. Typical propagation delay versus load capacitance; Tamb = 25 °C; VCC(A) = 2.5 V
74LVC_LVCH2T45_Q100
Product data sheet
19 / 30
Nexperia
001aai923
14
tPHL
(ns)
12
10
001aai924
14
tPLH
(ns)
12
10
(1)
(1)
8
8
(2)
6
(2)
6
(3)
(3)
4
2
(4)
(5)
(6)
10
15
2
30
35
CL (pF)
001aai925
14
tPHL
(ns)
12
8
(2)
(3)
(4)
(5)
(6)
4
2
10
15
30
35
CL (pF)
5
10
15
30
35
CL (pF)
001aai926
14
tPLH
(ns)
12
10
(1)
10
6
(4)
(5)
(6)
6
(1)
4
(2)
(3)
2
(4)
(5)
(6)
10
15
30
35
CL (pF)
(1) VCC(B) = 1.2 V.
(2) VCC(B) = 1.5 V.
(3) VCC(B) = 1.8 V.
(4) VCC(B) = 2.5 V.
(5) VCC(B) = 3.3 V.
(6) VCC(B) = 5.0 V.
Fig. 12. Typical propagation delay versus load capacitance; Tamb = 25 °C; VCC(A) = 3.3 V
74LVC_LVCH2T45_Q100
Product data sheet
20 / 30
Nexperia
001aai927
14
tPHL
(ns)
12
10
001aai928
14
tPLH
(ns)
12
10
(1)
(1)
8
8
(2)
6
(2)
6
(3)
(3)
4
2
(4)
(5)
(6)
10
15
2
30
35
CL (pF)
001aai929
14
tPHL
(ns)
12
(4)
(5)
(6)
10
15
30
35
CL (pF)
001aai930
14
tPLH
(ns)
12
10
10
8
8
6
(1)
6
4
(2)
(3)
4
(2)
(3)
2
(4)
(5)
(6)
2
(4)
(5)
(6)
10
15
30
35
CL (pF)
10
15
30
35
CL (pF)
(1) VCC(B) = 1.2 V.
(2) VCC(B) = 1.5 V.
(3) VCC(B) = 1.8 V.
(4) VCC(B) = 2.5 V.
(5) VCC(B) = 3.3 V.
(6) VCC(B) = 5.0 V.
Fig. 13. Typical propagation delay versus load capacitance; Tamb = 25 °C; VCC(A) = 5.0 V
74LVC_LVCH2T45_Q100
Product data sheet
21 / 30
Nexperia
13. Application information
13.1. Unidirectional logic level-shifting application
The circuit given in Fig. 14 is an example of the 74LVC2T45-Q100; 74LVCH2T45-Q100 being used
in a unidirectional logic level-shifting application.
VCC1
VCC2
VCC(A)
VCC1
1A
1
8
VCC(B)
VCC2
1B
74LVC2T45-Q100 7
2A
2B
3 74LVCH2T45-Q100 6
GND
VCC1
2
4
5
DIR
system-1
VCC2
system-2
aaa-006263
Fig. 14. Unidirectional logic level-shifting application
Table 16. Description of unidirectional logic level-shifting application
Pin
Name
Function
Description
74LVC_LVCH2T45_Q100
Product data sheet
1
VCC(A)
VCC1
supply voltage of system-1 (1.2 V to 5.5 V)
2
1A
OUT
output level depends on VCC1 voltage
3
2A
OUT
4
GND
GND
device GND
5
DIR
DIR
the GND (LOW level) determines B port to A port
direction
6
2B
IN
input threshold value depends on VCC2 voltage
7
1B
IN
8
VCC(B)
VCC2
supply voltage of system-2 (1.2 V to 5.5 V)
22 / 30
Nexperia
13.2. Bidirectional logic level-shifting application
Fig. 15 shows the 74LVC2T45-Q100; 74LVCH2T45-Q100 being used in a bidirectional logic
level-shifting application. Since the device does not have an output enable pin, the system designer
should take precautions to avoid bus contention between system-1 and system-2 when changing
directions.
VCC1
I/O-1
VCC1
VCC2
VCC(A)
PULL-UP/DOWN
1A
2A
GND
1
8
VCC2
VCC(B)
PULL-UP/DOWN
I/O-2
1B
2
74LVC2T45-Q100 7
2B
74LVCH2T45-Q100
3
6
4
5
DIR
DIR CTRL
DIR CTRL
system-1
system-2
aaa-006264
Pull-up or pull-down only needed for 74LVC2T45-Q100.
Fig. 15. Bidirectional logic level-shifting application
Table 17 gives a sequence that will illustrate data transmission from system-1 to system-2 and then
from system-2 to system-1.
Table 17. Description of bidirectional logic level-shifting application
State
DIR CTRL I/O-1
I/O-2
Description
1
H
output
input
system-1 data to system-2
2
H
Z
Z
system-2 is getting ready to send data to
system-1. I/O-1 and I/O-2 are disabled.
The bus-line state depends on bus hold
3
L
Z
Z
DIR bit is set LOW.
I/O-1 and I/O-2 still are disabled.
4
L
input
output
system-2 data to system-1
13.3. Power-up considerations
The device is designed such that no special power-up sequence is required other than GND being
applied first.
Table 18. Typicaltotal supply current (ICC(A) + ICC(B))
VCC(A)
VCC(B)
74LVC_LVCH2T45_Q100
Product data sheet
Unit
0V
1.8 V
2.5 V
3.3 V
5.0 V
0V
很抱歉,暂时无法提供与“74LVC2T45DC-Q100H”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7.589341+0.91979
- 10+6.6736310+0.80881
- 25+6.2695625+0.75984
- 100+5.11559100+0.61998
- 250+4.75178250+0.57589
- 500+4.04419500+0.49014
- 1000+3.235351000+0.39211
- 国内价格
- 1+3.33720
- 10+2.97000
- 30+2.78640
- 100+2.60280
- 500+2.30040
- 1000+2.24640
