74AUP1T34GS,132
74AUP1T34GS,132
    NEXPERIA(安世)
    XSON6_1X1MM
    电压电平 转换器 单向 1 电路 1 通道 6-XSON,SOT1202(1x1)
74AUP1T34GS,132 数据手册
74AUP1T34 Low-power dual supply translating buffer Rev. 6 — 28 January 2019 Product data sheet 1. General description The 74AUP1T34 provides a single buffer with two separate supply voltages. Input A is designed to track VCC(A). Output Y is designed to track VCC(Y). Both, VCC(A) and VCC(Y) accepts any supply voltage from 1.1 V to 3.6 V. This feature allows universal low voltage interfacing between any of the 1.2 V, 1.5 V, 1.8 V, 2.5 V, and 3.3 V voltage nodes. Schmitt trigger action at all inputs makes the circuit tolerant to slower input rise and fall times across the entire VCC range from 1.1 V to 3.6 V. This device ensures a very low static and dynamic power consumption across the entire VCC range from 1.1 V to 3.6 V. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. 2. Features and benefits • • • • • • • • • • • • • Wide supply voltage range from 1.1 V to 3.6 V High noise immunity Complies with JEDEC standards: • JESD8-7 (1.2 V to 1.95 V) • JESD8-5 (1.8 V to 2.7 V) • JESD8-B (2.7 V to 3.6 V) ESD protection: • HBM JESD22-A114F Class 3A exceeds 5000 V • MM JESD22-A115-A exceeds 200 V • CDM JESD22-C101E exceeds 1000 V Wide supply voltage range: • VCC(A): 1.1 V to 3.6 V • VCC(Y): 1.1 V to 3.6 V Low static power consumption; ICC = 0.9 µA (maximum) Each port operates over the full 1.1 V to 3.6 V power supply range Latch-up performance exceeds 100 mA per JESD 78 Class II Inputs accept voltages up to 3.6 V Low noise overshoot and undershoot < 10 % of VCC IOFF circuitry provides partial Power-down mode operation Multiple package options Specified from -40 °C to +85 °C and -40 °C to +125 °C 74AUP1T34 Nexperia Low-power dual supply translating buffer 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AUP1T34GW -40 °C to +125 °C TSSOP5 plastic thin shrink small outline package; 5 leads; SOT353-1 body width 1.25 mm 74AUP1T34GM -40 °C to +125 °C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1 × 1.45 × 0.5 mm SOT886 74AUP1T34GF -40 °C to +125 °C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1 × 1 × 0.5 mm SOT891 74AUP1T34GN -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9 × 1.0 × 0.35 mm SOT1115 74AUP1T34GS -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0 × 1.0 × 0.35 mm SOT1202 74AUP1T34GX -40 °C to +125 °C X2SON5 X2SON5: plastic thermal enhanced extremely SOT1226 thin small outline package; no leads; 5 terminals; body 0.8 × 0.8 × 0.35 mm 4. Marking Table 2. Marking Type number Marking code [1] 74AUP1T34GW pQ 74AUP1T34GM pQ 74AUP1T34GF pQ 74AUP1T34GN pQ 74AUP1T34GS pQ 74AUP1T34GX pQ [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram A Y A 001aac538 Fig. 1. Logic symbol 74AUP1T34 Product data sheet Y 001aac537 Fig. 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 January 2019 001aac536 Fig. 3. Logic diagram © Nexperia B.V. 2019. All rights reserved 2 / 22 74AUP1T34 Nexperia Low-power dual supply translating buffer 6. Pinning information 6.1. Pinning 74AUP1T34 74AUP1T34 VCC(A) 1 A 2 GND 5 3 4 VCC(A) 1 6 VCC(Y) A 2 5 n.c. GND 3 4 Y VCC(Y) Y 001aad740 Transparent top view 001aad741 Fig. 4. Pin configuration SOT353-1 (TSSOP5) Fig. 5. Pin configuration SOT886 (XSON6) 74AUP1T34 74AUP1T34 VCC(A) 1 6 VCC(Y) A 2 5 n.c. GND 3 4 Y VCC(A) 5 VCC(Y) 4 Y 3 GND A 001aad832 Transparent top view Fig. 6. 1 2 aaa-003015 Pin configuration SOT891, SOT1115 and SOT1202 (XSON6) Transparent top view Fig. 7. Pin configuration SOT1226 (X2SON5) 6.2. Pin description Table 3. Pin description Symbol Pin Description TSSOP5 and X2SON5 XSON6 VCC(A) 1 1 supply voltage port A A 2 2 data input A GND 3 3 ground (0 V) Y 4 4 data output Y n.c. - 5 not connected VCC(Y) 5 6 supply voltage port Y 7. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level. Input Output A Y L L H H 74AUP1T34 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 January 2019 © Nexperia B.V. 2019. All rights reserved 3 / 22 74AUP1T34 Nexperia Low-power dual supply translating buffer 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit VCC(A) supply voltage A -0.5 +4.6 V VCC(Y) supply voltage Y -0.5 +4.6 V IIK input clamping current VI input voltage IOK output clamping current VO < 0 V VO output voltage Active mode and Power-down mode IO output current VO = 0 V to VCC(Y) ICC IGND -50 - -0.5 +4.6 -50 - -0.5 +4.6 V - ±20 mA supply current - 50 mA ground current -50 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 250 mW Min Max Unit [1] [2] VI < 0 V [1] [1] Tamb = -40 °C to +125 °C [2] mA V mA The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed. For TSSOP5 packages: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K. For XSON6 and X2SON5 packages: above 118 °C the value of Ptot derates linearly with 7.8 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter Conditions VCC(A) supply voltage A 1.1 3.6 V VCC(Y) supply voltage Y 1.1 3.6 V VI input voltage 0 3.6 V VO output voltage 0 VCC(Y) V Tamb ambient temperature -40 +125 °C Δt/ΔV input transition rise and fall rate 0 200 ns/V control and data inputs; VCC(A) = 1.1 V to 3.6 V 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VCC(A) = 1.1 V to 1.95 V; VCC(Y) = 1.1 V to 3.6 V 0.65VCC(A) - - V VCC(A) = 2.3 V to 2.7 V; VCC(Y) = 1.1 V to 3.6 V 1.6 - - V VCC(A) = 3.0 V to 3.6 V; VCC(Y) = 1.1 V to 3.6 V 2.0 - - V VCC(A) = 1.1 V to 1.95 V; VCC(Y) = 1.1 V to 3.6 V - - VCC(A) = 2.3 V to 2.7 V; VCC(Y) = 1.1 V to 3.6 V - - 0.7 V VCC(A) = 3.0 V to 3.6 V; VCC(Y) = 1.1 V to 3.6 V - - 0.9 V Tamb = 25 °C VIH VIL HIGH-level input voltage LOW-level input voltage 74AUP1T34 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 January 2019 0.35VCC(A) V © Nexperia B.V. 2019. All rights reserved 4 / 22 74AUP1T34 Nexperia Low-power dual supply translating buffer Symbol Parameter VOH VOL Conditions Min Typ Max VCC(Y) - 0.1 - - V IO = -1.1 mA; VCC(A) = VCC(Y) = 1.1 V 0.75VCC(Y) - - V IO = -1.7 mA; VCC(A) = VCC(Y) = 1.4 V 1.11 - - V IO = -1.9 mA; VCC(A) = VCC(Y) = 1.65 V 1.32 - - V IO = -2.3 mA; VCC(A) = VCC(Y) = 2.3 V 2.05 - - V IO = -3.1 mA; VCC(A) = VCC(Y) = 2.3 V 1.9 - - V IO = -2.7 mA; VCC(A) = VCC(Y) = 3.0 V 2.72 - - V IO = -4.0 mA; VCC(A) = VCC(Y) = 3.0 V 2.6 - - V - - 0.1 V IO = 1.1 mA; VCC(A) = VCC(Y) = 1.1 V - - 0.3VCC(Y) V IO = 1.7 mA; VCC(A) = VCC(Y) = 1.4 V - - 0.31 V IO = 1.9 mA; VCC(A) = VCC(Y) = 1.65 V - - 0.31 V IO = 2.3 mA; VCC(A) = VCC(Y) = 2.3 V - - 0.31 V IO = 3.1 mA; VCC(A) = VCC(Y) = 2.3 V - - 0.44 V IO = 2.7 mA; VCC(A) = VCC(Y) = 3.0 V - - 0.31 V IO = 4.0 mA; VCC(A) = VCC(Y) = 3.0 V - - 0.44 V - - ±0.1 μA - - ±0.2 μA Y output; VO = 0 V to 3.6 V; VCC(A) = 0 V to 3.6 V; VI = 0 V or 3.6 V; VCC(Y) = 0 V - - ±0.2 μA A input; VI = 0 V to 3.6 V; VCC(A) = 0 V to 0.2 V; additional power-off leakage VCC(Y) = 0 V to 3.6 V current Y output; VO = 0 V to 3.6 V; VCC(A) = 0 V to 3.6 V; VI = 0 V or 3.6 V; VCC(Y) = 0 V to 0.2 V - - ±0.2 μA - - ±0.2 μA VCC(A) = VCC(Y) = 1.1 V to 3.6 V - - 0.5 μA VCC(A) = 3.6 V; VCC(Y) = 0 V - - 0.5 μA VCC(A) = 0 V; VCC(Y) = 3.6 V - 0.0 - μA VCC(A) = VCC(Y) = 1.1 V to 3.6 V - - 0.5 μA VCC(A) = 3.6 V; VCC(Y) = 0 V - 0.0 - μA VCC(A) = 0 V; VCC(Y) = 3.6 V HIGH-level output VI = VIH voltage IO = -20 μA; VCC(A) = VCC(Y) = 1.1 V to 3.6 V LOW-level output VI = VIL voltage IO = 20 μA; VCC(A) = VCC(Y) = 1.1 V to 3.6 V II input leakage current IOFF power-off leakage A input; VI = 0 V to 3.6 V; VCC(A) = 0 V; VCC(Y) = 0 V to 3.6 V current ΔIOFF ICC supply current VI = 0 V to 3.6 V; VCC(A) = VCC(Y) = 1.1 V to 3.6 V Unit port A; VI = GND or VCC(A); IO = 0 A port Y; VI = GND or VCC(A); IO = 0 A - - 0.5 μA port A and port Y; VI = GND or VCC(A); IO = 0 A; VCC(A) = VCC(Y) = 1.1 V to 3.6 V - - 0.5 μA A input; VCC(A) = 3.3 V; VCC(Y) = 0 V to 3.6 V; VI = VCC(A) - 0.6 V - - 40 μA ΔICC additional supply current CI input capacitance A input; VCC(A) = VCC(Y) = 0 V to 3.6 V; VI = GND or VCC(A) - 1.0 - pF CO output capacitance - 1.8 - pF 74AUP1T34 Product data sheet Y output; VO = GND; VCC(Y) = 0 V; VCC(A) = 0 V to 3.6 V All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 January 2019 © Nexperia B.V. 2019. All rights reserved 5 / 22 74AUP1T34 Nexperia Low-power dual supply translating buffer Symbol Parameter Conditions Min Typ Max Unit VCC(A) = 1.1 V to 1.95 V; VCC(Y) = 1.1 V to 3.6 V 0.65VCC(A) - - V VCC(A) = 2.3 V to 2.7 V; VCC(Y) = 1.1 V to 3.6 V 1.6 - - V VCC(A) = 3.0 V to 3.6 V; VCC(Y) = 1.1 V to 3.6 V 2.0 - - V VCC(A) = 1.1 V to 1.95 V; VCC(Y) = 1.1 V to 3.6 V - - VCC(A) = 2.3 V to 2.7 V; VCC(Y) = 1.1 V to 3.6 V - - 0.7 V VCC(A) = 3.0 V to 3.6 V; VCC(Y) = 1.1 V to 3.6 V - - 0.9 V VCC(Y) - 0.1 - - V IO = -1.1 mA; VCC(A) = VCC(Y) = 1.1 V 0.7VCC(Y) - - V IO = -1.7 mA; VCC(A) = VCC(Y) = 1.4 V 1.03 - - V IO = -1.9 mA; VCC(A) = VCC(Y) = 1.65 V 1.30 - - V IO = -2.3 mA; VCC(A) = VCC(Y) = 2.3 V 1.97 - - V IO = -3.1 mA; VCC(A) = VCC(Y) = 2.3 V 1.85 - - V IO = -2.7 mA; VCC(A) = VCC(Y) = 3.0 V 2.67 - - V IO = -4.0 mA; VCC(A) = VCC(Y) = 3.0 V 2.55 - - V Tamb = -40 °C to +85 °C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output VI = VIH voltage IO = -20 μA; VCC(A) = VCC(Y) = 1.1 V to 3.6 V LOW-level output VI = VIL voltage IO = 20 μA; VCC(A) = VCC(Y) = 1.1 V to 3.6 V - - 0.1 V IO = 1.1 mA; VCC(A) = VCC(Y) = 1.1 V - - 0.3VCC(Y) V IO = 1.7 mA; VCC(A) = VCC(Y) = 1.4 V - - 0.37 V IO = 1.9 mA; VCC(A) = VCC(Y) = 1.65 V - - 0.35 V IO = 2.3 mA; VCC(A) = VCC(Y) = 2.3 V - - 0.33 V IO = 3.1 mA; VCC(A) = VCC(Y) = 2.3 V - - 0.45 V IO = 2.7 mA; VCC(A) = VCC(Y) = 3.0 V - - 0.33 V IO = 4.0 mA; VCC(A) = VCC(Y) = 3.0 V - - 0.45 V - - ±0.5 μA - - ±0.5 μA Y output; VO = 0 V to 3.6 V; VCC(A) = 0 V to 3.6 V; VI = 0 V or 3.6 V; VCC(Y) = 0 V - - ±0.5 μA A input; VI = 0 V to 3.6 V; VCC(A) = 0 V to 0.2 V; additional power-off leakage VCC(Y) = 0 V to 3.6 V current Y output; VO = 0 V to 3.6 V; VCC(A) = 0 V to 3.6 V; VI = 0 V or 3.6 V; VCC(Y) = 0 V to 0.2 V - - ±0.6 μA - - ±0.6 μA II input leakage current IOFF power-off leakage A input; VI = 0 V to 3.6 V; VCC(A) = 0 V; VCC(Y) = 0 V to 3.6 V current ΔIOFF 0.35VCC(A) V 74AUP1T34 Product data sheet VI = 0 V to 3.6 V; VCC(A) = VCC(Y) = 1.1 V to 3.6 V All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 January 2019 © Nexperia B.V. 2019. All rights reserved 6 / 22 74AUP1T34 Nexperia Low-power dual supply translating buffer Symbol Parameter Conditions ICC port A; VI = GND or VCC(A); IO = 0 A supply current Min Typ Max Unit VCC(A) = VCC(Y) = 1.1 V to 3.6 V - - 0.9 μA VCC(A) = 3.6 V; VCC(Y) = 0 V - - 0.9 μA VCC(A) = 0 V; VCC(Y) = 3.6 V - 0.0 - μA VCC(A) = VCC(Y) = 1.1 V to 3.6 V - - 0.9 μA VCC(A) = 3.6 V; VCC(Y) = 0 V - 0.0 - μA VCC(A) = 0 V; VCC(Y) = 3.6 V port Y; VI = GND or VCC(A); IO = 0 A ΔICC additional supply current - - 0.9 μA port A and port Y; VI = GND or VCC(A); IO = 0 A; VCC(A) = VCC(Y) = 1.1 V to 3.6 V - - 0.9 μA A input; VCC(A) = 3.3 V; VCC(Y) = 0 V to 3.6 V; VI = VCC(A) - 0.6 V - - 50 μA VCC(A) = 1.1 V to 1.95 V; VCC(Y) = 1.1 V to 3.6 V 0.7VCC(A) - - V VCC(A) = 2.3 V to 2.7 V; VCC(Y) = 1.1 V to 3.6 V 1.6 - - V VCC(A) = 3.0 V to 3.6 V; VCC(Y) = 1.1 V to 3.6 V 2.0 - - V VCC(A) = 1.1 V to 1.95 V; VCC(Y) = 1.1 V to 3.6 V - - 0.3VCC(A) V VCC(A) = 2.3 V to 2.7 V; VCC(Y) = 1.1 V to 3.6 V - - 0.7 V VCC(A) = 3.0 V to 3.6 V; VCC(Y) = 1.1 V to 3.6 V - - 0.9 V VCC(Y) - 0.11 - - V IO = -1.1 mA; VCC(A) = VCC(Y) = 1.1 V 0.6VCC(Y) - - V IO = -1.7 mA; VCC(A) = VCC(Y) = 1.4 V 0.93 - - V IO = -1.9 mA; VCC(A) = VCC(Y) = 1.65 V 1.17 - - V IO = -2.3 mA; VCC(A) = VCC(Y) = 2.3 V 1.77 - - V IO = -3.1 mA; VCC(A) = VCC(Y) = 2.3 V 1.67 - - V IO = -2.7 mA; VCC(A) = VCC(Y) = 3.0 V 2.40 - - V IO = -4.0 mA; VCC(A) = VCC(Y) = 3.0 V 2.30 - - V - - 0.11 V IO = 1.1 mA; VCC(A) = VCC(Y) = 1.1 V - - IO = 1.7 mA; VCC(A) = VCC(Y) = 1.4 V - - 0.41 V IO = 1.9 mA; VCC(A) = VCC(Y) = 1.65 V - - 0.39 V IO = 2.3 mA; VCC(A) = VCC(Y) = 2.3 V - - 0.36 V IO = 3.1 mA; VCC(A) = VCC(Y) = 2.3 V - - 0.50 V IO = 2.7 mA; VCC(A) = VCC(Y) = 3.0 V - - 0.36 V IO = 4.0 mA; VCC(A) = VCC(Y) = 3.0 V - - 0.50 V Tamb = -40 °C to +125 °C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output VI = VIH voltage IO = -20 μA; VCC(A) = VCC(Y) = 1.1 V to 3.6 V LOW-level output VI = VIL voltage IO = 20 μA; VCC(A) = VCC(Y) = 1.1 V to 3.6 V 74AUP1T34 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 January 2019 0.33VCC(Y) V © Nexperia B.V. 2019. All rights reserved 7 / 22 74AUP1T34 Nexperia Low-power dual supply translating buffer Symbol Parameter Conditions II input leakage current VI = 0 V to 3.6 V; VCC(A) = VCC(Y) = 1.1 V to 3.6 V IOFF power-off leakage A input; VI = 0 V to 3.6 V; VCC(A) = 0 V; VCC(Y) = 0 V to 3.6 V current ΔIOFF ICC Min Typ Max Unit - - ±0.75 μA - - ±0.75 μA Y output; VO = 0 V to 3.6 V; VCC(A) = 0 V to 3.6 V; VI = 0 V or 3.6 V; VCC(Y) = 0 V - - ±0.75 μA A input; VI = 0 V to 3.6 V; VCC(A) = 0 V to 0.2 V; additional power-off leakage VCC(Y) = 0 V to 3.6 V current Y output; VO = 0 V to 3.6 V; VCC(A) = 0 V to 3.6 V; VI = 0 V or 3.6 V; VCC(Y) = 0 V to 0.2 V - - ±0.75 μA - - ±0.75 μA VCC(A) = VCC(Y) = 1.1 V to 3.6 V - - 1.4 μA VCC(A) = 3.6 V; VCC(Y) = 0 V - - 1.4 μA VCC(A) = 0 V; VCC(Y) = 3.6 V - 0.0 - μA supply current port A; VI = GND or VCC(A); IO = 0 A port Y; VI = GND or VCC(A); IO = 0 A ΔICC additional supply current VCC(A) = VCC(Y) = 1.1 V to 3.6 V - - 1.4 μA VCC(A) = 3.6 V; VCC(Y) = 0 V - 0.0 - μA VCC(A) = 0 V; VCC(Y) = 3.6 V - - 1.4 μA port A and port Y; VI = GND or VCC(A); IO = 0 A; VCC(A) = VCC(Y) = 1.1 V to 3.6 V - - 1.4 μA A input; VCC(A) = 3.3 V; VCC(Y) = 0 V to 3.6 V; VI = VCC(A) - 0.6 V - - 75 μA 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 9. Symbol Parameter Conditions 25 °C -40 °C to +125 °C Unit Min Typ [1] Max Min Max Max (85 °C) (125 °C) VCC(Y) = 1.1 V to 1.3 V 2.6 9.8 25.4 2.3 25.9 25.9 ns VCC(Y) = 1.4 V to 1.6 V 2.4 7.1 15.3 2.2 16.3 16.7 ns VCC(Y) = 1.65 V to 1.95 V 2.1 6.0 12.7 1.9 13.8 14.3 ns VCC(Y) = 2.3 V to 2.7 V 2.0 5.1 9.8 2.0 10.5 10.9 ns VCC(Y) = 3.0 V to 3.6 V 2.1 4.7 8.8 1.9 9.1 9.3 ns VCC(Y) = 1.1 V to 1.3 V 2.3 9.1 23.9 2.0 24.5 24.5 ns VCC(Y) = 1.4 V to 1.6 V 2.1 6.4 13.6 1.9 14.7 15.2 ns VCC(Y) = 1.65 V to 1.95 V 1.8 5.3 10.9 1.6 12.1 12.6 ns VCC(Y) = 2.3 V to 2.7 V 1.7 4.3 7.8 1.6 8.7 9.2 ns VCC(Y) = 3.0 V to 3.6 V 1.8 3.9 6.6 1.6 7.1 7.5 ns CL = 5 pF; VCC(A) = 1.1 V to 1.3 V tpd propagation delay A to Y; see Fig. 8 [2] CL = 5 pF; VCC(A) = 1.4 V to 1.6 V tpd propagation delay 74AUP1T34 Product data sheet A to Y; see Fig. 8 [2] All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 January 2019 © Nexperia B.V. 2019. All rights reserved 8 / 22 74AUP1T34 Nexperia Low-power dual supply translating buffer Symbol Parameter Conditions 25 °C -40 °C to +125 °C Unit Min Typ [1] Max Min Max Max (85 °C) (125 °C) VCC(Y) = 1.1 V to 1.3 V 2.2 8.8 23.2 1.9 23.9 24.0 ns VCC(Y) = 1.4 V to 1.6 V 2.0 6.0 13.0 1.8 14.1 14.6 ns VCC(Y) = 1.65 V to 1.95 V 1.8 4.9 10.3 1.5 11.4 12.0 ns VCC(Y) = 2.3 V to 2.7 V 1.6 3.9 7.2 1.5 8.0 8.5 ns VCC(Y) = 3.0 V to 3.6 V 1.7 3.5 5.9 1.5 6.4 6.8 ns VCC(Y) = 1.1 V to 1.3 V 2.2 8.4 22.8 1.9 23.4 23.4 ns VCC(Y) = 1.4 V to 1.6 V 1.9 5.7 12.3 1.8 13.4 14.0 ns VCC(Y) = 1.65 V to 1.95 V 1.7 4.6 9.6 1.5 10.7 11.2 ns VCC(Y) = 2.3 V to 2.7 V 1.5 3.5 6.3 1.5 7.2 7.7 ns VCC(Y) = 3.0 V to 3.6 V 1.6 3.1 5.1 1.4 5.6 6.0 ns VCC(Y) = 1.1 V to 1.3 V 2.2 8.1 22.5 1.9 22.9 22.9 ns VCC(Y) = 1.4 V to 1.6 V 1.9 5.4 12.0 1.8 12.9 13.4 ns VCC(Y) = 1.65 V to 1.95 V 1.7 4.3 9.2 1.5 10.2 10.7 ns VCC(Y) = 2.3 V to 2.7 V 1.5 3.3 6.0 1.5 6.7 7.2 ns VCC(Y) = 3.0 V to 3.6 V 1.6 2.9 4.8 1.4 5.2 5.5 ns VCC(Y) = 1.1 V to 1.3 V 2.6 10.7 27.1 2.5 27.6 27.6 ns VCC(Y) = 1.4 V to 1.6 V 2.6 7.7 16.7 2.3 17.5 17.6 ns VCC(Y) = 1.65 V to 1.95 V 2.7 6.6 13.4 2.4 14.2 14.7 ns VCC(Y) = 2.3 V to 2.7 V 2.2 5.6 10.3 2.2 11.0 11.4 ns VCC(Y) = 3.0 V to 3.6 V 2.5 5.3 9.5 2.2 9.7 10.0 ns VCC(Y) = 1.1 V to 1.3 V 2.4 10.0 25.6 2.2 26.1 26.1 ns VCC(Y) = 1.4 V to 1.6 V 2.4 7.0 15.0 2.0 15.8 16.4 ns VCC(Y) = 1.65 V to 1.95 V 2.4 5.9 11.6 2.1 12.5 13.1 ns VCC(Y) = 2.3 V to 2.7 V 2.0 4.8 8.4 1.9 9.2 9.7 ns VCC(Y) = 3.0 V to 3.6 V 2.2 4.4 7.4 1.9 7.7 8.1 ns VCC(Y) = 1.1 V to 1.3 V 2.3 9.7 24.8 2.1 25.5 25.7 ns VCC(Y) = 1.4 V to 1.6 V 2.3 6.6 14.3 2.0 15.3 15.8 ns VCC(Y) = 1.65 V to 1.95 V 2.3 5.5 11.0 2.0 11.9 12.5 ns VCC(Y) = 2.3 V to 2.7 V 1.9 4.4 7.7 1.8 8.6 9.0 ns VCC(Y) = 3.0 V to 3.6 V 2.1 4.0 6.6 1.8 7.1 7.4 ns CL = 5 pF; VCC(A) = 1.65 V to 1.95 V tpd propagation delay A to Y; see Fig. 8 [2] CL = 5 pF; VCC(A) = 2.3 V to 2.7 V tpd propagation delay A to Y; see Fig. 8 [2] CL = 5 pF; VCC(A) = 3.0 V to 3.6 V tpd propagation delay A to Y; see Fig. 8 [2] CL = 10 pF; VCC(A) = 1.1 V to 1.3 V tpd propagation delay A to Y; see Fig. 8 [2] CL = 10 pF; VCC(A) = 1.4 V to 1.6 V tpd propagation delay A to Y; see Fig. 8 [2] CL = 10 pF; VCC(A) = 1.65 V to 1.95 V tpd propagation delay 74AUP1T34 Product data sheet A to Y; see Fig. 8 [2] All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 January 2019 © Nexperia B.V. 2019. All rights reserved 9 / 22 74AUP1T34 Nexperia Low-power dual supply translating buffer Symbol Parameter Conditions 25 °C -40 °C to +125 °C Unit Min Typ [1] Max Min Max Max (85 °C) (125 °C) VCC(Y) = 1.1 V to 1.3 V 2.3 9.3 24.4 2.1 25.1 25.1 ns VCC(Y) = 1.4 V to 1.6 V 2.2 6.3 13.6 1.9 14.6 15.1 ns VCC(Y) = 1.65 V to 1.95 V 2.2 5.1 10.3 2.0 11.2 11.7 ns VCC(Y) = 2.3 V to 2.7 V 1.8 4.1 6.9 1.8 7.7 8.2 ns VCC(Y) = 3.0 V to 3.6 V 2.0 3.6 5.8 1.7 6.3 6.6 ns VCC(Y) = 1.1 V to 1.3 V 2.3 9.0 24.2 2.1 24.6 24.6 ns VCC(Y) = 1.4 V to 1.6 V 2.2 6.0 13.3 1.9 14.1 14.6 ns VCC(Y) = 1.65 V to 1.95 V 2.2 4.9 9.9 2.0 10.6 11.2 ns VCC(Y) = 2.3 V to 2.7 V 1.8 3.9 6.5 1.8 7.3 7.7 ns VCC(Y) = 3.0 V to 3.6 V 2.0 3.5 5.4 1.7 5.8 6.2 ns VCC(Y) = 1.1 V to 1.3 V 3.0 11.5 28.6 2.8 29.2 29.2 ns VCC(Y) = 1.4 V to 1.6 V 3.1 8.3 17.3 2.7 18.6 19.1 ns VCC(Y) = 1.65 V to 1.95 V 2.8 7.1 14.1 2.7 15.2 15.8 ns VCC(Y) = 2.3 V to 2.7 V 2.6 6.1 11.1 2.7 11.6 12.1 ns VCC(Y) = 3.0 V to 3.6 V 2.9 5.7 9.9 2.6 10.3 10.6 ns VCC(Y) = 1.1 V to 1.3 V 2.8 10.8 27.1 2.6 27.7 27.7 ns VCC(Y) = 1.4 V to 1.6 V 2.8 7.6 15.7 2.4 17.0 17.6 ns VCC(Y) = 1.65 V to 1.95 V 2.5 6.3 12.3 2.4 13.5 14.1 ns VCC(Y) = 2.3 V to 2.7 V 2.3 5.3 9.2 2.4 9.9 10.3 ns VCC(Y) = 3.0 V to 3.6 V 2.6 4.9 7.8 2.3 8.3 8.7 ns VCC(Y) = 1.1 V to 1.3 V 2.7 10.5 26.4 2.5 27.1 27.3 ns VCC(Y) = 1.4 V to 1.6 V 2.7 7.2 15.0 2.3 16.4 17.0 ns VCC(Y) = 1.65 V to 1.95 V 2.4 6.0 11.7 2.3 12.8 13.5 ns VCC(Y) = 2.3 V to 2.7 V 2.2 4.9 8.5 2.2 9.2 9.7 ns VCC(Y) = 3.0 V to 3.6 V 2.5 4.5 7.1 2.2 7.7 8.0 ns VCC(Y) = 1.1 V to 1.3 V 2.6 10.1 26.0 2.4 26.7 26.7 ns VCC(Y) = 1.4 V to 1.6 V 2.7 6.9 14.3 2.3 15.7 16.3 ns VCC(Y) = 1.65 V to 1.95 V 2.4 5.6 10.9 2.2 12.1 12.7 ns VCC(Y) = 2.3 V to 2.7 V 2.1 4.5 7.6 2.2 8.4 8.9 ns VCC(Y) = 3.0 V to 3.6 V 2.4 4.1 6.2 2.1 6.8 7.2 ns CL = 10 pF; VCC(A) = 2.3 V to 2.7 V tpd propagation delay A to Y; see Fig. 8 [2] CL = 10 pF; VCC(A) = 3.0 V to 3.6 V tpd propagation delay A to Y; see Fig. 8 [2] CL = 15 pF; VCC(A) = 1.1 V to 1.3 V tpd propagation delay A to Y; see Fig. 8 [2] CL = 15 pF; VCC(A) = 1.4 V to 1.6 V tpd propagation delay A to Y; see Fig. 8 [2] CL = 15 pF; VCC(A) = 1.65 V to 1.95 V tpd propagation delay A to Y; see Fig. 8 [2] CL = 15 pF; VCC(A) = 2.3 V to 2.7 V tpd propagation delay 74AUP1T34 Product data sheet A to Y; see Fig. 8 [2] All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 January 2019 © Nexperia B.V. 2019. All rights reserved 10 / 22 74AUP1T34 Nexperia Low-power dual supply translating buffer Symbol Parameter Conditions 25 °C -40 °C to +125 °C Unit Min Typ [1] Max Min Max Max (85 °C) (125 °C) VCC(Y) = 1.1 V to 1.3 V 2.6 9.8 25.7 2.4 26.2 26.2 ns VCC(Y) = 1.4 V to 1.6 V 2.7 6.6 14.0 2.3 15.2 15.7 ns VCC(Y) = 1.65 V to 1.95 V 2.4 5.4 10.5 2.2 11.6 12.1 ns VCC(Y) = 2.3 V to 2.7 V 2.1 4.3 7.3 2.2 7.9 8.4 ns VCC(Y) = 3.0 V to 3.6 V 2.4 3.9 5.9 2.1 6.4 6.8 ns VCC(Y) = 1.1 V to 1.3 V 3.7 13.7 32.9 3.5 33.5 33.5 ns VCC(Y) = 1.4 V to 1.6 V 3.6 9.8 19.5 3.6 20.9 21.4 ns VCC(Y) = 1.65 V to 1.95 V 3.7 8.4 15.9 3.5 17.0 17.7 ns VCC(Y) = 2.3 V to 2.7 V 3.0 7.2 12.2 3.4 12.7 13.2 ns VCC(Y) = 3.0 V to 3.6 V 3.8 6.8 10.9 3.4 12.2 12.5 ns VCC(Y) = 1.1 V to 1.3 V 3.5 13.1 31.5 3.2 32.0 32.0 ns VCC(Y) = 1.4 V to 1.6 V 3.3 9.1 17.8 3.3 19.2 19.9 ns VCC(Y) = 1.65 V to 1.95 V 3.4 7.6 14.2 3.2 15.4 16.0 ns VCC(Y) = 2.3 V to 2.7 V 2.8 6.4 10.3 3.1 11.0 11.5 ns VCC(Y) = 3.0 V to 3.6 V 3.5 5.9 8.9 3.1 10.1 10.5 ns VCC(Y) = 1.1 V to 1.3 V 3.4 12.7 30.7 3.1 31.5 31.5 ns VCC(Y) = 1.4 V to 1.6 V 3.2 8.8 17.2 3.2 18.7 19.3 ns VCC(Y) = 1.65 V to 1.95 V 3.3 7.3 13.5 3.1 14.7 15.4 ns VCC(Y) = 2.3 V to 2.7 V 2.7 6.0 9.6 3.0 10.4 10.9 ns VCC(Y) = 3.0 V to 3.6 V 3.4 5.6 8.2 2.9 9.4 9.8 ns VCC(Y) = 1.1 V to 1.3 V 3.3 12.4 30.3 3.1 31.0 31.0 ns VCC(Y) = 1.4 V to 1.6 V 3.2 8.4 16.5 3.1 18.0 18.7 ns VCC(Y) = 1.65 V to 1.95 V 3.2 6.9 12.8 3.0 14.0 14.6 ns VCC(Y) = 2.3 V to 2.7 V 2.6 5.6 8.8 2.9 9.6 10.1 ns VCC(Y) = 3.0 V to 3.6 V 3.3 5.2 7.3 2.9 8.5 9.0 ns VCC(Y) = 1.1 V to 1.3 V 3.3 12.0 30.0 3.1 30.5 30.5 ns VCC(Y) = 1.4 V to 1.6 V 3.2 8.1 16.2 3.1 17.5 18.1 ns VCC(Y) = 1.65 V to 1.95 V 3.2 6.7 12.4 3.0 13.4 14.1 ns VCC(Y) = 2.3 V to 2.7 V 2.6 5.5 8.5 2.9 9.1 9.6 ns VCC(Y) = 3.0 V to 3.6 V 3.2 5.0 7.0 2.9 8.1 8.5 ns CL = 15 pF; VCC(A) = 3.0 V to 3.6 V tpd propagation delay A to Y; see Fig. 8 [2] CL = 30 pF; VCC(A) = 1.1 V to 1.3 V tpd propagation delay A to Y; see Fig. 8 [2] CL = 30 pF; VCC(A) = 1.4 V to 1.6 V tpd propagation delay A to Y; see Fig. 8 [2] CL = 30 pF; VCC(A) = 1.65 V to 1.95 V tpd propagation delay A to Y; see Fig. 8 [2] CL = 30 pF; VCC(A) = 2.3 V to 2.7 V tpd propagation delay A to Y; see Fig. 8 [2] CL = 30 pF; VCC(A) = 3.0 V to 3.6 V tpd propagation delay 74AUP1T34 Product data sheet A to Y; see Fig. 8 [2] All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 January 2019 © Nexperia B.V. 2019. All rights reserved 11 / 22 74AUP1T34 Nexperia Low-power dual supply translating buffer Symbol Parameter Conditions 25 °C -40 °C to +125 °C Unit Min Typ [1] Max Min Max Max (85 °C) (125 °C) VCC(A) = VCC(Y) = 1.2 V - 3.8 - - - - pF VCC(A) = VCC(Y) = 1.5 V - 3.8 - - - - pF VCC(A) = VCC(Y) = 1.8 V - 4.1 - - - - pF VCC(A) = VCC(Y) = 2.5 V - 4.2 - - - - pF VCC(A) = VCC(Y) = 3.3 V - 4.6 - - - - pF CL = 5 pF, 10 pF, 15 pF and 30 pF CPD [1] [2] [3] [4] power dissipation capacitance fi = 1 MHz; VI = GND to VCC(A) [3][4] All typical values are measured at nominal VCC. tpd is the same as tPLH and tPHL. All specified values are the average typical values over all stated loads. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of the outputs. 11.1. Waveforms and test circuit VI VM A input GND t PHL t PLH VOH VM Y output VOL mnb153 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage drop that occur with the output load. Fig. 8. The data input (A) to output (Y) propagation delays Table 9. Measurement points Supply voltage Output Input VCC(A)/VCC(Y) VM VM VI tr = tf 1.1 V to 3.6 V 0.5 × VCC(Y) 0.5 × VCC(A) VCC(A) ≤ 3.0 ns 74AUP1T34 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 January 2019 © Nexperia B.V. 2019. All rights reserved 12 / 22 74AUP1T34 Nexperia Low-power dual supply translating buffer VCCA PULSE GENERATOR VI VCCY DUT VEXT 5 kΩ VO RT CL RL 001aad742 Test data is given in Table 10. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 9. Test circuit for measuring switching times Table 10. Test data Supply voltage Load VCC(A)/VCC(Y) CL RL [1] tPLH, tPHL 1.1 V to 3.6 V 5 pF, 10 pF, 15 pF and 30 pF 5 kΩ or 1 MΩ open [1] VEXT For measuring enable and disable times RL = 5 kΩ. For measuring propagation delays, setup and hold times and pulse width RL = 1 MΩ. 74AUP1T34 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 January 2019 © Nexperia B.V. 2019. All rights reserved 13 / 22 74AUP1T34 Nexperia Low-power dual supply translating buffer 12. Package outline TSSOP5: plastic thin shrink small outline package; 5 leads; body width 1.25 mm D E SOT353-1 A X c y HE v M A Z 5 4 A2 A (A3) A1 θ 1 Lp 3 e e1 L w M bp detail X 0 1.5 3 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D(1) E(1) e e1 HE L Lp v w y Z(1) θ mm 1.1 0.1 0 1.0 0.8 0.15 0.30 0.15 0.25 0.08 2.25 1.85 1.35 1.15 0.65 1.3 2.25 2.0 0.425 0.46 0.21 0.3 0.1 0.1 0.60 0.15 7° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT353-1 REFERENCES IEC JEDEC JEITA MO-203 SC-88A EUROPEAN PROJECTION ISSUE DATE 00-09-01 03-02-19 Fig. 10. Package outline SOT353-1 (TSSOP5) 74AUP1T34 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 January 2019 © Nexperia B.V. 2019. All rights reserved 14 / 22 74AUP1T34 Nexperia Low-power dual supply translating buffer SOT886 XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm b 1 2 3 4x (2) L L1 e 6 5 e1 4 e1 6x A (2) A1 D E terminal 1 index area 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 0.5 A1 b D E 0.04 0.25 1.50 1.05 0.20 1.45 1.00 0.17 1.40 0.95 e e1 0.6 0.5 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. Outline version SOT886 sot886_po References IEC JEDEC JEITA European projection Issue date 04-07-22 12-01-05 MO-252 Fig. 11. Package outline SOT886 (XSON6) 74AUP1T34 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 January 2019 © Nexperia B.V. 2019. All rights reserved 15 / 22 74AUP1T34 Nexperia Low-power dual supply translating buffer XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1 x 0.5 mm 1 SOT891 b 3 2 4× (1) L L1 e 6 5 4 e1 e1 6× A (1) A1 D E terminal 1 index area 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max A1 max b D E e e1 L L1 mm 0.5 0.04 0.20 0.12 1.05 0.95 1.05 0.95 0.55 0.35 0.35 0.27 0.40 0.32 Note 1. Can be visible in some manufacturing processes. OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 05-04-06 07-05-15 SOT891 Fig. 12. Package outline SOT891 (XSON6) 74AUP1T34 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 January 2019 © Nexperia B.V. 2019. All rights reserved 16 / 22 74AUP1T34 Nexperia Low-power dual supply translating buffer XSON6: extremely thin small outline package; no leads; 6 terminals; body 0.9 x 1.0 x 0.35 mm 1 SOT1115 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e max 0.35 0.04 0.20 0.95 1.05 nom 0.15 0.90 1.00 0.55 min 0.12 0.85 0.95 e1 0.3 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1115_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-07 SOT1115 Fig. 13. Package outline SOT1115 (XSON6) 74AUP1T34 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 January 2019 © Nexperia B.V. 2019. All rights reserved 17 / 22 74AUP1T34 Nexperia Low-power dual supply translating buffer XSON6: extremely thin small outline package; no leads; 6 terminals; body 1.0 x 1.0 x 0.35 mm 1 SOT1202 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.05 1.05 0.35 0.40 nom 0.15 1.00 1.00 0.55 0.35 0.30 0.35 min 0.12 0.95 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1202_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1202 Fig. 14. Package outline SOT1202 (XSON6) 74AUP1T34 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 January 2019 © Nexperia B.V. 2019. All rights reserved 18 / 22 74AUP1T34 Nexperia Low-power dual supply translating buffer X2SON5: plastic thermal enhanced extremely thin small outline package; no leads; 5 terminals; body 0.8 x 0.8 x 0.35 mm D A B SOT1226 X A E A1 A3 detail X terminal 1 index area e v w b 1 2 terminal 1 index area C C A B C y1 C y k D h 3 L 5 4 0 1 mm scale Dimensions Unit mm A(1) A1 A3 D Dh E b e k L max 0.35 0.04 0.128 0.85 0.30 0.85 0.27 0.27 nom 0.80 0.25 0.80 0.22 0.48 0.22 min 0.040 0.75 0.20 0.75 0.17 0.20 0.17 v 0.1 w y y1 0.05 0.05 0.05 Note 1. Dimension A is including plating thickness. 2. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Outline version References IEC JEDEC EIAJ sot1226_po European projection Issue date 12-04-10 12-04-25 SOT1226 Fig. 15. Package outline SOT1226 (X2SON5) 74AUP1T34 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 January 2019 © Nexperia B.V. 2019. All rights reserved 19 / 22 74AUP1T34 Nexperia Low-power dual supply translating buffer 13. Abbreviations Table 11. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 14. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AUP1T34 v.6 20190128 Product data sheet - Modifications: • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. 74AUP1T34 v.5 20130904 Modifications: • 74AUP1T34 v.4 20120316 Modifications: • 74AUP1T34 v.3 20111128 Modifications: • 74AUP1T34 v.2 20100819 74AUP1T34 v.1 20061204 74AUP1T34 Product data sheet 74AUP1T34 v.5 Product data sheet - 74AUP1T34 v.4 Added type number 74AUP1T34GX (SOT1226) Product data sheet - 74AUP1T34 v.3 Package outline drawing of SOT886 (Fig. 11) modified. Product data sheet - 74AUP1T34 v.2 Product data sheet - 74AUP1T34 v.1 Product data sheet - - Legal pages updated. All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 January 2019 © Nexperia B.V. 2019. All rights reserved 20 / 22 74AUP1T34 Nexperia Low-power dual supply translating buffer 15. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74AUP1T34 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 January 2019 © Nexperia B.V. 2019. All rights reserved 21 / 22 74AUP1T34 Nexperia Low-power dual supply translating buffer Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................2 4. Marking.......................................................................... 2 5. Functional diagram.......................................................2 6. Pinning information......................................................3 6.1. Pinning.........................................................................3 6.2. Pin description............................................................. 3 7. Functional description................................................. 3 8. Limiting values............................................................. 4 9. Recommended operating conditions..........................4 10. Static characteristics..................................................4 11. Dynamic characteristics.............................................8 11.1. Waveforms and test circuit.......................................12 12. Package outline........................................................ 14 13. Abbreviations............................................................ 20 14. Revision history........................................................20 15. Legal information......................................................21 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 28 January 2019 74AUP1T34 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 28 January 2019 © Nexperia B.V. 2019. All rights reserved 22 / 22
74AUP1T34GS,132
物料型号:74AUP1T34
器件简介: 74AUP1T34是一款低功耗双电源转换缓冲器,提供单个缓冲器并具有两个独立的电源电压。输入A设计为跟踪VCC(A),输出Y设计为跟踪VCC(Y)。VCC(A)和VCC(Y)均可接受1.1V至3.6V的任何电源电压,允许在1.2V、1.5V、1.8V、2.5V和3.3V电压节点之间进行通用的低电压接口。
引脚分配: - VCC(A):电源电压端口A - A:数据输入A - GND:地(0V) - Y:数据输出Y - n.c.:不连接
参数特性: - 宽电源电压范围:1.1V至3.6V - 高噪声容限 - 符合JEDEC标准 - ESD保护等级:HBM Class 3A超过5000V,MM超过200V,CDM超过1000V - 低静态功耗:ICC最大为0.9µA - 输入可接受高达3.6V的电压 - IOFF电路提供部分断电模式操作
功能详解: - Schmitt触发器动作在所有输入上,使电路在1.1V至3.6V的整个VCC范围内对输入上升和下降时间的变化具有容忍度。 - 确保在整个VCC范围内具有非常低的静态和动态功耗。 - 完全规范用于使用IOFF的部分断电应用。
应用信息: - 指定在-40°C至+85°C和-40°C至+125°C的温度范围内使用。
封装信息: 提供多种封装选项,包括TSSOP5、XSON6、SOT353-1、SOT886、SOT891、SOT1115、SOT1202和X2SON5。
74AUP1T34GS,132 价格&库存
很抱歉,暂时无法提供与“74AUP1T34GS,132”相匹配的价格&库存,您可以联系我们找货
74AUP1T34GS,132
  • 5000+1.320585000+0.16561
  • 10000+1.2869910000+0.16139
  • 15000+1.2701715000+0.15928
  • 25000+1.2515325000+0.15695
  • 35000+1.2406435000+0.15558
  • 50000+1.2301650000+0.15427
库存:2313
74AUP1T34GS,132
  • 1+3.897961+0.48882
  • 10+2.7275210+0.34204
  • 25+2.4319925+0.30498
  • 100+2.10861100+0.26443
  • 250+1.95292250+0.24490
  • 500+1.85922500+0.23315
  • 1000+1.785641000+0.22393
库存:2313
74AUP1T34GS,132
