HEF4104BT-Q100J
HEF4104BT-Q100J
    NEXPERIA(安世)
    SOIC-16
    带3态输出的四路低到高电压转换器 SOIC16
HEF4104BT-Q100J 数据手册
HEF4104B-Q100 Quad low-to-high voltage translator with 3-state outputs Rev. 1 — 24 March 2014 Product data sheet 1. General description The HEF4104B-Q100 is a quad low voltage-to-high voltage translator with 3-state outputs. It provides the capability of interfacing low voltage circuits to high-voltage circuits. For example, low voltage Local Oxidation Complementary MOS (LOCMOS) and Transistor-Transistor Logic (TTL) to high-voltage LOCMOS. It has four data inputs (A0 to A3) and an active HIGH output enable input (OE). It also has four data outputs (B0 to B3) with their complements (B0 to B3). With OE = HIGH, the outputs B0 to B3 and B0 to B3 are in the low impedance ON-state. The inputs A0 to A3 determine whether it is HIGH or LOW. With OE = LOW, the outputs B0 to B3 and B0 to B3 are in the high-impedance OFF-state. It uses a common negative supply (VSS) and separate positive supplies for the inputs (VDD(A)) and the outputs (VDD(B)). VDD(A) must always be less than or equal to VDD(B), even during power turn-on and turn-off. For the permissible operating range of VDD(A) and VDD(B), see Figure 4. Each input protection circuit is terminated between VDD(B) and VSS. It allows the input signals to be driven from any potential between VDD(B) and VSS, without regard to current limiting. When driving from potentials greater than VDD(B) or less than VSS, the current at each input must be limited to 10 mA. It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 3) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 3)  Specified from 40 C to +85 C  Fully static operation  5 V, 10 V, and 15 V parametric ratings  Standardized symmetrical output characteristics  Inputs and outputs are protected against electrostatic effects  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Complies with JEDEC standard JESD 13-B HEF4104B-Q100 Nexperia Quad low-to-high voltage translator with 3-state outputs 3. Ordering information Table 1. Ordering information All types operate from 40 C to +85 C. Type number Package Name HEF4104BT-Q100 SO16 Description Version plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 4. Functional diagram VDD(A) VDD(B) 16 1 3 A0 4 B0 LEVEL CONVERTER A0 2 B0 B0 B0 A1 6 5 7 A2 11 LEVEL CONVERTER B1 LEVEL CONVERTER A1 B1 B1 LEVEL CONVERTER A2 10 B1 B2 B2 B2 9 A3 B2 LEVEL CONVERTER A3 12 13 B3 B3 LEVEL CONVERTER OE 14 OE 15 B3 B3 VDD(A) VDD(B) 001aag264 8 VSS Fig 1. Logic symbol HEF4104B_Q100 Product data sheet 001aag262 Fig 2. Logic diagram All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 March 2014 © Nexperia B.V. 2017. All rights reserved 2 of 14 HEF4104B-Q100 Nexperia Quad low-to-high voltage translator with 3-state outputs 5. Pinning information 5.1 Pinning +()%4 9'' %   9'' $ %   2( %   % $   % $   $ %   $ %   % 966   % DDD Fig 3. Pin configuration 5.2 Pin description Table 2. Pin description Symbol Pin Description VDD(B) 1 supply voltage port B B0 to B3 2, 7, 9, 14 complementary data output B0 to B3 3, 6, 10, 13 data output A0 to A3 4, 5, 11, 12 data input VSS 8 common negative supply voltage (0 V) OE 15 output enable input VDD(A) 16 supply voltage port A 6. Functional description Table 3. Function table[1] Control Output OE Bn Bn H An An L Z Z [1] H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. HEF4104B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 March 2014 © Nexperia B.V. 2017. All rights reserved 3 of 14 HEF4104B-Q100 Nexperia Quad low-to-high voltage translator with 3-state outputs 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to VSS = 0 V (ground). Symbol Parameter Conditions Min Max Unit VDD(A) supply voltage A port A; VDD(A)  VDD(B) 0.5 +18 V VDD(B) supply voltage B port B; VDD(B)  VDD(A) 0.5 +18 V IIK input clamping current VI < 0.5 V or VI > VDD(A) + 0.5 V - 10 mA VI input voltage 0.5 VDD(A) + 0.5 V IOK output clamping current - 10 - 10 mA - 50 mA 65 +150 C 40 +85 C II/O input/output current IDD supply current Tstg storage temperature Tamb ambient temperature VO < 0.5 V or VO > VDD(B) + 0.5 V [1] Ptot total power dissipation Tamb = 40 C to +85 C P power dissipation per output [1] IDD is the combined current of IDD(A) and IDD(B). [2] For SO16 packages: above Tamb = 70 C, Ptot derates linearly at 8 mW/K. [2] mA - 500 mW - 100 mW 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VDD(A) VDD(B) Min Typ supply voltage A 3 -  VDD(B) V supply voltage B  VDD(A) - 15 V VI input voltage 0 - VDD(A) V Tamb ambient temperature in free air 40 - +85 C t/V input transition rise and fall rate VDD(A) = 5 V - - 3.75 s/V VDD(A) = 10 V - - 0.5 s/V VDD(A) = 15 V - - 0.08 s/V HEF4104B_Q100 Product data sheet Conditions All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 March 2014 Max © Unit Nexperia B.V. 2017. All rights reserved 4 of 14 HEF4104B-Q100 Nexperia Quad low-to-high voltage translator with 3-state outputs 9. Static characteristics Table 6. Static characteristics VDD(A) = VDD(B); VSS = 0 V; VI = VSS or VDD(A); unless otherwise specified. Symbol Parameter Conditions Tamb = 40 C Tamb = +25 C Tamb = +85 C Unit VDD[1] Min HIGH-level input voltage VIH LOW-level input voltage VIL VOH VOL IO < 1 A LOW-level output voltage IO < 1 A LOW-level output current IOL supply current IDD OFF-state output current IOZ input capacitance CI Max 5V 3.5 - 3.5 - 3.5 - V 7.0 - 7.0 - 7.0 - V 15 V 11.0 - 11.0 - 11.0 - V 5V - 1.5 - 1.5 - 1.5 V 10 V - 3.0 - 3.0 - 3.0 V 15 V - 4.0 - 4.0 - 4.0 V 5V 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - V 5V - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 V 15 V - 0.05 - 0.05 - 0.05 V mA 5V - 1.7 - 1.4 - 1.1 5V - 0.52 - 0.44 - 0.36 mA VO = 9.5 V 10 V - 1.3 - 1.1 - 0.9 mA VO = 13.5 V 15 V - 3.6 - 3.0 - 2.4 mA VO = 0.4 V 5V 0.52 - 0.44 - 0.36 - mA VO = 0.5 V 10 V 1.3 - 1.1 - 0.9 - mA VO = 1.5 V 15 V 3.6 - 3.0 - 2.4 - mA - 0.3 - 0.3 - 1.0 A 15 V - 20 - 20 - 150 A 10 V - 40 - 40 - 300 A 15 V - 80 - 80 - 600 A HIGH level; VO = VDD(B) 15 V - 1.6 - 1.6 - 12.0 A LOW level; VO = VSS 15 V - 1.6 - 1.6 - 12.0 A digital inputs - - - - 7.5 - all valid input combinations; IO = 0 A [1] VDD is the same as VDD(A) and VDD(B). IDD is the combined current of IDD(A) and IDD(B). Product data sheet Min VO = 2.5 V [2] HEF4104B_Q100 Max VO = 4.6 V input leakage current II Min 10 V IO < 1 A HIGH-level output voltage HIGH-level output current IOH IO < 1 A Max 5V [2] All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 March 2014 © - pF Nexperia B.V. 2017. All rights reserved 5 of 14 HEF4104B-Q100 Nexperia Quad low-to-high voltage translator with 3-state outputs 001aag265 15 VDD(B) (V) operating area 10 5 0 0 5 10 15 VDD(A) (V) The shaded area shows the permissible operating range. Fig 4. VDD(B) as a function of VDD(A) 10. Dynamic characteristics Table 7. Dynamic characteristics Tamb = 25 C, unless otherwise specified. For test circuit, see Figure 7. Symbol Parameter tPHL tPLH tTHL tTLH tPHZ HIGH to LOW propagation delay LOW to HIGH propagation delay Extrapolation formula[1] Min Typ Max Unit VDD(A) = VDD(B) = 5 V 143 ns + (0.55 ns/pF)CL - 170 340 ns VDD(A) = VDD(B) = 10 V 69 ns + (0.23 ns/pF)CL - 80 160 ns VDD(A) = VDD(B) = 15 V 57 ns + (0.16 ns/pF)CL - 65 135 ns 143 ns + (0.55 ns/pF)CL - 170 340 ns VDD(A) = VDD(B) = 10 V 69 ns + (0.23 ns/pF)CL - 80 160 ns VDD(A) = VDD(B) = 15 V 62 ns + (0.16 ns/pF)CL - 70 140 ns 10 ns + (1.00 ns/pF)CL - 60 120 ns VDD(A) = VDD(B) = 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns VDD(A) = VDD(B) = 15 V 6 ns + (0.28 ns/pF)CL - 20 40 ns 10 ns + (1.00 ns/pF)CL - 60 120 ns VDD(A) = VDD(B) = 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns VDD(A) = VDD(B) = 15 V 6 ns + (0.28 ns/pF)CL - 20 40 ns VDD(A) = VDD(B) = 5 V - 70 135 ns VDD(A) = VDD(B) = 10 V - 55 110 ns VDD(A) = VDD(B) = 15 V - 60 120 ns Conditions An to Bn, Bn; see Figure 5 An to Bn, Bn; see Figure 5 VDD(A) = VDD(B) = 5 V HIGH to LOW output Bn or Bn; see Figure 6 transition time VDD(A) = VDD(B) = 5 V LOW to HIGH output Bn or Bn; see Figure 6 transition time VDD(A) = VDD(B) = 5 V HIGH to OFF-state propagation delay HEF4104B_Q100 Product data sheet OE to Bn, Bn; see Figure 6 All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 March 2014 © Nexperia B.V. 2017. All rights reserved 6 of 14 HEF4104B-Q100 Nexperia Quad low-to-high voltage translator with 3-state outputs Table 7. Dynamic characteristics …continued Tamb = 25 C, unless otherwise specified. For test circuit, see Figure 7. Extrapolation formula[1] Symbol Parameter Conditions tPLZ OE to Bn, Bn; see Figure 6 LOW to OFF-state propagation delay OFF-state to HIGH propagation delay tPZH OFF-state to LOW propagation delay tPZL [1] Min Typ Max Unit VDD(A) = VDD(B) = 5 V - 70 135 ns VDD(A) = VDD(B) = 10 V - 55 105 ns VDD(A) = VDD(B) = 15 V - 55 110 ns VDD(A) = VDD(B) = 5 V - 195 395 ns VDD(A) = VDD(B) = 10 V - 95 195 ns VDD(A) = VDD(B) = 15 V - 80 165 ns VDD(A) = VDD(B) = 5 V - 195 395 ns VDD(A) = VDD(B) = 10 V - 95 190 ns VDD(A) = VDD(B) = 15 V - 80 160 ns OE to Bn, Bn; see Figure 6 OE to Bn, Bn; see Figure 6 Typical value of the propagation delay and output transition time can be calculated with the extrapolation formula (CL in pF). Table 8. Dynamic power dissipation VDD(A) = VDD(B); VSS = 0 V; tr = tf  20 ns; Tamb = 25 C. Symbol Parameter dynamic power dissipation PD VDD[1] Typical formula (W) where 5V PD = 3000  fi + (fo  CL)  VDD 10 V PD = 12200  fi + (fo  CL)  VDD 15 V PD = 31000  fi + (fo  CL)  VDD2 2 fi = input frequency in MHz; 2 fo = output frequency in MHz; CL = output load capacitance in pF; (fo  CL) = sum of the outputs; VDD = supply voltage in V. [1] VDD is the same as VDD(A) and VDD(B). HEF4104B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 March 2014 © Nexperia B.V. 2017. All rights reserved 7 of 14 HEF4104B-Q100 Nexperia Quad low-to-high voltage translator with 3-state outputs 11. Waveforms VI An input VM 0V tPHL VOH tPLH VY Bn output VM VX VOL tTHL tTLH tPLH VOH tPHL VY Bn output VX VOL tTLH tTHL 001aaj783 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 5. Data input (An) to data output (Bn, Bn) propagation delays and output transition times VI OE input VM VSS tPLZ output LOW-to-OFF OFF-to-LOW tPZL VOH VY VX VOL tPHZ VOH tPZH VY output HIGH-to-OFF OFF-to-HIGH VX VOL outputs on outputs off outputs on 001aaj782 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 6. Table 9. Enable and disable times Measurement points Input Output VI VM VM VX VY VSS or VDD(A) 0.5VDD(A) 0.5VDD(B) 0.1VDD(B) 0.9VDD(B) HEF4104B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 March 2014 © Nexperia B.V. 2017. All rights reserved 8 of 14 HEF4104B-Q100 Nexperia Quad low-to-high voltage translator with 3-state outputs tW VI 90 % 90 % negative pulse VM VM 10 % 0V 10 % tf tr tr tf VI 90 % positive pulse 90 % VM VM 10 % 0V 10 % tW 001aaj781 a. Input waveforms VEXT VDD VI RL VO G DUT RT CL 001aaj915 b. Test circuit Test data given in Table 10. Definitions for test circuit: DUT = Device Under Test. CL = load capacitance including jig and probe capacitance. RL = load resistance. RT = termination resistance should be equal to the output impedance Zo of the pulse generator. Fig 7. Test circuit for measuring switching times Table 10. Test data Supplies Input Load VDD(A) = VDD(B) tr, tf RL CL tPHL, tPLH tPZL, tPLZ tPZH, tPHZ 5 V to 15 V  20 ns 1 k 50 pF open VDD(B) VSS HEF4104B_Q100 Product data sheet VEXT All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 March 2014 © Nexperia B.V. 2017. All rights reserved 9 of 14 HEF4104B-Q100 Nexperia Quad low-to-high voltage translator with 3-state outputs 12. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e 0 detail X w M bp 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.039 0.016 0.028 0.020 inches 0.010 0.057 0.069 0.004 0.049 0.16 0.15 0.05 0.244 0.041 0.228 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig 8. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT109-1 (SO16) HEF4104B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 March 2014 © Nexperia B.V. 2017. All rights reserved 10 of 14 HEF4104B-Q100 Nexperia Quad low-to-high voltage translator with 3-state outputs 13. Abbreviations Table 11. Abbreviations Acronym Description HBM Human Body Model ESD ElectroStatic Discharge MM Machine Model MIL Military 14. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes HEF4104B_Q100 v.1 20140324 Product data sheet - - HEF4104B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 March 2014 © Nexperia B.V. 2017. All rights reserved 11 of 14 HEF4104B-Q100 Nexperia Quad low-to-high voltage translator with 3-state outputs 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. HEF4104B_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 March 2014 © Nexperia B.V. 2017. All rights reserved 12 of 14 HEF4104B-Q100 Nexperia Quad low-to-high voltage translator with 3-state outputs No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com HEF4104B_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 24 March 2014 © Nexperia B.V. 2017. All rights reserved 13 of 14 HEF4104B-Q100 Nexperia Quad low-to-high voltage translator with 3-state outputs 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 6 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . 12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contact information. . . . . . . . . . . . . . . . . . . . . 13 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 24 March 2014
HEF4104BT-Q100J 价格&库存
很抱歉,暂时无法提供与“HEF4104BT-Q100J”相匹配的价格&库存,您可以联系我们找货
