74LVC1G79
Single D-type flip-flop; positive-edge trigger
Rev. 12 — 5 December 2016
Product data sheet
1. General description
The 74LVC1G79 provides a single positive-edge triggered D-type flip-flop.
Information on the data input is transferred to the Q-output on the LOW-to-HIGH transition
of the clock pulse. The D-input must be stable one set-up time prior to the LOW-to-HIGH
clock transition for predictable operation.
Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of this
device in a mixed 3.3 V and 5 V environment.
This device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing the damaging backflow current through the device
when it is powered down.
2. Features and benefits
Wide supply voltage range from 1.65 V to 5.5 V
High noise immunity
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.7 V)
JESD8B/JESD36 (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Inputs accept voltages up to 5 V
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C.
74LVC1G79
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LVC1G79GW
40 C to +125 C
TSSOP5
plastic thin shrink small outline package;
5 leads; body width 1.25 mm
SOT353-1
74LVC1G79GV
40 C to +125 C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
74LVC1G79GM
40 C to +125 C
XSON6
plastic extremely thin small outline package;
no leads; 6 terminals; body 1 1.45 0.5 mm
SOT886
74LVC1G79GF
40 C to +125 C
XSON6
no leads; 6 terminals; body 1 1 0.5 mm
SOT891
74LVC1G79GN
40 C to +125 C
XSON6
extremely thin small outline package; no leads; SOT1115
6 terminals; body 0.9 1.0 0.35 mm
74LVC1G79GS
40 C to +125 C
XSON6
extremely thin small outline package; no leads; SOT1202
6 terminals; body 1.0 1.0 0.35 mm
74LVC1G79GX
40 C to +125 C
X2SON5
X2SON5: plastic thermal enhanced extremely
thin small outline package; no leads; 5
terminals; body 0.8 0.8 0.35 mm
SOT1226
4. Marking
Table 2.
Marking codes
Type number
Marking[1]
74LVC1G79GW
VP
74LVC1G79GV
V79
74LVC1G79GM
VP
74LVC1G79GF
VP
74LVC1G79GN
VP
74LVC1G79GS
VP
74LVC1G79GX
VP
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
4
&3
Logic symbol
74LVC1G79
Product data sheet
&3
PQD
PQD
Fig 1.
4
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 21
74LVC1G79
Nexperia
&3
7*
7*
Fig 3.
4
7*
7*
PQD
Logic diagram
6. Pinning information
6.1 Pinning
/9&*
/9&*
&3
*1'
9&&
&3
QF
*1'
4
9&&
4
DDI
7UDQVSDUHQWWRSYLHZ
DDI
Fig 4.
Pin configuration SOT353-1 and SOT753
Fig 5.
Pin configuration SOT886
/9&*
/9&*
9&&
&3
QF
*1'
4
&3
4
DDD
Pin configuration SOT891, SOT1115 and
SOT1202
Product data sheet
9&&
7UDQVSDUHQWWRSYLHZ
7UDQVSDUHQWWRSYLHZ
74LVC1G79
*1'
DDI
Fig 6.
Fig 7.
Pin configuration SOT1226 (X2SON5)
3 of 21
74LVC1G79
Nexperia
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
D
Description
TSSOP5 and X2SON5
XSON6
1
1
data input
CP
2
2
clock pulse input
GND
3
3
ground (0 V)
Q
4
4
data output
n.c.
5
not connected
VCC
5
6
supply voltage
7. Functional description
Table 4.
Function table[1]
Input
Output
CP
D
Q
L
L
H
H
L
X
q
[1]
H = HIGH voltage level;
L = LOW voltage level;
= LOW-to-HIGH CP transition;
X = don’t care;
q = lower case letter indicates the state of referenced input, one set-up time prior to the LOW-to-HIGH CP transition.
74LVC1G79
Product data sheet
4 of 21
74LVC1G79
Nexperia
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
Conditions
IO
output current
ICC
supply current
IGND
ground current
Ptot
total power dissipation
Tstg
storage temperature
Max
Unit
0.5
+6.5
V
50
0.5
+6.5
V
mA
VI < 0 V
[1]
50
Active mode
0.5
VCC + 0.5
V
Power-down mode
[1][2]
0.5
+6.5
V
50
mA
100
mA
100
mA
250
mW
65
+150
C
VO = 0 V to VCC
Tamb = 40 C to +125 C
[3]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation.
[3]
mA
[1][2]
VO > VCC or VO < 0 V
output voltage
VO
Min
For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 and X2SON5 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
Tamb
ambient temperature
t/V
input transition rise and fall rate
74LVC1G79
Product data sheet
Min
Typ
Max
Unit
1.65
5.5
V
V
Active mode
VCC
V
VCC = 0 V; Power-down mode
V
40
+125
C
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 5.5 V
10
ns/V
5 of 21
74LVC1G79
Nexperia
10. Static characteristics
Table 7.
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ[1]
Max
Unit
Tamb = 40 C to +85 C
VIH
VIL
VOH
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
0.65 VCC
V
VCC = 2.3 V to 2.7 V
1.7
V
VCC = 2.7 V to 3.6 V
2.0
V
VCC = 4.5 V to 5.5 V
0.7 VCC
V
VCC = 1.65 V to 1.95 V
0.7
V
0.8
V
0.3 VCC
V
VCC 0.1
V
IO = 4 mA; VCC = 1.65 V
1.2
V
IO = 8 mA; VCC = 2.3 V
1.9
V
IO = 12 mA; VCC = 2.7 V
2.2
V
IO = 24 mA; VCC = 3.0 V
2.3
V
IO = 32 mA; VCC = 4.5 V
3.8
V
IO = 100 A; VCC = 1.65 V to 5.5 V
0.1
V
0.45
V
0.3
V
0.4
V
0.55
V
0.55
V
VI = VIH or VIL
VOL
LOW-level output voltage
0.35 VCC V
VI = VIH or VIL
II
input leakage current
VI = 5.5 V or GND; VCC = 0 V to 5.5 V
0.1
1
A
IOFF
power-off leakage current
VCC = 0 V; VI or VO = 5.5 V
0.1
2
A
ICC
supply current
VI = 5.5 V or GND;
VCC = 1.65 V to 5.5 V; IO = 0 A
0.1
4
A
ICC
additional supply current
per pin; VCC = 2.3 V to 5.5 V;
VI = VCC 0.6 V; IO = 0 A
5
500
A
CI
input capacitance
VCC = 3.3 V; VI = GND to VCC
5
pF
0.65 VCC
V
1.7
V
VIH
VIL
74LVC1G79
Product data sheet
2.0
V
0.7 VCC
V
0.8
V
0.3 VCC
V
0.35 VCC V
0.7
V
6 of 21
74LVC1G79
Nexperia
Table 7.
Static characteristics …continued
Min
Typ[1]
Max
VCC 0.1
V
0.95
V
1.7
V
1.9
V
2.0
V
3.4
V
0.1
V
0.70
V
0.45
V
0.60
V
0.80
V
0.80
V
Symbol Parameter
Conditions
VOH
VI = VIH or VIL
VOL
Unit
VI = VIH or VIL
II
1
A
IOFF
2
A
ICC
supply current
VI = 5.5 V or GND;
4
A
ICC
500
A
[1]
All typical values are measured at VCC = 3.3 V and Tamb = 25 C.
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 10.
Symbol Parameter
tpd
tsu
40 C to +85 C
Conditions
Min
Max
Min
Max
1.0
3.6
9.9
1.0
12.5
ns
0.5
2.3
7.0
0.5
9.0
ns
VCC = 2.7 V
0.5
2.6
6.0
0.5
8.0
ns
VCC = 3.0 V to 3.6 V
0.5
2.2
5.0
0.5
6.5
ns
0.5
1.7
3.8
0.5
5.0
ns
2.5
1.4
2.5
ns
propagation delay CP to Q; see Figure 8
set-up time
Product data sheet
[2]
D to CP; see Figure 9
74LVC1G79
40 C to +125 C Unit
Typ[1]
1.7
0.9
1.7
ns
VCC = 2.7 V
1.7
0.9
1.7
ns
1.3
0.6
1.2
ns
1.2
0.6
1.2
ns
7 of 21
74LVC1G79
Nexperia
Table 8.
Dynamic characteristics …continued
Symbol Parameter
th
hold time
pulse width
tW
40 C to +85 C
Conditions
Min
Max
Min
Max
ns
ns
VCC = 2.7 V
+0.5
0.3
0.5
ns
+0.5
0.3
0.5
ns
+0.5
0.2
0.5
ns
3.0
1.1
3.0
ns
CP HIGH or LOW;
see Figure 9
maximum
frequency
fmax
power dissipation
capacitance
CPD
40 C to +125 C Unit
Typ[1]
2.5
0.7
2.5
ns
VCC = 2.7 V
2.5
0.6
2.5
ns
2.5
0.6
2.5
ns
2.0
0.5
2.0
ns
160
250
160
MHz
160
300
160
MHz
VCC = 2.7 V
160
350
160
MHz
160
450
160
MHz
200
500
200
MHz
17
pF
CP; see Figure 9
[3]
VI = GND to VCC;
VCC = 3.3 V
[1]
Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively.
[2]
tpd is the same as tPLH and tPHL.
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
74LVC1G79
Product data sheet
8 of 21
74LVC1G79
Nexperia
12. Waveforms
9,
'LQSXW
*1'
9,
&3LQSXW
90
90
*1'
W3+/
W3/+
92+
90
4RXWSXW
90
92/
PQD
Measurement points are given in Table 9.
VOL and VOH are typical output voltage levels that occur with the output.
Fig 8.
Clock (CP) to output (Q) propagation delay times
9,
90
'LQSXW
*1'
WK
WK
W VX
W VX
IPD[
9,
&3LQSXW
90
*1'
W:
W 3+/
W 3/+
92+
90
4RXWSXW
92/
PQD
Fig 9.
Clock (CP) to output (Q) propagation delay times, clock pulse width, D to set-up times, the CP to D hold
times and maximum clock pulse frequency
74LVC1G79
Product data sheet
9 of 21
74LVC1G79
Nexperia
Table 9.
Measurement points
Supply voltage
Input
Output
VCC
VM
VM
1.65 V to 1.95 V
0.5 VCC
0.5 VCC
2.3 V to 2.7 V
0.5 VCC
0.5 VCC
2.7 V
1.5 V
1.5 V
3.0 V to 3.6 V
1.5 V
1.5 V
4.5 V to 5.5 V
0.5 VCC
0.5 VCC
9(;7
9&&
9,
5/
92
'87
57
5/
PQD
Test data is given in Table 10.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig 10. Test circuit for measuring switching times
Table 10.
Test data
Supply voltage
Input
VCC
VI
tr = tf
CL
RL
tPLH, tPHL
1.65 V to 1.95 V
VCC
2.0 ns
30 pF
1 k
open
2.3 V to 2.7 V
VCC
2.0 ns
30 pF
500
open
2.7 V
2.7 V
2.5 ns
50 pF
500
open
3.0 V to 3.6 V
2.7 V
2.5 ns
50 pF
500
open
4.5 V to 5.5 V
VCC
2.5 ns
50 pF
500
open
74LVC1G79
Product data sheet
Load
VEXT
10 of 21
74LVC1G79
Nexperia
13. Package outline
76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP
627
F
Y 0 $
ș
/S
H
Z 0
ES
GHWDLO;
H
PP
VFDOH
',0(16,216PPDUHWKHRULJLQDOGLPHQVLRQV
81,7
PD[
ES
F
H
H
PP
/S
Y
Z
ș
1RWH
3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG
287/,1(
9(56,21
627
5()(5(1&(6
-(,7$
02
6&$
(8523($1
352-(&7,21
,668('$7(
Fig 11. Package outline SOT353-1 (TSSOP5)
74LVC1G79
Product data sheet
11 of 21
74LVC1G79
Nexperia
3ODVWLFVXUIDFHPRXQWHGSDFNDJHOHDGV
627
Y 0 $
4
F
/S
GHWDLO;
ES
H
Z 0 %
PP
VFDOH
81,7
ES
F
H
/S
4
Y
Z
PP
287/,1(
9(56,21
5()(5(1&(6
-(,7$
6&$
627
(8523($1
352-(&7,21
,668('$7(
Fig 12. Package outline SOT753 (SC-74A)
74LVC1G79
Product data sheet
12 of 21
74LVC1G79
Nexperia
627
;621SODVWLFH[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGVWHUPLQDOVERG\[[PP
E
H
H
H
WHUPLQDO
LQGH[DUHD
PP
VFDOH
'LPHQVLRQVPPDUHWKHRULJLQDOGLPHQVLRQV
8QLW
PP
PD[
QRP
PLQ
E
H
H
1RWHV
,QFOXGLQJSODWLQJWKLFNQHVV
&DQEHYLVLEOHLQVRPHPDQXIDFWXULQJSURFHVVHV
2XWOLQH
YHUVLRQ
627
VRWBSR
5HIHUHQFHV
-(,7$
(XURSHDQ
SURMHFWLRQ
,VVXHGDWH
02
Fig 13. Package outline SOT886 (XSON6)
74LVC1G79
Product data sheet
13 of 21
74LVC1G79
Nexperia
627
E
î
H
H
H
î
WHUPLQDO
LQGH[DUHD
PP
VFDOH
81,7
PD[
PD[
E
H
H
PP
1RWH
5()(5(1&(6
287/,1(
9(56,21
627
-(,7$
(8523($1
352-(&7,21
,668('$7(
Fig 14. Package outline SOT891 (XSON6)
74LVC1G79
Product data sheet
14 of 21
74LVC1G79
Nexperia
;621H[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGV
WHUPLQDOVERG\[[PP
627
E
î
H
H
H
î
WHUPLQDO
LQGH[DUHD
VFDOH
'LPHQVLRQV
8QLW
PP
PP
E
H
H
PD[
QRP
PLQ
1RWH
9LVLEOHGHSHQGLQJXSRQXVHGPDQXIDFWXULQJWHFKQRORJ\
VRWBSR
5HIHUHQFHV
2XWOLQH
YHUVLRQ
-(,7$
627
(XURSHDQ
SURMHFWLRQ
,VVXHGDWH
Fig 15. Package outline SOT1115 (XSON6)
74LVC1G79
Product data sheet
15 of 21
74LVC1G79
Nexperia
WHUPLQDOVERG\[[PP
627
E
î
H
H
H
î
WHUPLQDO
LQGH[DUHD
VFDOH
'LPHQVLRQV
8QLW
PP
PP
E
H
H
PD[
QRP
PLQ
1RWH
VRWBSR
5HIHUHQFHV
2XWOLQH
YHUVLRQ
-(,7$
627
(XURSHDQ
SURMHFWLRQ
,VVXHGDWH
Fig 16. Package outline SOT1202 (XSON6)
74LVC1G79
Product data sheet
16 of 21
74LVC1G79
Nexperia
;621SODVWLFWKHUPDOHQKDQFHGH[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGV
WHUPLQDOVERG\[[PP
627
GHWDLO;
WHUPLQDO
LQGH[DUHD
H
Y
Z
E
WHUPLQDO
LQGH[DUHD
N
K
PP
VFDOH
'LPHQVLRQV
8QLW
PP
'K
E
H
N
PD[
QRP
PLQ
Y
Z
1RWH
'LPHQVLRQ$LVLQFOXGLQJSODWLQJWKLFNQHVV
2XWOLQH
YHUVLRQ
5HIHUHQFHV
VRWBSR
(XURSHDQ
SURMHFWLRQ
,VVXHGDWH
627
Fig 17. Package outline SOT1226 (X2SON5)
74LVC1G79
Product data sheet
17 of 21
74LVC1G79
Nexperia
14. Abbreviations
Table 11.
Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
15. Revision history
Table 12.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LVC1G79 v.12
20161205
Product data sheet
74LVC1G79 v.11
Modifications:
74LVC1G79 v.11
Modifications:
74LVC1G79 v.10
Modifications:
74LVC1G79 v.9
Modifications:
Table 7: The maximum limits for leakage current and supply current have changed.
20120702
74LVC1G79 v.10
Product data sheet
74LVC1G79 v.9
Errata in tabel 3 corrected (description CP input).
20111202
Added type number 74LVC1G79GX (SOT1226)
20120402
Product data sheet
Product data sheet
74LVC1G79 v.8
Legal pages updated.
74LVC1G79 v.8
20100930
Product data sheet
74LVC1G79 v.7
74LVC1G79 v.7
20070829
Product data sheet
74LVC1G79 v.6
74LVC1G79 v.6
20061009
Product data sheet
74LVC1G79 v.5
74LVC1G79 v.5
20040910
Product specification
74LVC1G79 v.4
74LVC1G79 v.4
20040317
74LVC1G79 v.3
74LVC1G79 v.3
20030516
74LVC1G79 v.2
74LVC1G79 v.2
20030130
74LVC1G79 v.1
74LVC1G79 v.1
20010404
74LVC1G79
Product data sheet
18 of 21
74LVC1G79
Nexperia
16. Legal information
16.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
16.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
16.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74LVC1G79
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
19 of 21
74LVC1G79
Nexperia
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
16.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
17. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74LVC1G79
Product data sheet
20 of 21
Nexperia
74LVC1G79
18. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
12
13
14
15
16
16.1
16.2
16.3
16.4
17
18
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5
Recommended operating conditions. . . . . . . . 5
Static characteristics. . . . . . . . . . . . . . . . . . . . . 6
Dynamic characteristics . . . . . . . . . . . . . . . . . . 7
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 18
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 18
Legal information. . . . . . . . . . . . . . . . . . . . . . . 19
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 19
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 19
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 20
Contact information. . . . . . . . . . . . . . . . . . . . . 20
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21
Date of release: 05 December 2016
