74HC107PW-Q100J
74HC107PW-Q100J
    NEXPERIA(安世)
    TSSOP14_5.1X4.5MM
    带复位功能的双JK触发器;负边触发器
74HC107PW-Q100J 数据手册
74HC107-Q100; 74HCT107-Q100 Dual JK flip-flop with reset; negative-edge trigger Rev. 2 — 26 January 2015 Product data sheet 1. General description The 74HC107-Q100; 74HCT107-Q100 is a dual negative edge triggered JK flip-flop featuring individual J and K inputs, clock (CP) and reset (R) inputs and complementary Q and Q outputs. The reset is an asynchronous active LOW input and operates independently of the clock input. The J and K inputs control the state changes of the flip-flops as described in the mode select function table. The J and K inputs must be stable one set-up time prior to the HIGH-to-LOW clock transition for predictable operation. Inputs include clamp diodes that enable the use of current limiting resistors to interface inputs to voltages in excess of VCC. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Input levels:  For 74HC107-Q100: CMOS level  For 74HCT107-Q100: TTL level  Complies with JEDEC standard no. 7A  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Multiple package options 3. Ordering information Table 1. Ordering information Type number 74HC107D-Q100 Package Temperature range Name Description Version 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74HCT107D-Q100 74HC107PW-Q100 74HC107-Q100; 74HCT107-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger 4. Functional diagram     - - 4     ))  &3  &3 &3   . . . 4 4 4 4   4   5  5 5    - .  5 -  & .  5 DDD DDD Fig 1.  & Logic symbol Fig 2. & & IEC logic symbol & & . 4 & & & & 4 5 &3 & DDE & Fig 3. Logic diagram (one flip-flop) 74HC_HCT107_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 2 of 17 74HC107-Q100; 74HCT107-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger 5. Pinning information 5.1 Pinning +&4 +&74 -   9&& 4   5 4   &3 .   . 4   5 4   &3 *1'   DDD Fig 4. Pin configuration SO14 and TSSOP14 5.2 Pin description Table 2. Pin description Symbol Pin Description 1J, 2J 1, 8 synchronous J input 1Q, 2Q 2, 6 complement output 1Q, 2Q 3, 5 true output 1K, 2K 4, 11 synchronous K input 1CP, 2CP 12, 9 clock input (HIGH-to-LOW edge-triggered) 1R, 2R 13, 10 asynchronous reset input (active LOW) GND 7 ground (0 V) VCC 14 supply voltage 74HC_HCT107_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 3 of 17 74HC107-Q100; 74HCT107-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger 6. Functional description Table 3. Function table[1] Input Output Operating mode R CP J K Q Q L X X X L H H  h h q q toggle H  l h L H load 0 (reset) H  h l H L load 1 (set) H  l l q q hold (no change) [1] asynchronous reset H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the HIGH-to-LOW clock transition; L = LOW voltage level; I = LOW voltage level one set-up time prior to the HIGH-to-LOW clock transition; q = state of referenced output one set-up time prior to the HIGH-to-LOW clock transition; X = don’t care;  = HIGH-to-LOW clock transition. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V IO output current VO = 0.5 V to VCC + 0.5 V ICC supply current IGND ground current Tstg storage temperature Ptot total power dissipation Min Max Unit 0.5 +7.0 V [1] - 20 mA [1] - 20 mA - 25 mA - 50 mA 50 - mA 65 +150 C Tamb = 40 C to +125 C SO14 package [2] - 500 mW TSSOP14 package [3] - 500 mW [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Ptot derates linearly with 8 mW/K above 70 C. [3] Ptot derates linearly with 5.5 mW/K above 60 C. 74HC_HCT107_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 4 of 17 74HC107-Q100; 74HCT107-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC107-Q100 Min Typ 74HCT107-Q100 Max Min Typ Unit Max VCC supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature 40 +25 +125 40 +25 +125 C t/V input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions Min Typ VCC = 2.0 V 1.5 VCC = 4.5 V 3.15 VCC = 6.0 V 4.2 VCC = 2.0 V - VCC = 4.5 V - VCC = 6.0 V 40 C to +85 C 40 C to +125 C Unit Max Min Max Min Max 1.2 - 1.5 - 1.5 - V 2.4 - 3.15 - 3.15 - V 3.2 - 4.2 - 4.2 - V 0.8 0.5 - 0.5 - 0.5 V 2.1 1.35 - 1.35 - 1.35 V - 2.8 1.8 - 1.8 - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = 4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = 5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V 74HC107-Q100 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - 0.1 - 1.0 - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 4.0 - 40 - 80 A 74HC_HCT107_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 5 of 17 74HC107-Q100; 74HCT107-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions Min CI input capacitance Typ 40 C to +85 C 40 C to +125 C Unit Max - 3.5 - Min Max Min Max pF 74HCT107-Q100 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A 4.4 4.5 - 4.4 - 4.4 - V IO = 4 mA 3.98 4.32 - 3.84 - 3.7 - V LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA - 0.16 0.26 - 0.33 - 0.4 V VOL II input leakage current VI = VCC or GND; VCC = 5.5 V - - 0.1 - 1.0 - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 4.0 - 40 - 80 A ICC additional supply current per input pin; VI = VCC  2.1 V; IO = 0 A; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V CI input capacitance 74HC_HCT107_Q100 Product data sheet pin nCP, nJ - 100 360 - 450 - 490 A pin nR - 65 234 - 293 - 319 A pin nK - 60 216 - 270 - 294 A - 3.5 - All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 - - - © - pF Nexperia B.V. 2017. All rights reserved 6 of 17 74HC107-Q100; 74HCT107-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger 10. Dynamic characteristics Table 7. Dynamic characteristics GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 7 Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max 74HC107-Q100 tpd propagation delay nCP to nQ; see Figure 5 [1] VCC = 2.0 V - 52 160 - 200 - 240 ns VCC = 4.5 V - 19 32 - 40 - 48 ns VCC = 5.0 V; CL = 15 pF - 16 - - - - - ns VCC = 6.0 V - 15 27 - 34 - 41 ns VCC = 2.0 V - 52 160 - 200 - 240 ns nCP to nQ; see Figure 5 VCC = 4.5 V - 19 32 - 40 - 48 ns VCC = 5.0 V; CL = 15 pF - 16 - - - - - ns VCC = 6.0 V - 15 27 - 34 - 41 ns VCC = 2.0 V - 52 155 - 195 - 235 ns VCC = 4.5 V - 19 31 - 39 - 47 ns VCC = 5.0 V; CL = 15 pF - 16 - - - - - ns - 15 26 - 33 - 40 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns VCC = 2.0 V 80 22 - 100 - 120 - ns VCC = 4.5 V 16 8 - 20 - 24 - ns VCC = 6.0 V 14 6 - 17 - 20 - ns VCC = 2.0 V 80 22 - 100 - 120 - ns VCC = 4.5 V 16 8 - 20 - 24 - ns VCC = 6.0 V 14 6 - 17 - 20 - ns VCC = 2.0 V 60 19 - 75 - 90 - ns VCC = 4.5 V 12 7 - 15 - 18 - ns VCC = 6.0 V 20 6 - 13 - 15 - ns VCC = 2.0 V 100 22 - 125 - 150 - ns VCC = 4.5 V 20 8 - 25 - 30 - ns VCC = 6.0 V 17 6 - 21 - 26 - ns nR to nQ, nQ; see Figure 6 VCC = 6.0 V tt tW [2] transition time nQ, nQ; see Figure 5 pulse width nCP input, HIGH or LOW; see Figure 5 nR input, HIGH or LOW; see Figure 6 trec tsu recovery time set-up time 74HC_HCT107_Q100 Product data sheet nR to nCP; see Figure 6 nJ, nK to nCP; see Figure 5 All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 7 of 17 74HC107-Q100; 74HCT107-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger Table 7. Dynamic characteristics …continued GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 7 Symbol Parameter th fmax hold time maximum frequency 25 C Conditions Min Max Min Max VCC = 2.0 V 3 6 - 3 - 3 - ns VCC = 4.5 V 3 2 - 3 - 3 - ns VCC = 6.0 V 3 2 - 3 - 3 - ns nCP input; see Figure 5 VCC = 2.0 V 6 23 - 4.8 - 4.0 - MHz VCC = 4.5 V 30 70 - 24 - 20 - MHz - 78 - - - - - MHz 35 85 - 28 - 24 - MHz - 30 - - - - - pF VCC = 4.5 V - 19 36 - 45 - 54 ns VCC = 5.0 V; CL = 15 pF - 16 - - - - - ns VCC = 4.5 V - 21 36 - 45 - 54 ns VCC = 5.0 V; CL = 15 pF - 18 - - - - - ns - 20 38 - 48 - 57 ns - 17 - - - - - ns - 7 15 - 19 - 22 ns 16 9 - 20 - 24 - ns 20 11 - 25 - 30 - ns 14 8 - 18 - 21 - ns 20 7 - 25 - 30 - ns 5 2 - 5 - 5 - ns VCC = 6.0 V power dissipation capacitance Min Typ Max nJ, nK to nCP; see Figure 5 VCC = 5.0 V; CL = 15 pF CPD 40 C to +85 C 40 C to +125 C Unit per flip-flop; VI = GND to VCC [3] nCP to nQ; see Figure 5 [1] 74HCT107-Q100 tpd propagation delay nCP to nQ; see Figure 5 nR to nQ, nQ; see Figure 6 VCC = 4.5 V VCC = 5.0 V; CL = 15 pF tt [2] transition time nQ, nQ; see Figure 5 VCC = 4.5 V tW pulse width nCP input, HIGH or LOW; see Figure 5 VCC = 4.5 V nR input, HIGH or LOW; see Figure 6 VCC = 4.5 V trec recovery time nR to nCP; see Figure 6 VCC = 4.5 V tsu set-up time nJ, nK to nCP; see Figure 5 th hold time nJ, nK to nCP; see Figure 5 VCC = 4.5 V VCC = 4.5 V 74HC_HCT107_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 8 of 17 74HC107-Q100; 74HCT107-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger Table 7. Dynamic characteristics …continued GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 7 Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max fmax maximum frequency power dissipation capacitance VCC = 4.5 V [3] per flip-flop; VI = GND to VCC  1.5 V [1] tpd is the same as tPHL, tPLH. [2] tt is the same as tTHL, tTLH. [3] Max Min Max nCP input; see Figure 5 VCC = 5.0 V; CL = 15 pF CPD Min 30 66 - 24 - 20 - MHz - 73 - - - - - MHz - 30 - - - - - pF CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 11. Waveforms 9, Q-Q. LQSXW *1' 90 WK WVX IPD[ 9, WVX WK 90 Q&3LQSXW *1' W: W3/+ W3+/ 92+  Q4RXWSXW  90  92/  W7+/ 92+ W7/+   Q4RXWSXW 90  92/  W7/+ W3/+ W7+/ W3+/ DDE The shaded areas indicate when the input is permitted to change for predictable output performance. Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 5. Waveforms showing the clock propagation delays, pulse width, nJ and nK to nCP set-up and hold times, output transition times and maximum clock frequency 74HC_HCT107_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 9 of 17 74HC107-Q100; 74HCT107-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger 9, 90 Q&3LQSXW *1' WUHF W: 9, 90 Q5LQSXW *1' W3+/ 92+ Q4RXWSXW 92/ 92+ W3/+ Q4RXWSXW DDE 92/ Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 6. Table 8. Waveforms showing reset (nR) input to output (nQ, nQ) propagation delays and pulse width, and nR to nCP recovery time Measurement points Type Input Output VI VM VM 74HC107-Q100 VCC 0.5VCC 0.5VCC 74HCT107-Q100 3V 1.3 V 1.3 V 74HC_HCT107_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 10 of 17 74HC107-Q100; 74HCT107-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger 9, W:  QHJDWLYH SXOVH 90 9 WI WU WU WI 9,  SRVLWLYH SXOVH 9 90  90 90  W: 9&& 9&& * 9, 92 5/ 6 RSHQ '87 &/ 57 DDG Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig 7. Table 9. Test circuit for measuring switching times Test data Type Input VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 74HC107-Q100 VCC 6 ns 15 pF, 50 pF 1 k open GND VCC 74HCT107-Q100 3V 6 ns 15 pF, 50 pF 1 k open GND VCC 74HC_HCT107_Q100 Product data sheet Load S1 position All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 11 of 17 74HC107-Q100; 74HCT107-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger 12. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV        ș R R  1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG Fig 8. 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Package outline SOT108-1 (SO14) 74HC_HCT107_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 12 of 17 74HC107-Q100; 74HCT107-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ SLQLQGH[ $   $ $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWHV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 Fig 9. 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Package outline SOT402-1 (TSSOP14) 74HC_HCT107_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 13 of 17 74HC107-Q100; 74HCT107-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger 13. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date 74HC_HCT107_Q100 v.2 20150126 Modifications: • Product data sheet Change notice Supersedes Product data sheet - 74HC_HCT107_Q100 v.1 Table 7: Power dissipation capacitance condition for 74HCT107-Q100 is corrected. 74HC_HCT107_Q100 v.1 20131118 74HC_HCT107_Q100 Data sheet status Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 - © Nexperia B.V. 2017. All rights reserved 14 of 17 74HC107-Q100; 74HCT107-Q100 Nexperia Dual JK flip-flop with reset; negative-edge trigger 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC_HCT107_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 15 of 17 Nexperia 74HC107-Q100; 74HCT107-Q100 Dual JK flip-flop with reset; negative-edge trigger No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC_HCT107_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 26 January 2015 © Nexperia B.V. 2017. All rights reserved 16 of 17 Nexperia 74HC107-Q100; 74HCT107-Q100 Dual JK flip-flop with reset; negative-edge trigger 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 12 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14 Legal information. . . . . . . . . . . . . . . . . . . . . . . 15 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Contact information. . . . . . . . . . . . . . . . . . . . . 16 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 26 January 2015
74HC107PW-Q100J 价格&库存
很抱歉,暂时无法提供与“74HC107PW-Q100J”相匹配的价格&库存,您可以联系我们找货
