74HCT273BQ-Q100X
74HCT273BQ-Q100X
    NEXPERIA(安世)
    DHVQFN20_4.5X2.5MM_EP
    带复位的八进制D型触发器;正边缘触发器
74HCT273BQ-Q100X 数据手册
74HC273-Q100; 74HCT273-Q100 Octal D-type flip-flop with reset; positive-edge trigger Rev. 1 — 19 June 2013 Product data sheet 1. General description The 74HC273-Q100; 74HCT273-Q100 is an octal positive-edge triggered D-type flip-flop. The device features clock (CP) and master reset (MR) inputs. The outputs Qn assume the state of their corresponding Dn inputs that meet the set-up and hold time requirements on the LOW-to-HIGH clock (CP) transition. A LOW on MR forces the outputs LOW independently of clock and data inputs. Inputs include clamp diodes which enable the use of current limiting resistors to interface inputs to voltages in excess of VCC. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Input levels:  For 74HC273-Q100: CMOS level  For 74HCT273-Q100: TTL level  Common clock and master reset  Eight positive edge-triggered D-type flip-flops  Complies with JEDEC standard no. 7A  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V.  Multiple package options 3. Ordering information Table 1. Ordering information Type number 74HC273D-Q100 Package Temperature range Name Description Version 40 C to +125 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 40 C to +125 C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 40 C to +125 C DHVQFN20 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 20 terminals; body 2.5  4.5  0.85 mm 74HCT273D-Q100 74HC273PW-Q100 74HCT273PW-Q100 74HC273BQ-Q100 74HCT273BQ-Q100 SOT764-1 74HC273-Q100; 74HCT273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 4. Functional diagram CP MR 11 1 C1 R 11 3 4 7 8 13 14 17 18 1 11 D0 D1 D2 D3 D4 D5 D6 D7 FF1 TO FF8 Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 2 5 6 9 12 15 16 19 3 4 7 8 13 14 17 MR 18 CP Functional diagram 74HC_HCT273_Q100 Product data sheet D0 Q0 D1 Q1 D2 Q2 D3 Q3 D4 Q4 D5 Q5 D6 Q6 D7 Q7 2 5 1 Fig 2. D1 6 D2 9 D3 12 15 16 19 MR 001aae055 Fig 1. D0 CP D4 D5 D6 D7 3 2 1D 4 5 7 6 8 9 13 12 14 15 17 16 18 19 All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2013 Q1 Q2 Q3 Q4 Q5 Q6 Q7 mna764 mna763 Logic symbol Q0 Fig 3. IEC logic symbol © Nexperia B.V. 2017. All rights reserved 2 of 19 74HC273-Q100; 74HCT273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger D0 D1 D Q D2 D Q D3 D Q D Q CP FF1 CP FF2 CP FF3 CP FF4 RD RD RD RD CP MR Q0 D4 Q1 D5 D Q Q2 D6 D Q Q3 D7 D Q D Q CP FF5 CP FF6 CP FF7 CP FF8 RD RD RD RD Q4 Q5 Q6 Q7 001aae056 Fig 4. Logic diagram 74HC_HCT273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2013 © Nexperia B.V. 2017. All rights reserved 3 of 19 74HC273-Q100; 74HCT273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 5. Pinning information 5.1 Pinning 05  WHUPLQDO LQGH[DUHD +&4 +&74  9&& +&4 +&74 4   4 '   ' '   ' 05   9&& 4   4 '   ' 4   4   4    ' 4   4 ' 4   4 '   ' '   ' 4   4 *1'   &3    '  4 *1'  ' 4  ' *1'  &3  ' 4 DDD 7UDQVSDUHQWWRSYLHZ DDD (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. Fig 5. Pin configuration SO20 and TSSOP20 Fig 6. Pin configuration DHVQFN20 5.2 Pin description Table 2. Pin description Symbol Pin Description MR 1 master reset input (active LOW) Q0, Q1, Q2, Q3, Q4, Q5, Q6, Q7 2, 5, 6, 9, 12, 15, 16, 19 flip-flop output D0, D1, D2, D3, D4, D5, D6, D7 3, 4, 7, 8, 13, 14, 17, 18 data input GND 10 ground (0 V) CP 11 clock input (LOW-to-HIGH, edge-triggered) VCC 20 supply voltage 74HC_HCT273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2013 © Nexperia B.V. 2017. All rights reserved 4 of 19 74HC273-Q100; 74HCT273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 6. Functional description Table 3. Function table[1] Operating modes Inputs Outputs MR CP Dn Qn reset (clear) L X X L load “1” H  h H load “0” H  l L [1] H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the LOW-to-HIGH clock transition; L = LOW voltage level; l = LOW voltage level one set-up time prior to the LOW-to-HIGH clock transition; X = don’t care;  = LOW-to-HIGH clock transition. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V) Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +7 V - 20 mA - 20 mA - 25 mA IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V [1] IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] IO output current 0.5 V < VO < VCC + 0.5 V ICC supply current - 50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot [1] [2] Tamb = 40 C to +125 C [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SO20 package: above 70 C the value of Ptot derates linearly with 8 mW/K. For TSSOP20 package: above 60 C the value of Ptot derates linearly with 5.5 mW/K. For DHVQFN20 package: Ptot derates linearly with 4.5 mW/K above 60 C. 74HC_HCT273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2013 © Nexperia B.V. 2017. All rights reserved 5 of 19 74HC273-Q100; 74HCT273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC273-Q100 Min Typ 74HCT273-Q100 Max Min Typ Unit Max VCC supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature 40 - +125 40 - +125 C t/V input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = 4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = 5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V 74HC273-Q100 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - 0.1 - 1 - 1 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 A 74HC_HCT273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2013 © Nexperia B.V. 2017. All rights reserved 6 of 19 74HC273-Q100; 74HCT273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter CI 25 C Conditions input capacitance 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max - 3.5 - - - - - pF 74HCT273-Q100 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A 4.4 4.5 - 4.4 - 4.4 - V IO = 4.0 mA 3.98 4.32 - 3.84 - 3.7 - V LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 5.2 mA; VCC = 5.5 V - 0.15 0.26 - 0.33 - 0.4 V VOL II input leakage current VI = VCC or GND; VCC = 5.5 V - - 0.1 - 1 - 1 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 8.0 - 80 - 160 A ICC additional supply current per input pin; VI = VCC  2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V CI MR input - 100 360 - 450 - 490 A CP input - 175 630 - 787.5 - 857.5 A Dn input - 15 54 - 67.5 - 73.5 A - 3.5 - - - - - pF input capacitance 10. Dynamic characteristics Table 7. Dynamic characteristics GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 10 Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V - 41 150 - 185 - 225 ns VCC = 4.5 V - 15 30 - 37 - 45 ns VCC = 5.0 V; CL = 15 pF - 15 - - - - - ns VCC = 6.0 V - 13 26 - 31 - 38 ns 74HC273-Q100 tpd propagation delay 74HC_HCT273_Q100 Product data sheet [1] CP to Qn; see Figure 7 All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2013 © Nexperia B.V. 2017. All rights reserved 7 of 19 74HC273-Q100; 74HCT273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger Table 7. Dynamic characteristics …continued GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 10 Symbol Parameter tPHL HIGH to LOW propagation delay 25 C Conditions tW transition time pulse width Min Typ Max Min Max Min Max MR to Qn; see Figure 8 VCC = 2.0 V - 44 150 - 185 - 225 ns VCC = 4.5 V - 16 30 - 37 - 45 ns VCC = 5.0 V; CL = 15 pF - 15 - - - - - ns - 14 26 - 31 - 38 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 15 - 19 ns VCC = 2.0 V 80 14 - 100 - 120 - ns VCC = 4.5 V 16 5 - 20 - 24 - ns VCC = 6.0 V 14 4 - 17 - 20 - ns VCC = 2.0 V 60 17 - 75 - 90 - ns VCC = 4.5 V 12 6 - 15 - 18 - ns VCC = 6.0 V 10 5 - 13 - 15 - ns VCC = 2.0 V 50 6 - 65 - 75 - ns VCC = 4.5 V 10 2 - 13 - 15 - ns VCC = 6.0 V 9 2 - 11 - 13 - ns VCC = 2.0 V 60 11 - 75 - 90 - ns VCC = 4.5 V 12 4 - 15 - 18 - ns VCC = 6.0 V 10 3 - 13 - 15 - ns VCC = 2.0 V 3 6 - 3 - 3 - ns VCC = 4.5 V 3 2 - 3 - 3 - ns VCC = 6.0 V 3 2 - 3 - 3 - ns VCC = 2.0 V 6 20.6 - 4.8 - 4 - MHz VCC = 4.5 V 30 103 - 24 - 20 - MHz - 66 - - - - - MHz 35 122 - 28 - 24 - MHz - 20 - - - - - pF VCC = 6.0 V tt 40 C to +85 C 40 C to +125 C Unit Qn output; see Figure 7 [2] CP input HIGH or LOW; see Figure 7 MR input LOW; see Figure 8 trec tsu th fmax recovery time set-up time hold time maximum frequency MR to CP; see Figure 8 Dn to CP; see Figure 9 Dn to CP; see Figure 9 CP input; see Figure 7 VCC = 5.0 V; CL = 15 pF VCC = 6.0 V CPD power dissipation capacitance 74HC_HCT273_Q100 Product data sheet per package; VI = GND to VCC [3] All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2013 © Nexperia B.V. 2017. All rights reserved 8 of 19 74HC273-Q100; 74HCT273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger Table 7. Dynamic characteristics …continued GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 10 Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 4.5 V - 16 30 - 38 - 45 ns VCC = 5.0 V; CL = 15 pF - 15 - - - - - ns 74HCT273-Q100 tpd tPHL tt propagation delay HIGH to LOW propagation delay transition time [1] CP to Qn; see Figure 7 MR to Qn; see Figure 8 VCC = 4.5 V - 23 34 - 43 - 51 ns VCC = 5.0 V; CL = 15 pF - 20 - - - - - ns - 7 15 - 19 - 22 ns 16 9 - 20 - 24 - ns 16 8 - 20 - 24 - ns 10 2 - 13 - 15 - ns 12 5 - 15 - 18 - ns 3 4 - 3 - 3 - ns Qn output; see Figure 7 [2] VCC = 4.5 V tW pulse width CP input; see Figure 7 VCC = 4.5 V MR input LOW; see Figure 8 VCC = 4.5 V trec recovery time MR to CP; see Figure 8 VCC = 4.5 V tsu set-up time Dn to CP; see Figure 9 th hold time Dn to CP; see Figure 9 VCC = 4.5 V VCC = 4.5 V fmax maximum frequency CP input; see Figure 7 VCC = 4.5 V VCC = 5.0 V; CL = 15 pF CPD [1] power dissipation capacitance per package; VI = GND to VCC  1.5 V [3] 30 56 - 24 - 20 - MHz - 36 - - - - - MHz - 23 - - - - - pF tpd is the same as tPHL and tPLH. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz;  (CL  VCC2  fo) = sum of outputs; CL = output load capacitance in pF; VCC = supply voltage in V. 74HC_HCT273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2013 © Nexperia B.V. 2017. All rights reserved 9 of 19 74HC273-Q100; 74HCT273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 11. Waveforms 1/fmax VI CP input VM VM GND tW tW t PHL t PLH VOH 90% VM 10% Qn output VOL tTHL tTLH 001aae062 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 7. Propagation delay clock input (CP) to output (Qn), clock (CP) pulse width, output transition time and the maximum clock pulse frequency VI VM MR input GND tW trec VI CP input VM GND tPHL VOH VM Qn output VOL mna464 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 8. Propagation delay master reset (MR) to output (Qn), pulse width master reset (MR) and recovery time master reset (MR) to clock (CP) 74HC_HCT273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2013 © Nexperia B.V. 2017. All rights reserved 10 of 19 74HC273-Q100; 74HCT273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger VI VM CP input GND t su t su th th VI VM Dn input GND VOH VM Qn output VOL mna767 Measurement points are given in Table 8. The shaded areas indicate when the input is permitted to change for predictable output performance. VOL and VOH are typical voltage output levels that occur with the output load. Fig 9. Table 8. Data set-up and hold times data input (Dn) Measurement points Type Input Output VI VM VM 74HC273-Q100 VCC 0.5VCC 0.5VCC 74HCT273-Q100 3V 1.3 V 1.3 V 74HC_HCT273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2013 © Nexperia B.V. 2017. All rights reserved 11 of 19 74HC273-Q100; 74HCT273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VCC VCC G VI VO RL S1 open DUT CL RT 001aad983 Test data is given in Table 9. Definitions for test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch Fig 10. Test circuit for measuring switching times Table 9. Test data Type Input VI tr, tf CL RL tPHL, tPLH 74HC273-Q100 VCC 6 ns 15 pF, 50 pF 1 k open 74HCT273-Q100 3V 6 ns 15 pF, 50 pF 1 k open 74HC_HCT273_Q100 Product data sheet Load All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2013 S1 position © Nexperia B.V. 2017. All rights reserved 12 of 19 74HC273-Q100; 74HCT273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 12. Package outline SO20: plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 D E A X c HE y v M A Z 20 11 Q A2 A (A 3) A1 pin 1 index θ Lp L 10 1 e detail X w M bp 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 13.0 12.6 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.01 0.019 0.013 0.014 0.009 0.51 0.49 0.30 0.29 0.05 0.419 0.043 0.055 0.394 0.016 inches 0.1 0.012 0.096 0.004 0.089 0.043 0.039 0.01 0.01 Z (1) 0.9 0.4 0.035 0.004 0.016 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT163-1 075E04 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 11. Package outline SOT163-1 (SO20) 74HC_HCT273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2013 © Nexperia B.V. 2017. All rights reserved 13 of 19 74HC273-Q100; 74HCT273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 E D A X c HE y v M A Z 11 20 Q A2 (A 3) A1 pin 1 index A θ Lp L 1 10 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 6.6 6.4 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT360-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Fig 12. Package outline SOT360-1 (TSSOP20) 74HC_HCT273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2013 © Nexperia B.V. 2017. All rights reserved 14 of 19 74HC273-Q100; 74HCT273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT764-1 20 terminals; body 2.5 x 4.5 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 9 y y1 C v M C A B w M C b L 1 10 Eh e 20 11 19 12 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 4.6 4.4 3.15 2.85 2.6 2.4 1.15 0.85 0.5 3.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT764-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 13. Package outline SOT764-1 (DHVQFN20) 74HC_HCT273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2013 © Nexperia B.V. 2017. All rights reserved 15 of 19 74HC273-Q100; 74HCT273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 13. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT273_Q100 v.1 20130619 Product data sheet - - 74HC_HCT273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2013 © Nexperia B.V. 2017. All rights reserved 16 of 19 74HC273-Q100; 74HCT273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC_HCT273_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2013 © Nexperia B.V. 2017. All rights reserved 17 of 19 Nexperia 74HC273-Q100; 74HCT273-Q100 Octal D-type flip-flop with reset; positive-edge trigger No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC_HCT273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2013 © Nexperia B.V. 2017. All rights reserved 18 of 19 Nexperia 74HC273-Q100; 74HCT273-Q100 Octal D-type flip-flop with reset; positive-edge trigger 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 5 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 6 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 16 Legal information. . . . . . . . . . . . . . . . . . . . . . . 17 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 17 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Contact information. . . . . . . . . . . . . . . . . . . . . 18 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 19 June 2013
74HCT273BQ-Q100X 价格&库存
很抱歉,暂时无法提供与“74HCT273BQ-Q100X”相匹配的价格&库存,您可以联系我们找货
