74LVC273BQ-Q100X
74LVC273BQ-Q100X
    NEXPERIA(安世)
    DHVQFN20_4.5X2.5MM_EP
    带复位的八进制D型触发器;正边缘触发器
74LVC273BQ-Q100X 数据手册
74LVC273-Q100 Octal D-type flip-flop with reset; positive-edge trigger Rev. 1 — 16 September 2013 Product data sheet 1. General description The 74LVC273-Q100 has eight edge-triggered, D-type flip-flops with individual Dn inputs and Qn outputs. The common clock (CP) and master reset (MR) inputs load and reset (clear) all flip-flops simultaneously. The state of each Dn input, one set-up time before the LOW-to-HIGH clock transition, is transferred to the corresponding output (Qn) of the flip-flop. All outputs are forced LOW independent of clock or data inputs by a LOW voltage level on the MR input. The device is useful for applications where the true output only is required and the clock and master reset are common to all storage elements. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Wide supply voltage range from 1.2 V to 3.6 V  Inputs accept voltages up to 5.5 V  CMOS low power consumption  Direct interface with TTL levels  Output drive capability 50  transmission lines at +85 C  Complies with JEDEC standard:  JESD8-7A (1.65 V to 1.95 V)  JESD8-5A (2.3 V to 2.7 V)  JESD8-C/JESD36 (2.7 V to 3.6 V)  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 ) 74LVC273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 40 C to +125 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 74LVC273PW-Q100 40 C to +125 C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 74LVC273BQ-Q100 40 C to +125 C DHVQFN20 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 20 terminals; body 2.5  4.5  0.85 mm 74LVC273D-Q100 SOT764-1 4. Functional diagram CP MR 11 1 C1 R 11 3 4 7 8 13 14 17 18 CP D0 Q0 D1 Q1 D2 Q2 D3 Q3 D4 Q4 D5 Q5 D6 Q6 D7 Q7 D0 2 D1 5 6 D2 9 D3 12 D4 15 D5 16 D6 19 MR 1 Fig 1. Logic symbol 74LVC273_Q100 Product data sheet D7 3 2 1D 4 5 7 6 8 9 13 12 14 15 17 16 18 19 mna763 Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 mna764 Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 September 2013 © Nexperia B.V. 2017. All rights reserved 2 of 16 74LVC273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 5. Pinning information 5.1 Pinning 05  WHUPLQDO LQGH[DUHD 4   4 '   '  9&&  4 '   '   4  4  4  '   ' 4   ' 4    4 '  4   4 '  '   ' '   ' 4  4   4 *1'   &3  ' *1'   '  4 *1'  ' 4 &3  /9&4 05  9&& /9&4 DDD 7UDQVSDUHQWWRSYLHZ DDD (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. Fig 3. Pin configuration for SO20 and TSSOP20 Fig 4. Pin configuration for DHVQFN20 5.2 Pin description Table 2. Pin description Symbol Pin Description MR 1 master reset input (active LOW) CP 11 clock input (LOW-to-HIGH; edge-triggered) D[0:7] 3, 4, 7, 8, 13, 14, 17, 18 data input Q[0:7] 2, 5, 6, 9, 12, 15, 16, 19 flip-flop output GND 10 ground (0 V) VCC 20 supply voltage 74LVC273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 September 2013 © Nexperia B.V. 2017. All rights reserved 3 of 16 74LVC273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 6. Functional description Table 3. Function table[1] Operating mode Input Output MR CP Dn Qn L X X L Load ‘1’ H  h H Load ‘0’ H  l L Reset (clear) [1] H = HIGH voltage level L = LOW voltage level X = don’t care h = HIGH voltage level one set-up time prior to the LOW-to-HIGH CP transition l = LOW voltage level one set-up time prior to the LOW-to-HIGH CP transition  = LOW-to-HIGH clock transition 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO output voltage Conditions VI < 0 V [1] VO > VCC or VO < 0 V [2] Min Max Unit 0.5 +6.5 V 50 - mA 0.5 +6.5 V - 50 mA 0.5 VCC + 0.5 V IO output current - 50 mA ICC supply current - 100 mA IGND ground current 100 - mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot VO = 0 V to VCC Tamb = 40 C to +125 C [3] [1] The minimum input voltage ratings may be exceeded if the input current ratings are observed. [2] The output voltage ratings may be exceeded if the output current ratings are observed. [3] For SO20 packages: above 70 C the value of Ptot derates linearly with 8 mW/K. For TSSOP20 packages: above 60 C the value of Ptot derates linearly with 5.5 mW/K. For DHVQFN20 packages: above 60 C the value of Ptot derates linearly with 4.5 mW/K. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC supply voltage Conditions functional Min Typ Max Unit 1.65 - 3.6 V 1.2 - - V VI input voltage 0 - 5.5 V VO output voltage 0 - VCC V 74LVC273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 September 2013 © Nexperia B.V. 2017. All rights reserved 4 of 16 74LVC273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger Table 5. Recommended operating conditions …continued Symbol Parameter Conditions Min Typ Max Unit Tamb ambient temperature in free air 40 - +125 C t/V input transition rise and fall rate VCC = 1.65 V to 2.7 V 0 - 20 ns/V VCC = 2.7 V to 3.6 V 0 - 10 ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter 40 C to +85 C Conditions Min HIGH-level input voltage VIH LOW-level input voltage VIL VOH HIGH-level output voltage LOW-level output voltage VOL Typ[1] 40 C to +125 C Max Min Unit Max VCC = 1.2 V 1.08 - - 1.08 - V VCC = 1.65 V to 1.95 V 0.65  VCC - - 0.65  VCC - V VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 1.2 V - - 0.12 - 0.12 V VCC = 1.65 V to 1.95 V - - 0.35  VCC - 0.35  VCC V VCC = 2.3 V to 2.7 V - - 0.7 - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V IO = 100 A; VCC = 1.65 V to 3.6 V VCC  0.2 - - VCC  0.3 - V IO = 4 mA; VCC = 1.65 V 1.2 - - 1.05 - V IO = 8 mA; VCC = 2.3 V 1.8 - - 1.65 - V IO = 12 mA; VCC = 2.7 V 2.2 - - 2.05 - V IO = 18 mA; VCC = 3.0 V 2.4 - - 2.25 - V IO = 24 mA; VCC = 3.0 V 2.2 - - 2.0 - V IO = 100 A; VCC = 1.65 V to 3.6 V - - 0.2 - 0.3 V IO = 4 mA; VCC = 1.65 V - - 0.45 - 0.65 V IO = 8 mA; VCC = 2.3 V - - 0.6 - 0.8 V IO = 12 mA; VCC = 2.7 V - - 0.4 - 0.6 V IO = 24 mA; VCC = 3.0 V - VI = VIH or VIL VI = VIH or VIL - 0.55 - 0.8 V II input leakage VCC = 3.6 V; VI = 5.5 V or GND current 0.1 5 - 20 A ICC supply current VCC = 3.6 V; VI = VCC or GND; IO = 0 A - 0.1 10 - 40 A ICC additional supply current per input pin; - 5 500 - 5000 A VCC = 2.7 V to 3.6 V; VI = VCC  0.6 V; IO = 0 A input capacitance VCC = 0 V to 3.6 V; VI = GND to VCC - 5.0 - - - pF CI [1] All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 C. 74LVC273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 September 2013 © Nexperia B.V. 2017. All rights reserved 5 of 16 74LVC273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit, see Figure 8. Symbol Parameter tpd tPHL tW propagation delay HIGH to LOW propagation delay pulse width 40 C to +85 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max - 18 - - - ns VCC = 1.65 V to 1.95 V 2.5 9.7 19.2 2.5 22.2 ns VCC = 2.3 V to 2.7 V 1.8 4.9 9.9 1.8 11.4 ns VCC = 2.7 V 1.5 4.5 8.4 1.5 10.5 ns VCC = 3.0 V to 3.6 V 1.5 4.1 8.2 1.5 10.5 ns - 18 - - - ns VCC = 1.65 V to 1.95 V 2.4 10.2 20.4 2.4 23.5 ns VCC = 2.3 V to 2.7 V 1.7 5.2 10.5 1.7 12.1 ns VCC = 2.7 V 1.5 4.7 8.9 1.5 11.5 ns VCC = 3.0 V to 3.6 V 1.5 4.3 8.7 1.5 11.0 ns VCC = 1.65 V to 1.95 V 6.0 - - 6.0 - ns VCC = 2.3 V to 2.7 V 5.0 - - 5.0 - ns VCC = 2.7 V 5.0 1.8 - 5.0 - ns VCC = 3.0 V to 3.6 V 4.0 1.2 - 4.0 - ns VCC = 1.65 V to 1.95 V 6.0 - - 6.0 - ns VCC = 2.3 V to 2.7 V 5.0 - - 5.0 - ns VCC = 2.7 V 5.0 1.7 - 5.0 - ns VCC = 3.0 V to 3.6 V 4.0 1.2 - 4.0 - ns 2.0 - - 2.0 - ns CP to Qn; see Figure 5 VCC = 1.2 V [2] MR to Qn; see Figure 6 VCC = 1.2 V clock HIGH or LOW; see Figure 5 master reset LOW; see Figure 6 trec recovery time MR to CP; see Figure 6 VCC = 1.65 V to 1.95 V tsu th set-up time hold time 74LVC273_Q100 Product data sheet VCC = 2.3 V to 2.7 V 2.0 - - 2.0 - ns VCC = 2.7 V 2.0 1.0 - 2.0 - ns VCC = 3.0 V to 3.6 V 2.0 1.0 - 2.0 - ns Dn to CP; see Figure 7 VCC = 1.65 V to 1.95 V 5.0 - - 5.0 - ns VCC = 2.3 V to 2.7 V 3.5 - - 3.5 - ns VCC = 2.7 V 3.0 1.0 - 3.0 - ns VCC = 3.0 V to 3.6 V 1.0 0.0 - 1.0 - ns VCC = 1.65 V to 1.95 V 3.0 - - 3.0 - ns VCC = 2.3 V to 2.7 V 2.5 - - 2.5 - ns VCC = 2.7 V 2.0 0.2 - 2.0 - ns VCC = 3.0 V to 3.6 V 1.0 0.0 - 1.0 - ns Dn to CP; see Figure 7 All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 September 2013 © Nexperia B.V. 2017. All rights reserved 6 of 16 74LVC273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V). For test circuit, see Figure 8. Symbol Parameter fmax maximum frequency 40 C to +85 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max see Figure 5 VCC = 1.65 V to 1.95 V 80 - - 64 - MHz VCC = 2.3 V to 2.7 V 100 - - 80 - MHz VCC = 2.7 V 150 - - 150 - MHz 150 230 - 150 - MHz - - 1.0 - 1.5 ns - 14.0 - - - pF VCC = 2.3 V to 2.7 V - 17.7 - - - pF VCC = 3.0 V to 3.6 V - 21.0 - - - pF VCC = 3.0 V to 3.6 V [3] tsk(o) output skew time CPD power dissipation per flip-flop; VI = GND to VCC capacitance VCC = 1.65 V to 1.95 V VCC = 3.0 V to 3.6 V [4] [1] Typical values are measured at Tamb = 25 C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V and 3.3 V respectively. [2] tpd is the same as tPLH and tPHL. [3] Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design. [4] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volt N = number of inputs switching (CL  VCC2  fo) = sum of the outputs 11. Waveforms 1/fmax VI CP input VM VM GND tW t PHL t PLH VOH VM Qn output mna765 VOL Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 5. Clock (CP) to output (Qn) propagation delays, the clock pulse width, and the maximum frequency 74LVC273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 September 2013 © Nexperia B.V. 2017. All rights reserved 7 of 16 74LVC273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger VI VM MR input GND tW trec VI CP input VM GND tPHL VOH VM Qn output VOL mna464 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 6. Master reset (MR) pulse width, the master reset to output (Qn) propagation delays, and the master reset to clock (CP) recovery time VI VM CP input GND t su t su th th VI VM Dn input GND VOH VM Qn output VOL mna767 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. The shaded areas indicate when the input is permitted to change for predictable output performance. Fig 7. Data set-up and hold times for the data input (Dn) 74LVC273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 September 2013 © Nexperia B.V. 2017. All rights reserved 8 of 16 74LVC273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger Table 8. Measurement points Supply voltage Input Output VCC VI VM VM VX VY 1.2 V VCC 0.5  VCC 0.5  VCC VOL + 0.15 V VOH  0.15 V 1.65 V to 1.95 V VCC 0.5  VCC 0.5  VCC VOL + 0.15 V VOH  0.15 V 2.3 V to 2.7 V VCC 0.5  VCC 0.5  VCC VOL + 0.15 V VOH  0.15 V 2.7 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH  0.3 V 3.0 V to 3.6 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH  0.3 V VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VCC PULSE GENERATOR VI VO DUT RT CL RL 001aaf615 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. Fig 8. Table 9. Load circuitry for switching times Test data Supply voltage Input VCC VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 1.2 V VCC  2 ns 30 pF 1 k open 2  VCC GND 1.65 V to 1.95 V VCC  2 ns 30 pF 1 k open 2  VCC GND 2.3 V to 2.7 V VCC  2 ns 30 pF 500  open 2  VCC GND 2.7 V 2.7 V  2.5 ns 50 pF 500  open 2  VCC GND 3.0 V to 3.6 V 2.7 V  2.5 ns 50 pF 500  open 2  VCC GND 74LVC273_Q100 Product data sheet Load VEXT All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 September 2013 © Nexperia B.V. 2017. All rights reserved 9 of 16 74LVC273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 12. Package outline SO20: plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 D E A X c HE y v M A Z 20 11 Q A2 A (A 3) A1 pin 1 index θ Lp L 10 1 e bp detail X w M 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 13.0 12.6 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.01 0.019 0.013 0.014 0.009 0.51 0.49 0.30 0.29 0.05 0.419 0.043 0.055 0.394 0.016 inches 0.1 0.012 0.096 0.004 0.089 0.043 0.039 0.01 0.01 Z (1) 0.9 0.4 0.035 0.004 0.016 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig 9. REFERENCES OUTLINE VERSION IEC JEDEC SOT163-1 075E04 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT163-1 (SO20) 74LVC273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 September 2013 © Nexperia B.V. 2017. All rights reserved 10 of 16 74LVC273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 E D A X c HE y v M A Z 11 20 Q A2 (A 3) A1 pin 1 index A θ Lp L 1 10 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 6.6 6.4 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT360-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Fig 10. Package outline SOT360-1 (TSSOP20) 74LVC273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 September 2013 © Nexperia B.V. 2017. All rights reserved 11 of 16 74LVC273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT764-1 20 terminals; body 2.5 x 4.5 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 9 y y1 C v M C A B w M C b L 1 10 Eh e 20 11 19 12 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 4.6 4.4 3.15 2.85 2.6 2.4 1.15 0.85 0.5 3.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT764-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 11. Package outline SOT764-1 (DHVQFN20) 74LVC273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 September 2013 © Nexperia B.V. 2017. All rights reserved 12 of 16 74LVC273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 13. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC273_Q100 v.1 20130916 Product data sheet - - 74LVC273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 September 2013 © Nexperia B.V. 2017. All rights reserved 13 of 16 74LVC273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74LVC273_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 September 2013 © Nexperia B.V. 2017. All rights reserved 14 of 16 74LVC273-Q100 Nexperia Octal D-type flip-flop with reset; positive-edge trigger No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74LVC273_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 16 September 2013 © Nexperia B.V. 2017. All rights reserved 15 of 16 Nexperia 74LVC273-Q100 Octal D-type flip-flop with reset; positive-edge trigger 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 6 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13 Legal information. . . . . . . . . . . . . . . . . . . . . . . 14 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Contact information. . . . . . . . . . . . . . . . . . . . . 15 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 16 September 2013
74LVC273BQ-Q100X 价格&库存
很抱歉,暂时无法提供与“74LVC273BQ-Q100X”相匹配的价格&库存,您可以联系我们找货
