74ABT74PW,118
74ABT74PW,118
    NEXPERIA(安世)
    TSSOP-14
    具有置位和复位功能的双D型触发器;正边沿触发器
74ABT74PW,118 数据手册
74ABT74 Dual D-type flip-flop with set and reset; positive edge-trigger Rev. 2 — 12 August 2016 Product data sheet 1. General description The 74ABT74 high-performance BiCMOS device combines low static and dynamic power dissipation with high speed and high output drive. The 74ABT74 is a dual positive edge-triggered D-type flip-flop featuring individual data, clock, set, and reset inputs; also true and complementary outputs. Set (nSD) and reset (nRD) are asynchronous active low inputs and operate independently of the clock input. When set and reset are inactive (HIGH), data at the nD input is transferred to the nQ and nQ outputs on the LOW-to-HIGH clock transition. Data must be stable just one setup time prior to the LOW-to-HIGH clock transition for predictable operation. Clock triggering occurs at a voltage level and is not directly related to the transition time of the positive-going pulse. Following the hold time interval, data at the nD input may be changed without affecting the levels of the output. 2. Features and benefits  Latch-up protection exceeds 500 mA per JESD78B class II level A  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74ABT74D 40 C to +85 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74ABT74DB 40 C to +85 C SSOP14 plastic shrink small outline package; 14 leads; body width 5.3 mm SOT337-1 74ABT74PW 40 C to +85 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74ABT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 4. Functional diagram     6' 6'  6'     ' ' ' &3 &3 &3 4 4 4    4     )) 4 4 5'   5' 5'   Fig 1. 6  & '  5 6  & '  5 PQD PQD Logic symbol Fig 2. IEC logic symbol Q6' Q5' 4 4 Q&3 Q' Fig 3. DDD Logic diagram for one flip-flop 5. Pinning information 5.1 Pinning $%7 5'   9&& '   5' &3   ' 6' 4 4 *1'  $%7 5'   9&& '   5' &3   ' 6'   &3  6' 4   6'  4   4 *1'   4  &3     4 4 DDD DDD Fig 4. Pin configuration for SO14 74ABT74 Product data sheet Fig 5. Pin configuration for SSOP14 and TSSOP14 All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 August 2016 © Nexperia B.V. 2017. All rights reserved 2 of 15 74ABT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 5.2 Pin description Table 2. Pin description Symbol Pin Description 1RD, 2RD 1, 13 asynchronous reset-direct input (active LOW) 1D, 2D 2, 12 data input 1CP, 2CP 3, 11 clock input (LOW-to-HIGH, edge-triggered) 1SD, 2SD 4, 10 asynchronous set-direct input (active LOW) 1Q, 2Q 5, 9 output 1Q, 2Q 6, 8 complement output GND 7 ground (0 V) VCC 14 supply voltage 6. Functional description Table 3. Function table[1] Input Output Operating mode nSD nRD nCP nD nQ nQ L H X X H L Asynchronous set H L X X L H Asynchronous reset L L X X H H Undetermined[2] H H  h H L Load “1” H H  l L H Load “0” [1] H = HIGH voltage level h = HIGH voltage level one setup time prior to low-to-high clock transition L = LOW voltage level l = LOW voltage level one setup time prior to low-to-high clock transition X = don’t care  = LOW-to-HIGH clock transition [2] This setup is unstable and changes when either set or reset returns to the high level. 74ABT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 August 2016 © Nexperia B.V. 2017. All rights reserved 3 of 15 74ABT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +7.0 V [1] 1.2 +7.0 V [1] 0.5 +5.5 V VI input voltage VO output voltage output in OFF-state or HIGH-state IIK input clamping current VI < 0 V 18 - mA IOK output clamping current VO < 0 V 50 - mA IO output current output in LOW-state Tj junction temperature Tstg storage temperature [2] - 40 mA - 150 C 65 +150 C [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. The maximum junction temperature of this integrated circuit should not exceed 150 C. 8. Recommended operating conditions Table 5. Operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI input voltage VIH Conditions Min Typ Max Unit 4.5 - 5.5 V 0 - VCC V HIGH-level input voltage 2.0 - - V VIL LOW-level input voltage - - 0.8 V IOH HIGH-level output current 15 - - mA IOL LOW-level output current - - 20 mA t/V input transition rise and fall rate 0 - 10 ns/V Tamb ambient temperature 40 - +85 C 74ABT74 Product data sheet in free air All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 August 2016 © Nexperia B.V. 2017. All rights reserved 4 of 15 74ABT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 9. Static characteristics Table 6. Static characteristics Symbol Parameter 25 C Conditions 40 C to +85 C Unit Min Typ Max Min Max 1.2 0.9 - 1.2 - V 2.5 2.9 - 2.5 - V 0.5 - 0.5 V VIK input clamping voltage VCC = 4.5 V; IIK = 18 mA VOH HIGH-level output voltage VCC = 4.5 V; IOH = 15 mA; VI = VIL or VIH VOL LOW-level output voltage VCC = 4.5 V; IOL = 20 mA; VI = VIL or VIH - 0.35 II input leakage current VCC = 5.5 V; VI = GND or 5.5 V - 0.01 1.0 - 1.0 A IOFF power-off leakage current VCC = 0 V; VI or VO  4.5 V - 5.0 100 - 100 A ICEX output high leakage current HIGH-state; VO = 5.5 V; VCC = 5.5 V; VI = GND or VCC - 5.0 50 - 50 A IO output current VCC = 5.5 V; VO = 2.5 V 50 75 180 50 180 mA ICC supply current VCC = 5.5 V; VI = GND or VCC - 2 50 - 50 A - 0.25 500 - 500 A - 3 - - - pF ICC additional supply current per input pin; VCC = 5.5 V; one input at 3.4 V; other inputs at VCC or GND CI input capacitance VI = 0 V or VCC [1] [2] [1] Not more than one output should be tested at a time, and the duration of the test should not exceed one second. [2] This is the increase in supply current for each input at 3.4 V. 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; for test circuit, see Figure 9. Symbol Parameter 25 C; VCC = 5.0 V Conditions 40 C to +85 C; Unit VCC = 5.0 V  0.5 V Min Typ Max Min Max fmax maximum frequency nCP; see Figure 6 180 250 - 150 - tPLH LOW to HIGH propagation delay nCP to nQ, nQ; see Figure 6 1.0 3.0 4.2 1.0 4.7 ns tPHL HIGH to LOW propagation delay nCP to nQ, nQ; see Figure 6 1.0 2.5 3.5 1.0 4.0 ns tPLH LOW to HIGH propagation delay nSD, nRD to nQ, nQ; see Figure 7 1.0 3.4 4.9 1.0 6.2 ns tPHL HIGH to LOW propagation delay nSD, nRD to nQ, nQ; see Figure 7 1.0 2.9 4.5 1.0 5.2 ns tsk(o) output skew time - 0.5 0.6 - 0.6 ns 74ABT74 Product data sheet [1] All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 August 2016 © MHz Nexperia B.V. 2017. All rights reserved 5 of 15 74ABT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger Table 7. Dynamic characteristics …continued GND = 0 V; for test circuit, see Figure 9. Symbol Parameter tsu set-up time 25 C; VCC = 5.0 V Conditions 40 C to +85 C; Unit VCC = 5.0 V  0.5 V Min Typ Max Min Max nD to nCP HIGH; see Figure 6 2.6 1.4 - 2.6 - ns nD to nCP LOW; see Figure 6 2.4 1.4 - 2.4 - ns 0 1.4 - 0 - ns th hold time nD to nCP HIGH or LOW; see Figure 6 tW pulse width nCP HIGH or LOW; see Figure 6 1.7 1.0 - 2.1 - ns nSD, nRD LOW; see Figure 7 2.0 1.3 - 2.2 - ns trec recovery time nSD, nRD to nCP; see Figure 8 2.1 1.4 - 2.4 - ns [1] Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design. 11. Waveforms 9, 90 Q'LQSXW *1' WK WK W VX W VX IPD[ 9, 90 Q&3LQSXW *1' W: W 3+/ W 3/+ 92+ 90 Q4RXWSXW 92/ 92+ Q4RXWSXW 90 92/ W 3/+ W 3+/ PQD VM = 1.5 V The shaded areas indicate when the input is permitted to change for predictable output performance. VOL and VOH are typical output voltage levels that occur with the output load. Fig 6. Propagation delay clock input (nCP) to output (nQ, nQ), set-up and hold times data input (nD) to clock input, clock pulse width and maximum clock (nCP) frequency 74ABT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 August 2016 © Nexperia B.V. 2017. All rights reserved 6 of 15 74ABT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 9, 90 Q&3LQSXW *1' W UHF 9, 90 Q6'LQSXW *1' W: W: 9, 90 Q5'LQSXW *1' W 3/+ W 3+/ 92+ Q4RXWSXW 90 92/ 92+ 90 Q4RXWSXW 92/ W 3+/ W 3/+ PQD VM = 1.5 V VOL and VOH are typical output voltage levels that occur with the output load Fig 7. Propagation delay set (nSD) and reset (nSD) input to output (nQ, nQ), and set (nSD) and reset nRD pulse width. 9O 90 Q6'Q5'LQSXW *1' WUHF 9O Q&3LQSXW 90 *1' DDD VM = 1.5 V Fig 8. Recovery time set (nSD) and reset (nRD) to nCP 74ABT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 August 2016 © Nexperia B.V. 2017. All rights reserved 7 of 15 74ABT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 9, W:   QHJDWLYH SXOVH 90 9 9(;7 WI WU WU WI 9,  SRVLWLYH SXOVH 9 90   9&& *  9, 90 90  '87 57  W: 5/ 92 &/ PQD DDL a. Input pulse definition 5/ b. Test circuit Test data is given in Table 8. RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 9. Table 8. Test circuit for measuring switching times Test data Input Load VEXT VI fi tW tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 3.0 V 1 MHz 500 ns  2.5 ns 50 pF 500  open open 7.0 V 74ABT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 August 2016 © Nexperia B.V. 2017. All rights reserved 8 of 15 74ABT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 12. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV        ș R R  1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 10. Package outline SOT108-1 (SO14) 74ABT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 August 2016 © Nexperia B.V. 2017. All rights reserved 9 of 15 74ABT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 6623SODVWLFVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S /   GHWDLO; Z 0 ES H   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 11. Package outline SOT337-1 (SSOP14) 74ABT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 August 2016 © Nexperia B.V. 2017. All rights reserved 10 of 15 74ABT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ SLQLQGH[ $   $ $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWHV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 12. Package outline SOT402-1 (TSSOP14) 74ABT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 August 2016 © Nexperia B.V. 2017. All rights reserved 11 of 15 74ABT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 13. Abbreviations Table 9. Abbreviations Acronym Description BiCMOS Bipolar Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 14. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes 74ABT74A v.2 20160812 Product data sheet - 74ABT74A v.1 Modifications: 74ABT74A v.1 74ABT74 Product data sheet • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • Legal texts have been adapted to the new company name where appropriate. 19950922 Product specification - All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 August 2016 - © Nexperia B.V. 2017. All rights reserved 12 of 15 74ABT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74ABT74 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 August 2016 © Nexperia B.V. 2017. All rights reserved 13 of 15 74ABT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74ABT74 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 12 August 2016 © Nexperia B.V. 2017. All rights reserved 14 of 15 74ABT74 Nexperia Dual D-type flip-flop with set and reset; positive edge-trigger 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 5 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 12 August 2016
74ABT74PW,118 价格&库存
很抱歉,暂时无法提供与“74ABT74PW,118”相匹配的价格&库存,您可以联系我们找货
74ABT74PW,118
  • 2500+4.700222500+0.58298
  • 5000+4.582375000+0.56836
