74HC393; 74HCT393
Dual 4-bit binary ripple counter
Rev. 7.1 — 21 October 2020
Product data sheet
1. General description
The 74HC393; 74HCT393 is a dual 4-stage binary ripple counter. Each counter features a clock
input (nCP), an overriding asynchronous master reset input (nMR) and 4 buffered parallel outputs
(nQ0 to nQ3). The counter advances on the HIGH-to-LOW transition of nCP. A HIGH on nMR
clears the counter stages and forces the outputs LOW, independent of the state of nCP. Inputs
include clamp diodes. This enables the use of current limiting resistors to interface inputs to
voltages in excess of VCC.
2. Features and benefits
Wide supply voltage range from 2.0 V to 6.0 V
CMOS low power dissipation
High noise immunity
Latch-up performance exceeds 100 mA per JESD 78 Class II Level B
Complies with JEDEC standards:
• JESD8C (2.7 V to 3.6 V)
• JESD7A (2.0 V to 6.0 V)
Input levels:
• For 74HC393: CMOS level
• For 74HCT393: TTL level
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V.
Two 4-bit binary counters with individual clocks
Divide by any binary module up to 28 in one package
Two master resets to clear each 4-bit counter individually
3. Ordering information
Table 1. Ordering information
Type number
Package
74HC393D
Temperature range
Name
Description
Version
-40 °C to +125 °C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
-40 °C to +125 °C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
-40 °C to +125 °C
DHVQFN14 plastic dual in-line compatible thermal enhanced
very thin quad flat package; no leads; 14 terminals;
body 2.5 × 3 × 0.85 mm
74HCT393D
74HC393PW
74HCT393PW
74HC393BQ
74HCT393BQ
SOT762-1
74HC393; 74HCT393
Nexperia
4. Functional diagram
1
1Q0
1CP
1
2
1MR
13
2CP
2
12
2MR
CTR4
3
2
1Q1
4
1Q2
5
1Q3
6
2Q0
11
1
1
2Q1
10
2Q2
9
2Q3
8
CTR4
2
13
12
1MR
2CP
2MR
3
6
CT = 0
13
10
9
3
8
001aad533
1Q0
IEC logic symbol
3
1Q1
4
1Q2
5
1Q3
2Q0
4-BIT
BINARY
RIPPLE
COUNTER
5
CT
Fig. 2.
4-BIT
BINARY
RIPPLE
COUNTER
4
12
Logic symbol
1CP
3
CT
001aad532
Fig. 1.
CT = 0
11
2Q1
10
2Q2
9
2Q3
8
1
2
3
15
5
14
6
13
7
12
11
10
9
Functional diagram
CP
Fig. 4.
T
FF
1
8
001aad535
001aad534
Fig. 3.
4
Q
T
RD
FF
2
State diagram
Q
T
RD
FF
3
Q
T
RD
FF
4
Q
RD
MR
Q0
Q1
Q2
Q3
001aad536
Fig. 5.
Logic diagram (one counter)
74HC_HCT393
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2020. All rights reserved
2 / 15
74HC393; 74HCT393
Nexperia
5. Pinning information
5.1. Pinning
1CP
1
terminal 1
index area
1MR
2
13 2CP
1Q0
3
12 2MR
74HC393
74HCT393
1CP
1
14 VCC
1MR
2
13 2CP
1Q0
3
12 2MR
1Q1
4
11 2Q0
1Q2
5
10 2Q1
1Q1
4
11 2Q0
1Q3
6
9
2Q2
1Q2
5
10 2Q1
GND
7
8
2Q3
1Q3
6
9
2Q2
GND
7
8
2Q3
Fig. 6.
Pin configuration
SOT108-1 (SO14)
Fig. 7.
Pin configuration
SOT402-1 (TSSOP14)
12 2MR
1Q1
4
11 2Q0
1Q2
5
1Q3
6
VCC(1)
13 2CP
10 2Q1
9
2Q2
aaa-007521
Transparent top view
(1) This is not a supply pin. There
is no electrical or mechanical
requirement to solder the pad.
In case soldered, the solder
land should remain floating or
connected to VCC
aaa-007523
aaa-007518
3
2Q3
14 VCC
1Q0
8
1
2
7
1CP
1MR
GND
74HC393
74HCT393
14 VCC
74HC393
74HCT393
Fig. 8.
Pin configuration
SOT762-1 (DHVQFN14)
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
1CP
1
clock input (HIGH-to-LOW, edge-triggered)
1MR
2
asynchronous master reset input (active HIGH)
1Q0, 1Q1, 1Q2, 1Q3
3, 4, 5, 6
flip-flop output
GND
7
ground (0 V)
2Q3, 2Q2, 2Q1, 2Q0
8, 9, 10, 11
flip-flop output
2MR
12
2CP
13
VCC
14
supply voltage
74HC_HCT393
Product data sheet
3 / 15
74HC393; 74HCT393
Nexperia
6. Functional description
Table 3. Count sequence for one counter
H = HIGH voltage level; L = LOW voltage level.
Count
Output
nQ0
nQ1
nQ2
nQ3
L
L
L
L
1
H
L
L
L
2
L
H
L
L
3
H
H
L
L
4
L
L
H
L
5
H
L
H
L
6
L
H
H
L
7
H
H
H
L
8
L
L
L
H
9
H
L
L
H
10
L
H
L
H
11
H
H
L
H
12
L
L
H
H
13
H
L
H
H
14
L
H
H
H
15
H
H
H
H
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
Unit
-0.5
+7
V
VCC
supply voltage
IIK
input clamping current
VI < -0.5 V or VI > VCC + 0.5 V
±20
mA
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
±20
mA
IO
output current
VO = -0.5 V to VCC + 0.5 V
±25
mA
ICC
supply current
±50
mA
IGND
ground current
±50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
[1]
[1]
For SOT108-1 (SO14) package: Ptot derates linearly with 10.1 mW/K above 100 °C.
For SOT402-1 (TSSOP14) package: Ptot derates linearly with 7.3 mW/K above 81 °C.
For SOT762-1 (DHVQFN14) package: Ptot derates linearly with 9.6 mW/K above 98 °C.
74HC_HCT393
Product data sheet
4 / 15
74HC393; 74HCT393
Nexperia
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
74HC393
74HCT393
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
-40
+25
+125
-40
+25
+125
°C
Δt/ΔV
input transition rise and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
-40 °C to
+125 °C
Unit
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
VI = VIH or VIL
HIGH-level
output voltage
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = -4.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = -5.2 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
VI = VIH or VIL
LOW-level
output voltage
IO = 20 μA; VCC = 2.0 V
0.1
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
0.1
V
IO = 4.0 mA; VCC = 4.5 V
0.15
0.26
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
74HC393
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
0.16
0.26
0.33
0.4
V
II
input leakage VI = VCC or GND; VCC = 6.0 V
current
±0.1
±1.0
±1.0
μA
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
8.0
80
160
μA
CI
input
capacitance
3.5
pF
74HC_HCT393
Product data sheet
5 / 15
74HC393; 74HCT393
Nexperia
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Min
Typ
Max
Min
Max
Min
Max
Unit
74HCT393
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
0.8
V
VOH
VI = VIH or VIL; VCC = 4.5 V
HIGH-level
output voltage
IO = -20 μA
4.4
4.5
4.4
4.4
V
3.98
4.32
3.84
3.7
V
IO = -6 mA
VOL
LOW-level
output voltage
IO = 20 μA
IO = 6.0 mA
0.1
0.1
V
0.15
0.26
0.33
0.4
V
II
input leakage VI = VCC or GND; VCC = 5.5 V
current
±0.1
±1.0
±1.0
μA
ICC
VCC = 5.5 V
8.0
80
160
μA
ΔICC
VI = VCC - 2.1 V;
additional
supply current other inputs at VCC or GND;
VCC = 4.5 V to 5.5 V; IO = 0 A
per input pin; nCP
40
144
180
196
μA
per input pin; nMR
100
360
450
490
μA
3.5
pF
CI
input
capacitance
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Fig. 11.
Symbol Parameter
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
41
125
155
190
ns
VCC = 4.5 V
15
25
31
38
ns
VCC = 5 V; CL = 15 pF
12
ns
VCC = 6.0 V
12
21
26
32
ns
VCC = 2.0 V
14
45
55
70
ns
VCC = 4.5 V
5
9
11
14
ns
5
ns
VCC = 6.0 V
4
8
9
12
ns
74HC393
tpd
propagation
delay
nCP to nQ0; see Fig. 9
nQx to nQ(x+1); see Fig. 9
74HC_HCT393
Product data sheet
[1]
[1]
6 / 15
74HC393; 74HCT393
Nexperia
Symbol Parameter
tPHL
tt
tW
HIGH to LOW
propagation
delay
Conditions
25 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
39
140
175
210
ns
VCC = 4.5 V
14
28
35
42
ns
11
ns
VCC = 6.0 V
11
24
30
36
ns
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
VCC = 6.0 V
6
13
16
19
ns
VCC = 2.0 V
80
17
100
120
ns
VCC = 4.5 V
16
6
ns
VCC = 6.0 V
14
5
17
ns
VCC = 2.0 V
80
19
100
120
ns
VCC = 4.5 V
16
7
ns
VCC = 6.0 V
14
6
17
ns
VCC = 2.0 V
5
3
5
5
ns
VCC = 4.5 V
5
1
5
5
ns
VCC = 6.0 V
5
1
5
5
ns
VCC = 2.0 V
6
30
5
4
MHz
VCC = 4.5 V
30
90
24
MHz
99
MHz
35
107
28
24
MHz
23
pF
VCC = 4.5 V
15
25
31
38
ns
ns
VCC = 4.5 V
6
10
13
15
ns
6
ns
VCC = 4.5 V
18
32
40
48
ns
15
ns
7
15
19
22
ns
nMR to nQx; see Fig. 10
transition time Qn; see Fig. 9
pulse width
-40 °C to
+85 °C
[2]
nCP HIGH or LOW; see Fig. 9
nMR HIGH; see Fig. 10
trec
fclk(max)
recovery time
maximum
clock
frequency
nMR to nCP; see Fig. 10
see Fig. 9
VCC = 6.0 V
CPD
power
dissipation
capacitance
CL = 50 pF; f = 1 MHz;
VI = GND to VCC
[3]
[1]
74HCT393
tpd
propagation
delay
tPHL
tt
HIGH to LOW
propagation
delay
VCC = 4.5 V
74HC_HCT393
Product data sheet
[1]
[2]
7 / 15
74HC393; 74HCT393
Nexperia
Symbol Parameter
tW
pulse width
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
19
11
24
29
ns
16
6
ns
5
5
ns
27
48
22
18
MHz
53
MHz
25
pF
VCC = 4.5 V
VCC = 4.5 V
trec
recovery time
fclk(max)
maximum
clock
frequency
see Fig. 9
power
dissipation
capacitance
VI = GND to VCC - 1.5 V
VCC = 4.5 V
CPD
[1]
[2]
[3]
VCC = 4.5 V
[3]
tpd is the same as tPLH and tPHL.
tt is the same as tTHL and tTLH.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL × VCC × fo) = sum of outputs.
10.1. Waveforms
1/f max
VI
input nCP
VM
GND
t PHL
t PLH
VOH
output nQx
VM
VOL
t THL
t TLH
001aad537
Measurement points are given in Table 8.
VOL and VOH are the typical output voltage levels that occur with the output load.
Fig. 9.
Propagation delays clock (nCP) to output (nQx), the output transition times and the maximum clock
frequency
74HC_HCT393
Product data sheet
8 / 15
74HC393; 74HCT393
Nexperia
VI
input nMR
VM
GND
tW
t rec
VI
input nCP
VM
GND
t PHL
VOH
output nQx
VM
VOL
001aad538
Fig. 10. Propagation delays clock (nCP) to output (nQx), pulse width master reset (nMR), and recovery time
master reset (nMR) to clock (nCP)
Table 8. Measurement points
Type
Input
Output
VM
VM
74HC393
0.5VCC
0.5VCC
74HCT393
1.3 V
1.3 V
VI
negative
pulse
VM
VI
GND
VM
10 %
GND
positive
pulse
tW
90 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
DUT
VO
RT
CL
001aah768
Test data is given in Table 9.
Definitions test circuit:
RT = termination resistance should be equal to output impedance Zo of the pulse generator.
CL = load capacitance including jig and probe capacitance.
Fig. 11. Test circuit for measuring switching times
Table 9. Test data
Type
Load
Input
Test
VI
tr, tf
CL
74HC393
VCC
6.0 ns
15 pF, 50 pF
tPLH, tPHL
74HCT393
3.0 V
6.0 ns
15 pF, 50 pF
tPLH, tPHL
74HC_HCT393
Product data sheet
9 / 15
74HC393; 74HCT393
Nexperia
11. Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
A2
Q
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.05
0.01
0.01
0.004
0.028
0.012
0.244
0.039 0.028
0.041
0.228
0.016 0.024
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 12. Package outline SOT108-1 (SO14)
74HC_HCT393
Product data sheet
10 / 15
74HC393; 74HCT393
Nexperia
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
D
SOT402-1
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
7
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 13. Package outline SOT402-1 (TSSOP14)
74HC_HCT393
Product data sheet
11 / 15
74HC393; 74HCT393
Nexperia
DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
14 terminals; body 2.5 x 3 x 0.85 mm
B
D
SOT762-1
A
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
v
w
b
2
6
C A B
C
y
y1 C
L
1
7
14
8
Eh
e
k
13
9
Dh
X
k
Dimensions (mm are the original dimensions)
Unit
max
nom
min
mm
A(1)
1
A1
b
0.05 0.30
0.02 0.25
0.00 0.18
4 mm
scale
c
D(1)
Dh
E(1)
Eh
e
e1
0.2
3.1
3.0
2.9
1.65
1.50
1.35
2.6
2.5
2.4
1.15
1.00
0.85
0.5
2
k
L
v
0.2
0.5
0.4
0.3
0.1
w
y
0.05 0.05
y1
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
Outline
version
SOT762-1
References
IEC
JEDEC
JEITA
sot762-1_po
European
projection
Issue date
15-04-10
15-05-05
MO-241
Fig. 14. Package outline SOT762-1 (DHVQFN14)
74HC_HCT393
Product data sheet
12 / 15
74HC393; 74HCT393
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74HC_HCT393 v.7.1
20201021
Product data sheet
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type numbers 74HC393DB and 74HCT393DB (SOT337-1/SSOP14) removed.
Section 1 (Errata) and Section 2 updated.
Table 4: Derating values for Ptot total power dissipation updated.
v.7.1: Table 6: Values input leakage current for 74HC393 aligned with 74HCT393. (Errata)
74HC_HCT393 v.6
20151203
Modifications:
74HC_HCT393 v.5
20140401
Modifications:
74HC_HCT393 v.4
20130516
Modifications:
74HC_HCT393 v.6
Product data sheet
74HC_HCT393 v.5
Type numbers 74HC393N and 74HCT393N (SOT27-1) removed.
Product data sheet
74HC_HCT393 v.4
Table 7: The conditions for CPD have been corrected (errata).
Product data sheet
74HC_HCT393 v.3
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
74HC_HCT393 v.3
20050906
Product data sheet
74HC_HCT393_CNV v.2
74HC_HCT393_CNV v.2
19901201
Product specification
74HC_HCT393
Product data sheet
13 / 15
74HC393; 74HCT393
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74HC_HCT393
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
14 / 15
74HC393; 74HCT393
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................3
5.1. Pinning.........................................................................3
5.2. Pin description............................................................. 3
6. Functional description................................................. 4
7. Limiting values............................................................. 4
8. Recommended operating conditions..........................5
9. Static characteristics....................................................5
10. Dynamic characteristics............................................ 6
10.1. Waveforms.................................................................8
11. Package outline........................................................ 10
12. Abbreviations............................................................ 13
13. Revision history........................................................13
14. Legal information......................................................14
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 21 October 2020
74HC_HCT393
Product data sheet
15 / 15
