74HC161
Presettable synchronous 4-bit binary counter; asynchronous
reset
Rev. 4 — 4 October 2018
Product data sheet
1. General description
The 74HC161 is a synchronous presettable binary counter with an internal look-head carry.
Synchronous operation is provided by having all flip-flops clocked simultaneously on the positivegoing edge of the clock (CP). The outputs (Q0 to Q3) of the counters may be preset HIGH or LOW.
A LOW at the parallel enable input (PE) disables the counting action and causes the data at the
data inputs (D0 to D3) to be loaded into the counter on the positive-going edge of the clock. Preset
takes place regardless of the levels at count enable inputs (CEP and CET). A LOW at the master
reset input (MR) sets Q0 to Q3 LOW regardless of the levels at input pins CP, PE, CET and CEP
(thus providing an asynchronous clear function). The look-ahead carry simplifies serial cascading
of the counters. Both CEP and CET must be HIGH to count. The CET input is fed forward to enable
the terminal count output (TC). The TC output thus enabled will produce a HIGH output pulse of a
duration approximately equal to a HIGH output of Q0. This pulse can be used to enable the next
cascaded stage. The maximum clock frequency for the cascaded counters is determined by the CP
to TC propagation delay and CEP to CP set-up time, according to the following formula:
Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to
voltages in excess of VCC.
2. Features and benefits
Complies with JEDEC standard no. 7A
CMOS input levels
Synchronous counting and loading
2 count enable inputs for n-bit cascading
Asynchronous reset
Positive-edge triggered clock
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from -40 °C to +85 °C and -40 °C to +125 °C
3. Ordering information
Table 1. Ordering information
Type number Package
Temperature range Name
Description
Version
74HC161D
-40 °C to +125 °C
SO16
plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
74HC161DB
-40 °C to +125 °C
SSOP16
plastic shrink small outline package; 16 leads;
body width 5.3 mm
SOT338-1
74HC161PW
-40 °C to +125 °C
TSSOP16 plastic thin shrink small outline package; 16 leads;
body width 4.4 mm
SOT403-1
74HC161
Nexperia
Presettable synchronous 4-bit binary counter; asynchronous reset
4. Functional diagram
1
9
15
7
10
TC
3
D0
Q0
14
4
D1
Q1
13
5
D2
Q2
12
6
D3
Q3
11
9
PE
CEP CET
CP
2
3
4
MR
CTR4
R
M1
G3
G4
C2/1,3,4+
14
1,2D
13
5
12
6
11
15
4 CT = 15
7
Fig. 1.
10
2
1 mna905
mna906
Logic symbol
Fig. 2.
3
4
D0
9
10
7
2
1
PE
D1
6
D2
D3
PARALLEL LOAD
CIRCUITRY
CET
TC
CEP
15
BINARY
COUNTER
CP
MR
Q0
14
Fig. 3.
5
IEC logic symbol
Q1
13
Q2
12
Q3
11
mna907
Functional diagram
74HC161
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2018. All rights reserved
2 / 18
74HC161
Nexperia
D1
D0
D2
D3
CET
CEP
PE
D
FF0
Q
D
CP
RD
FF1
Q
D
CP
Q
RD
FF2
Q
D
CP
Q
RD
FF3
Q
CP
Q
RD
Q
CP
MR
Q0
Q1
Q2
Q3
TC
mna910
Fig. 4.
Logic diagram
74HC161
Product data sheet
3 / 18
74HC161
Nexperia
5. Pinning information
5.1. Pinning
74HC161
MR
1
16 VCC
CP
2
15 TC
D0
3
14 Q0
D1
4
13 Q1
D2
5
12 Q2
D3
6
11 Q3
CEP
7
10 CET
GND
8
9
74HC161
1
16 VCC
CP
2
15 TC
D0
3
14 Q0
D1
4
13 Q1
D2
5
12 Q2
D3
6
11 Q3
CEP
7
10 CET
GND
8
PE
9
PE
aaa-024397
aaa-024396
Fig. 5.
MR
Fig. 6.
Pin configuration SOT109-1 (SO16)
Pin configuration SOT338-1 (SSOP16) and
SOT403-1 (TSSOP16)
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
MR
1
asynchronous master reset (active LOW)
CP
2
clock input (LOW-to-HIGH, edge-triggered)
D0, D1, D2, D3
3, 4, 5, 6
data input
CEP
7
count enable input
GND
8
ground (0 V)
PE
9
parallel enable input (active LOW)
CET
10
count enable carry input
Q0, Q1, Q2, Q3
14, 13, 12, 11
flip-flop output
TC
15
VCC
16
supply voltage
74HC161
Product data sheet
4 / 18
74HC161
Nexperia
6. Functional description
Table 3. Function table[1]
Operating
Input
modes
MR
CP
CEP
CET
PE
Dn
Qn
TC
Reset (clear) L
X
X
X
X
X
L
L
H
X
X
l
l
L
L
Parallel load
Output
H
X
X
l
h
H
[2]
Count
H
h
h
h
X
count
[2]
Hold
(do nothing)
H
X
l
X
h
X
qn
[2]
H
X
X
l
h
X
qn
L
[1]
[2]
H = HIGH voltage level
h = HIGH voltage level one set-up time prior to the LOW-to-HIGH clock transition
L = LOW voltage level
l = LOW voltage level one set-up time prior to the LOW-to-HIGH clock transition
qn = lower case letters indicate the state of the referenced output one set-up time prior to the LOW-to-HIGH clock transition
X = don’t care
↑ = LOW-to-HIGH clock transition
The TC output is HIGH when CET is HIGH and the counter is at terminal count (HHHH)
2
3
4
15
5
14
6
13
7
12
11
10
9
8
aaa-012187
Fig. 7.
State diagram
74HC161
Product data sheet
5 / 18
74HC161
Nexperia
MR
PE
D0
D1
D2
D3
CP
CEP
CET
Q0
Q1
Q2
Q3
TC
12
reset
13
14
15
2
count
preset
inhibit
mna909
Typical timing sequence: reset outputs to zero; preset to binary twelve; count to thirteen, fourteen, fifteen, zero,
one and two; inhibit.
Fig. 8.
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
IOK
output clamping current
IO
output current
ICC
Min
Max
Unit
-0.5
+7.0
V
VI < -0.5 V or VI > VCC + 0.5 V
±20
mA
VO < -0.5 V or VO > VCC + 0.5 V
±20
mA
VO = -0.5 V to VCC + 0.5 V
±25
mA
supply current
50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
[1]
Conditions
[1]
For SO16 packages: above 70 °C the value of Ptot derates linearly at 8 mW/K.
For (T)SSOP16 packages: above 60 °C the value of Ptot derates linearly at 5.5 mW/K.
74HC161
Product data sheet
6 / 18
74HC161
Nexperia
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
Min
Typ
Max
Unit
2.0
5.0
6.0
V
VCC
V
VCC
V
-40
+25
+125
°C
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
25 °C
Min Typ
VIH
VIL
VOH
VOL
-40 °C to +85 °C -40 °C to +125 °C Unit
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
VI = VIH or VIL
HIGH-level
output voltage
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = -4.0; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = -5.2; VCC = 6.0 V
HIGH-level
input voltage
LOW-level
input voltage
5.48
5.81
5.34
5.2
V
VI = VIH or VIL
LOW-level
output voltage
IO = 20 μA; VCC = 2.0 V
0.1
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
0.1
V
IO = 4.0 mA; VCC = 4.5 V
0.15
0.26
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
0.16
0.26
0.33
0.4
V
±0.1
±1.0
±1.0
μA
II
input leakage
current
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
8.0
80.0
160.0
μA
CI
input
capacitance
3.5
pF
74HC161
Product data sheet
VI = VCC or GND; VCC = 6.0 V
7 / 18
74HC161
Nexperia
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Fig. 14.
Symbol Parameter
tpd
propagation
delay
Conditions
25 °C
-40 °C to +85 °C
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
61
190
240
285
ns
VCC = 4.5 V
22
38
48
57
ns
VCC = 5.0 V; CL = 15 pF
19
ns
VCC = 6.0 V
18
32
41
48
ns
VCC = 2.0 V
69
215
270
325
ns
VCC = 4.5 V
25
43
54
65
ns
21
ns
VCC = 6.0 V
46
55
ns
VCC = 2.0 V
33
150
190
225
ns
VCC = 4.5 V
12
30
38
45
ns
10
ns
VCC = 6.0 V
10
26
38
31
ns
VCC = 2.0 V
63
210
265
315
ns
VCC = 4.5 V
23
42
53
63
ns
ns
VCC = 6.0 V
18
36
45
54
ns
VCC = 2.0 V
63
220
275
330
ns
VCC = 4.5 V
23
44
55
66
ns
ns
VCC = 6.0 V
18
37
47
56
ns
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
VCC = 6.0 V
6
13
16
19
ns
VCC = 2.0 V
80
22
100
120
ns
VCC = 4.5 V
16
8
ns
VCC = 6.0 V
14
6
17
ns
VCC = 2.0 V
80
19
100
120
ns
VCC = 4.5 V
16
7
ns
VCC = 6.0 V
14
6
17
ns
CP to Qn; see Fig. 9
[1]
CP to TC; see Fig. 9
CET to TC; see Fig. 10
tPHL
HIGH to LOW
propagation
delay
MR to Qn; see Fig. 11
MR to TC; see Fig. 11
tt
tW
transition
time
pulse width
see Fig. 9 and Fig. 10
[2]
CP; HIGH or LOW; see Fig. 9
MR; LOW; see Fig. 11
74HC161
Product data sheet
8 / 18
74HC161
Nexperia
Symbol Parameter
trec
recovery
time
tsu
set-up time
Conditions
25 °C
-40 °C to +85 °C
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
100
19
125
150
ns
VCC = 4.5 V
25
30
ns
VCC = 6.0 V
17
6
21
26
ns
VCC = 2.0 V
80
25
100
120
ns
VCC = 4.5 V
16
9
ns
VCC = 6.0 V
14
7
17
ns
VCC = 2.0 V
100
30
125
150
ns
VCC = 4.5 V
25
30
ns
VCC = 6.0 V
17
9
21
26
ns
VCC = 2.0 V
170
47
215
255
ns
VCC = 4.5 V
34
17
43
51
ns
VCC = 6.0 V
29
14
37
43
ns
VCC = 2.0 V
ns
VCC = 4.5 V
ns
VCC = 6.0 V
ns
VCC = 2.0 V
4.6
13
3.6
3.0
MHz
VCC = 4.5 V
23
40
18
15
MHz
44
MHz
27
48
21
18
MHz
33
pF
MR to CP; see Fig. 11
Dn to CP; see Fig. 12
PE to CP; see Fig. 12
CEP, CET to CP; see Fig. 13
th
hold time
fmax
maximum
frequency
Dn, PE, CEP, CET to CP;
see Fig. 12 and Fig. 13
CP; see Fig. 9
VCC = 6.0 V
CPD
[1]
[2]
[3]
power
dissipation
capacitance
VI = GND to VCC; VCC = 5 V; [3]
fi = 1 MHz
tpd is the same as tPHL and tPLH.
tt is the same as tTHL and tTLH.
CPD is used to determine the dynamic power dissipation (PD in μW):
2
2
PD = CPD x VCC x fi × N + ∑(CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
∑(CL x VCC x fo) = sum of outputs.
74HC161
Product data sheet
9 / 18
74HC161
Nexperia
10.1. Waveforms and test circuit
1/fmax
VI
CP input
VM
GND
tW
tPHL
VOH
Qn, TC
output
tPLH
90 %
90 %
VM
10 %
VOL
10 %
tTHL
tTLH
aaa-012353
Measurement points are given in Table 8.
Logic levels VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 9.
The clock (CP) to outputs (Qn, TC) propagation delays, pulse width, output transition times and maximum
frequency
VI
CET input
VM
GND
tPLH
tPHL
VOH
90 %
TC output
VOL
10 %
90 %
VM
10 %
tTLH
tTHL
aaa-012354
Fig. 10. The count enable carry input (CET) to terminal count output (TC) propagation delays and output transition
times
VI
VM
MR input
GND
t rec
tW
VI
CP input
VM
GND
t PHL
VOH
Qn, TC output
VM
VOL
mna913
Fig. 11. The master reset (MR) pulse width, master reset to output (Qn, TC) propagation delays, and the master
reset to clock (CP) recovery times
74HC161
Product data sheet
10 / 18
74HC161
Nexperia
VI
VM
PE input
GND
tsu
VI
tsu
th
th
VM
CP input
GND
tsu
VI
tsu
th
th
VM
Dn input
GND
aaa-012356
The shaded areas indicate when the input is permitted to change for predictable output performance.
Fig. 12. The data input (Dn) and parallel enable input (PE) set-up and hold times
CEP, CET
input
VI
VM
GND
tsu
VI
CP input
th
tsu
th
VM
GND
aaa-012358
Fig. 13. The count enable input (CEP) and count enable carry input (CET) set-up and hold times
Table 8. Measurement points
Input
Output
VM
VI
VM
0.5 × VCC
GND to VCC
0.5 × VCC
74HC161
Product data sheet
11 / 18
74HC161
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
DUT
VCC
VO
RT
RL
S1
open
CL
001aad983
Test data is given in Table 9.
Test circuit definitions:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator
CL = Load capacitance including jig and probe capacitance
RL = Load resistance.
S1 = Test selection switch
Fig. 14. Test circuit for measuring switching times
Table 9. Test data
Input
S1 position
Load
VI
tr, tf
CL
RL
tPHL, tPLH
VCC
6 ns
15 pF, 50 pF
1 kΩ
open
74HC161
Product data sheet
12 / 18
74HC161
Nexperia
11. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
w M
bp
detail X
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.16
0.15
0.039
0.016
0.028
0.020
inches
0.010 0.057
0.069
0.004 0.049
0.05
0.244
0.041
0.228
0.01
0.01
0.028
0.004
0.012
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 15. Package outline SOT109-1 (SO16)
74HC161
Product data sheet
13 / 18
74HC161
Nexperia
SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm
D
SOT338-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
L
8
1
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
2
0.21
0.05
1.80
1.65
0.25
0.38
0.25
0.20
0.09
6.4
6.0
5.4
5.2
0.65
7.9
7.6
1.25
1.03
0.63
0.9
0.7
0.2
0.13
0.1
1.00
0.55
8o
0o
Note
1. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT338-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-150
Fig. 16. Package outline SOT338-1 (SSOP16)
74HC161
Product data sheet
14 / 18
74HC161
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
D
SOT403-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
8
detail X
w M
bp
e
5 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 17. Package outline SOT403-1 (TSSOP16)
74HC161
Product data sheet
15 / 18
74HC161
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC161 v.4
20181004
Product data sheet
74HC161 v.3
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
74HC161 v.3
20170104
Modifications:
74HC_HCT161 v.2
74HC161
Product data sheet
Product data sheet
74HC_HCT161 v.2
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Type numbers 74HCT161D, 74HCT161DB, 74HCT161PW removed.
19901201
Product specification
16 / 18
74HC161
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74HC161
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
17 / 18
74HC161
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................4
5.1. Pinning.........................................................................4
5.2. Pin description............................................................. 4
6. Functional description................................................. 5
7. Limiting values............................................................. 6
8. Recommended operating conditions..........................7
9. Static characteristics....................................................7
10. Dynamic characteristics............................................ 8
10.1. Waveforms and test circuit...................................... 10
11. Package outline........................................................ 13
12. Abbreviations............................................................ 16
13. Revision history........................................................16
14. Legal information......................................................17
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 4 October 2018
74HC161
Product data sheet
18 / 18
