74HC4040-Q100;
74HCT4040-Q100
12-stage binary ripple counter
Rev. 2 — 8 June 2020
Product data sheet
1. General description
The 74HC4040-Q100; 74HCT4040-Q100 is a 12-stage binary ripple counter with a clock input
(CP), an overriding asynchronous master reset input (MR) and twelve parallel outputs (Q0 to Q11).
The counter advances on the HIGH-to-LOW transition of CP. A HIGH on MR clears all counter
stages and forces all outputs LOW, independent of the state of CP. Each counter stage is a static
toggle flip-flop. Inputs include clamp diodes that enable the use of current limiting resistors to
interface inputs to voltages in excess of VCC.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
Wide supply voltage range from 2.0 V to 6.0 V
CMOS low power dissipation
High noise immunity
Latch-up performance exceeds 100 mA per JESD 78 Class II Level B
Complies with JEDEC standards:
• JESD8C (2.7 V to 3.6 V)
• JESD7A (2.0 V to 6.0 V)
Input levels:
• For 74HC4040-Q100: CMOS level
• For 74HCT4040-Q100: TTL level
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω)
Multiple package options
DHVQFN package with Side-Wettable Flanks enabling Automatic Optical Inspection (AOI) of
solder joints
3. Applications
Frequency dividing circuits
Time delay circuits
Control counters
Nexperia
4. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
-40 °C to +125 °C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
74HC4040DB-Q100
-40 °C to +125 °C
SSOP16
plastic shrink small outline package;
16 leads; body width 5.3 mm
SOT338-1
74HC4040PW-Q100
-40 °C to +125 °C
TSSOP16
plastic thin shrink small outline package;
16 leads; body width 4.4 mm
SOT403-1
-40 °C to +125 °C
DHVQFN16 plastic dual in-line compatible
thermal enhanced very thin quad
flat package; no leads; 16 terminals;
body 2.5 × 3.5 × 0.85 mm
74HC4040D-Q100
74HCT4040D-Q100
74HCT4040PW-Q100
74HC4040BQ-Q100
74HCT4040BQ-Q100
SOT763-1
5. Functional diagram
CP
MR
10
11
T
12-STAGE COUNTER
CD
9
7
6
5
3
2
4
13
12
14
15
1
Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 Q8 Q9 Q10 Q11
001aad589
Fig. 1.
Functional diagram
CTR12
10
11
CP
MR
Q0
Q1
Q2
Q3
Q4
Q5
Q6
Q7
Q8
Q9
Q10
Q11
9
7
6
5
3
2
4
13
12
14
15
1
10
11
CT = 0
CT
11
Logic symbol
74HC_HCT4040_Q100
Product data sheet
9
7
6
5
3
2
4
13
12
14
15
1
001aad586
001aad585
Fig. 2.
Fig. 3.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2020. All rights reserved
2 / 17
Nexperia
FF
T 1
CP
Q
FF
T 2
Q
Q
FF
T 3
Q
RD
Q
FF
T 4
Q
RD
Q
FF
T 5
Q
RD
Q
FF
T 6
Q
RD
Q
Q
RD
RD
MR
Q0
FF
T 7
Q
Q1
FF
T 8
Q
Q
Q2
FF
T 9
Q
RD
Q
Q3
FF
T 10
Q
RD
Q7
FF
T 11
Q
RD
Q6
Q
Q4
Q
FF
T 12
Q
RD
Q8
Q5
Q
RD
Q9
Q
RD
Q10
Q11
001aad588
Fig. 4.
Logic diagram
6. Pinning information
1
terminal 1
index area
2
15 Q10
Q4
3
14 Q9
Q6
4
Q3
5
Q2
6
11 MR
Q1
7
10 CP
GND
8
13 Q7
4040
12 Q8
9
Product data sheet
14 Q9
4
Q3
5
Q2
6
Q1
7
4040
GND(1)
13 Q7
12 Q8
11 MR
10 CP
001aad584
Transparent top view
Q0
Pin configuration SOT109-1 (SO16) , SOT338-1
(SSOP16) and SOT403-1 (TSSOP16)
74HC_HCT4040_Q100
3
Q6
(1) This is not a ground pin. There is no electrical or
mechanical requirement to solder the pad. In case
soldered, the solder land should remain floating or
connected to GND.
001aad583
Fig. 5.
Q4
9
Q5
15 Q10
Q0
16 VCC
2
8
1
Q5
GND
Q11
16 VCC
Q11
6.1. Pinning
Fig. 6.
Pin configuration SOT763-1 (DHVQFN16)
3 / 17
Nexperia
6.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
Q11
1
output 11
Q5
2
output 5
Q4
3
output 4
Q6
4
output 6
Q3
5
output 3
Q2
6
output 2
Q1
7
output 1
GND
8
ground (0 V)
Q0
9
output 0
CP
10
clock input (HIGH-to-LOW, edge-triggered)
MR
11
master reset input (active HIGH)
Q8
12
output 8
Q7
13
output 7
Q9
14
output 9
Q10
15
output 10
VCC
16
positive supply voltage
7. Functional description
7.1. Function table
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care;
↑ = LOW-to-HIGH clock transition; ↓ = HIGH-to-LOW clock transition.
Output
Input
CP
MR
Q0 to Q11
L
no change
L
count
X
H
L
74HC_HCT4040_Q100
Product data sheet
4 / 17
Nexperia
7.2. Timing diagram
CP input
1
2
4
8
16
32
64
128
256
512 1024 2048 4096
MR input
Q0
Q1
Q2
Q3
Q4
Q5
Q6
Q7
Q8
Q9
Q10
Q11
001aad587
Fig. 7.
Timing diagram
8. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI < -0.5 V or VI > VCC + 0.5 V
IOK
output clamping current
IO
output current
-0.5 V < VO < VCC + 0.5 V
ICC
IGND
Tstg
storage temperature
Ptot
total power dissipation
[1]
[2]
Conditions
Min
Max
-0.5
+7
V
[1]
±20
mA
[1]
±20
mA
±25
mA
supply current
±50
mA
ground current
±50
mA
-65
+150
°C
500
mW
Tamb = -40 °C to +125 °C
[2]
Unit
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C.
For SOT338-1 (SSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C.
For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C.
For SOT763-1 (DHVQFN16) package: Ptot derates linearly with 11.2 mW/K above 106 °C.
74HC_HCT4040_Q100
Product data sheet
5 / 17
Nexperia
9. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
74HC4040-Q100
74HCT4040-Q100
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
-40
+25
+125
-40
+25
+125
°C
Δt/ΔV
input transition rise and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
10. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
25 °C
-40 °C to +85 °C -40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
74HC4040-Q100
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output voltage
LOW-level
output voltage
VI = VIH or VIL
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = -4.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = -5.2 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
IO = 20 μA; VCC = 2.0 V
0.1
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
0.1
V
IO = 4.0 mA; VCC = 4.5 V
0.15
0.26
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
0.16
0.26
0.33
0.4
V
VI = VIH or VIL
II
input leakage
current
VI = VCC or GND; VCC = 6.0 V
±0.1
±1.0
±1.0
μA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
8.0
80
160
μA
CI
input
capacitance
3.5
74HC_HCT4040_Q100
Product data sheet
pF
6 / 17
Nexperia
Symbol Parameter
Conditions
25 °C
Min
Typ
Max
Min
Max
Min
Max
74HCT4040-Q100
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
0.8
V
VOH
HIGH-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
IO = -20 μA
4.4
4.5
4.4
4.4
V
IO = -4 mA
3.98
4.32
3.84
3.7
V
IO = 20 μA
0.1
0.1
V
IO = 4.0 mA
LOW-level
output voltage
0.15
0.26
0.33
0.4
V
II
input leakage
current
VI = VCC or GND; VCC = 5.5 V
±0.1
±1.0
±1.0
μA
ICC
supply current
VCC = 5.5 V
8.0
80
160
μA
ΔICC
additional
supply current
per input pin; VI = VCC - 2.1 V;
IO = 0 A; other inputs at VCC
or GND; VCC = 4.5 V to 5.5 V
VOL
CI
input
capacitance
74HC_HCT4040_Q100
Product data sheet
pin CP
85
306
383
417
μA
pin MR
110
396
495
539
μA
3.5
pF
7 / 17
Nexperia
11. Dynamic characteristics
Table 7. Dynamic characteristics
GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Fig. 9.
Symbol Parameter
Conditions
25 °C
Min Typ Max
Min
Max
Min
Max
74HC4040-Q100
tpd
propagation
delay
CP to Q0; see Fig. 8
[1]
VCC = 2.0 V
47
150
190
225
ns
VCC = 4.5 V
17
30
38
45
ns
VCC = 5.0 V; CL = 15 pF
14
ns
VCC = 6.0 V
14
26
33
38
ns
VCC = 2.0 V
28
100
125
150
ns
VCC = 4.5 V
10
30
ns
8
ns
VCC = 6.0 V
8
17
21
26
ns
61
185
230
280
ns
22
37
46
56
ns
18
31
39
48
ns
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
VCC = 6.0 V
6
13
16
19
ns
VCC = 2.0 V
80
14
100
120
ns
VCC = 4.5 V
16
5
ns
VCC = 6.0 V
14
4
17
ns
VCC = 2.0 V
80
22
100
120
ns
VCC = 4.5 V
16
8
ns
VCC = 6.0 V
14
6
17
ns
VCC = 2.0 V
50
8
65
75
ns
VCC = 4.5 V
10
3
13
15
ns
VCC = 6.0 V
9
2
11
13
ns
VCC = 2.0 V
6
27
4.8
4
MHz
VCC = 4.5 V
30
82
24
MHz
90
MHz
35
98
28
24
MHz
Qn to Qn+1; see Fig. 8
tPHL
HIGH to LOW MR to Qn; see Fig. 8
propagation
VCC = 2.0 V
delay
VCC = 4.5 V
VCC = 6.0 V
tt
tW
transition time Qn; see Fig. 8
pulse width
[2]
CP input, HIGH or LOW;
see Fig. 8
MR input, HIGH; see Fig. 8
trec
fmax
recovery time
maximum
frequency
MR to CP; see Fig. 8
CP input; see Fig. 8
VCC = 6.0 V
74HC_HCT4040_Q100
Product data sheet
8 / 17
Nexperia
Symbol Parameter
Conditions
25 °C
Min Typ Max
CPD
power
dissipation
capacitance
VI = GND to VCC
[3]
[1]
Min
Max
Min
Max
pF
VCC = 4.5 V
19
40
50
60
ns
16
ns
VCC = 4.5 V
10
30
ns
8
ns
23
45
56
68
ns
7
15
19
22
ns
16
7
ns
16
6
ns
10
2
13
15
ns
30
72
24
MHz
79
MHz
pF
74HCT4040-Q100
tpd
propagation
delay
tPHL
propagation
VCC = 4.5 V
delay
tt
tW
pulse width
[2]
VCC = 4.5 V
see Fig. 8
VCC = 4.5 V
VCC = 4.5 V
trec
recovery time
VCC = 4.5 V
fmax
maximum
frequency
power
dissipation
capacitance
VI = GND to VCC
VCC = 4.5 V
CPD
[1]
[2]
[3]
[3]
tpd is the same as tPHL, tPLH.
tt is the same as tTHL, tTLH.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD x VCC x fi x N + ∑(CL x VCC x fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
∑(CL x VCC x fo) = sum of outputs.
74HC_HCT4040_Q100
Product data sheet
9 / 17
Nexperia
11.1. Waveforms and test circuit
VI
VM
MR input
tW
trec
VI
1/fmax
VM
CP input
tPHL
tW
tPLH
90 %
Q0 or Qn
output
tPHL
90 %
10 %
VM
10 %
tTLH
tTHL
001aad590
74HC4040-Q100: VM = 50 %; VI = GND to VCC.
74HCT4040-Q100: VM = 1.3 V; VI = GND to 3 V.
Fig. 8.
Clock propagation delays, pulse width, transition times, maximum pulse frequency and master resets
VI
negative
pulse
VM
tf
tr
tr
VI
GND
VM
10 %
GND
positive
pulse
tW
90 %
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
DUT
VO
RT
CL
001aah768
Test data is given in Table 8.
Definitions test circuit:
RT = termination resistance should be equal to output impedance Zo of the pulse generator.
CL = load capacitance including jig and probe capacitance.
Fig. 9.
Test circuit for measuring switching times
Table 8. Test data
Type
Load
Input
Test
VI
tr, tf
CL
74HC4040-Q100
VCC
6.0 ns
15 pF, 50 pF
tPLH, tPHL
74HCT4040-Q100
3.0 V
6.0 ns
15 pF, 50 pF
tPLH, tPHL
74HC_HCT4040_Q100
Product data sheet
10 / 17
Nexperia
12. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
w M
bp
detail X
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.16
0.15
0.05
0.039
0.016
0.028
0.020
0.01
0.01
0.004
0.028
0.012
0.244
0.041
0.228
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 10. Package outline SOT109-1 (SO16)
74HC_HCT4040_Q100
Product data sheet
11 / 17
Nexperia
SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm
D
SOT338-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
L
8
1
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
2
0.21
0.05
1.80
1.65
0.25
0.38
0.25
0.20
0.09
6.4
6.0
5.4
5.2
0.65
7.9
7.6
1.25
1.03
0.63
0.9
0.7
0.2
0.13
0.1
1.00
0.55
8o
0o
Note
1. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT338-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-150
Fig. 11. Package outline SOT338-1 (SSOP16)
74HC_HCT4040_Q100
Product data sheet
12 / 17
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
D
SOT403-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
8
detail X
w M
bp
e
5 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 12. Package outline SOT403-1 (TSSOP16)
74HC_HCT4040_Q100
Product data sheet
13 / 17
Nexperia
DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT763-1
16 terminals; body 2.5 x 3.5 x 0.85 mm
B
D
A
A
E
A1
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
b
2
7
y
y1 C
v M C A B
w M C
L
1
8
Eh
e
16
9
15
10
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
c
D (1)
Dh
E (1)
Eh
e
e1
L
v
w
y
y1
mm
1
0.05
0.00
0.30
0.18
0.2
3.6
3.4
2.15
1.85
2.6
2.4
1.15
0.85
0.5
2.5
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT763-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig. 13. Package outline SOT763-1 (DHVQFN16)
74HC_HCT4040_Q100
Product data sheet
14 / 17
Nexperia
13. Abbreviations
Table 9. Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 10. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT4040_Q100 v.2 20200608
Product data sheet
74HC_HCT4040_Q100 v.1
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type number 74HCT4040DB-Q100 (SOT338-1/SSOP16) removed.
Section 2 updated.
Table 4: Derating values for Ptot total power dissipation have been updated.
74HC_HCT4040_Q100 v.1 20140324
74HC_HCT4040_Q100
Product data sheet
Product data sheet
15 / 17
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
15. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74HC_HCT4040_Q100
Product data sheet
16 / 17
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Ordering information....................................................2
5. Functional diagram.......................................................2
6. Pinning information......................................................3
6.1. Pinning.........................................................................3
6.2. Pin description............................................................. 4
7. Functional description................................................. 4
7.1. Function table.............................................................. 4
7.2. Timing diagram............................................................ 5
8. Limiting values............................................................. 5
9. Recommended operating conditions..........................6
10. Static characteristics..................................................6
11. Dynamic characteristics.............................................8
11.1. Waveforms and test circuit.......................................10
12. Package outline........................................................ 11
13. Abbreviations............................................................ 15
14. Revision history........................................................15
15. Legal information......................................................16
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 8 June 2020
74HC_HCT4040_Q100
Product data sheet
17 / 17
