74LV4060PW-Q100J
74LV4060PW-Q100J
    NEXPERIA(安世)
    TSSOP16_5X4.4MM
    IC COUNTER 14STAGE BIN 16TSSOP
74LV4060PW-Q100J 数据手册
74LV4060-Q100 14-stage binary ripple counter with oscillator Rev. 1 — 25 July 2014 Product data sheet 1. General description The 74LV4060-Q100 is a low-voltage Si-gate CMOS device and is pin and function compatible with the 74HC4060-Q100; 74HCT4060-Q100. The 74LV4060-Q100 is a 14-stage ripple-carry counter/divider and oscillator with three oscillator terminals (RS, RTC and CTC). It has ten buffered outputs (Q3 to Q9 and Q11 to Q13) and an overriding asynchronous master reset (MR). The oscillator configuration allows design of either RC or crystal oscillator circuits. The oscillator can be replaced by an external clock signal at input RS. In this case, keep the oscillator pins (RTC and CTC) floating. The counter advances on the negative-going transition of RS. A HIGH-level on MR resets the counter (Q3 to Q9 and Q11 to Q13 = LOW), independent of the other input conditions. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Wide operating voltage range from 1.0 V to 5.5 V  Optimized for low voltage applications from 1.0 V to 3.6 V  Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V  Typical VOLP (output ground bounce) < 0.8 V at VCC = 3.3 V; Tamb = 25 C  Typical VOHV (output VOH undershoot) > 2 V at VCC = 3.3 V; Tamb = 25 C  All active components on chip  RC or crystal oscillator configuration  Complies with JEDEC standard no. 7A  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 ) 3. Applications     Control counters Timers Frequency dividers Time-delay circuits 74LV4060-Q100 Nexperia 14-stage binary ripple counter with oscillator 4. Ordering information Table 1. Ordering information Type number 74LV4060D-Q100 Package Temperature range Name Description Version 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 74LV4060PW-Q100 40 C to +125 C 5. Functional diagram   57& &7&   56 05 4  4  4  4  4  4  4  4  4  4  DDL Fig 1. Logic symbol &75  &75  * &7&      57&  56    05   &7 &7     $1'       &7   &7            D   E DDL Fig 2. IEC logic symbol 74LV4060_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 25 July 2014 © Nexperia B.V. 2017. All rights reserved 2 of 21 74LV4060-Q100 Nexperia 14-stage binary ripple counter with oscillator &7& ))  57& 56 ))  ))  &3 &3 &3 &3 4 05 4 05 4 05 4 05 ))  &3 4 4 05 ))  4 05 4 4 DDL Fig 3. Logic diagram   57&   &7& 56 &3 05 67$*(%,1$5
74LV4060PW-Q100J
物料型号:74LV4060-Q100
器件简介:74LV4060-Q100是一款低压硅门CMOS设备,与74HC4060-Q100和74HCT4060-Q100引脚和功能兼容。它是一个具有三个振荡器端点(RS、RTC和CTC)的14级涟漪进位计数器/分频器和振荡器。该设备具有十个缓冲输出(Q3到Q9和Q11到Q13)以及一个覆盖的异步主复位(MR)。振荡器配置允许设计RC或晶体振荡器电路。在RS输入端可以替换为外部时钟信号,此时应使振荡器引脚(RTC和CTC)悬空。
引脚分配:文档提供了详细的引脚配置图和引脚描述表,包括计数器输出、接地、外部电容连接、外部电阻连接、时钟输入/振荡器引脚、主复位和供电电压等。
参数特性:产品符合汽车电子委员会(AEC)标准Q100(1级),适用于汽车应用。工作电压范围宽,从1.0V至5.5V,优化用于1.0V至3.6V的低电压应用,接受在VCC为2.7V至3.6V之间的TTL输入电平。
功能详解:计数器在RS的负跳变上前进。MR上的高电平独立于其他输入条件重置计数器(Q3到Q9和Q11到Q13 = 低)。振荡器配置允许设计RC或晶体振荡器电路,或者可以用外部时钟信号替换振荡器。
应用信息:适用于控制计数器、定时器、频率分频器和延时电路。
封装信息:提供SO16和TSSOP16两种封装类型,详细描述了封装的尺寸和特性。
74LV4060PW-Q100J 价格&库存
很抱歉,暂时无法提供与“74LV4060PW-Q100J”相匹配的价格&库存,您可以联系我们找货
