74LV393PW-Q100J
74LV393PW-Q100J
    NEXPERIA(安世)
    TSSOP-14
    IC RIPPLE COUNTER 4B BIN 14TSSOP
74LV393PW-Q100J 数据手册
74LV393-Q100 Dual 4-bit binary ripple counter Rev. 2 — 17 September 2014 Product data sheet 1. General description The 74LV393-Q100 is a low–voltage Si-gate CMOS device and is pin and function compatible with 74HC393-Q100 and 74HCT393-Q100. The 74LV393-Q100 is a dual 4-stage binary ripple counter. Each counter features a clock input (nCP), an overriding asynchronous master reset input (nMR) and 4 buffered parallel outputs (nQ0 to nQ3). The counter advances on the HIGH-to-LOW transition of nCP. A HIGH on nMR clears the counter stages and forces the outputs LOW, independent of the state of nCP. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Optimized for low voltage applications: 1.0 V to 3.6 V  Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V  Typical VOLP (output ground bounce) 0.8 V at VCC = 3.3 V, Tamb = 25 C  Typical VOHV (output VOH undershoot) 2 V at VCC = 3.3 V, Tamb = 25 C  Two 4-bit binary counters with individual clocks  Divide-by any binary module up to 28 in one package  Two master resets to clear each 4-bit counter individually  Complies with JEDEC standard no. 7A  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 ) 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LV393D-Q100 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74LV393PW-Q100 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74LV393-Q100 Nexperia Dual 4-bit binary ripple counter 4. Functional diagram 4  &75  &3 4    4  4  4   05  &75 &3 4     4  4   05 Fig 2. &3 05 %,7 %,1$5 VCC + 0.5 V - 50 mA IO output current VO = 0.5 V to VCC + 0.5 V - 25 mA ICC supply current - +50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C SO14 package [1] - 500 mW TSSOP14 packages [2] - 400 mW Min Typ Max Unit 1.0 3.3 3.6 V total power dissipation Ptot [1] For SO14 package: Ptot derates linearly with 8 mW/K above 70 C. [2] For TSSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter VCC supply voltage VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature 40 - +125 C t/V input transition rise and fall rate - - 500 ns/V 74LV393_Q100 Product data sheet Conditions VCC = 1.0 V to 2.0 V VCC = 2.0 V to 2.7 V - - 200 ns/V VCC = 2.7 V to 3.6 V - - 100 ns/V All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 September 2014 © Nexperia B.V. 2017. All rights reserved 5 of 16 74LV393-Q100 Nexperia Dual 4-bit binary ripple counter 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter HIGH-level input voltage VIH LOW-level input voltage VIL VOH Conditions 40 C to +85 C 40 C to +125 C Min Typ[1] Max Min Max Unit VCC = 1.2 V 0.9 - - 0.9 - V VCC = 2.0 V 1.4 - - 1.4 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 1.2 V - - 0.3 - 0.3 V VCC = 2.0 V - - 0.6 - 0.6 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V - 1.2 - - - V HIGH-level output voltage VI = VIH or VIL IO = 100 A; VCC = 1.2 V IO = 100 A; VCC = 2.0 V 1.8 2.0 - 1.8 - V IO = 100 A; VCC = 2.7 V 2.5 2.7 - 2.5 - V IO = 100 A; VCC = 3.0 V 2.80 3.0 - 2.8 - V IO = 6 mA; VCC = 3.0 V 2.40 2.82 - 2.20 - V IO = 100 A; VCC = 1.2 V - 0 - - - V IO = 100 A; VCC = 2.0 V - 0 0.2 - 0.2 V IO = 100 A; VCC = 2.7 V - 0 0.2 - 0.2 V LOW-level output voltage VI = VIH or VIL VOL IO = 100 A; VCC = 3.0 V - 0 0.2 - 0.2 V IO = 6 mA; VCC = 3.0 V - 0.25 0.40 - 0.50 V II input leakage current VI = VCC or GND; VCC = 3.6 V - - 1.0 - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 3.6 V - - 20.0 - 160 A ICC additional supply current quiescent per input VI = VCC  0.6 V; VCC = 2.7 V to 3.6 V - - 500 - 850 A CI input capacitance - 3.5 - - - pF [1] All typical values are measured at Tamb = 25 C. 74LV393_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 September 2014 © Nexperia B.V. 2017. All rights reserved 6 of 16 74LV393-Q100 Nexperia Dual 4-bit binary ripple counter 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 10. Symbol tpd Parameter propagation delay 40 C to +85 C Conditions Min Max Min Max VCC = 1.2 V - 75 - - - ns VCC = 2.0 V - 26 49 - 60 ns VCC = 2.7 V - 19 36 - 44 ns VCC = 3.3 V, CL = 15 pF - 12 - - - ns VCC = 3.0 V to 3.6 V - 14 29 - 35 ns VCC = 1.2 V - 25 - - - ns VCC = 2.0 V - 9 17 - 20 ns VCC = 2.7 V - 6 13 - 15 ns VCC = 3.3 V, CL = 15 pF - 4 - - - ns - 5[2] 10 - 12 ns VCC = 1.2 V - 70 - - - ns VCC = 2.0 V - 24 44 - 54 ns VCC = 2.7 V - 18 33 - 40 ns VCC = 3.3 V, CL = 15 pF - 11 - - - ns VCC = 3.0 V to 3.6 V - 13[2] 26 - 32 ns VCC = 2.0 V - - - - - ns VCC = 2.7 V - - - - - ns VCC = 3.0 V to 3.6 V - - - - - ns VCC = 2.0 V 34 10 - 41 - ns VCC = 2.7 V 25 8 - 30 - ns VCC = 3.0 V to 3.6 V 20 6[2] - 24 - ns VCC = 2.0 V 34 12 - 41 - ns VCC = 2.7 V 25 9 - 30 - ns VCC = 3.0 V to 3.6 V 20 7[2] - 24 - ns VCC = 1.2 V - 5 - - - ns VCC = 2.0 V 5 2 - 5 - ns VCC = 2.7 V 5 2 - 5 - ns 5 1[2] - 5 - ns nCP to nQ0; see Figure 8 nQ to nQn1; see Figure 8 [3] [3] VCC = 3.0 V to 3.6 V tPHL tt tW HIGH to LOW propagation delay transition time pulse width 40 C to +125 C Unit Typ[1] nMR to nQx; see Figure 9 nQx; see Figure 8 [4] nCP HIGH or LOW; see Figure 8 nMR HIGH; see Figure 9 trec recovery time nMR to nCP; see Figure 9 VCC = 3.0 V to 3.6 V 74LV393_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 September 2014 © Nexperia B.V. 2017. All rights reserved 7 of 16 74LV393-Q100 Nexperia Dual 4-bit binary ripple counter Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 10. Symbol fmax Parameter maximum frequency 40 C to +85 C Conditions Min Max Min Max VCC = 2.0 V 14 53 - 12 - MHz VCC = 2.7 V 19 72 - 16 - MHz - 99 - - - MHz 24 90[2] - 20 - MHz - 23[2] - - - pF see Figure 8 VCC = 3.3 V, CL = 15 pF VCC = 3.0 V to 3.6 V power dissipation capacitance CPD 40 C to +125 C Unit Typ[1] VI = GND to VCC [1] All typical values are measured at Tamb = 25 C. [2] Typical values are measured at VCC = 3.3 V. [3] tpd is the same as tPLH and tPHL. [4] tt is the same as tTHL and tTLH. [5] CPD is used to determine the dynamic power dissipation (PD in W). [5] PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 74LV393_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 September 2014 © Nexperia B.V. 2017. All rights reserved 8 of 16 74LV393-Q100 Nexperia Dual 4-bit binary ripple counter 10.1 Waveforms I PD[ 9, LQSXWQ&3 90 *1' W 3+/ W 3/+ 92+ RXWSXWQ4[ 90 92/ W 7+/ W 7/+ DDG tTLH = 10 % and tTHL = 90 %, Measurement points are given in Table 8. Fig 8. Table 8. Propagation delays clock (nCP) to output (nQx), output transition times and maximum clock frequency Measurement points Supply voltage VCC Input Output VM VM VX VY < 2.7 V 0.5VCC 0.5VCC VOL + 0.1VCC VOH  0.1VCC 2.7 V to 3.6 V 1.5VCC 1.5VCC VOL + 0.3VCC VOH  0.3VCC 9, LQSXWQ05 90 *1' W: W UHF 9, LQSXWQ&3 90 *1' W 3+/ 92+ RXWSXWQ4[ 90 92/ DDG Measurement points are given in Table 8. Fig 9. Propagation delays clock (nCP) to output (nQx), pulse width master reset (nMR), and recovery time master reset (nMR) to clock (nCP) 74LV393_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 September 2014 © Nexperia B.V. 2017. All rights reserved 9 of 16 74LV393-Q100 Nexperia Dual 4-bit binary ripple counter 9, W:  QHJDWLYH SXOVH 90 9 WI WU WU WI 9,  SRVLWLYH SXOVH 9 90  90 90  W: 9(;7 9&& 9, * 5/ 92 '87 57 5/ &/ DDH Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig 10. Test circuit for measuring switching times Table 9. Test data Supply voltage Input VCC VI tr, tf CL RL tPHL, tPLH < 2.7 V VCC  2.5 ns 50 pF 1 k open 2.7 V to 3.6 V 2.7 V  2.5 ns 15 pF, 50 pF 1 k open 74LV393_Q100 Product data sheet Load VEXT All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 September 2014 © Nexperia B.V. 2017. All rights reserved 10 of 16 74LV393-Q100 Nexperia Dual 4-bit binary ripple counter 11. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV        ș R R  1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 11. Package outline SOT108-1 (SO14) 74LV393_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 September 2014 © Nexperia B.V. 2017. All rights reserved 11 of 16 74LV393-Q100 Nexperia Dual 4-bit binary ripple counter 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ SLQLQGH[ $   $ $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWHV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 12. Package outline SOT402-1 (TSSOP14) 74LV393_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 September 2014 © Nexperia B.V. 2017. All rights reserved 12 of 16 74LV393-Q100 Nexperia Dual 4-bit binary ripple counter 12. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LV393_Q100 v.2 20140917 Product data sheet - 74LV393_Q100 v.1 Modifications: 74LV393_Q100 v.1 74LV393_Q100 Product data sheet • Figure 10 and Table 9 updated because of a missing load resistance in the test circuit. 20140526 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 September 2014 - © Nexperia B.V. 2017. All rights reserved 13 of 16 74LV393-Q100 Nexperia Dual 4-bit binary ripple counter 14. Legal information 14.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74LV393_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 September 2014 © Nexperia B.V. 2017. All rights reserved 14 of 16 74LV393-Q100 Nexperia Dual 4-bit binary ripple counter No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 15. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74LV393_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 17 September 2014 © Nexperia B.V. 2017. All rights reserved 15 of 16 Nexperia 74LV393-Q100 Dual 4-bit binary ripple counter 16. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 14.1 14.2 14.3 14.4 15 16 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13 Legal information. . . . . . . . . . . . . . . . . . . . . . . 14 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Contact information. . . . . . . . . . . . . . . . . . . . . 15 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 17 September 2014
74LV393PW-Q100J 价格&库存
很抱歉,暂时无法提供与“74LV393PW-Q100J”相匹配的价格&库存,您可以联系我们找货
74LV393PW-Q100J
  • 1+2.828421+0.36593
  • 10+1.9766910+0.25574
  • 25+1.7512725+0.22658
  • 100+1.50931100+0.19527
  • 250+1.39316250+0.18025
  • 500+1.32310500+0.17118
  • 1000+1.265371000+0.16371
74LV393PW-Q100J
  • 2500+1.204472500+0.15583
  • 5000+1.167775000+0.15109
  • 7500+1.149387500+0.14871
  • 12500+1.1290112500+0.14607
  • 17500+1.1171017500+0.14453
  • 25000+1.1056625000+0.14305
