PESD3V3V1BCSFYL
PESD3V3V1BCSFYL
    NEXPERIA(安世)
    DSN0603
    ESD VRWM=3.3 V VBR(Min)=4.5 V VC=8.9 V IPP=7.1 A DSN0603-2
PESD3V3V1BCSFYL 数据手册
PESD3V3V1BCSF Ultra low clamping bidirectional ESD protection diode 21 July 2017 Product data sheet 1. General description Ultra low capacitance bidirectional ElectroStatic Discharge (ESD) protection diode in a DSN0603-2 (SOD962) leadless ultra small Surface-Mounted Device (SMD) package. The device is designed to protect one signal line from the damage caused by ESD and other transients. 2. Features and benefits • • • • • • Bidirectional ESD protection of one line Ultra small leadless package with a height of 0.3 mm IEC 61000-4-5 (surge); IPPM = 8.3 A (average measured) Very low clamping voltage: VCL = 8.9 V max for 7.1 A, 8/20 µs pulse Ultra low leakage current: IRM < 1 nA ESD protection up to 27 kV 3. Applications ESD and surge protection for: • • very sensitive interface lines generic interface lines in portable electronics, communication, consumer and computing devices. 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit Cd diode capacitance f = 1 MHz; VR = 0 V; Tamb = 25 °C - 8.5 10 pF IPPM rated peak pulse current tp = 8/20 µs - - 7.1 A VRWM reverse standoff voltage Tamb = 25 °C - - 3.3 V [1] [2] According to IEC 61000-4-5. Average measured IPPM = 8.3 A. [1] [2] PESD3V3V1BCSF Nexperia Ultra low clamping bidirectional ESD protection diode 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 K1 cathode (diode 1) 2 K2 cathode (diode 2) Simplified outline 1 2 Graphic symbol 1 2 sym045 Transparent top view DSN0603-2 (SOD962-2) 6. Ordering information Table 3. Ordering information Type number PESD3V3V1BCSF Package Name Description Version DSN0603-2 Leadless ultra small package; 2 terminals; body 0.6 x 0.3 x 0.3 mm SOD962-2 7. Marking Table 4. Marking codes Type number Marking code PESD3V3V1BCSF T PESD3V3V1BCSF Product data sheet All information provided in this document is subject to legal disclaimers. 21 July 2017 © Nexperia B.V. 2017. All rights reserved 2 / 11 PESD3V3V1BCSF Nexperia Ultra low clamping bidirectional ESD protection diode 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit IPPM rated peak pulse current tp = 8/20 µs - 7.1 A Tj junction temperature - 150 °C Tamb ambient temperature -40 125 °C Tstg storage temperature -65 150 °C [1] [2] ESD maximum ratings VESD [1] [2] [3] electrostatic discharge voltage IEC 61000-4-2; contact discharge [3] - 27 kV IEC 61000-4-2; air discharge [3] - 27 kV According to IEC 61000-4-5. Average measured IPPM = 8.3 A. Device stressed with ten non-repetitive ESD pulses. 001aaa631 001aaa630 120 IPP 100 % 100 % IPP; 8 µs IPP (%) 80 90 % e-t 50 % IPP; 20 µs 40 10 % 0 Fig. 1. 0 10 20 30 tp (µs) 8/20 µs pulse waveform according to IEC 61000-4-5 t tr = 0.6 ns to 1 ns 40 30 ns 60 ns Fig. 2. ESD pulse waveform according to IEC 61000-4-2 9. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit VRWM reverse standoff voltage Tamb = 25 °C - - 3.3 V VBR breakdown voltage IR = 5 mA; Tamb = 25 °C 4.5 5.5 8 V IRM reverse leakage current VR = 3.3 V; Tamb = 25 °C - 0.1 50 nA Cd diode capacitance f = 1 MHz; VR = 0 V; Tamb = 25 °C - 8.5 10 pF PESD3V3V1BCSF Product data sheet All information provided in this document is subject to legal disclaimers. 21 July 2017 © Nexperia B.V. 2017. All rights reserved 3 / 11 PESD3V3V1BCSF Nexperia Ultra low clamping bidirectional ESD protection diode Symbol Parameter Conditions VCL clamping voltage IPPM = 7.1 A; tp = 8/20 μs; Tamb = 25 °C Rdyn [1] [2] dynamic resistance Min Typ Max Unit [1] - - 8.9 V IPP = 8 A; tp = TLP; Tamb = 25 °C [2] - 5.5 7.5 V IPP = 16 A; tp = TLP; Tamb = 25 °C [2] - 9 11 V IR = 10 A; Tamb = 25 °C [2] - 0.17 - Ω Device stressed with 8/20 µs exponential decay waveform according to IEC 61000-4-5. Non-repetitive current pulse, Transmission Line Pulse (TLP); square pulse; ANSI / ESD STM5.5.1-2008. IPPM IPP aaa-024654 10 C (pF) 8 6 IR IRM -VCL -VBR -VRWM -IRM -IR VRWM VBR VCL - 4 2 + 0 -5.0 -IPP -IPPM Fig. 3. Fig. 4. V-I characteristics for a bidirectional ESD protection diode 0 2.5 5.0 aaa-024756 0 IPP (A) VR (V) Diode capacitance as a function of reverse voltage; typical values aaa-024755 50 IPP (A) 40 -10 30 -20 20 -30 10 -40 0 0 4 8 12 VCL (V) -50 -16 16 tp = 100 ns; Transmission Line Pulse (TLP) Fig. 5. -2.5 006aab325 Product data sheet -8 -4 VCL (V) 0 tp = 100 ns; Transmission Line Pulse (TLP) Positive clamping voltage (TLP); typical values PESD3V3V1BCSF -12 Fig. 6. Negative clamping voltage (TLP); typical values All information provided in this document is subject to legal disclaimers. 21 July 2017 © Nexperia B.V. 2017. All rights reserved 4 / 11 PESD3V3V1BCSF Nexperia Ultra low clamping bidirectional ESD protection diode ESD TESTER 4 GHz DIGITAL OSCILLOSCOPE RG 223/U 50 Ω coax Rd 40 dB ATTENUATOR Cs 50 Ω DUT (DEVICE UNDER TEST) IEC 61000-4-2 ed.2 Cs = 150 pF; Rd = 330 Ω 10 2 V (kV) 8 V (kV) 0 6 -2 4 -4 2 -6 0 -8 -2 -10 0 10 20 30 40 50 t (ns) 60 -10 -10 70 unclamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) 0 10 20 30 40 50 t (ns) 60 70 unclamped -8 kV ESD pulse waveform (IEC 61000-4-2 network) aaa-003952 Fig. 7. ESD clamping test setup and waveforms aaa-024757 35 aaa-024759 10 VCL (V) VCL (V) 25 0 15 VCL at 30 ns = +7.5 V -10 VCL at 30 ns = -7.3 V 5 -20 -5 -15 -10 Fig. 8. 10 30 50 t (ns) -30 -10 70 Clamped +8 kV pulse waveform (IEC 61000-4-2 network) PESD3V3V1BCSF Product data sheet Fig. 9. 30 50 t (ns) 70 Clamped -8 kV pulse waveform (IEC 61000-4-2 network) All information provided in this document is subject to legal disclaimers. 21 July 2017 10 © Nexperia B.V. 2017. All rights reserved 5 / 11 PESD3V3V1BCSF Nexperia Ultra low clamping bidirectional ESD protection diode 10. Application information The device is designed for the protection of one bidirectional data line from surge pulses and ESD damage. The device is suitable on lines where the signal polarities are both positive and negative with respect to ground. The device is not designed to be used on lines connected to a DC supply. line to be protected ESD protection diode GND aaa-002737 Fig. 10. Application diagram Circuit board layout and protection device placement Circuit board layout is critical for the suppression of ESD, Electrical Fast Transient (EFT) and surge transients. The following guidelines are recommended: 1. 2. 3. 4. 5. 6. 7. 8. Place the device as close to the input terminal or connector as possible. Minimize the path length between the device and the protected line. Keep parallel signal paths to a minimum. Avoid running protected conductors in parallel with unprotected conductors. Minimize all Printed-Circuit Board (PCB) conductive loops including power and ground loops. Minimize the length of the transient return path to ground. Avoid using shared transient return paths to a common ground point. Use ground planes whenever possible. For multilayer PCBs, use ground vias. 11. Package outline 0.325 0.275 0.32 0.28 1 0.03 max 0.15 0.13 0.4 0.625 0.575 2 Dimensions in mm 0.25 0.23 14-12-03 Fig. 11. Package outline DSN0603-2 (SOD962-2) PESD3V3V1BCSF Product data sheet All information provided in this document is subject to legal disclaimers. 21 July 2017 © Nexperia B.V. 2017. All rights reserved 6 / 11 PESD3V3V1BCSF Nexperia Ultra low clamping bidirectional ESD protection diode 12. Soldering Footprint information for reflow soldering of leadless ultra small package; 2 terminals SOD962-2 0.85 0.6 0.2 0.2 0.2 0.4 0.4 0.28 0.256 0.16 0.256 0.676 occupied area solder paste solder lands Dimensions in mm 14-06-12 16-02-01 sod962-2_fr Fig. 12. Reflow soldering footprint for DSN0603-2 (SOD962-2) PESD3V3V1BCSF Product data sheet All information provided in this document is subject to legal disclaimers. 21 July 2017 © Nexperia B.V. 2017. All rights reserved 7 / 11 PESD3V3V1BCSF Nexperia Ultra low clamping bidirectional ESD protection diode 13. Revision history Table 7. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PESD3V3V1BCSF v.2 20170721 Product data sheet - PESD3V3V1BCSF v.1 Modifications: PESD3V3V1BCSF v.1 PESD3V3V1BCSF Product data sheet • Table 5 Limiting values: VESD maximum robustness (contact and air discharge) changed to 27 kV. 20160929 Product data sheet - All information provided in this document is subject to legal disclaimers. 21 July 2017 - © Nexperia B.V. 2017. All rights reserved 8 / 11 PESD3V3V1BCSF Nexperia Ultra low clamping bidirectional ESD protection diode for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. 14. Legal information Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’ aggregate and cumulative liability towards customer PESD3V3V1BCSF Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’ warranty of the product for such automotive applications, use and specifications, and (b) whenever All information provided in this document is subject to legal disclaimers. 21 July 2017 © Nexperia B.V. 2017. All rights reserved 9 / 11 PESD3V3V1BCSF Nexperia Ultra low clamping bidirectional ESD protection diode customer uses the product for automotive applications beyond Nexperia’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’ standard warranty and Nexperia’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PESD3V3V1BCSF Product data sheet All information provided in this document is subject to legal disclaimers. 21 July 2017 © Nexperia B.V. 2017. All rights reserved 10 / 11 PESD3V3V1BCSF Nexperia Ultra low clamping bidirectional ESD protection diode 15. Contents 1. General description......................................................1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Characteristics..............................................................3 10. Application information............................................. 6 11. Package outline.......................................................... 6 12. Soldering..................................................................... 7 13. Revision history..........................................................8 14. Legal information....................................................... 9 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 21 July 2017 PESD3V3V1BCSF Product data sheet All information provided in this document is subject to legal disclaimers. 21 July 2017 © Nexperia B.V. 2017. All rights reserved 11 / 11
PESD3V3V1BCSFYL 价格&库存
很抱歉,暂时无法提供与“PESD3V3V1BCSFYL”相匹配的价格&库存,您可以联系我们找货
PESD3V3V1BCSFYL
  • 1+1.762281+0.22797
  • 10+1.0776710+0.13941
  • 100+0.66508100+0.08604
  • 500+0.48383500+0.06259
  • 1000+0.425191000+0.05500
  • 2000+0.375562000+0.04858
库存:7346
PESD3V3V1BCSFYL
  • 9000+0.264789000+0.03425
  • 18000+0.2382518000+0.03082
  • 27000+0.2247227000+0.02907
  • 45000+0.2095045000+0.02710
  • 63000+0.2004963000+0.02594
  • 90000+0.1917290000+0.02480
库存:7346
PESD3V3V1BCSFYL
    • 10+0.29549
    • 100+0.23426
    • 300+0.20358
    • 1000+0.18069
    • 5000+0.16233
    库存:8118
