MBRF1020CT THRU MBRF10100CT
Reverse Voltage - 20 to 100 Volts
Forward Current - 10.0 Ampere
SCHOTTKY BARRIER RECTIFIER
Features
ITO-220AB
High surge capacity.
For use in low voltage, high frequency inverters,free
wheeling,and polarity protection applications.
Metal silicon junction,majority carrier conduction.
High current capability,low forward voltage drop.
Guard ring for over voltage protection.
4.5± 0.2
10.2± 0.2
φ 3 .3± 0.1
φ 3 .2± 0.2
PIN
2 3
8.2± 0.2
1
16.5± 0.3
15.0± 0.5
3.1+0.2
-0.1
13.5± 0.5
4.0± 0.3
1.4± 0.1
0.6± 0.1
Mechanical Data
0.6± 0.1
2.6± 0.15
Case : JEDEC TO-220AB Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.080 ounce, 2.24 grams
0.195 (4.95)
PIN 1
PIN 2
PIN 3
CASE
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
MDD
MDD
MDD
MDD
MDD
MDD
MDD
MDD
MDD
MDD
MBRF MBRF MBRF MBRF MBRF MBRF MBRF MBRF MBRF
1020CT 1030CT 1040CT 1045CT 1050CT 1060CT 0170CT 1080CT 1090CT 10100CT
SYMBOLS MBRF
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified
current (see fig.1)
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 5.0A
Maximum DC reverse current
TA=25℃
at rated DC blocking voltage
TA=100℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
storage temperature range
VRRM
V RMS
V DC
21
30
40
28
40
45
32
45
50
35
50
60
42
60
70
49
70
80
56
80
90
63
90
100
70
100
UNITS
V
V
V
I(AV)
10.0
A
IFSM
150
A
VF
0.55
IR
15.0
550
CJ
R θJC
TJ
T STG
0.75
1.0
0.85
50.0
450
2.0
-50 to +125
-50 to +150
-50 to +150
V
mA
pF
℃/W
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.Thermal resistance from junction to case.
DN:T21708A1
http://www.microdiode.com
Rev:2021A1
Page :1
FIG. 1- FORWARD CURRENT DERATING CURVE
10
8
6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
4
MBRF1020CT-MBRF1045CT
MBRF1050CT-MBRF10100CT
2
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
150
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
125
100
75
50
175
25
1
10
AMBIENT TEMPERATURE, C
INSTANTANEOUS FORWARD
CURRENT,AMPERES
50
10
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
0.1
MBRF1050CT-MBRF1060CT
MBRF1070CT-MBRF10100CT
0.01
0.2
0.4
0.6
0.8
1.0
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
1
1.1
100
10
TJ=100 C
1
TJ=75 C
0.1
0.01
60
80
100
2000
TJ=25 C
100
MBRF1020CT-MBR1045CT
MBR1050CT-MBRF10100CT
TRANSIENT THERMAL IMPEDANCE,
C/W
PERCENT OF PEAK REVERSE VOLTAGE,%
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
TJ=25 C
0.001
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
1000
100
NUMBER OF CYCLES AT 60 Hz
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
10
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2021A1
Page :2
很抱歉,暂时无法提供与“MBRF10100CT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.96300
- 50+1.63562
- 150+1.49535
- 500+1.32029
- 2000+1.24235
- 5000+1.19552
- 国内价格
- 50+0.78930
- 1000+0.77066
