DL4007
DL4007
    MDD(辰达半导体)
    DO213AB
    整流二极管 VR=1000V IF=1A VF=1.1V IR=5uA
DL4007 数据手册
DL4001 THRU DL4007 Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere SURFACE MOUNT RECTIFIER Features DO-213AB  The plastic package carries Underwrites Laboratory  Flammability classification 94V-0 SOLDERABLE ENDS 0 D2=D1 + -0.20 D1 2.6± 0.15  For surface mounted application D2 0.5± 0.1 0.5± 0.1 Mechanical Data 4.9± 0.2 Case : JEDEC DO-213AB Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight: 0.0046 ounces ,0.116 gram Dimensions in millimeters Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SYMBOLS Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL=110℃ Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) Maximum instantaneous forward voltage at 1.0A Maximum DC reverse current at rated DC blocking voltage TA=25℃ TA=125℃ Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) Operating junction and storage temperature range VRRM VRMS VDC MDD MDD MDD DL4001 DL4002 DL4003 MDD DL4004 MDD DL4005 MDD DL4006 100 70 400 280 400 600 420 600 800 560 800 50 35 50 100 200 140 200 MDD DL4007 1000 700 1000 UNITS V V V I(AV) 1.0 A IFSM 30 A VF 1.10 V IR CJ RθJA TJ,TSTG 5.0 50 15.0 50.0 -55 to +175 uA pF ℃/W ℃ NOTES:1. Measured at 1.0MHz and applied average voltage of 4.0V DC. 2. Thermal resistance junction to lead, 6.0 mm 2 coppeer pads to each terminal. DN:T20514A0 http://www.microdiode.com Rev:2020A0 Page :1 DL4001 THRU DL4007 Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Ampere Ratings And Characteristic Curves 1.0 .8 .6 .4 Single Phase Half Wave 60Hz Resistive or Inductive Load .2 0 0 25 50 75 FIG. 2 - MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT PEAK FORWARD SURGE CURRENT, (A) AVERAGE FORWARD CURRENT, (A) FIG. 1 - TYPICAL FORWARD CURRENT DERATING CURVE 100 125 150 175 AMBIENT TEMPERATURE, ( ) 50 40 30 20 10 0 1 INSTANTANEOUS REVERSE CURRENT, (uA) INSTANTANEOUS FORWARD CURRENT, (A) 1.0 T J = 25 .1 Pulse Width = 300us 1% Duty Cycle .8 1.0 1.2 1.4 4 6 8 10 20 40 60 80 100 FIG. 4 - TYPICAL REVERSE CHARACTERISTICS 10 .6 2 NUMBER OF CYCLES AT 60Hz FIG. 3 - TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS .01 .4 8.3ms Single Half Sine-Wave (JEDED Method) 1.6 10 TJ = 100 1.0 .4 .1 .04 TJ = 25 .01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE, (%) INSTANTANEOUS FORWARD VOLTAGE, (V) JUNCTION CAPACITANCE, (pF) FIG. 5 - TYPICAL JUNCTION CAPACITANCE http://www.microdiode.com 200 100 60 40 20 10 6 4 TJ = 25 2 1 .1 .2 .4 1.0 2 4 10 20 40 100 Rev:2020A0 Page :2
DL4007 价格&库存
很抱歉,暂时无法提供与“DL4007”相匹配的价格&库存,您可以联系我们找货
DL4007
    • 10+0.26568
    • 100+0.21903
    • 300+0.19570
    • 1000+0.17820
    • 5000+0.14332
    • 10000+0.13630
    库存:11845
    DL4007
    • 20+0.33270
    • 100+0.24880
    • 500+0.19290
    • 5000+0.13980
    • 25000+0.12580
    库存:2095
    DL4007
    • 1+0.16201
    • 100+0.15121
    • 300+0.14041
    • 500+0.12961
    • 2000+0.12421
    • 5000+0.12097
    库存:4992
    DL4007
    • 1+0.14796
    • 10+0.13716
    • 30+0.13500
    • 100+0.12852
    库存:213
