KBPC35005 THRU KBPC3512
Reverse Voltage - 50 to 1000 Volts Forward Current -35.0 Amperes
SILICON BRIDGE RECTIFIERS
Features
KBPC-25
The plastic package carries Underwriters Laboratory
.452(11.50) MAX.
Flammability Classification 94V-0
Ideal for printed circuit boards
.480 (12.20)
.402 (10.2)
Low reverse leakage
1.181(30.0)
1.102(28.0)
.673(17.1)
.633(16.1)
260°C/10 seconds,5 lbs. (2.3kg) tension
hole for 10 screw
5.35±0.25DIA
.673(17.1)
.633(16.1)
1.181(30.0)
1.102(28.0)
.732(18.6)
.692(17.6)
Case : JEDEC KBPC-25 Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 1.02 ounce, 29 grams
Mechanical Data
.583(14.8)
.543(13.8)
High forward surge current capability
High temperature soldering guaranteed:
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unless otherwisespecified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward
output rectified current at TC=55°C ( N o t e 1 )
Peak forward surge current
8.3ms single half sine-wave superimposed
on rated load (JEDEC Method)
Rating for Fusing(t
很抱歉,暂时无法提供与“KBPC3510”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 30+3.60470
- 300+3.54255
- 国内价格
- 1+7.25987
- 10+6.10751
- 30+5.46848
- 100+3.88660
- 500+3.57232
- 1000+3.42566
- 国内价格
- 10+6.05460
- 30+5.41420
- 100+3.84790
- 500+3.53670
- 1000+3.39150
- 国内价格
- 1+6.79140
- 10+5.71340
- 30+5.11560
- 100+3.63580
