VB8658
www.VBsemi.com
P-Channel 60 V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
-60
RDS(on) ( Ω) Typ.
I D (A) d
0.050 at VGS = -10 V
-6.5
0.060 at VGS = -4.5 V
-5.1
• TrenchFET® power MOSFET
Qg (TYP.)
• 100 % Rg and UIS tested
10.1 nC
APPLICATIONS
• Load switches
• DC/DC converter
TSOP-6
Top View
1
6
2
5
3
4
(4) S
(3) G
3 mm
(1, 2, 5, 6) D
2.85 mm
P-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS (TA = 25 °C, unless otherwise noted)
PARAMETER
SYMBOL
LIMIT
Drain-Source Voltage
VDS
-60
Gate-Source Voltage
VGS
± 20
Continuous Drain Current (TJ = 150 °C)
TC = 25 °C
-6.5
TC = 70 °C
-4.5
ID
TA = 25 °C
Continuous Source-Drain Diode Current
-3.1a,b
Avalanche Current
Single-Pulse Avalanche Energy
IDM
TC = 25 °C
-20
L = 0.1 mH
-1.7 a,b
IAS
-15
EAS
11.25
TC = 25 °C
Maximum Power Dissipation
mJ
4.2
TC = 70 °C
2.7
PD
TA = 25 °C
2 a,b
W
1.3 a,b
TA = 70 °C
Operating Junction and Storage Temperature Range
A
-3.5
IS
TA = 25 °C
V
-3.8a,b
TA = 70 °C
Pulsed Drain Current (t = 100 μs)
UNIT
TJ, Tstg
-55 to 150
°C
THERMAL RESISTANCE RATINGS
PARAMETER
Maximum Junction-to-Ambient a,c
Maximum Junction-to-Foot
SYMBOL
TYPICAL
MAXIMUM
t ≤ 10 s
RthJA
40
62.5
Steady State
RthJF
25
30
UNIT
°C/W
Notes
a. Surface mounted on 1" x 1" FR4 board.
b. t = 10 s.
c. Maximum under steady state conditions is 110 °C/W.
d. Based on TC = 25 °C.
1
VB8658
www.VBsemi.com
SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
PARAMETER
SYMBOL
TEST CONDITIONS
MIN.
TYP.
MAX.
UNIT
VDS
VGS = 0 V, ID = -250 μA
-60
V
-6.7
4.3
Static
Drain-Source Breakdown Voltage
ΔVDS/TJ
VDS Temperature Coefficient
ID = -250 μA
VGS(th) Temperature Coefficient
ΔVGS(th)/TJ
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = -250 μA
-0.5
IGSS
VDS = 0 V, VGS = ± 20 V
± 100
VDS = -60 V, VGS = 0 V
-1
VDS = -60 V, VGS = 0 V, TJ = 55 °C
-5
VDS ≥ -10 V, VGS = -10 V
-30
VGS = -10 V, ID = -3.5 A
0.050
VGS = -4.5 V, ID = -2.8 A
0.060
VDS = -30 V, ID = -3.5 A
11
832
VDS = -30 V, VGS = 0 V, f = 1 MHz
88
63
Gate-Source Leakage
Zero Gate Voltage Drain Current
IDSS
On-State Drain Current a
ID(on)
Drain-Source On-State Resistance a
Forward Transconductance a
RDS(on)
gfs
mV/°C
-2V
nA
μA
A
Ω
S
Dynamic b
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Gate Resistance
Rg
Turn-On Delay Time
Rise Time
Turn-Off DelayTime
Fall Time
Turn-On Delay Time
Rise Time
Turn-Off DelayTime
Fall Time
VDS = -30 V, VGS = -10 V, ID = -3.5 A
10.1
15.2
VDS = -30 V, VGS = -4.5 V, ID = -3.5 A
3.3
3.9
f = 1 MHz
1.8
9
18
8
16
VDD = -30 V, RL = 10.7 Ω
ID ≅ -2.8 A, VGEN = -10 V, Rg = 1 Ω
6
12
35
53
tf
16
24
td(on)
40
60
28
42
31
47
15
23
td(on)
tr
td(off)
tr
td(off)
ID ≅ -2.8 A, VGEN = -4.5 V, Rg = 1 Ω
tf
pF
nC
Ω
ns
Drain-Source Body Diode Characteristics
Continous Source-Drain Diode Current
IS
Pulse Diode Forward Current (t = 100 μs)
ISM
Body Diode Voltage
VSD
Body Diode Reverse Recovery Time
trr
Body Diode Reverse Recovery Charge
Qrr
Reverse Recovery Fall Time
ta
Reverse Recovery Rise Time
tb
TC = 25 °C
IS = -2.8 A, VGS = 0 V
IF = -2.8 A, dI/dt = 100 A/μs,
TJ = 25 °C
-3.5
-20
-0.85
-1.2
V
32
48
ns
45
68
nC
24
8
A
ns
Notes
a. Pulse test; pulse width ≤ 300 μs, duty cycle ≤ 2 %.
b. Guaranteed by design, not subject to production testing.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
2
VB8658
www.VBsemi.com
TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
2
15
VGS = 10V thru 4.5V
VGS = 4 V
ID - Drain Current (A)
1.5
10
5
1
TC = 25 °C
TC = 125 °C
0.5
VGS = 3 V
TC = - 55 °C
1.2
1.8
2.4
3
2
3
4
VDS - Drain-to-Source Voltage (V)
VGS - Gate-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
0.2
1260
0.15
945
C - Capacitance (pF)
RDS(on) - On-Resistance (Ω)
VGS = 4.5 V
0.05
Ciss
630
315
VGS = 10 V
Coss
Crss
10
15
18
24
On-Resistance vs. Drain Current
Capacitance
30
2
10
VDS = 15 V
VGS = 10 V, 3.5A
RDS(on) - On-Resistance (Normalized)
ID = 3.5 A
6
8
VDS = 30 V
6
4
VDS = 48 V
2
10
15
Qg - Total Gate Charge (nC)
Gate Charge
1.65
1.3
VGS = 4.5 V, 2.8 A
0.95
0.6
- 50
- 25
50
75
100
125
150
TJ - Junction Temperature (°C)
On-Resistance vs. Junction Temperature
3
VB8658
www.VBsemi.com
0.20
100
IS - Source Current (A)
ID = 3.5 A
TJ = 150 °C
10
TJ = 25 °C
1
TJ = 125 °C
0.10
TJ = 25 °C
0.05
0.0
0.3
0.6
0.9
1.2
2
6
10
Source-Drain Diode Forward Voltage
On-Resistance vs. Gate-to-Source Voltage
50
ID = 250 μA
1.75
30
Power (W)
40
1.55
1.35
- 25
50
75
100
125
150
10- 2
10- 1
1
10
100
TJ - Temperature (°C)
Time (s)
Threshold Voltage
Single Pulse Power, Junction-to-Ambient
100
Limited by IDM
10
Limited by RDS(on)*
100 μs
1 ms
1
10 ms
100 ms
0.1
TA = 25 °C
10 s, 1 s
BVDSS Limited
DC
0.01
0.1
1
10
100
* VGS > minimum VGS at which RDS(on) is specified
Safe Operating Area
4
8
1.95
1.15
- 50
4
VSD - Source-to-Drain Voltage (V)
2.15
VGS(th) (V)
0.15
600
VB8658
www.VBsemi.com
6
4.5
3
1.5
50
75
100
125
150
TC - Case Temperature (°C)
5
1.5
4
1.2
3
0.9
Power (W)
Power (W)
Current Derating*
2
0.6
0.3
1
0.0
50
75
100
Power, Junction-to-Foot
125
150
50
75
100
125
150
TA - Ambient Temperature (°C)
Power Derating, Junction-to-Ambient
* The power dissipation PD is based on TJ (max.) = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper
dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the
package limit.
5
VB8658
www.VBsemi.com
2
1
Normalized Effective Transient
Thermal Impedance
Duty Cycle = 0.5
0.2
Notes:
0.1
PDM
0.1
0.05
t1
t2
1. Duty Cycle, D =
t1
t2
2. Per Unit Base = RthJA = 110 °C/W
0.02
3. TJM - TA = PDMZthJA(t)
Single Pulse
4. Surface Mounted
0.01
10- 4
10- 3
10- 2
10- 1
1
Square Wave Pulse Duration (s)
10
100
600
Normalized Thermal Transient Impedance, Junction-to-Ambient
2
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10- 4
10- 3
10- 2
10- 1
Normalized Thermal Transient Impedance, Junction-to-Foot
6
1
10
VB8658
www.VBsemi.com
TSOP: 5/6−LEAD
JEDEC Part Number: MO-193C
e1
e1
5
4
6
E1
1
2
5
4
E
E1
1
3
2
3
-B-
e
b
E
-B-
e
0.15 M C B A
5-LEAD TSOP
b
0.15 M C B A
6-LEAD TSOP
4x 1
-A-
D
0.17 Ref
c
R
R
A2 A
L2
Gauge Plane
Seating Plane
Seating Plane
0.08
C
L
A1
-C-
(L1)
4x 1
MILLIMETERS
Dim
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
L2
R
INCHES
Min
Nom
Max
Min
Nom
Max
0.91
1.10
0.036
0.043
0.01
0.10
0.0004
0.004
0.90
1.00
0.035
0.038
0.039
0.30
0.32
0.45
0.012
0.013
0.018
0.10
0.15
0.20
0.004
0.006
0.008
2.95
3.05
3.10
0.116
0.120
0.122
2.70
2.85
2.98
0.106
0.112
0.117
1.55
1.65
1.70
0.061
0.065
0.067
0.95 BSC
0.0374 BSC
1.80
1.90
2.00
0.071
0.075
0.079
0.32
0.50
0.012
0.020
0.60 Ref
0.024 Ref
0.25 BSC
0.010 BSC
0.10
0.004
8
8
7 Nom
1
ECN: C-06593-Rev. I, 18-Dec-06
DWG: 5540
7 Nom
7
VB8658
www.VBsemi.com
RECOMMENDED MINIMUM PADS FOR TSOP-6
0.099
0.039
0.020
0.019
(1.001)
(0.508)
(0.493)
Recommended Minimum Pads
Dimensions in Inches/(mm)
Return to Index
8
0.064
(1.626)
0.028
(0.699)
(3.023)
0.119
(2.510)
VB8658
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
