VBA2412
VBA2412
    VBSEMI(微碧)
    SOIC-8
    MOS管 P-Channel VDS=40V VGS=±20V ID=16.1A RDS(ON)=10mΩ@10V SOIC8_150MIL
VBA2412 数据手册
VBA2412 www.VBsemi.com P-Channel 40 V (D-S) MOSFET FEATURES PRODUCT SUMMARY RDS(on) () ID (A)a 0.010 at VGS = - 10 V - 16.1 0.014 at VGS = - 4.5 V - 13.3 VDS (V) - 40 • Halogen-free According to IEC 61249-2-21 Definition Qg (Typ.) • 100 % Rg Tested • 100 % UIS Tested • Compliant to RoHS Directive 2002/95/EC 33 nC APPLICATIONS • Load Switch • POL S SO-8 S 1 8 D S 2 7 D S 3 6 D G 4 5 D G D P-Channel MOSFET Top View ABSOLUTE MAXIMUM RATINGS TA = 25 °C, unless otherwise noted Parameter Symbol Limit Drain-Source Voltage VDS - 40 Gate-Source Voltage VGS ± 20 TC = 25 °C Continuous Drain Current (TJ = 150 °C) - 12.9 ID TA = 25 °C - 10.2b, c - 8.2b, c Pulsed Drain Current IDM Single Pulse Avalanche Current Single Pulse Avalanche Energy TC = 25 °C - 5.3 - 2.1b, c IAS - 28 EAS 6.3 TC = 70 °C 4 PD TA = 25 °C W 2.5b, c 1.6b, c TA = 70 °C Operating Junction and Storage Temperature Range mJ 39 TC = 25 °C Maximum Power Dissipation A - 50 IS TA = 25 °C L = 0.1 mH V - 16.1 TC = 70 °C TA = 70 °C Continous Source-Drain Diode Current Unit TJ, Tstg °C - 55 to 150 THERMAL RESISTANCE RATINGS Parameter b, d Maximum Junction-to-Ambient t  10 s Steady State Maximum Junction-to-Foot (Drain) Notes: a. Based on TC = 25 °C. b. Surface mounted on 1" x 1" FR4 board. c. t = 10 s. d. Maximum under steady state conditions is 85 °C/W. Symbol Typical Maximum RthJA 37 50 RthJF 16 20 Unit °C/W 1 VBA2412 www.VBsemi.com SPECIFICATIONS TJ = 25 °C, unless otherwise noted Parameter Symbol Test Conditions Min. VDS VGS = 0 V, ID = - 250 µA - 40 Typ. Max. Unit Static Drain-Source Breakdown Voltage VDS Temperature Coefficient VDS/TJ V - 36 ID = - 250 µA mV/°C VGS(th) Temperature Coefficient VGS(th)/TJ Gate-Source Threshold Voltage VGS(th) VDS = VGS , ID = - 250 µA - 2.5 V IGSS VDS = 0 V, VGS = ± 20 V ± 100 nA VDS = - 40 V, VGS = 0 V -1 VDS = - 40 V, VGS = 0 V, TJ = 55 °C -5 Gate-Source Leakage Zero Gate Voltage Drain Current IDSS On-State Drain Currenta ID(on) Drain-Source On-State Resistancea Forward Transconductancea RDS(on) gfs VDS - 5 V, VGS = - 10 V 5 - 1.2 - 25 µA A VGS - 10 V, ID = - 10.2 A 0.010 VGS - 4.5 V, ID = - 8.4 A 0.014 VDS = - 15 V, ID = - 10.2 A 37  S b Dynamic Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd Gate Resistance Rg Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time 3007 VDS = - 20 V, VGS = 0 V, f = 1 MHz pF 335 291 VDS = - 20 V, VGS = - 10 V, ID = - 10.2 A 64 95 33 50 9.8 VDS = - 20 V, VGS = - 4.5 V, ID = - 10.2 A 15.7 2 4 57 86 50 75 40 60 tf 17 26 td(on) 13 20 11 20 45 68 9 18 f = 1 MHz td(on) tr td(off) tr td(off) nC VDD = - 20 V, RL = 2.4  ID  - 8.2 A, VGEN = - 4.5 V, Rg = 1  VDD = - 20 V, RL = 2.4  ID  - 8.2 A, VGEN = - 10 V, Rg = 1  tf 0.4  ns Drain-Source Body Diode Characteristics Continuous Source-Drain Diode Current IS Pulse Diode Forward Current ISM Body Diode Voltage VSD Body Diode Reverse Recovery Time trr Body Diode Reverse Recovery Charge Qrr Reverse Recovery Fall Time ta Reverse Recovery Rise Time tb TC = 25 °C - 5.3 - 50 IS = - 8.2 A, VGS 0 V IF = - 8.2 A, dI/dt = 100 A/µs, TJ = 25 °C A - 0.8 - 1.2 V 36 54 ns 41 62 nC 20 16 ns Notes: a. Pulse test; pulse width  300 µs, duty cycle  2 %. b. Guaranteed by design, not subject to production testing. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 2 VBA2412 www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted 10 50 V GS = 10 V thru 5 V V GS = 4 V 8 ID - Drain Current (A) ID - Drain Current (A) 40 30 20 6 4 T C = 25 °C 2 10 T C = 125 °C V GS = 3 V 1.0 0.5 1.5 0 2.0 1 2 3 4 VDS - Drain-to-Source Voltage (V) VGS - Gate-to-Source Voltage (V) Output Characteristics Transfer Characteristics 0.030 4500 0.024 3600 Ciss C - Capacitance (pF) RDS(on) - On-Resistance (Ω) T C = - 55 °C 0 0 0.0 V GS = 4.5 V 0.018 V GS = 10 V 0.012 2700 1800 0.006 900 0 0 Coss Crss 0 10 20 30 40 50 0 8 24 16 32 ID - Drain Current (A) VDS - Drain-to-Source Voltage (V) On-Resistance vs. Drain Current Capacitance 40 1.8 10 1.6 8 V GS = 10.2 V; I D = 10.2 A V DS = 10 V 6 V DS = 20 V V DS = 32 V 4 2 1.4 (Normalized) RDS(on) - On-Resistance VGS - Gate-to-Source Voltage (V) ID = 10.2 A 1.2 V GS = 4.5 V; I D = 8.4 A 1.0 0.8 0 0 14 28 42 Qg - Total Gate Charge (nC) Gate Charge 56 70 0.6 - 50 - 25 0 25 50 75 100 125 150 TJ - Junction Temperature (°C) On-Resistance vs. Junction Temperature 3 VBA2412 www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted 100 0.05 RDS(on) - On-Resistance (Ω) IS - Source Current (A) ID = 10.2 A T J = 150 °C 10 T J = 25 °C 1 0.04 0.03 T J = 125 °C 0.02 T J = 25 °C 0.01 0 0.1 0 0.5 1.0 2 1.5 4 VSD - Source-to-Drain Voltage (V) 2.5 80 2.2 60 1.9 ID = 250 μA 40 20 1.6 - 25 0 25 50 75 100 125 0 10 -2 150 10 -1 1 10 100 1000 TJ - Temperature (°C) Time (s) Threshold Voltage Single Pulse Power (Junction-to-Ambient) 100 Limited by RDS(on) * 100 μs ID - Drain Current (A) 10 1 ms 10 ms 1 100 ms 1s 10 s 0.1 TA = 25 °C Single Pulse 0.01 0.1 BVDSS Limited 1 DC 10 VDS - Drain-to-Source Voltage (V) * VGS > minimum VGS at which RDS(on) is specified Safe Operating Area, Junction-to-Ambient 4 10 8 On-Resistance vs. Gate-to-Source Voltage Power (W) VGS(th) (V) Source-Drain Diode Forward Voltage 1.3 - 50 6 VGS - Gate-to-Source Voltage (V) 100 VBA2412 www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted 18.0 ID - Drain Current (A) 13.5 9.0 4.5 0 0 25 50 75 100 125 150 TC - Case Temperature (°C) 8 1.80 6 1.35 Power (W) Power (W) Current Derating* 4 0.90 0.45 2 0.00 0 0 25 50 75 100 125 150 0 25 50 75 100 125 TC - Case Temperature (°C) TA - Ambient Temperature (°C) Power, Junction-to-Foot Power, Junction-to-Ambient 150 * The power dissipation PD is based on TJ(max) = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package limit. 5 VBA2412 www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted 2 Normalized Effective Transient Thermal Impedance 1 Duty Cycle = 0.5 0.2 Notes: 0.1 PDM 0.1 0.05 t1 t2 1. Duty Cycle, D = t1 t2 2. Per Unit Base = R thJA = 85 °C /W 0.02 3. T JM - TA = PDMZthJA(t) Single Pulse 0.01 10 -4 4. Surface Mounted 10 -3 10 -2 10 -1 1 10 100 600 Square Wave Pulse Duration (s) Normalized Thermal Transient Impedance, Junction-to-Ambient 2 Normalized Effective Transient Thermal Impedance 1 Duty Cycle = 0.5 0.2 0.1 0.1 0.05 0.02 Single Pulse 0.01 10 -4 10 -3 10 -2 10 -1 Square Wave Pulse Duration (s) Normalized Thermal Transient Impedance, Junction-to-Foot 6 1 10 VBA2412 www.VBsemi.com SOIC (NARROW): 8-LEAD JEDEC Part Number: MS-012 8 6 7 5 E 1 3 2 H 4 S h x 45 D C 0.25 mm (Gage Plane) A e B All Leads q A1 L 0.004" MILLIMETERS INCHES DIM Min Max Min Max A 1.35 1.75 0.053 0.069 A1 0.10 0.20 0.004 0.008 B 0.35 0.51 0.014 0.020 C 0.19 0.25 0.0075 0.010 D 4.80 5.00 0.189 0.196 E 3.80 4.00 0.150 e 0.101 mm 1.27 BSC 0.157 0.050 BSC H 5.80 6.20 0.228 0.244 h 0.25 0.50 0.010 0.020 L 0.50 0.93 0.020 0.037 q 0° 8° 0° 8° S 0.44 0.64 0.018 0.026 ECN: C-06527-Rev. I, 11-Sep-06 DWG: 5498 7 VBA2412 www.VBsemi.com RECOMMENDED MINIMUM PADS FOR SO-8 0.172 (4.369) 0.028 0.022 0.050 (0.559) (1.270) Recommended Minimum Pads Dimensions in Inches/(mm) 8 0.152 (3.861) 0.047 (1.194) 0.246 (6.248) (0.711) VBA2412 www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be RoHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
